Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Unable to code Rain Sensor, Coding rejected error 31
    There's an official 16.8.1 coming soon, but until we have all the stuff to put a full installer together, try one of those .exes:
    http://download.ross-tech.com/VCDS/d...-8-0-5-x86.zip
    http://download.ross-tech.com/VCDS/d...-8-0-5-x64.zip
    and confirm that it fixes your issues
  2. Likes Uwe, Boki Ar, Dana liked this post
  3. #12
    Sep 2015
    Japan
    One of my customers has the similar problem. He cannot change the RLFS coding with VCDS 16.8.03. It was possible with the previous version of VCDS.
    VCDS Version: 16.8.0.3 (x64)
    Data version: 20160803 DS255
    Chassis Type: 8X (8U0)
    Scan: 01 03 05 08 09 10 14 15 16 17 19 22 25 2B 42 44 46 47 52 55
              56 57 5F 62 72 A9
    VIN: WAUZZZ8X3GB086046   Mileage: 4960km-3082miles
    Address 01: Engine (J623-CWZA)       Labels: 06K-907-425-V1.clb
       Part No SW: 8X0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 0A1900322406010B1002
       Shop #: WSC 00046 412 00000
       ASAM Dataset: EV_ECM20TFS0208X0906259 001007
       ROD: EV_ECM20TFS0208X0906259.rod
       VCID: 7F0D79BDE6B334BAD9-802A
    21388 - Valve for Exhaust Flap 1 (N321)
              P3019 00 [047] - Open Circuit
                        Mileage: 3691 km
                        Date: 2016.07.24
                        Time: 15:42:01
                        Engine speed: 802.25 /min
                        Normed load value: 9.4 %
                        Coolant temperature: 108 ーC
                        Intake air temperature: 49 ーC
                        Voltage terminal 30: 14.335 V
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_INTR
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 34 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
                        FAC_TPS_1_SAE: 12.109375 %
                        FUP_H_SAE: 11350.0 kPa
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
       Part No SW: 6C0 907 379 L    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0004
       Serial number: 08505896160129
       Coding: 36DF708B8D2B33C64914306D00576C0EB1CC920C0013E3090700
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
       VCID: 387F52A1831DC38258-806C
       Revision: 00092000    Serial number: 0392603402
       Coding: 030C0C
       ROD: EV_KESSYPQ35G.rod
       VCID: 377D519D8E03CCFA51-8062
       Part No SW: 8XA 820 043     HW: 8XA 820 043
       Component: Klima 1 Zone  H01 0010
       Serial number: 00000000386020
       Coding: 6423680890
       ASAM Dataset: EV_AirCondiFrontAU210 007002
       ROD: EV_AirCondiFrontAU210.rod
       VCID: 020BF04995415952B6-8056
    Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
       Part No SW: 8X0 907 063 AC    HW: 8X0 907 063 AC
       Component: BCM PQ35  M   113 0817
       Revision: AC113817
       Coding: 60970A97A8051AC4201840E0210408CC53F7620A21EF5DB2E4088787E0C5
       Shop #: WSC 00046 123 12345
       VCID: 7DF183B5E4BF26AACB-8028
       Subsystem 1 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Serial number: 61276535
       Coding: 180023
    Address 10: Park/Steer Assist (J446)       Labels: 8X0-919-475.clb
       Part No SW: 8X0 919 475 AF    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0060
       Revision: 11001001    Serial number: 55961601400633
       Coding: 040203
       ASAM Dataset: EV_EPHVA18AU21X0000 002006
       ROD: EV_EPHVA18AU21X0000.rod
       VCID: 0A1BD869AD710112FE-805E
    Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
       Part No SW: 6C0 907 359     HW: 6C0 907 359
       Component: DAEMPFUNGS-SG H04 0007
       Serial number: 26011602000309
       Coding: 82
       ASAM Dataset: EV_SwitcDampeContiTemic 001004
       ROD: EV_SwitcDampeContiTemic.rod
       VCID: 6ADBB8E98D31A1121E-803E
    Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
       Part No SW: 8XA 959 655 A    HW: 8XA 959 655 A
       Component: Airbag10.41   H08 0011
       Revision: --------    Serial number: 003NZ0012R5A
       Coding: 30323236303330323532554A305238584153
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_Airba1041BPAAU210 001018
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 59B9F72558573A8A87-800C
       Serial number: 3554VRB4008558KKFGL-
       Serial number: 3575HRB400S55AB8GI08
       Serial number: 3585HRB400S55AB8712S
       Rear Impact Crash Sensor:
       Serial number: 3515ZRB40613K8QGF0N.
    Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
       Part No SW: 8X0 953 521 AH    HW: 5K0 953 569 BG
       Component: LENKS.MODUL   018 0230
       Revision: FF010018    Serial number: 20160129100811
       Coding: 1004004000
       ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
       ROD: EV_SMLSNGVOLWSR8C.rod
       Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
       Serial number: 28 12 2015  G0078684
    Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
       Part No SW: 8XA 920 930 C    HW: 8XA 920 930 C
       Component: KOMBI_MEDIUM  H09 0480
       Coding: 53CE01
       VCID: 4B951D6DE28B581A05-801E
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 AC    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0074
       Revision: 1P140041    Serial number: 4141P1612504EF
       Coding: FBCF7059000100010353
       VCID: 0305F54D825B505ABD-8056
       Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0190
       Serial number: 33013658595701372236
       Serial number: 151107000000000002E2
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Fault Frequency: 10
                        Reset counter: 183
                        Mileage: 2770 km
                        Date: 2016.07.09
                        Time: 18:47:01
                        Bin. Bits:    00000
                        Voltage: 0.00 V
       Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7540
       Serial number: HA1-00002.12.15
       Coding: 0201
       ROD: EV_AllWheelContrHA1VW37X_VW36.rod
       VCID: 52AB000905A109D246-8006
       Component: IMMO          H09 0480
       Coding: 000007
       ROD: EV_Immo_UDS_VDD_AU10.rod
       Revision: 00000000    Serial number: 16000011647009
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 31696F85606712CA1F-8064
    Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H11 0415
       Coding: 011E13205C01000000
       VCID: 52AB00090DA109D246-8006
    Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
       Part No SW: 6R2 909 144 AJ    HW: 6R2 909 144 E
       Component: EPS_TRW_ALow  322 3132
       Serial number: CG210476
       Coding: 802700
       ASAM Dataset: EV_SteerAssisUDSTRW 016029
       ROD: EV_SteerAssisUDSTRW_VW26.rod
       VCID: 000FFA419B4D4B42A0-8054
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 8X0 035 223 D    HW: 8X0 035 223 B
       Component: BOSE-G3-A1Q3  H05 0160
       Revision: CK005201    Serial number: 00000000051977
       Coding: 030000
       VCID: 3365658D927B20DA6D-8066
    Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H11 0415
       Coding: 011E13201E01000000
       VCID: 51A90F0508A772CA7F-8004
    Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
       Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
       Serial number: 160203-0002-050
       Coding: 11B3AC1010002500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 44873651CFD59762C4-8010
       Part No SW: 4G0 035 083     HW: 4G0 035 083
       Component: Radio U JP    H50 0055
       Revision: AB001007    Serial number: 448A 0G2503299
       Coding: 030005010000000002
       VCID: 5EB3E4394979DDB2F2-800A
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4G1 919 129 C    HW: 4G1 919 129
       Component: NGTV-JP       H03 0430
       Revision: R0030000    Serial number: 07001101728001
       Coding: 10000000
       VCID: 2E5374F979590D3202-807A
       Part No SW: 8XA 035 678 C    HW: 8XA 035 678 B
       Component: H-BN-JP       042 0615
       Revision: --------    Serial number: K5FAN1HHB2ZHO
       Coding: 0D0601040208E0E90500032600000001FC0030020000000000
       Subsystem 1 - Part No: 8R0 060 884 DN
       Component: JPN-24.06.15.  7911
       Subsystem 2 - Part No SW: 4F0 035 503 F    HW: 4F0 035 503 F
       Component: ETC-VICS-Ant.  H05 0020
       Subsystem 3 - Part No SW: 4L0 919 813 F    HW: 4L0 919 813 F
       Component: Card reader  H04 0110
       Serial number: 382506351122
       Subsystem 4 - Part No SW: 8X0 919 604     HW: 8X0 919 604
       Component: DU6 High  H42 0084
       Serial number: 9463AW0G2563605
       Subsystem 5 - Part No: 8R0 060 961 G
       Component: CD-Database  6208
       Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
       Component: TSG HL        H08 0415
       Coding: 010813200001000000
       VCID: 50AF0A0103AD7BC270-8004
       Component: TSG HR        H08 0415
       Part No SW: 8X0 907 159 C    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 160106201936
       VCID: 428B3049D5C19952F6-8016
  4. #13
    Quote Originally Posted by MoToM View Post
    Please have him replace his VCDS.EXE with the appropriate one from two posts up and try it. We are reasonably confident that will fix the problem.
