Results 1 to 9 of 9
Thread: 2016 Golf TSI Various Fault Codes
    Aug 2016
    I just bought a brand new Golf about two months ago and recently picked up a new Micro-CAN cable. I wanted to program the car to open and close the windows with the remote, but before I did that I did an Auto Scan to make sure everything was a-okay. When I preformed the scan it came up with a few errors in some of the secondary systems. I don't know if this is normal (I would think not). Should I go to the dealer? If I show them the Auto Scan report, would the dealer know how to interpret the results? I'm going to copy and paste the report in this message so you guys can take a look. Should I be concerned?
    Saturday,20,August,2016,11:21:16:22105
    VCDS Version: 16.8.0.3
    Data version: 20160803 DS255
    VIN: 3VW217AU7GM055601   License Plate:
    Mileage: 3015km-1873mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
              75 A5
    VIN: 3VW217AU7GM055601   Mileage: 3015km-1873miles
    Address 01: Engine (J623-CXBB)       Labels: 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 091A00322464002F1000
       Shop #: WSC 00066 790 00060
       ASAM Dataset: EV_ECM18TFS0208V0906264F 001004
       ROD: EV_ECM18TFS0208V0906264F.rod
       VCID: 3FA3BE62A62BE5BA99-806A
    17178 - Databus
    Address 02: Auto Trans (J217)       Labels: 09G-927-749.clb
       Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
       Component: AISIN AG6 G3  129 2943
       ROD: EV_TCMAQ250031.rod
       VCID: 07336682BE7B6D7AE1-8052
       Revision: 00000000    Serial number: 60326000000119
       Coding: 01FA6AA124250971007D020081C4298056249000408194B416405052C082
       Shop #: WSC 01383 790 50316
       VCID: 7AD50F76FD890092EE-802E
       Revision: 00021000    Serial number: 0391975429
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_VW37.rod
       VCID: 3A55CF76BD09C092AE-806E
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
       Revision: 00001K01
       Coding: 00020004200100000100000000000002
       ROD: EV_ACManueBHBVW37X.rod
       VCID: 46ADAB86F9F1B472DA-8012
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 86580712150450
       Coding: 00111A464041A26969E44000001407001800000000000000000000000000
       Shop #: WSC 00066 790 00194
       ROD: EV_BCMBOSCH_VW37.rod
       Component: WWS    150819  043 0581
       Serial number:         160308143010
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S5Y15M12D28H06M20S49
       Coding: 90A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
       Component: J245 PS60.036  H06 0150
       Serial number: 03691681042208152054
       Coding: 181803
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
    722437 - Control Module for Power Sunroof
              B13C6 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 9
                        Mileage: 20 km
                        Date: 2016.05.20
                        Time: 00:00:14
    329480 - Heated Passenger Seat
              B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
       Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0054
       Revision: --------    Serial number: 39491533702419
       Coding: 0031165011
       ASAM Dataset: EV_EPHVA2CAU3700000 003021
       ROD: EV_EPHVA2CAU3700000_VW37.rod
       VCID: 47B3A682FEFBAD7A21-8012
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 28071503211941
       Coding: 01045400FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       Serial number: 003GCR04ADKJ
       Occupant Detection:
       Component: BF-Gewichtss.  H12 0021
       Serial number: IBH000000000004KUN3/
       Coding: 303135
       Subsystem 2 - Part No SW: -----------    HW: 480 000 102 16
       Serial number: 35700000000B845CF51X
       Subsystem 3 - Part No SW: -----------    HW: 480 000 102 16
       Serial number: 358000000003045CF51I
       Subsystem 4 - Part No SW: -----------    HW: 480 401 301 16
       Serial number: 3510002A91E85EB4227C
       Subsystem 5 - Part No SW: -----------    HW: 480 402 701 16
       Serial number: 3520002C31E9F0E0B1DJ
       Subsystem 6 - Part No SW: -----------    HW: 480 402 501 16
       Serial number: 35500029B1EDD3E6223K
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 501 16
       Serial number: 3560002A71E9F0E4D19R
       Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160126500539
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 73CB2252DAE371DAAD-8026
       Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
       Component: KOMBI         242 6420
       Coding: 0BA4191AED98CF0502886A0B5000000000000000
       ROD: EV_DashBoardVDDMQBAB_VW37.rod
       VCID: 256F0C0A24B75F6AF3-8070
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 09121510800146
       Coding: 0101000830085900FB00001A1C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07030
       ROD: EV_GatewConti.rod
       VCID: 79D7107AF88F0B8AE7-802C
       Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150001633190015335
       Coding: 35FFFF
       Revision: 00000000    Serial number: 16000011616010
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_VW37.rod
       VCID: 3449E14E9F6D36E274-8060
    Address 3C: Lane Change (J1086)       Labels: None
       Component: HRE_Master    H11 0071
       Serial number: 0391777731
       Coding: 02011103
       ROD: EV_HREntryHella.rod
       VCID: 3C59C96EB73DFEA2BC-8068
       Serial number: 24021606050B2J
       Coding: 003A13200000020000000000
       VCID: 43ABB292CAC3815AFD-8016
       Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
       Serial number: 00000000000011666435
       Coding: 011000
    589829 - Window Regulator; Rear Driver side
              B131F F5 [008] - Supply Voltage too Low
                        Mileage: 20 km
                        Date: 2016.05.19
                        Time: 23:50:17
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 1302
       ROD: EV_SteerAssisMQB_VW37.rod
       VCID: 44A9B18ECFCD8662C4-8010
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0130
       Revision: 00000001    Serial number: VWZ8Z1FBA01B49V
       VCID: 6DFF342ABCC7A72A7B-8038
