Results 1 to 10 of 10
Thread: Passat ABS coding
    Egypt
    Passat ABS coding
    I have changed the ABS control module and I want the code of this new control module
    Wednesday,18,June,2014,06:16:04:45597
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WVWZZZ3CZ6P176361   License Plate:
    Mileage: 117560km-73048mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ6P176361   Mileage: 117560km/73048miles
    44-Steering Assist -- Status: Not registered 0011
    53-Parking Brake -- Status: Not registered 0011
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 AA    HW: Hardware No
       Component: MED9.5.10       G00 9312
       Revision: --H08---    Serial number: VWZCZ000000000
       Coding: 0000075
       Shop #: WSC 00028 028 00001
       VCID: 62CF5506BDFDAC0EED3-8037
    10 Faults Found:
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 001 -
                        Fault Status: 01100001
                        Fault Frequency: 75
                        Mileage: 117373 km
                        Date: 2014.06.11
                        Time: 21:44:43
                        Temperature: 86.0C
    008851 - Fuel Pressure Regulator Valve (N276)
                   P2293 - 002 - Mechanical Malfunction - MIL ON
                        Fault Status: 11100010
                        Mileage: 117373 km
                        Date: 2014.06.11
                        Time: 21:45:29
                        RPM: 720 /min
                        Load: 42.7 %
                        Temperature: 85.0C
    012434 - Internal Control Module
                   P3092 - 004 - Memory Check Sum Error - MIL ON
                        Fault Status: 11100100
                        Mileage: 117373 km
                        Date: 2014.06.11
                        Time: 21:47:15
                        RPM: 960 /min
                        Load: 22.3 %
                        Speed: 16.0 km/h
                        Temperature: 82.0C
    001281 - Vehicle Speed Sensor
                   P0501 - 004 - Implausible Signal
                        Mileage: 117379 km
                        Date: 2014.06.12
                        Time: 10:58:57
                        RPM: 1040 /min
                        Load: 87.4 %
                        Temperature: 27.0C
    000311 - Oxygen (Lambda) Sensor B1 S2
                   P0137 - 002 - Signal too Low - MIL ON
                        Mileage: 117499 km
                        Date: 2014.06.15
                        Time: 16:29:08
                        RPM: 760 /min
                        Load: 43.1 %
                        Speed: 5.0 km/h
                        Temperature: 73.0C
    000152 - Intake Air Temperature Sensor 2 (G299)
                   P0098 - 002 - Signal too Low
                        Fault Status: 01100010
                        Temperature: 63.0C
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 008 -  - Intermittent
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:09:18
                        Temperature: 63.0C
    006420 - Pressure Sensor for Brake Boost (G294)
                   P1914 - 008 - Implausible Signal
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:09:18
                        Temperature: 63.0C
                   P1653 - 004 -
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:09:18
                        Temperature: 63.0C
    006418 - Pressure Sensor for Brake Boost (G294)
                   P1912 - 001 - Short to Plus
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:09:18
                        Temperature: 63.0C
    Readiness: 1110 0101
    Address 02: Auto Trans        Labels: 09G-927-750.lbl
       Part No SW: 09G 927 750 R    HW: 09G 927 750 R
       Component: AQ 250 6F           0761
       Revision: 00H38000    Serial number:
       Coding: 0000072
       VCID: 408BBF8E1331DE1EDB7-8015
    01683 - Wheel Speed Signals / Vehicle Speed
    01679 - ABS Wheel Speed Signal; Front Left
    01680 - ABS Wheel Speed Signal; Front Right
    01682 - ABS Wheel Speed Signal; Rear Right
    Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0658013351
       Coding: 0013755
       VCID: 306BEF4EA3914E9E2B7-8065
    6 Faults Found:
                        Reset counter: 203
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:11:19
                        Reset counter: 203
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:11:19
    01542 - Yaw Rate Sensor (G202)
                        Reset counter: 203
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:11:19
                        Reset counter: 203
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:11:19
                        Reset counter: 203
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:11:19
    00810 - Sensor 1/2 for Brake Pressure
                        Reset counter: 203
                        Mileage: 117565 km
                        Date: 2014.06.18
                        Time: 16:11:19
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AA    HW: 3C0 907 044 AA
       Component: ClimatronicPQ46 050 0404
       Revision: 00050005    Serial number: 00000000000000
       VCID: 60CB5F0EB3F1BE1EFB7-8035
                        Fault Status: 00111101
                        Reset counter: 114
                        Mileage: 117510 km
                        Date: 2014.06.17
                        Time: 07:52:18
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000003828005