  5. Likes Boki Ar liked this post
  6. #14
    16.8.1 is official on our download page now.
  7. #15
    Aug 2016
    Luxembourg
    I can confirm that this patch has fixed the problem.
    I could successfully re-code the RLS component of 09 and get the rain-closing function working.
    Thank you!
  8. Likes Boki Ar, Uwe, dvdtrmbl liked this post
  9. #16
    Nov 2018
    Europe - Hungary
    Same problem with 19.6.1
    Saturday,24,August,2019,17:04:54:64377
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
    VCDS Version 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
    Workshop Code: 790 73430 000063
    VIN: TMBLK9NS4K8066223   License Plate: RLH-386
    Mileage: 9019km-5604mi   Repair Order:
    Chassis Type: NS-SK37 (3Q0)
    Scan: 01 02 03 05 06 08 09 10 13 14 15 17 18 19 22 2B 36 3C 42 44
              47 4B 52 5F 69 6C 6D 75 A5 BB BC CA D6 D7
    VIN: TMBLK9NS4K8066223   Mileage: 9019km-5604miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DFHA)       Labels: None
       Part No SW: 04L 906 026 RA    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H25 6580
       Revision: B4H25---
       Coding: 0125003A04761D083000
       Shop #: WSC 33361 790 00162
       ASAM Dataset: EV_ECM20TDI01104L906026RA 004004
       ROD: EV_ECM20TDI01104L906026RA.rod
       VCID: 7AADF1932C50EE4784D-802F
    5456 - Unknown Error Code
              P06E9 00 [109] - -
                        Mileage: 7500 km
                        Date: 2019.08.16
                        Time: 07:34:54
                        Coolant temperature: 90 °C
                        Intake air temperature: 74 °C
                        Voltage terminal 30: 12.280 V
                        Starter control: terminal 50 acknowledgment-Bits 0-7: 32
                        Status of starter activation relay-Bits 0-7: 3
                        Starter control: release conditions-Bits 0-7: 98
                        Starter control: release conditions-Bits 0-7: 90
                        Starter control: shut-off conditions 1-Bits 0-7: 0
                        Number of manual engine starts-Bits 0-7: 0
                        Number of manual engine starts-Bits 0-7: 39
                        Number of automatic engine starts-Bits 0-7: 0
    34193 - Implausible Data Received from ESP Control Module
              U0416 00 [032] - -
                        Fault Frequency: 8
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 18:47:00
                        Coolant temperature: 84 °C
                        Intake air temperature: 76 °C
                        Voltage terminal 30: 12.160 V
                        Unlearning counter according OBD: 29
                        Engine status: COENG_READY
    9690 - Sensor for NOx (G295)
              P1032 00 [096] - Signal too High
       Part No SW: 0DL 300 013 A    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 3004
       Revision: 00H06V07
       VCID: 2809FBDB827CACD7A29-807D
       Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
       Component: ESC           H35 0107
       Revision: 00000000    Serial number: 60829000003034
       Coding: 60076A9F50260B724779070262C64906560AD0E2E0469275386150F8F2A94A0B00402F641A1B13111435351919323200
       VCID: 79AFEE9F2956E55F8D7-802D
    0297 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 220
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 18:47:00
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 225
                        Mileage: 7520 km
                        Date: 2019.08.16
                        Time: 16:02:46
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0510012082
       Coding: 032C0C0723
       VCID: 43D34C771B1A6F8F97B-8017
       Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
       Component: GEB.F.Heckoef  H17 0904
       Serial number: 58618341
    Address 06: Seat Mem. Pass (J521)       Labels:* None
       Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
       Component: Sitzmemory    H09 0024
       Serial number: Y0006SBR16933
       Coding: 0010000000000500018280818180000000008181000000D400
       ASAM Dataset: EV_SeatMemorPasseSide 002022
       ROD: EV_SeatMemorPasseSide.rod
