Results 1 to 8 of 8
Thread: Audi S3 help needed to disable TPMS
    May 2016
    South Africa
    Good day I need help on the disabling of the TPMS, as i cant access the module and want to get rid of the warning.
    Vehicle is a audi S3 2011.
    Monday,29,August,2016,17:22:13:26592
    VCDS Version: 16.8.0.3
    Data version: 20160803 DS255
    VIN: WAUZZZ8P1CA001480   License Plate: S3 2011
    Mileage: 39220km-24370mi   Repair Order:
    Chassis Type: 8P (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 52 55 56 62
              72 77
    VIN: WAUZZZ8P1CA001480   Mileage: 39220km-24370miles
    Address 01: Engine (CDL)       Labels: 06F-907-115-CDL.clb
       Part No SW: 8P0 907 115 AQ    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5BH20---    Serial number: AUX7Z0K4FNJ0CU
       Coding: 0103000C1C0F0160
       Shop #: WSC 06314 000 00000
       VCID: 0103A1BB586EEA4AAF-8054
    Readiness: 0010 0101
       Part No SW: 02E 300 012 G    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1906
       Revision: 04844002    Serial number: 00000901080540
       VCID: 142D98EF371C6FE214-8040
       Revision: 00H31001
       Coding: 16428012092200FB680F01EC901900813F0400
       VCID: 7BFFD353FA82809AF5-802E
                        Reset counter: 56
                        Mileage: 39223 km
                        Date: 2015.10.13
                        Time: 00:51:28
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 16390
                        Count: 41728
                        Count: 65025
    00667 - Ambient Temperature Signal
                        Reset counter: 56
                        Mileage: 39223 km
                        Date: 2015.10.13
                        Time: 00:51:28
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 8259
                        Count: 41728
                        Count: 65025
       Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
       Component: KlimavollautomatH09 0170
       Revision: 000344      Serial number: 8P0820043BM
       VCID: 78F5CC5F0BB4AB8298-802C
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 47
                        Time: 23:44:05
    00756 - Left Vent Temp Sensor (G150)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 27
                        Mileage: 38840 km
                        Date: 2015.08.05
                        Time: 01:08:13
                        Temperature: -50.0C
                        Voltage: 11.50 V
                        Temperature: 15.6C
    00797 - Sunlight Photo Sensor (G107)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 28
                        Mileage: 38840 km
                        Date: 2015.08.05
                        Time: 01:08:13
    Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
       Part No SW: 8P0 907 063 N    HW: 8P0 907 063 N
       Component: BCM PQ35  M   110 0653
       Revision: 00110 AF
       Coding: 46000A2FA005F2C0207241E00100095C407E2CAA306DD928E40008840040
       VCID: 3F876743AE1A5CBA99-806A
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
       Subsystem 2 - Part No SW: 4E0 910 557     HW: 4E0 955 559 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSEN  H10 0040
       Coding: 024C2D
       Component: Innenraumuebe  H04 0020
       Subsystem 5 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    01134 - Alarm Horn (H12)
                        Reset counter: 56
                        Mileage: 39223 km
                        Date: 2015.10.13
                        Time: 00:51:28
                        Voltage: 11.60 V
                            Term 50 Off
                        Reset counter: 96
                        Mileage: 39225 km
                        Date: 2015.10.13
                        Time: 02:04:10
                            Term 15 Off
                        Voltage: 12.00 V
                            Term 50 Off
                        Reset counter: 56
                        Mileage: 39225 km
                        Date: 2015.10.13
                        Time: 02:14:29
                        Voltage: 11.60 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J446)       Labels: 8P0-919-475-7X1.clb
       Part No SW: 8P0 919 475 M    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H01 0140
       Revision: 11001001    Serial number: 36891112986409
       Coding: 000103
       VCID: 48957C9FFBD41B0228-801C
    Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
       Component: Airbag AU1042 H09 0250
       Revision: --------    Serial number: 003JU0028NCB
       Coding: 30314238303830303037554A305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 52A15EF70588A1D246-8006