       Serial number: 27021606050739
       VCID: 42A5B796D5D98852F6-8016
       Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
       Serial number: 00000000000011513780
       Coding: 091000
    589845 - Window Regulator; Front Passenger side
              B1320 F5 [008] - Supply Voltage too Low
                        Mileage: 20 km
                        Date: 2016.05.19
                        Time: 23:50:25
       Coding: 021A00010B000400
       VCID: 40A1BD9EDBD59A42E0-8014
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
       Part No SW: 3Q0 035 844     HW: 3Q0 035 844
       Component: MU-S-S-US     620 0613
       Coding: 027300000000000051220002001808001F0100F40120010002
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 6CF9392E87DDAE226C-8038
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJW00AKM
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [009] - -
                        Reset counter: 9
                        Mileage: 20 km
                        Date: 2016.05.19
                        Time: 23:41:13
                        Voltage terminal 30: 8.4 V
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2823A017F1E06000000
       ROD: EV_OCULowMQB.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0060
       Serial number: 10000471365
       Coding: 0100000000020300000400010100000100
       ROD: EV_MFKBoschAU370.rod
    May 2014
    iaco: Hi and welcome to the forum! I most certainly would return to the dealer and have a chat with whoever presented you with the car - but not because of the reason that you think!!
    With the exception of the DTC in the ECU, the other error messages have the following information:
    Mileage: 20 km
    Date: 2016.05.20
    This says that the DTC was first recorded in the control module when the car had travelled 20kms and the fault has not occurred again in an ignition sequence since first appearing on 19/20 May 2016. Clearly these faults are part of the production/pre-delivery process (I assume that you hadn't taken delivery of the car on this date because of the low kms when you made the auto-scan). Your conversation with the dealer ought to be about what pre-delivery checks are undertaken for their new car customers!! Alas, most VW dealers seem to believe that pre-delivery procedures are nothing more than a car-wash and a beaming smile from the sales rep that accepted your final payment as your drive the vehicle out of the showroom ( and ticking-off the boxes in the check-sheet by wrote)!!
  3. Likes Jack@European_Parts, Uwe liked this post
    Yeah man sloppy PDI....... I agree.
    The factory should be informed that their franchise is in breach of agreement......screw the dealer for CSI points and hold back money, for further not doing their job.
    Personally, if there are no functional problems with that car, I would just clear those codes. IMO, it wouldn't be worth the time and aggravation to deal with the red tape at the dealer. Even if you do take it to the dealer, all they're going to do is clear the codes, so what's the point? You've got plenty of warranty left if there are any actual problems with the car, right?
  6. Likes DV52 liked this post
    Nope I disagree and here is why............
    Always document that someone didn't do their job or live up to their responsibility, with certified letter return receipt, and one to you to leave unopened.
    As time goes on and depending on how the dealership or even the OEM happen to handle themselves.......... is suspect.
    Do this to protect yourself and if you don't say something, the same old crap will only continue to happen.
    Patterns of behavior may help you later, especially if you have to make an unknown argument......... should something not be right or going your way.
    What might seem small now......... may not be later.............
    Aug 2016
    Thank you everyone for the responses. Unfortunately the dealer is in Maryland and I live in New York. They had a great deal on the car and I couldn't pass it up.
    Should I go to my local dealer with the Auto Scan?
    Quote Originally Posted by iaco View Post
    Going to a dealer "with a scan" may not be the greatest idea, unless you know the dealer's service department well, and they're familiar with VCDS. If you do not, it is better to go to them with some kind of functional complaint...
  10. #8
    Aug 2016
    That's a good point. The sunroof does behave a little odd. I'm not familiar with the new four way switch for the panoramic roof as I'm used to the dial, but I don't have one touch open and close. Would that be apart of the code I'm getting for the roof? I need to make an appointment anyway because I have to get it inspected (temporary tags are expiring soon). I'll just mention the behavior with the roof and maybe they'll scan it themselves and reset the systems.
    For future reference, how would I go about resetting the modules with VCDS? Is it under OBDII and clear the DTC's or does that just do Check Engine Light stuff?
  11. #9
    I like that approach. Maybe ask them for a copy of the diagnostic printout from your car, "for future reference". I think most dealers will provide that if you ask (some seem to do it as matter of course).
    You may also want to ask if any of the techs use "Ross-Tech". If one or more do, IMO, those are the guys you want working on your car, 'cause they care enough to have invested some of their own money in a brand-specific tool.
    From the main screen, click:
    [Auto-Scan]
    [Gateway Installation List]
    That gives you a list of modules. The ones with faults will be in red.
    Double-click on one of the modules in red. That will take you to the Fault Codes function in that module, where you can review the fault codes you're about to clear by clicking:
    [Clear Codes]
    Then back out of the module.
    Repeat for other modules that are in red.
    When you're all done, exit everything gracefully. Turn the ignition off for a bit, turn it back on, and do another complete Auto-Scan to check that nothing has come back already.
  12. Likes Jack@European_Parts liked this post
