Results 1 to 8 of 8
Thread: 2011 Sportswagen - many outside light errors, but intermittent
    Jun 2014
    The problem started yesterday on my 2011 JSW TDI. The amber "light bulb" MIL turned on, and a slew of messages such as "Check your left brake light, " Check your rear license plate light," etc. scrolled through.
    All lights are stock and still original bulbs. I did a walk around check with an assistant operating the light switch and stalk inside the car, and a bunch of lights were indeed out. On one side: driving light, the rear brake light, etc., and on the other side: turn signal, headlight, etc., plus license plate and third brake light in the middle.
    • All bulbs are ok; all filaments are intact (and they would turn on again the in the evening - see below),
    • Fuses are all good,
    • VCDS scan returned 11 Central Electronic faults 0010: 00979, 00985, 01497, etc. Here's the full scan at pastebin.com (can unmask VIN if needed).
    • After sunset and the temp has dropped a bit, tried the lights and all worked!
    • This morning, I waited for the sun to cook the car on the driveway, and the issues returned. Car was not moved.
    Any thoughts? Relay? Headlight switch? Wiring harness? I'm hoping it's something easy to fix.
    (FWIW, Navigation is also returning CD Changer fault but I don't think it's related).
    Found http://wiki.ross-tech.com/wiki/index.php/00979, http://wiki.ross-tech.com/wiki/index.php/01499 and http://wiki.ross-tech.com/wiki/index.php/02394: either bad bulb (not the case), bad wiring (why intermittent without the car moved?), or bad module coding (why intermittent?), or do an output test (how do I do this?).
    - Can someone point me to any particular wiring harness I should check? I haven't worked on this car that much.
    - Main ground point near battery is ok. Coated it with Deoxit when dealer replaced battery under warranty.
    - Open to plus, exactly means?
    Quote Originally Posted by logue View Post
    That's not a full scan, that's just data from the 09-BCM module. A full scan includes all the modules.
    Stoke on Trent, England
    It means Open circuit or short circuit to plus, I always say positive. It means it getting another power feed from somewhere.
    New User Keith
    Jun 2014
    Ok - sure. You know what I mean. I got it from the autoscan and the two modules that gave errors are listed on the OP. So, other than correcting my terminology, any other pointers?
    Bad ground/corrosion most likely............or bad module.........and yeah modules can go bad sporadic based on temp or humidity.
    Have you performed outputs in 0x09-03 ?
    While condition exists.
    Well, it's always preferable to post an entire Auto-Scan as opposed to a snippet containing data from just one module. The modules in modern cars are so heavily networked and interdependent that there are often clues in other modules.
    If I were a betting man, my money would be on a flaky module. If all the faults were at one end of the car, I'd check to see if all those lights and such had a common ground point and suspect that ground point as being loose or corroded. But your faults are at both the front and the rear of the car, so I doubt they all have a common ground.
  7. Likes Jack@European_Parts, Dana, logue liked this post
    Jun 2014
    So I was curious and disconnected the battery yesterday for a while. It's a cooler day and after reconnecting it, the issues went away for the night (though I initially got Fuel Pressure Sensor, TPMS and Steering Assist faults that cleared after driving). Though the light issues were (temporarily) gone, 3 new faults came up - from 09: "02092 - Enabling Heated Seat
    009 - Open or Short to Ground" and from 4F: Cent Elect II (J520) "01512 - Control Module for Sliding Roof | 02907 - Control Module for Roof Shade (J394), 004 - No Signal/Communication" (see autoscan). The panoramic moon roof and the shade now wouldn't open.
    And this morning, the light issues came back. I re-checked all the fuses on the side panel and the engine bay; they were all good, no sign of overheating/melting.
    I'm going to replace the BCM. There are so many part numbers for mk5/mk6. My 2011 JSW has the 5K0 937 084 E. I found a used one listed locally from a 2012 GTI, 1K0 937 086 P. Would it be compatible?
