I have replaced an ABS control module, and copied the old coding to the new module(same part numbers), but the coding is being accepted, then showing up as all 0s a few minutes later. I am pretty sure now, after looking at codes in old module, that long coding was incorrect to start with. Please help, if you could figure out how to get the correct coding, it would be awesome. the files for scans with old and new(used) modules are attached, as well as PR code sticker shot.
first scan: old faulty abs module to see coding:
second scan is with replacement abs module, used, same part number. at first coding was accepted, then when checking again all 0s, then this scan shows the coding I entered.
Wednesday,17,August,2016,12:57:55:53310
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: 3VWRJ71K49M040649 License Plate:
Mileage: 154060km-95728mi Repair Order: 1
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRJ71K49M040649 Mileage: 154060km-95728miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H724N04L
Coding: 0403010A1C070160
VCID: 699A77CE40A9DC76C6-803C
001378 - System Voltage
P0562 - 000 - Too Low
Date: 2047.15.31
Time: 31:63:63
Speed: 255.0 km/h
Temperature: 33.0°C
Temperature: 34.0°C
Absolute Pres.: 980.0 mbar
Voltage: 8.128 V
050217 - Implausible Data Received from Steering Column Control Module
U0429 - 000 - - Intermittent
Mileage: 154060 km
Time: 23:09:23
Temperature: 38.0°C
Temperature: 39.0°C
Voltage: 12.065 V
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent - MIL ON
Fault Status: 10100000
Mileage: 154060 km
Time: 23:02:34
Temperature: 31.0°C
Temperature: 33.0°C
Voltage: 13.208 V
Readiness: 0010 0001
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 051 C HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1816
Revision: 04843012 Serial number: 00000806120102
VCID: 1366752632A5B6A6DC-8046
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Fault Frequency: 255
Reset counter: 40
Mileage: 154060 km
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B600D492600FA881106E892220041B100
VCID: 75A22BBEDC11089652-8020
7 Faults Found:
01130 - ABS Operation
Reset counter: 27
Mileage: 154057 km
Count: 7
Count: 13
Count: 12288
Count: 125
Count: 24320
Count: 64768
Count: 64768
01542 - Yaw Rate Sensor (G202)
Fault Status: 00101100
Reset counter: 27
Mileage: 154057 km
Count: 7
Count: 13
Count: 12288
Count: 259
Count: 64768
Count: 63232
Reset counter: 27
Mileage: 154057 km
Count: 3
Count: 12
Count: 12288
Count: 211
Count: 34560
Count: 64768
Count: 65024
16352 - Control Module - Electrical Error
014 - Defective
Fault Status: 01101110
Reset counter: 27
Mileage: 154057 km
Count: 3
Count: 12
Count: 12288
Count: 96
Count: 34560
Count: 64768
Count: 65024
Reset counter: 27
Mileage: 154057 km
Count: 3
Count: 12
Count: 12288
Count: 265
Count: 34560
Count: 64768
Count: 65024
00003 - Control Module
Fault Status: 01100101
Reset counter: 27
Mileage: 154057 km
Count: 3
Count: 12
Count: 12288
Count: 143
Count: 34560
Count: 64768
Count: 65024
00538 - Reference Voltage
Reset counter: 0
Mileage: 154057 km
Count: 3
Count: 12
Count: 12288
Count: 131
Count: 34560
Count: 64768
Count: 65024
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CB43E9A3F3B59DE2D-8028
00532 - Supply Voltage B+
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001059952
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
VCID: 3228D0A2ADFF5FAEB7-8066
Component: Wischer 270808 021 0501
Coding: 00038805
Shop #: WSC 00066
10 Faults Found:
Fault Status: 01111100
Reset counter: 28
Mileage: 154057 km
Voltage: 13.95 V
001 - Upper Limit Exceeded
Fault Status: 01110001
Reset counter: 28
Mileage: 154061 km
Voltage: 16.55 V
Reset counter: 67
Mileage: 154057 km
Voltage: 8.05 V
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Reset counter: 68
Mileage: 154060 km
Voltage: 14.00 V
Reset counter: 68
Mileage: 154057 km
Voltage: 8.35 V
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 68
Mileage: 154057 km
Voltage: 9.45 V
Reset counter: 68
Mileage: 154061 km
Voltage: 15.65 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 68
Mileage: 154057 km