       Serial number: 3572DRB400009164AA6W
       Serial number: 3582DRB40000DAE4A8DG
       Serial number: 35128RB4000061B8C65O
       Serial number: 35228RB4000061D8BB1R
       Serial number: 35547RB40000734A7ADY
       Serial number: 35647RB400007349FE1Y
    9437723 - Igniter for Passenger's Airbag
                 B1002 1B [137] - Resistance Too High
                        Mileage: 39225 km
                        Date: 2015.10.13
                        Time: 02:04:35
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0014142
       VCID: 468972A731C00D72DA-8012
       Component: E0221           H06 0030
    01304 - Radio
    01301 - Control Module for Voice Recognition (J507)
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 932 P    HW: 8P0 920 932 P
       Component: KOMBIINSTR. VDO H02 0150
       Revision: D0H02002    Serial number: 2244K002000025
       Coding: 0257828
       Shop #: WSC 27925 001 104857
       VCID: 418361BB18EE2A4AEF-8014
                        Reset counter: 56
                        Mileage: 39225 km
                        Date: 2015.10.13
                        Time: 02:37:49
       Revision:   H42       Serial number: 170511F1003699
       Coding: 352103
       Shop #: WSC 06314 123 12345
       VCID: 356B056B9C2696EA43-8060
       Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Component: Haldex 4Motion      3018
       Coding: 0000005
       VCID: 458B75AB0CC6066AD3-8010
       Revision: D0H02002    Serial number: AUX7Z0K4FNJ0CU
       Shop #: WSC 00451 001 1048576
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 P    HW: 8P0 959 801 P
       Component: Tuer-SG         H04 0101
       Coding: 0000692
       Shop #: WSC 33206 001 1048576
       VCID: 48957C9F3BD41B0228-801C
    00943 - Heated Exterior Mirror; Driver Side (Z4)
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 234    3201
       Revision: 00H20000
       VCID: 346D386F575C8FE274-8060
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0000660
       VCID: 4A91469725D8E9123E-801E
       Part No: 8P3 907 357 B
       Coding: 0000013
       VCID: 3C7D104F7F0C47A2BC-8068
       Part No SW: 8P0 035 186 AB    HW: 8P0 035 186 AB
       Component: R Concert2+     H03 0293
       Revision: 00H03000    Serial number: AUZ1Z3L2306822
       Coding: 0730101
       VCID: 72E1FE776DC8C1D2A6-8026
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
       VCID: 42816EB71DE83152F6-8016
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0000144
       VCID: 438F6BB302F2385AFD-8016
       Part No SW: 8P1 862 335     HW: 8P1 862 335
       Component: FSE_256x BT     H44 0650
       Revision: 00000000    Serial number: 00000005323947
       Coding: 0001292
       VCID: 74EDF86F17DCCFE2B4-8020
    End-------------------------(Elapsed Time: 02:39)--------------------------
    May 2016
    South Africa
    Can any body help he how to disable the TPMS on the S3.
    Help will be appreciated.
    May 2016
    South Africa
    I also receive a Error 31 when i do long coding on the ABS module
    Moving to Tweaks. This does not belong in Car Repair Support. One does not "Repair" a car by disabling TPMS.
  5. Likes Jack@European_Parts liked this post
    Please explain why you want to remove a safety feature on a car this new?
  7. Likes Jack@European_Parts liked this post
    Maybe it would help if the unit wasn't coded for both TPMS systems.
    JPPSG!
    Byte string 19
    Coding: 13420012092200FBC80F00EC90190000000000 ( VIN strip attributes RHD )
    ( with both TPMS systems active by some bad coding observation " your original coding presented" )
    HH RHD TPMS x2
    16428012092200FBC80F01EC90190081390400
    ( with one of the TPMS active via 0x17 )
    16428012092200FBC80F01EC901900813D0000
    ( with one of the TPMS active via separate controller 0x65 )
    Please choose the TPMS system your car requires, it is otherwise unlawful to vacate a safety system!
  10. #8
    Sep 2016
    Not sure if it is illegal in PA, US as it will pass safety inspection here with it inoperable and light on. On my 2008 B7 a4 I replaced rear antenna and then module. When a sensor went next I was broke and a little disgusted. I coded it out in 17 instruments>Adaption>61 got 4 digit value of 3843. Subtracted 512 and changed to 3331. I was using autoenginuity then not VCDS but used Rosstech wiki for navigation help. I got the 512 from a post that had installed all the components and turned it on by adding 512. I assume it only turned off in cluster but the light went out and warning in center display was gone. I like the feature when it works but it ran me out of money in a 2 week period and the light drove me nutty.