    Autoscan results (this is after I cleared the fuel pressure sensor intermittent; another topic) - also on pastebin:
    Friday,20,June,2014,08:20:57:14230
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: 3VWPL7AJ7BMxxxxxx   License Plate:
    Chassis Type: AJ (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
              77
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 DB    HW: 03L 906 019 DA
       Component: R4 2,0L EDC G000AG  9047
       Revision: 12H10---    Serial number:
       Coding: 0050078
       Shop #: WSC 09415 444 12545
       VCID: 6ED844DD79A0936E79B-803B
       Part No SW: 02E 300 052 G    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2267
       Revision: 05151112    Serial number: 00001009010900
       VCID: 183442052BA43DDE437-804D
       Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
       Component: ESP MK60EC1   H30 0106
       Revision: 00H30001
       Coding: 114B600C492600FD881106ED921A0042B70000
       Shop #: WSC 09415 444 63365
       VCID: 74EC56B5D78CB9BE8FF-8021
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       Shop #: WSC 00066 000 00149
       ROD: EV_ClimaBasis_SE36.rod
       VCID: 75EA6BB1D4F6A0B6B81-8020
       Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
       Component: BCM PQ35 B    011 0035
       Revision: BG011001
       Coding: 27380E3F802F3EC400880081600000040300008653598560648020000040
       VCID: 346C96B5970CF9BE4FF-8061
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 31101  21  0512
       Coding: 009795
    11 Faults Found:00927 - Terminal 30 (Right)
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:39:16
                        Voltage: 14.05 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:41
                        Voltage: 12.65 V
    00985 - Right Tail Light (M2)
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:41
                        Voltage: 12.65 V
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:41
                        Voltage: 12.65 V
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:41
                        Voltage: 12.65 V
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:41
                        Voltage: 12.65 V
    01501 - Bulb for Blinkers; Rear Left (M6)
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:41
                        Voltage: 12.65 V
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:41
                        Voltage: 12.65 V
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:42
                        Voltage: 12.65 V
                        Fault Status: 01101001
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:39:17
                        Voltage: 14.10 V
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:52:42
                        Voltage: 12.60 V
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R00ZWG0
       Coding: 00003044
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3972A781B86E04D69C9-806C
       Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
       Component: BF-Gewichtss.  007 0001
       Serial number: ---0000R--0005C84800
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME42582456ZZZT
       Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME5D615157ZZZ.
       Serial number: 3511HSME66451F23ZZZN
       Serial number: 3521HSME5D6A1F23ZZZ.
       Serial number: 35527SME5E4F4F23ZZZ
       Crash sensor for front airbag; passenger side:
       Serial number: 35627SME3A744F23ZZZP
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90440JI90006P
       Coding: 188A140000
       Shop #: WSC 00066 000 00192
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 76E86CBDC9F0ABAEB1B-8023
       Component: E221__MFL-TAS  H07 0013
       Serial number: 0036371
       Coding: 820000
       Part No SW: 5K0 920 971 CX    HW: 5K0 920 971 CX
       Component: KOMBI         H20 0420
       Coding: 430F01
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 871691793E1A22265AD-80D2
    Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530 A    HW: 1K0 907 951
       Component: J533  Gateway   H25 5603
       Revision:   H25       Serial number: 22101001200165
       Coding: ED807F0640061300002002
       VCID: 2E5884DDB920D36E39B-807B
       Component: IMMO          H20 0420
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EAD0C8CD0D48FF4EA53-80BF
       Revision: A1001003    Serial number: 7668528775
       Coding: 020000
       VCID: 275671F956DA8226FAD-8072
       Part No SW: 1K0 035 274     HW: 1K0 035 274
       Component: RNS315-NAR    H04 0007
       Serial number: VWZAZ2K8411820
       Coding: 060004210400000000001000
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_RNS315VWNARV1UDS A01005
       ROD: EV_RNS315VWNARV1UDS.rod
       VCID: E1C2AFE1F07EBC16749-80B4
    1048630 - CD Changer
              B1101 31 [009] - No Signal
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:39:16
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0001502544
       Coding: 0004B5
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide.rod
       VCID: 275671F95EDA8226FAD-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005264272
       Coding: 000490
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: 31629FA1A81ECC96249-8064
       Component: EZE_2         H25 5603
       Coding: 050B0500
       VCID: EFE6D9D93EAA1A66F2D-80BA
    2 Faults Found:01512 - Control Module for Sliding Roof
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:39:20
                        Reset counter: 119
                        Mileage: 75890 km
                        Date: 2019.14.19
                        Time: 00:39:20
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0307
       Revision: 15101005    Serial number: 0001467162
       Coding: 0004B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 285472C553C48D5EF37-807D
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005213699
       Coding: 000490
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668515781
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 326090AD6518F78E5D3-8067
  9. #8
    Only install part # s that are correct with continuity or superseded by your local dealer based on VIN #/production date and PR-codes from white tag in trunk/service book.
    Before replacement.
    I would try to default the controller by recoding and changing the WSC and clearing learned values in 0x09-10-00 test/save.
    Reboot.
    If that didn't help I would then take module out/disassemble and inspect the traces for any hot spots/damage/corrosion....clean connectors.
    If none found
    I would also take a heat gun to it to reflow all the solder joints of the chip sets. ( be careful )
    Then one more time try the default above.
    If it didn't work and all harness's were proper/with good grounds............ I would change the module.
  10. Likes logue liked this post
