Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: fault code audi A3/s3
    Jan 2015
    hi guy I had a thread a few weeks ago, and need a little if possible, I have had problems with a airbag fault showing on my car, I bought a new airbag ecu, but found out by a forum member that I may have been given a wrong part number from audi, so I have now bought a second hand unit from same car age etc, so I'm sure this is the right one for my car, I now don't have 2 faults I had when fitting the new unit, so I'm quite sure its right, part numbers are all the same, I am show one fault on the air bags and could do with somone pointing me in the right direction to sorting it, also a little help with other fault codes would be a big help, many thanks again guys
    Chassis Type: 8P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 37 42 44 46 47 52 55 56
              77
    VIN: WAUZZ
    2E-Media Player 3 -- Status: Not registered 0001
    Address 01: Engine (CDL)       Labels: 06F-907-115-CDL.clb
       Part No SW: 8P0 907 115 AP    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5BH19---    Serial number: AUX7Z0J2FNC0JK
       Coding: 0103000C1C0F0060
       Shop #: WSC 00024 000 00000
       VCID: 0005980453952F42A0-8054
    Readiness: 0110 0001
       Part No SW: 02E 300 012 N    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2115
       Revision:    51112    Serial number: 00001003050064
       Shop #: WSC 06314 000 00000
       VCID: 1B3FCF68DA33EC9A55-804E
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       Coding: 11428012092700FB880E01ED90220081390000
       Shop #: WSC 06314 123 12345
       VCID: 7AF1EAECF5497592EE-802E
       Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
       Component: KlimavollautomatH09 0180
       Revision: 000214      Serial number: 8P0820043BN
       VCID: 79F3F5E0304F7E8AE7-802C
    01856 - Temperature Sensor for Heated Seat; Front Right (G345)
                        Fault Status: 00101010
                        Reset counter: 132
                        Mileage: 60694 km
                        Date: 2015.02.11
                        Time: 02:43:32
                        Temperature: 27.5C
    00532 - Supply Voltage B+
                        Reset counter: 132
                        Mileage: 60694 km
                        Date: 2015.02.11
                        Time: 03:29:35
                        Voltage: 8.60 V
    01854 - Heated Seat; Front Right (Z46)
                        Fault Status: 00101100
                        Reset counter: 132
                        Mileage: 60694 km
                        Date: 2015.02.11
                        Time: 02:43:34
                        Temperature: 27.0C
    Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
       Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
       Component: BCM PQ35  M   105 0575
       Revision: 00105 AK
       Coding: 06000B2FB005F200207241E00000094C431E25AA204DD929E40008840040
       VCID: 326102CC6DB94DD266-8066
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
       Subsystem 2 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    01134 - Alarm Horn (H12)
                        Reset counter: 92
                        Mileage: 60694 km
                        Date: 2015.02.23
                        Time: 00:23:19
                        Voltage: 14.15 V
                            Term 50 Off
    Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
       Component: Airbag AU1042 H09 0250
       Revision: --------    Serial number: 003JU004NSS6
       Coding: 303142413039303030384A55305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 52A1624C05796DD246-8006
       Serial number: 34928RB4000056DDD0C1
       Serial number: 35028RB4000056DEEA4/
       Serial number: 35128RB4000056DDD34W
       Serial number: 35228RB4000056DEEFFF
       Serial number: 35547RB4000057B42AEX
       Serial number: 35647RB4000057B432DQ
    9438490 - Igniter for Driver head airbag
                 B1005 54 [137] - Missing Calibration / Basic Setting
                        Mileage: 60694 km
                        Date: 2015.02.23
                        Time: 00:22:03
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0012112
       VCID: 46894E1C3131C172DA-8012
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 983 A    HW: 8P0 920 983 A
       Component: KOMBIINSTR. VDO H04 0150
       Revision: D0H04003    Serial number: 2243L003000800
       Coding: 0257428
       Shop #: WSC 00762 210 97024
       VCID: 387530E44BC5A78258-806C
    00771 - Fuel Level Sensor (G)
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 92
                        Mileage: 60694 km
                        Date: 2015.02.23
                        Time: 00:21:58
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 92
                        Mileage: 60694 km
                        Date: 2015.02.23
                        Time: 00:21:58
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0233
    Jan 2015
    Anyone , bump
    Mar 2016
    preform a basic setting
    Quote Originally Posted by Dutchie View Post
    Seems like good advice, but I don't think we have a procedure for that at present.
    Jan 2015
    Thanks, I've clicked on it, but there's nothing there, like if doing that on another unit, didn't have this fault in first place until, I disconnected each airbag to eliminate each airbag as afault, now can't get rid, thanks for the input again
    Jan 2015
    Guys I really need some help, I'm struggling to clear this fault, a little up date, I have drivers side roof airbag saying too high , I've tried and diffrent roof airbag ( I take roof airbag is curtain airbag) tried that still got the fault, tried a diffrent airbag module still got fault tried taking out the 2 pins at the module connector block and connecting the new air bag direct into 2 pins that are plugged straight into the module block , to see if this will eliminate bad wires running to the rear of the car, but still got fault, can anyone please help me, maybe if someone can point me in the right direction to find the pin read out for the airbag module so I can see if there is possible a diffrent wire that could be damaged somewhere, the 2 wires I have tried are the same 2 wires that are at the rear of the car plugged into the curtain airbag, dose anyone no if these are the only wires that could cause this fault, I'm 100% airbag modules are fine and same on the 2 curtain airbags I have , please can someone help me, I just don't no what to do now, thanks
  7. #7
    Sep 2016
    Riga, Latvia
    If You could provide VIN of Your car, probably someone could trace down original equipment set of Your car and give some advice of airbag module coding.
  8. #8
    Jan 2015
    I've got the original module from the car part number ( 8p0 959 655p)
    Chassis number thought it was on the scan (
    VIN: WAUZZZ8P79A079027 )
    I'm total stuffed with it, could coding it make a difference to a fault head airbag, ,,what dose it mean when it says too high and not too low,
    I'll put another scan up tomorrow , it would complete tonight for some reason, got stuck loading last or end of scan so couldn't complete so I could put fresh atoms scan up
  9. #9
    Mar 2016
    A ressistance high means that a airbag module (not the ECU it self) has a internalfault. Please remove the airbag that is suspected of beeing faulty and place a 2.2ohms resistor, deleted all the dtc and recheck.
    Please, do know, if you dont know what you are doing with airbag's you can get your self killed!
    If the DTC reapears then disconnect the suspect airbag connector and check the resistance measurd by the ECU. It shut be 0. If yes, reconnect and check what it says. It shut be around 2.2ish
    Please report findings here
  10. #10
    Jan 2015
    Thanks for reply,
    Hi I think I'm referring sometimes to ecu, because I've been told in the past it's an ecu, I've taken the airbag off in question and put a 3ohm resister across , but still had the fault, bought a used airbag and tried that, still faults, so took pins out at module and did the same there both with resistor and airbag, but still got the same fault, so bought another module same part no etc, same faults doing the same as before, leaving me to think there must be some other wire fault other than the.2 wires that go the the airbag in question, so really puzzled , I've disconnected battery when doing all this , thanks
