Hi guys, got a car in today that's lost its ABS coding ive attached a full read and a data sticker shot if anyone can help, its long coding and believe its a dealer only SVM job but noticed someone else on here had the same issue and was resolved by a member on here.
Wednesday,24,August,2016,17:41:29:12016
VCDS Version: 16.8.0.1
Data version: 20160801 DS254
VIN: VSSZZZ6JZCR045103 License Plate: DY61WSE
Mileage: 157760km-98027mi Repair Order:
Chassis Type: 6J (6R0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56 61
VIN: VSSZZZ6JZCR045103 Mileage: 157760km-98027miles
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 AB HW: 03P 906 021 BC
Component: R3 1.2 DCM3.7 H06 9069
Revision: 12005001 Serial number:
Coding: 00114014032501080000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM12TDI03103P906021AB 001010
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 68D463E2935D2B020A-803C
15971 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Mileage: 153935 km
Date: 2016.05.18
Time: 23:01:06
Coolant temperature: 79 °C
Intake air temperature: 41 °C
Voltage terminal 30: 12.257 V
Unlearning counter according OBD: 178
Engine status: Engine stopped
OBD Driver demand indicated torque: 0 %
Mean injection quantity: 0.0 mg/stroke
Exhaust gas temperature sensor 1: 84 °C
Outside air temperature: 17 °C
Sensor for engine block temperature; raw value: 80 °C
Terminal 15 status: On
16275 - ROD - Unknown Error Code
- 00 [088]
Intermittent - Confirmed - Not Tested Since Memory Clear
Mileage: 157387 km
Date: 2016.08.10
Time: 07:52:14
Coolant temperature: 55 °C
Intake air temperature: 40 °C
Voltage terminal 30: 12.210 V
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Shop #: WSC 04941 000 00000
VCID: 0716405EB203C47AE3-8052
Reset counter: 51
Mileage: 153491 km
Date: 2016.05.06
Time: 01:24:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3213
Hex Value: 0x14A3
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Status: 01100101
Reset counter: 51
Mileage: 154756 km
Date: 2016.06.08
Time: 00:50:28
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B9E
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Reset counter: 51
Mileage: 153491 km
Date: 2016.05.06
Time: 01:24:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x32E1
Hex Value: 0x20A3
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
03306 - Coding Not Valid
Fault Frequency: 12
Reset counter: 91
Mileage: 157767 km
Date: 2016.08.24
Time: 02:28:26
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x259D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7E00
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0320
Revision: 00 25 08 Serial number: 0000001986183-
VCID: 244C37D2E7F50F62E6-8070
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 57
Reset counter: 31
Mileage: 153491 km
Date: 2016.05.06
Time: 01:23:09
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 BCM PQ25 Re4 H50 03510351
Revision: BU050001 Serial number: 0456 207111386
Coding: 258829E888612500922001F06E0B8CC8CF80620F7E8C0409200000000000
Shop #: WSC 64564 324 38760
VCID: 41829E46D8A73A4AED-8014
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3130
Coding: 430000
Subsystem 2 - Part No: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT
Coding: 420000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00
Component: LIN BACKUP HO
Subsystem 5 - Part No: 1K8 951 171 A
No Faults Found
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA05 H09 0020
Revision: -------- Serial number: 003GX00TA9N.
Coding: 003035
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 4A90B96AED91F9123C-801E
Serial number: 3495RRB40690LCOSG9TT
Serial number: 3505RRB40650LCOSOH15
Part No SW: 6J0 920 903 J HW: 6J0 920 903 J
Component: KOMBI H02 0504
Coding: 410200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3162CE866007AACA1D-8064
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H38 0034
Revision: H38 Serial number: 170811F2001857
Coding: 2542C1
VCID: 346CC79297159FE276-8060
Component: IMMO H02 0504
VCID: 6AD019EA8D5119121C-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11211
Shop #: WSC 06402
VCID: 2F66C8FEEA33BC3A0B-807A
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Shop #: WSC 77005 000 00000
VCID: 70E40B82638DE3C252-8024
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J2 035 153 G HW: 6J2 035 153 G
Component: Radio H15 0204
Revision: R0000000 Serial number: SEZAZ2L1953714
Coding: 0501020002
VCID: 2A50D9EA45D1D912DC-807E
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0034
Coding: 0303185A
VCID: 74EC0792D795DFE2B6-8020
Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
Component: J367-BDM H07 0150
Serial number: 00000000009370215607
End-------------------------(Elapsed Time: 02:28)--------------------------