       VCID: 3D273A8F7DFE197FE1F-8069
       Part No SW: 565 907 044 BC    HW: 565 907 044 BC
       Component: Climatronic   H04 2002
       Revision: 00001K00
       Coding: 16010104004111011105100C0010112A
       Shop #: WSC 00033 790 00138
       ASAM Dataset: EV_ACClimaBHBVW37X 006147
       VCID: 5DE79A0F9DBE397F81F-8009
       Air quality sensor:
       Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 89802293
       Part No SW: 5Q0 937 086 BR    HW: 5Q0 937 086 BR
       Revision: --------    Serial number: 86580303190052
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 0B43A45773CAE7CFAFB-805F
       Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS326 190227  051 0910
       Serial number: 887353F0401905800869
       Coding: 164DDD
       Component: RLHS  052 0107
       Serial number: S4Y19M03D25H19M05S41
       Coding: 00885D
       Steering Column Switch:
       Subsystem 4 - Part No SW: 5Q1 953 521 DH    HW: 5Q1 953 569 C
       Component: Lenks.Modul  H33 0170
       Serial number: 0100150320190C204762
       Seat Backrest Fan 1 Front Left:
       Subsystem 5 - Part No SW: 4N0 963 575     HW: 4N0 963 575
       Component: V512 LLR1SLvL  H01 0012
       Serial number: Q98AI33291302
       Seat Cushion Fan 1 Front Left:
       Subsystem 6 - Part No SW: 4N0 963 575     HW: 4N0 963 575
       Component: V514 LLR1SKvL  H01 0012
       Serial number: Q98AI33221227
       Seat Backrest Fan 1 Front Right:
       Subsystem 7 - Part No SW: 4N0 963 575     HW: 4N0 963 575
       Component: V516 LLR1SLvR  H01 0012
       Serial number: Q98AI332A1629
       Seat Cushion Fan 1 Front Right:
       Subsystem 8 - Part No SW: 4N0 963 575     HW: 4N0 963 575
       Component: V518 LLR1SKvR  H01 0012
       Serial number: Q98AI33262369
       Part No SW: 3Q0 919 298 C    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0038
       Serial number: 000211187498000
       Coding: 0231267A51
       ASAM Dataset: EV_EPHBO2CVW3260000 010019
       ROD: EV_EPHBO2CVW3260000.rod
    13637426 - Databus
                        Fault Frequency: 11
                        Reset counter: 220
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 18:47:00
    13688835 - Databus
              [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                        Reset counter: 231
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 19:09:39
       Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0342
       Coding: 320467CB58FF8728749C814530408700000000000000000000
       ASAM Dataset: EV_ACCMRRCONTIVW376 003015
       ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
       VCID: 42DD4973040066879CD-8017
    0803 - Databus
              [FAULT_BV1_FEHLER]
                        Fault Frequency: 9
                        Reset counter: 220
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 18:47:01
                        Voltage terminal 15: 12.2 V
                        Control Module temperature: 26 °C
                        Vehicle speed: 0.00 m/s
                        Longitudinal acceleration: -0.09 m/s²
                        Adaptive distance regulation: status: ACC_reversible_error
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                        Fault Frequency: 10
                        Reset counter: 220
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 18:47:01
                        Voltage terminal 15: 12.1 V
                        Longitudinal acceleration: -0.06 m/s²
                        Adaptive distance regulation: status: ACC_StandBy
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 227
                        Mileage: 7578 km
                        Date: 2019.08.18
                        Time: 17:36:34
                        Control Module temperature: 42 °C
    2055 - Databus
              [FAULT_ALP_STEERINGWHEEL_INIT]
                        Fault Frequency: 9
                        Reset counter: 220
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 18:47:02
       Serial number: 21031941351348
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 38292B9B52DC3C57329-806D
       Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
