Results 1 to 10 of 12
Thread: '14 SQ5 Trailer retrofit question
    Aug 2016
    SC PA
    I'm back in the VAG family and recently picked up a CPO '14 SQ5, beautiful car, I absolutely love it.
    Anyway... I installed the OEM hitch last weekend and just did the coding this past weekend. Everything seemed to go well except the Braking guard is off and the cruise control isn't working (Acc: Not available). My assumption is that it's because I couldn't figure out how to code the ABS module, unless something else is visibly wrong from the autoscan? You're supposed to subtract 16348 or whatever the value was from the existing code, but my coding has letters in it also. How to you come to that new value?
    Additionally, I didn't recode the backup camera because when I added one to the value, I lost the backup guide lines.
    I haven't been able to get into module 69 as per the electrical portion of the instruction manual as of yet to switch styles or whatever they called that. It is checked in the CAN gateway. The OBDEleven or the VAG COM tool can't get to it.
    Saturday,27,August,2016,15:02:14:06142
    VCDS Version: 16.8.0.3 (x64)
    Data version: 20160803 DS255
    VIN: WA1VGBFP6EA021254   License Plate:
    Mileage: 66060km-41047mi   Repair Order:
    Chassis Type: FP (8R0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 36 3C 42 44 46 47 52 53
              56 5F 62 69 6C 6D 72 A9
    VIN: WA1VGBFP6EA021254   Mileage: 66060km-41047miles
    69-Trailer -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CTUD)       Labels: 06E-907-551-CGW.clb
       Part No SW: 8R0 907 551 D    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0003
       Revision: --H07---
       Coding: 2A2A0034055600060000
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_ECM30TFS0218R0907551D 001004
       ROD: EV_ECM30TFS0218R0907551D.rod
       VCID: 397951FDB84E6C8AA7-806C
    6091 - No Communication with Towing System Control Module (J345)
              U1003 00 [045] - -
                        Mileage: 66064 km
                        Date: 2016.08.27
                        Time: 13:16:16
                        Coolant temperature: 99 °C
                        Intake air temperature: 56 °C
                        Voltage terminal 30: 11.984 V
                        Engine speed: actual: 0 /min
                        T_AST_ENVD: 0.00 s
                        Gear: 0
                        Engine: operating status: ES
                        Battery voltage: 12.492188 V
                        Vehicle speed: actual: 0 km/h
    6116 - Function Restriction due to Faults in Other Modules
              U1113 00 [037] - -
                        Mileage: 66069 km
                        Date: 2016.08.27
                        Time: 14:56:13
                        Coolant temperature: 98 °C
                        Intake air temperature: 63 °C
                        Voltage terminal 30: 12.187 V
                        MAF_ENVD: 0.00000 mg/stroke
                        Coolant temperature (unfiltered): 98.25 °C
                        Engine load: 0.000000 %
    Readiness: 0000 0100
    Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
       Part No SW: 8R0 927 158 AB    HW: 0BK 927 156 AM
       Component: 0BK 30TFSIUSA H16 1001
       Revision: --H16---
       Coding: 000001
       ROD: EV_TCMAL551211_AU48.rod
       VCID: 7DF185EDECE690AACB-8028
       Part No SW: 8R0 907 379 AM    HW: 8R0 907 379 AM
       Component: ESP8 quattro  H09 0030
       Coding: 302D1801
       VCID: 0B15DB35AA52AE1AC5-805E
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H12 0633
       Coding: 0D854040000000000000
       Shop #: WSC 06335 000 00000
       VCID: 0407F009870CE16284-8050
       Serial number: 2313000114613006
       Part No SW: 8K1 820 043 AL    HW: 8K1 820 043 AL
       Revision: C3000000    Serial number: 01040720131319
       Coding: 6601228200
       VCID: 72EBA6D1ADB8DFD2A6-8026
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000641501502
       Coding: 26000091863CAFF2110048C000003D0D0F9CC708A2090225000008004000010200040034000000
       VCID: 7AFB8EF1F5C8A792EE-802E
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 130625  H11 0050
       Serial number: 90243014130612200815
       Coding: 01DD13
       Serial number: 21495768
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000107131177
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R6QNY02
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0067740334
       Coding: 0F0000
       Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H05 0012
       Subsystem 7 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H05 0012
       Serial number: 1298C8B6000000000001
    Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
       Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
       Component: ACC3          H11 0100
       Coding: 00333E
       VCID: 377D57C5865A7AFA51-8062
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 196
                        Mileage: 66069 km
                        Date: 2016.08.27
                        Time: 14:56:13
                        Temperature: 48.0°C
                        Voltage: 12.29 V
                        Hex Value: 0x00D9
