how do you clear the fault log using a micro can
also are any of the errors major, car seems ok
Monday,15,August,2016,07:30:47:26169
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: TMBHT21Z3D202**** License Plate:
Mileage: 128820km-80045mi Repair Order: 2
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
VIN: TMBHT21Z3D202**** Mileage: 128820km-80045miles
Address 01: Engine
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Revision: 00H31001
Coding: 133B201C09240002C81204ED901B0091300000
Shop #: WSC 73430 790 00075
VCID: 7DDF0099E49757AACB-8028
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3T0 820 047 AF HW: 3T0 820 047 AF
Component: AC Manuell H20 0607
Revision: 00001012
Coding: 0010000003
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 73CB26A1DAD311DAAD-8026
Part No SW: 1K0 937 085 P HW: 1K0 937 085 P
Component: BCM PQ35 B+ 111 0709
Revision: AB111709
Coding: 48000AB8A05BB1904008008011000024430000AE424D81605CC5C7000041
VCID: 3C59CD9DBF0D9EA2BC-8068
Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 08061 26 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Fault Status: 00101110
Reset counter: 244
Mileage: 126501 km
Date: 2016.07.15
Time: 12:45:58
Term 15 On
Voltage: 14.85 V
Term 50 On
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2X6PPB
Coding: 0020788
VCID: 3D5FC099641797AA8B-8068
Subsystem 1 - Serial number: 6332MSME67426835C
Subsystem 2 - Serial number: 6342MSME66511A5FL
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LFR0002F
Coding: 5080140000
ROD: EV_SMLSNGKUDS_VW32.rod
VCID: 70C129ADABC52AC250-8024
Part No SW: 1Z0 920 943 S HW: 1Z0 920 943 S
Component: KOMBI H06 0608
Coding: 410A00
Shop #: WSC 73430 031 00075
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 49B7A449E8DF3B0A37-801C
Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
Component: J533 Gateway H43 1632
Revision: H43 Serial number: 190612F1000913
Coding: 352303
VCID: 40A1B96DD3E5FA42E0-8014
Component: IMMO H06 0608
VCID: 6AF53BC58D19D0121E-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2120
Coding: 0131700
VCID: 48B1A14D3BD5C20228-801C
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 3753D2B1462BBDFA51-8062
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131700
VCID: 47B3A27136CBCD7A21-8012
Address 56: Radio
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 J
Component: Batt.regelung H43 1632
Coding: 030B185A
VCID: 71C72CA9A8CF23CA5F-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900676842
02256 - Quiescent Current
Fault Status: 00110001
Reset counter: 6
Mileage: 127016 km
Date: 2016.07.21
Time: 21:51:03
End-------------------------(Elapsed Time: 01:32)--------------------------