       Revision: --------    Serial number: 003Z4P5CY6FA
       Coding: 98FCC0C0000000005C5400CF000840000065
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0E45AD4300D8D2E7485-805B
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1040
       Serial number: 566857705A0082T00835
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1040
       Serial number: 566857706A0084T00324
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 001 203 19
       Serial number: 3570000000046188E93P
       Subsystem 4 - Part No SW: -----------    HW: 454 001 203 19
       Serial number: 3580000000018061993A
       Subsystem 5 - Part No SW: -----------    HW: 454 800 903 19
       Serial number: 35100AE225818000000G
       Subsystem 6 - Part No SW: -----------    HW: 454 801 203 19
       Serial number: 35200ECC05C18000000V
       Subsystem 7 - Part No SW: -----------    HW: 454 800 303 19
       Serial number: 355003B9A5D17000000T
    1050117 - Databus
                        Fault Frequency: 11
                        Reset counter: 220
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 18:47:02
       Part No SW: 565 920 790 A    HW: 565 920 790 A
       Component: KOMBI         508 1691
       Coding: 04A4001CFF8400080188630B5001000880000000
       Shop #: WSC 73430 031 00162
       ASAM Dataset: EV_DashBoardVDDMQBA0 001026
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       VCID: 1C61D70BC6247077361-8049
       Part No SW: 5Q0 963 272 J    HW: 5Q0 963 272 J
       Component: STH-MQB       008 0080
       Coding: 9309
       Component: R64 D208L  004 0402
       Serial number: 00000000000000681812
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 27031910801851
       Coding: 0B0100345F087300EB1322DE9A0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 6E85CDC36018B2E7285-803B
       Component: 1-01-13-01-04
       Subsystem 2 - Part No SW: 3V0 919 719 H    HW: 3V0 919 719 H
       Component: E221__MFL-PR6  H03 0170
       Serial number: 000000000A1093210319
       Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
       Serial number: 758861030019021817AA
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 H    HW: 5Q0 907 155 H
       Component: U13DCAC  H27 0810
       Serial number: 5038475
       Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00023.01.19
       Coding: 0101
       VCID: 4CC1674B3644A0F7661-8019
       Serial number: 19000088144002
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_AU37.rod
       VCID: 33331CB74BBADF0F07B-8067
    Address 36: Seat Mem. Drvr (J810)       Labels:* None
       Serial number: Y0006SBR16707
       ASAM Dataset: EV_SeatMemorDriveSide 002022
       Component: HRE_Master    H12 0081
       Serial number: 0510838450
       Coding: 02012103
       ROD: EV_HREntryHella_VW37.rod
       Component: HRE_Slave  H12 0081
       Serial number: 0510481703
       Coding: 020121
    338048 - Databus
              [Parkhilfe_01::PH_Tongeber_H_verfuegbar]
                        Reset counter: 220
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 19:09:37
    733440 - Control Module for Blind Spot Assist
              C118F F0 [008] - Limited Visibility
                        Reset counter: 231
                        Mileage: 8285 km
                        Date: 2019.08.22
                        Time: 12:46:54
    733696 - Control Module 2 for Blind Spot Assist
              C1190 F5 [008] - Limited Visibility
                        Reset counter: 231
                        Mileage: 8284 km
                        Date: 2019.08.22
                        Time: 12:42:53
       Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
       Component: TSG FS        006 0248
       Serial number: 0000370342350
       Coding: 00158920DE00028000001100
       VCID: 48C95B5B223C4CD7429-801D
       Part No SW: 5QF 909 144 B    HW: 5QF 909 144 A
       Component: EPS_MQB_ZFLS  507 5582
       Coding: 93170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 49CF5E5F3936B5DF5D7-801D
    Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1KJE07014K
       Coding: 0323160000AA002AAA0000000000
       ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