                        Lateral Accel.: 0.00 m/s^2
                        Reset counter: 196
                        Mileage: 66064 km
                        Date: 2016.08.27
                        Time: 13:16:17
                        Temperature: 40.0°C
                        Voltage: 12.16 V
                        Hex Value: 0x00BD
    Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003GPDB05BFD
       Coding: 303334313432303030304A55304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 479D2705FEBA0A7A21-8012
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R130000EF6S
       Serial number: 6334MSME7C226A13G
       Serial number: 6344MSME7C002349B
       Serial number: 6352QSME28330A5CK
       Serial number: 6362QSME1332035A5
       Serial number: 63732SME0D351F42%
       Serial number: 63832SME5E33507C6
       Revision: --------    Serial number: 90372MFT0009O
       Coding: 00003F
       VCID: 44873009C78C2162C4-8010
    00895 - Cruise Control Switch (E45)
                        Reset counter: 196
                        Mileage: 66069 km
                        Date: 2016.08.27
                        Time: 14:56:12
    Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 982 D    HW: 8R0 920 982 D
       Component: KOMBIINSTR.   H35 0563
       Revision: 00400000    Serial number: WYK27A27E
       Coding: 8BB722002F01D705020000
       VCID: 3C7748E9BF7C59A2BC-8068
       Component: GW-BEM 5CAN-M H11 0056
       Revision: 1Z110028    Serial number: 2841Z1361201E9
       Coding: 80C103FF00
       VCID: 4C971829EFDCE9220C-8018
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 40171G36151461303405
    01517 - Control Module for Trailer/Towing Sensor (J345)
                        Reset counter: 196
                        Mileage: 66064 km
                        Date: 2016.08.27
                        Time: 13:13:24
                        Bin. Bits:    10111
                        Voltage: 12.00 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
       Part No SW: 8K0 907 144 L    HW: 8K0 907 144 L
       Component: DYNAMIKLENK.  H06 0720
       Coding: 040000
       VCID: 387F54F98B44758258-806C
       Part No SW: 8R0 959 760 E    HW: 8R0 959 760 C
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000064839871
       Coding: C0581B000F0000000000
       VCID: 43853315C282265AFD-8016
    Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H04 0060
       Serial number: 0310386881
       Coding: 010211
       Shop #: WSC 06334 000 00000
       VCID: 3F8D3FE5A66A42BA99-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H04 0060
       Serial number: 0310695115
       Coding: 000102
       Component: TSG FA        H02 0508
       Revision:             Serial number: 0000066856516
       Coding: 011D13205E00440004
       VCID: 4FAD0F251ECAD23A69-801A
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
       Component: RCEPS         H38 0510
       Revision: 00001000    Serial number: 0023612654
       Coding: 010000010000
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X.rod
       VCID: 45812D0DC4B6186AD3-8010
       Revision: 00002001    Serial number: 0310791062
       Coding: 0126023A20FA709586B0053200040000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000697074
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H05 0220
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Revision: 00005001    Serial number: 94813017035303
       VCID: 2D5175AD7406C02A3B-8078
       Component: TSG BF        H02 0508
       Revision:             Serial number: 0000067156015
       VCID: 4E93122119C0DB3262-801A
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 10000000236051
       ROD: EV_ParkiBrake_VW51.rod
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156G+0D7825128
       Coding: 020007010000000001
       VCID: 2447908927CC0162E4-8070
       Part No SW: 8R1 035 746 D    HW: 8R1 035 746 D
       Component: H-BNT-NA      H40 0738
       Revision: --------    Serial number: 204G70D7588983
       Coding: 1A0200060205A9EF75028B4E00000403140000000000000000
       Subsystem 1 - Part No: 8R0 060 884 BD
       Component: NAR 2013/2014  0802
       Component: DU7 High  H42 0104
       Serial number: A130GX0D2774913
       Serial number: 00000001558055
       Component: CD-Database  5298
       Revision:             Serial number: 0000066769483
       Coding: 010C13204000240004
       VCID: 46832A01F1B01372DA-8012
    Address 69: Trailer
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H08---    Serial number: 525PA8-J35A08B
       Coding: 1021010
       Shop #: WSC 11111 111 45799
       VCID: 346760C9572C91E274-8060
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B754BF5BA725E9AB5-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Revision:             Serial number: 0000066769583
       Part No SW: 8R0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0001
       Serial number: 130612200717
       VCID: 3A7B4EF1BD486792AE-806E
    End-------------------------(Elapsed Time: 04:28)--------------------------
  2. Likes Uwe liked this post
  3. #2
    Jan 2015
    Bosnia and Herzegovina
    Address 69: Trailer
    either you didn't connect to gateway or fuse is missing?
