- Joined
- May 1, 2016
- Messages
- 32
- Reaction score
- 14
- Location
- South Africa
- VCDS Serial number
- C?ID=117317
I messed around with the settings of my S8's instrument cluster (Note - I'm not referring to the MMI startup logo - google tells me that logo is changed via the green Hidden Menu).
Some time later, I realized the DIS is not showing the S8 logo on startup anymore, but the A8 logo.
I can't remember changing any setting which specifically referred to the splash/startup screen.
Although not logical, I suspect that the change was brought about by changing the Country Code of the Instrument.
So the question is, which of the settings changes the startup logo of the DIS? (I suppose I will have to play around with this setting once I know which one it is, until I find the correct logo. I'm afraid that's going to be a tedious process of trial and error, with changing the setting; turning the ignition Off and On again to check the effect of any changes as far as the startup logo is concerned.)
EDIT: I came across this on another forum:
- STG 17 (Schalttafel) auswählen
- STG Lange Codierung -> Funktion 07
- Byte 9
- Wert entsprechend setzen
00 - A6 Startup screen
01 - A7 Startup screen
02 - S6 Startup screen
03 - S7 Startup screen
04 - RS6 Startup screen
05 - RS7 Startup screen
06 - S6 allroad Startup screen
07 - S6 hybrid Startup screen
08 - A6 Startup screen
09 - A7 Startup screen
