Highline RVC (with module) in MK6 Gti
anicks
TX, USA
C?ID=234853
Hi
Need some help. I've searched the entire internet and tried a bunch of different things but nothing seems to work. Little bit of a long story.
I installed a highline reverse camera/backup camera in my MK6 Gti (2014). http://www.carsystems.pl/vw-golf-mk6-rear-emblem-high-line-camera-kit-with-guidance-line,id467.html
I've installed 2 regular ones before so the wiring and panel removing wasnt such a big deal for me. Once everything was connected, it worked! Lines moved with the steering wheel and everything. Then, the next day, I stuck it in reverse and I got this message "rear view camera system is not available at present" on the screen. I've got an RNS510. The camera pops out from under the emblem but nothing happens on the screen.
Wiring:
power from camera to fuse box for a constant 12v
16 pin female connector from camera to RNS
Yellow wire from camera to reverse light +
4 wires from 16pin cable, ground, can +, can -, power
I did all the VCDS settings as it was instructed... installation list, 6c, offroad... everything. I didnt change a single thing from when it was working to when it stopped working.
I tried to install a relay thinking that it might be a power issue with the reverse light or something of the sort.
Relay pins:
pin 30 - 12V from rear cig lighter
pin 85 - Gnd from rear cig lighter
pin 87 - + from camera (tapped)
pin 86 - reverse light (tapped) and yellow signal wire from camera
made no difference. I hard restarted the RNS also.
I had another thought that it might be my CAN Gateway but its not THAT old, 2013. 7N0 907 530 AF (I think the newest is AR)
Here's my scan: (its the open circuit that im dealing with. I know how to do the calibration)
Saturday,13,August,2016,19:36:20:20005
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWHD7AJ1EW010614   License Plate:
Mileage: 34090km-21182mi   Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 52 55 56 62
          6C 72 77
VIN: WVWHD7AJ1EW010614   Mileage: 34090km-21182miles
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 040301081C070160
   Shop #: WSC 00642 210 45725
   VCID: 78D11B500B9D6EFE46-802C
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 3513
   Revision: 05652104    Serial number: 00001309030775
   VCID: 2773082C96A331061F-8072
   Revision: 00H31001
   Coding: 114B600C492300FA881106E5921D0041B60C00
   VCID: 7DDF0A44E4BF4BD615-8028
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 05311 115 00000
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75CF1264D48F13965D-8020
   Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
   Component: BCM PQ35  M   111 0709
   Revision: AC111709
   Coding: 29180A3FE0652AC4008800C165008BE848FD2186432C0D60E48420040040
   VCID: 41A7B6B4D8C7EF3631-8014
   Component: Wischer 10091  26  0512
   Coding: 009795
   Component: RLS 200914 05  54  0403
   Coding: 0730AD
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R02LTXB
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 3C59C740B72582DE62-8068
   Serial number: ---0000R--00008UF000
   Serial number: 3572MSME6E4F407EZZZE
   Serial number: 3582MSME0228107DZZZR
   Serial number: 3512QSME78083512ZZZP
   Serial number: 3522QSME56094243ZZZP
   Serial number: 35527SME796E7D2FZZZ6
   Serial number: 35627SME64437D2FZZZV
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MIP000ZE
   Coding: 1892140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76CD1568C989188E54-8022
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Serial number: 0106245
   Coding: 830000
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Coding: 170D01
   VCID: 3753D86C8E03A1868F-8062
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 200913F1000196
   Coding: 356002
   Shop #: WSC 49176 001 104857
   VCID: 74C92F60D7F50A9E6A-8020
   VCID: 6AF531188D31CC6EC0-803E
   Revision: A1001003    Serial number: 7665289674
   Coding: 020100
   VCID: 2B7BF41C4A4B1566FB-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 T    HW: 1T0 035 680 R
   Component: RNS-MID       H30 6276
   Revision: AB001001    Serial number: VWZ6Z7N5324078
   Coding: 08010400040000820000
   VCID: 3FA3B04CAE3399C647-806A
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0001271
   VCID: 3753D86C4603A1868F-8062
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 74     3501
   Revision: 00H22000
   VCID: 3957DE547017B7F679-806C
Address 4C: Tire Pressure II
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0001270
   VCID: 3851DB504B1DAEFE86-806C
   Coding: 1446940
   VCID: 3449EF6057754A9EAA-8060
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Coding: 00000022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Coding: 0001232
   Shop #: WSC 01357 011 1012551
   VCID: 354FD2645C0F53969D-8060
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Revision: 00H13000    Serial number: 525PA8-J393492
   Coding: 0000110
   Shop #: WSC 98765 666 38384
   VCID: 2D7FFA04B45F1B56E5-8078
03006 - Back-up Camera System not calibrated
                    Reset counter: 73
02203 - Audio / Video Input 1
                    Reset counter: 73
                    Mileage: 34099 km
                    Date: 2016.08.13
                    Time: 03:26:20
                        Reverse ON
                    Count: 9
   Coding: 0001232
   VCID: 364DD5684109588E94-8062
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105243608
   Coding: 020100010100010000000100
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_SE36.rod
   VCID: 256F022424AF23162D-8070
End-------------------------(Elapsed Time: 02:10)--------------------------
Dutchie
C?ID=125479
I belive that 02203 is the isseu. Is there perhaps a lose connector on the camera or the module?