       Coding: 01840F0700041A00000A00000F00000000095D435C0000
       Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer VW461 001   0101
       Coding: 00063445
       Shop #: WSC 00028
       Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
       Component: 04 AIRBAG VW8   029 2521
       Revision: 09029000    Serial number: 003A2P1PHPBX
       Coding: 0012340
       VCID: 2D55F63AB4A32376001-8078
       Subsystem 1 - Serial number: 6332MSME0D28774C
       Subsystem 2 - Serial number: 6342MSME0D29396C
       Subsystem 3 - Serial number: 6351HTS64IK2E3R2
       Subsystem 4 - Serial number: 6361HTS63IKQAPM2
       Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
       Revision: 00005000    Serial number: 3C5953507P
       Coding: 0001111
       VCID: 2E57F136B9A5586E39B-807B
       Component: E0221           007 0050
       Part No SW: 3C0 920 870 P    HW: 3C0 920 870 P
       Revision: X0033000    Serial number: 00000000000000
       Coding: 0007105
       Shop #: WSC 12345 122 183346
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C06124022E
       Coding: 1FFC0C04C21002
       Shop #: WSC 36002 360 138209
       VCID: 214D1A0AF87BF716B49-8074
                        Fault Frequency: 50
                        Reset counter: 75
                        Mileage: 117373 km
                        Date: 2014.06.11
                        Time: 21:17:15
       Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
       Component:    IMMO         038 0367
       Revision: 00038000    Serial number: VWZCZ000000000
       Shop #: WSC 36002 360 105988
       VCID: 326FE546AD9D7C8E5D3-8067
    02823 - Requirements for Locking the Steering Column Lock not met
                        Fault Status: 00110000
                        Reset counter: 114
                        Mileage: 117379 km
                        Date: 2014.06.12
                        Time: 11:00:35
    02827 - Wake-Up request via ESP
                        Reset counter: 114
                        Mileage: 117379 km
                        Date: 2014.06.12
                        Time: 11:00:35
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2365
       Coding: 0000181
       VCID: 3667D95641F560AE71B-8063
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K1 909 144 K
       VCID: 3361E04252877586565-8066
    00750 - Warning Lamp
                        Mileage: 7360 km
                        Temperature: 37.0C
                        Voltage: 12.60 V
                        Voltage: 12.40 V
    00625 - Vehicle Speed Signal
                        Mileage: 7360 km
                        Temperature: 24.0C
                        Voltage: 14.40 V
                        Voltage: 14.20 V
       Component:    KSG PQ46 ELV 038 0455
       Coding: 00910A0801860E763804941570084F0B603800
       Part No: 1K0 959 702 K
       Coding: 0000180
       VCID: 3779D45246FF99A66AD-8062
       Revision:   013
       Coding: 0010000
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 75
                        Mileage: 117560 km
                        Date: 2014.06.18
                        Time: 16:09:20
                        Voltage: 11.90 V
                        Count: 171
                000 - - - MIL ON
                        Reset counter: 75
                        Mileage: 117560 km
                        Date: 2014.06.18
                        Time: 16:09:19
                        Voltage: 12.01 V
                        Count: 170
                        Fault Status: 11101101
                        Reset counter: 75
                        Mileage: 117096 km
                        Date: 2014.06.11
                        Time: 02:50:51
                        Voltage: 13.66 V
                        Count: 236
       Part No: 1K0 035 186 P
       Component: Radio GR0       015 0019
       Revision: 0001503S    Serial number: VWZ2Z2F3740088
       Coding: 0040400
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2432
       Coding: 0000144
       Part No: 1K0 959 704 F
       Coding: 0000144
       VCID: 3463E35E578972BE4FF-8061
    Last edited by Uwe; 06-18-2014 at 09:15 AM. Reason: Wrapped CODE tags around Auto-Scan
    Did you scan the car before changing the module?
    Egypt
    Yes , is it the same ?
    What is the status of 0x01-08-081 and 0x01-10-091 ?
    This might be part of the problem if that is the case.
    Egypt
    I have another question about a skoda rapid car
    how can I check the oil pressure is ok or no in skoda rapid 2013
    which channel I have to choose
    RTFB and put an actual measuring device on to verify a critical test such as this.
    Never rely on a sensor to report this to the ECU via VCDS if this is seriously suspect............
  7. #7
    With VW-Skoda-Seat-Audi history of oil sludge.......... I would say additionally a visual inspection of sump/pickup.
  8. #8
    Egypt
    I know that vag-com dont measure oil pressure
    But in other cars I enter insturment and then mass block channel 001
    It tell me if oil pressure is ok or not
    but in this car i dont know how to do it
  9. #9
    https://erwin.skoda-auto.cz/erwin/showHome.do
    Respectfully ......... please see the repair manual.
  10. #10
    United States
    Quote Originally Posted by mohamed View Post
    Do you still need assistance with the coding or did you paste the original coding back into the new/used replacement ABS module?