  4. Likes Uwe, lassi liked this post
  5. #3
    Aug 2016
    SC PA
    Quote Originally Posted by m87a View Post
    Address 69: Trailer
    Fuses are there.
    That got me wondering and I did some more searching. I'm starting to think I put the bracket you had to order separately in the wrong place. I found a Q5 pic which showed a red plug, plugging into the trailer module. Right now I do have an open plug on my module. I found that plug facing the front of the car, with only a couple inches of play, it appears to have the correct plug for the module. All my previous experiences with VAG products was that everything is typically where you're going to need it, I don't need to cut the factory wrap. Maybe that's the missing piece?
  6. #4
    Aug 2016
    SC PA
    I did miss a plug, the red one. Found this image:
    I guess I need to cut back some of the factory wrapping, as I do have the trailer control module bracket installed in the right location. The plug is just nowhere near being able to reach it. It's currently on the loom where the 12V power line is shown coming behind the trim.
    I'll hook that up, maybe at lunch and see if I can get the module to talk, I'm guessing it will.
    But won't I still need to code the ABS module by subtracting the 16384 value or whatever it is? I'd like to get back my cruise control as I have a 200 mile road trip this weekend!
    Aug 2016
    SC PA
    Well that did get me into the trailer control module and I was able to recode that. I didn't have time to test drive at lunch, but I didn't see the Braking Guard error on the dash when I started the car. I don't know if the cruise control function is working. Still a couple codes to work through I think, and I get a control module not responding trying to get into #10. I have errors in Engine and Auto Distance Regulation, which tells me the adaptive cruise still won't work. Suggestions? I'm sure it's one box I'm missing somewhere.
    Tuesday,30,August,2016,12:46:19:06142
    Mileage: 66280km-41184mi   Repair Order:
    VIN: WA1VGBFP6EA021254   Mileage: 66280km-41184miles
       Revision: --H07---
    7193 - Function Restriction due to Faults in Other Modules
              U1113 00 [037] - -
                        Mileage: 66289 km
                        Date: 2016.08.30
                        Time: 12:35:37
                        Coolant temperature: 44 °C
                        Intake air temperature: 46 °C
                        Voltage terminal 30: 12.085 V
                        Coolant temperature (unfiltered): 44.25 °C
    Readiness: 1110 1101
       Revision: --H16---
       Coding: 000001
       Coding: 30AD1801
       Coding: 6601228200
       Coding: 26000091863CAFF2110048C000003D0D0F9CE708A2090225000008004000010200040034000000
       Coding: 01DD13
       Coding: 02005C
       Coding: 0F0000
    H05 0012
    H05 0012
       Coding: 00333E
                        Reset counter: 202
                        Mileage: 66289 km
                        Date: 2016.08.30
                        Time: 12:40:40
                        Temperature: 39.0°C
                        Voltage: 12.16 V
                        Hex Value: 0x005D
                        Reset counter: 202
                        Mileage: 66289 km
                        Date: 2016.08.30
                        Time: 12:40:40
                        Temperature: 39.0°C
                        Voltage: 12.16 V
                        Hex Value: 0x00BD
       Coding: 00003F
       Coding: 80C103FF00
       Coding: 040000
       Coding: 010211
       Coding: 000102
    Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00008200841888
       Coding: 0200000000000000
       VCID: 36635AC1815083F24A-8062
       Coding: 1031010
    End-------------------------(Elapsed Time: 04:27)--------------------------
    After looking at the Wiki for 1044, is it possible that I need to re-apply the Channel 69 selection for trailer hitch installed after plugging in the missing cable? As in, uncheck/apply then check/apply?
    Aug 2016
    SC PA
    Well unchecking/applying and then checking/applying didn't fix it.
    Aug 2016
    SC PA
    Braking guard is still off and no cruise control now that I'm driving. Ugh.
  10. #8
    Jan 2015
    you need to code
    Address 13: Auto Dist. Reg (J428) for trailer, unfortunately i cant help you with that
  11. #9
    [13] - 003337
    [3C] - 010221 Master. Slave coding 000102 looks wrong to me ?
  12. Likes shaggymatt, Uwe, Camsdad911 liked this post
  13. #10
    Aug 2016
    SC PA
    [13] - Changed to your recommendation, which did indeed clear the errors and I have cruise control/braking guard again! Yay! Thanks!
    [3C] - Master - there was indeed a drop down box for hitch module installed and coded. I changed that which changed the master coding.
    [3C] - Slave - It wasn't able to communicate with the slave, no response.
    [01] same engine errors still exist. I feel like there are two now, but I only had time to do the quick scan/clear see if they came back after changing the other modules. I'll have to post the errors when I can get back to the car. I think the second was regarding an incorrectly coded module.