PS, please ad [ code] [/ code] w/o the space around the autoscan
m87a
Bosnia and Herzegovina
C?ID=156900
most likely one or more wires has broken, it's a common problem with VW/Audi cameras that because of flexing cable/wires break, just open and check wires/repair them and you will have working camera ;)
anicks
TX, USA
C?ID=234853
I've checked all the connections over and over with both a multi-meter and just bare eye. I've read something about the safety measures in the power supplies in VW's. Something about a 12.6 going to the rev light and if thats interrupted, it just ignores the interruption... in this case the camera. That would kind of make sense because theres 2 different power wires for this set up. One for the hatch (the 12V straight to the fuse box) and then the one that comes out of the 16 pin female
anicks
TX, USA
C?ID=234853
Anybody got any more ideas?
Dutchie
C?ID=125479
Comes the code directly back af an errase
anicks
TX, USA
C?ID=234853
What do you mean?
DV52
C?ID=194404
Alex:Yes, the mk6 does exactly the same as my mk7. The "trigger wire" for the RVC is the Left Reverse light (which gets its supply voltage from the BCM) - see my greatly simplified version of a WD below (I only have access to a mk6 Golf Plus WD). But only one power wire (fuse #23).
So, does the left reversing light actually illuminate when you put the car into R? If so , is there 12V on the connecting wire to M16 on the RVC end (yellow wire according to the WD)? Also, do you have +12V on the Fuse wire on the RVC (Red wire according to the WD)?
anicks
TX, USA
C?ID=234853
i had it connected to the left (driver's side) reverse light at first. Then when I put the relay in, I switched it to the right reverse light (I think because of wire lengths available). Both lights came on but the camera didnt work after the first couple times.
I've been thinking... my old camera was connected to the black/blue wire in the harness down above the rear driver's side wheel arch. Its a bit of a mission to lengthen the reverse wire from the camera and then thread it down into the trunk but does anyone think that might be a good idea?
DV52
C?ID=194404
Alex: Hi again. My WD says that the black/blue wire is electrically the same point as the switched-positive connection to M16 in my diagram!
I would defer to other more knowledgeable folk on this forum, but if you measure the volts of the power wires at the connector of the actual RVC and the volts on the trigger wire (again at the RVC connector end), and the volts are OK, then doesn't this tell you that the problem is elsewhere? I assume that the unit is correctly earthed.
anicks
TX, USA
C?ID=234853
Welcome to my puzzled world! The camera ground wire is connected to the reverse light ground wire. I dont know where else the problem would be. The whole open circuit thing would mean theres a loose connection somewhere but all the voltages on every wire are strong and steady. Is there was a fault in the camera module, the CANBUS wouldn't be able to read it. The fact that it worked the first couple times makes me believe its a power issue. Im going to try upgrading the can gateway but Im pretty sure that wont do much. Might try the black/blue wire just in case. From experience, the solution to things like this usually dont make much sense lol
Dutchie
C?ID=125479
anicks
TX, USA
C?ID=234853
i followed that pdf for the install. did every single little thing but it didnt work. i read... the best i could, on a russian forum about someone that had the same problem with the same camera from the same company and they installed a relay that made it work
DV52
C?ID=194404
Alex: My apology, but I would take Dutchie's advice: If you relook at the error message
The DTC strongly suggests that the "Open Circuit" failure is in the RVC-signal, rather than the RVC-power. Your observations as described in your posts confirms this hypothesis!!
anicks
TX, USA
C?ID=234853
theres no break in the signal wires though and theyre soldered to the can+ and can- behind the rns unit so theres no weak taps on the connection
im beginning to think theres something wrong with the hardware but then again, if there was, the module wouldnt connect in vcds
Viking
C?ID=151455
If you've soldered wires to the CAN+ & CAN- then those are the CAN wires. Your error is with the audio video signal wires - open circuit.
anicks
TX, USA
C?ID=234853
ok, were you planning on giving a solution to my prob or just here to feel clever?
Viking
C?ID=151455
You said "theres no break in the signal wires though and theyre soldered to the can+ and can- behind the rns unit so theres no weak taps on the connection". That's fair enough. But your fault code is not relevant to the CAN+ or CAN- connections. Your fault code is with the audio video input from the camera to the head unit. That circuit is not the can wires you say you've checked and soldered though. I wasn't being clever.
Carry on chasing the wrong problem though if you want to, or is there another reason you're being [redacted]?
People here may provide advice. Whether you can turn that advice into a solution to your problem is up to you. ;)
anicks
TX, USA
C?ID=234853
being a dick because ive been looking for advice but everyone is just saying its a broken wire, which it isnt, and providing no help whatsoever. like they just want to feel clever on the forum or something.
im chasing all possible issues.
where would you suggest the problem is if its audio/video but all wires are properly placed and unbroken