Voltage: 9.45 V
02384 - Windshield Wiper Motor Function Restricted due to Over-Voltage
Reset counter: 68
Mileage: 154061 km
Voltage: 15.70 V
01598 - Drive Battery Voltage
Fault Frequency: 7
Reset counter: 68
Mileage: 154057 km
Voltage: 9.45 V
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0397338
Coding: 0000100
VCID: 3326D5A652E556A6BC-8066
Fault Status: 01100001
Reset counter: 28
Mileage: 154061 km
Time: 00:54:49
Voltage: 16.00 V
Reset counter: 68
Mileage: 154060 km
Time: 23:09:18
Voltage: 8.30 V
Reset counter: 68
Mileage: 154060 km
Time: 23:08:48
Voltage: 8.30 V
Reset counter: 27
Mileage: 154057 km
Time: 22:47:22
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06JLPR
Coding: 0013889
VCID: 6C940EDA4F5BC95EBD-8038
Subsystem 2 - Serial number: 6332MSME25414E45A
Subsystem 3 - Serial number: 6342MSME38714F3FS
Subsystem 4 - Serial number: 6351HSME174A4B7BM
Subsystem 5 - Serial number: 6361HSME174A1A1DF
Subsystem 6 - Serial number: 63727SME17240671V
Subsystem 7 - Serial number: 63827SME17242760X
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010021
VCID: 0346456642C526266C-8056
Part No SW: 1K0 920 954 R HW: 1K0 920 954 R
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H724N04L
Coding: 0023203
VCID: 3B36FD867AB59EE664-806E
Fault Frequency: 12
Reset counter: 68
Mileage: 154057 km
Time: 03:49:53
Reset counter: 68
Mileage: 154057 km
Time: 03:50:49
Reset counter: 68
Mileage: 154060 km
Time: 23:02:34
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 090708F2000181
Coding: ED807F070003021002
VCID: 3522EBBE5C91489692-8060
Reset counter: 68
Mileage: 154057 km
Time: 03:49:19
Component: IMMO 3HL 1222
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000511688809
Coding: 0001205
VCID: 6FAE19D67E4D324698-803A
Reset counter: 67
Mileage: 154057 km
Fault Status: 00100101
Reset counter: 68
Mileage: 154057 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A18C8C2852F176E0F-807E
Reset counter: 78
Mileage: 154060 km
Time: 23:03:31
Voltage: 14.00 V
DU
Temperature: 33.0°C
RPM: 1139 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 0444467A47CB211E55-8050
Reset counter: 68
Mileage: 154057 km
Time: 03:49:04
Reset counter: 28
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000296388819
Coding: 0001204
VCID: 70AC1AAA63732DBE81-8024
Reset counter: 67
Mileage: 154057 km
Reset counter: 68
Mileage: 154057 km
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2226546
Coding: 0040401
VCID: 291A37CE80291C7606-807C
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003383432
Coding: 0001168
VCID: 76A02CB20117038E5B-8022
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Reset counter: 67
Mileage: 154057 km
Component: RDK 0450
Coding: 0100101
00625 - Vehicle Speed Signal
Fault Status: 00111000
Fault Frequency: 16
Reset counter: 68
Mileage: 154061 km
Time: 23:42:03
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003362754
Coding: 0001168
VCID: 77BE21B6061D7A8640-8022
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Reset counter: 67
Mileage: 154057 km
End-------------------------(Elapsed Time: 01:44)--------------------------
Wednesday,17,August,2016,13:05:56:53310
Mileage: 154060km-95728mi Repair Order: 2
Date: 2047.15.31
Time: 31:63:63
Speed: 255.0 km/h
Temperature: 33.0°C
Temperature: 34.0°C
Voltage: 8.128 V
Mileage: 154060 km
Time: 23:09:23
Temperature: 38.0°C
Temperature: 39.0°C
Voltage: 12.065 V
Mileage: 154060 km
Time: 23:02:34
Temperature: 31.0°C
Temperature: 33.0°C
Voltage: 13.208 V
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Shop #: WSC 00020 790 12345
Reset counter: 28
Mileage: 154061 km
Count: 7
Count: 2
Count: 12288
Count: 195
Count: 54016
Count: 65280
Reset counter: 28
Mileage: 154061 km
Count: 7
Count: 2
Count: 12288
Count: 279
Count: 54016
Count: 65280
Reset counter: 28
Mileage: 154061 km
Count: 7
Count: 2
Count: 12288
Count: 295
Count: 54016
Count: 65280
Reset counter: 28
Mileage: 154061 km
Count: 7
Count: 2
Count: 12288
Count: 270
Count: 54016
Count: 65280
Reset counter: 28
Mileage: 154061 km
Count: 2
Count: 2
Count: 12288
Count: 212
Count: 51712
Count: 65280