       ROD: EV_AMPMst16C4Gen2ALPI.rod
       VCID: 59EF8E1F8996C55FED7-800D
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 25031910801718
       Coding: 000000070900037206002D01190000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW41.rod
       VCID: 353722AF45CEC13F29F-8061
       Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
       Component: TSG BFS       006 0248
       Serial number: 0000370402951
       Coding: 00158120DE00028000001100
       ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
       VCID: 47CB58672F2243AF4B3-8013
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
       Part No SW: 565 035 021 D    HW: 565 035 021
       Component: MU-H-LND-EU   H55 1382
       Serial number: A853C0KB116655
       Coding: 03231601000000004111120200880A332F0103E4012084009E
       ROD: EV_MUHig4CGen2HBAS_SK37.rod
       VCID: 0F7BB04707D2DBEF433-805B
       Subsystem 1 - Part No SW: 565 919 606 D    HW: 565 919 606 D
       Component: ABT_High-2  H52 9130
       Serial number: SKZ6ZHW1181141
       Subsystem 2 - Part No SW: V03 959 801 JR    HW: -----------
       Component: ECE 2019  --- 0175
       Component: Gracenote2  --- 1017
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0511603218
       Coding: 0100000202000000
       Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
       Component: Areaview 2    H13 0608
       Serial number: C854707JG050662
       Coding: 04231601A70FA00000604014
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
       VCID: 392F2E9F69D6255FCD7-806D
       Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0266
       Revision: --------    Serial number: 32384661300000
       Coding: 1B88
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       VCID: 45D7526F152E51BFB9F-8011
       Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
       Component: OCULowMQBLGE  H19 0825
       Revision: --------
       Coding: 03231601EA423A0D3F1CBE020045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004049
       ROD: EV_OCULowMQBLGE_004_VW25.rod
       Part No SW: 3QD 980 654 A    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H10 1611
       Serial number: 25011941P20657
       Coding: 020307060000040100222355C150A90094000E20002000
       ROD: EV_MFKBoschMQBB_002_VW37.rod
    1123173 - Databus
              [ESP_21_ESP_Systemstatus]
                        Fault Frequency: 6
                        Reset counter: 220
                        Mileage: 7096 km
                        Date: 2019.08.14
                        Time: 18:47:02
                        Control Module temperature: 28 °C
                        Outside air temperature: 21.5 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 3.3 s
                        Voltage terminal 15: 12.0 V
                        mid: 02 E0
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 1
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 1
       Part No SW: 5Q4 959 595 F    HW: 8W0 959 595 F
       Component: TSG HFS       005 0246
       Serial number: 0000368521260
       Coding: 001081208000028000001100
       ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
       VCID: 4ACD61533C30BEC754D-801F
       Component: TSG HBFS      005 0246
       Serial number: 0000368526698
       ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
       Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
       Coding: 608040632612
       ROD: EV_SunRoofCONTIAU736_009_VW37.rod
       VCID: 75B7E2AF054E813FE9F-8021
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
       Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
       Component: LED1L         H07 0009
       ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
       VCID: 025D89734480A687DCD-8057
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
       Component: LED1R         H07 0009
       ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
    End----------(Elapsed Time: 02:45, VBatt start/end: 12.5V/12.5V)-----------
    Address 01: DTCs cleared
    Address 03: DTCs cleared
    Address 10: DTCs cleared
    Address 13: DTCs cleared
    Address 15: DTCs cleared
    Address 3C: DTCs cleared
    Address A5: DTCs cleared
