Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Code P1602-002 - Power Supply to terminal 30 voltage too low
    Jun 2016
    USA (Alabama)
    Code P1602-002 = Power to Terminal 30 voltage too low. The wiring diagram below shows Relay J271 and J623 ECM - on my Audi Q7. Per the manual with the ignition on...there should be battery voltage at Relay J-271 socket 30, however I'm getting nothing. I have removed the wiper arms from the transmission, and pulled off the windshield cowl cover, so I can now physically access the ECM. I think I need to remove the connector to the ECM and check the wire continuity, but I am unsure how to remove the tamper-proof retaining screws. Guidance is requested.
    Auto-scan in code tags to commence please......
    Jun 2016
    USA (Alabama)
    Hello Jack....the last full auto-scan was a month ago (below)...the Q7 has just been sitting since that time. I kept getting he EPC light, so I disconnected components to see if I could find out what was triggering it, my efforts were not conclusive. So the Q7 has both MAF's and both HPFP's disconnected. I also have the air intake tube going to the throttle body removed so I could access the wire harnesses at the back of the engine. For fun...wise or not....I decided to see if it would start this morning, and it did immediately...and ran quite smoothly for a few seconds, and then resumed it's rough idle, it rev'd up fine. I checked the engine management system to see what codes were there, and it showed MAF's as signal too low, Bank #2 fuel pressure regulator no signal, and the P1602-002 power to terminal 30 voltage too low....so I figured I'd tackle this low voltage issue first.
    Chassis Type: 4L0
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 34 36 37 3C 42 46
              47 4F 52 55 56 61 62 67 69 6C 6D 6F 72 76 77
    VIN: WA1AV94L47D009991   Mileage: 165670km/102942miles
    62-Door,Rear Left -- Status: Malfunction 0010
       Part No SW: 4L0 910 560 C    HW: 4L0 907 560 A
       Component: 4.2l V8/4V          0060
       Revision: --H16---    Serial number:
       Coding: 01210009190F0D60
       Shop #: WSC 08166 444 102996
    16 Faults Found:
    008583 - Bank 1; System too Lean at Idle
                   P2187 - 004 - No Signal/Communication - MIL ON
                        Fault Status: 11100100
                        Mileage: 157481 km
                        Date: 2015.12.24
                        Time: 09:22:06
                        RPM: 774 /min
                        Load: 15.7 %
                        Temperature: 99.0C
                        Temperature: 42.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 14.097 V
    008585 - Bank 2; System too Lean at Idle
                   P2189 - 004 - No Signal/Communication - MIL ON
                        Mileage: 157481 km
                        Date: 2015.12.24
                        Time: 09:22:10
                        RPM: 778 /min
                        Load: 15.7 %
                        Temperature: 99.0C
                        Temperature: 42.0C
                        Voltage: 13.970 V
    000135 - Fuel Rail/System Pressure: Too Low
                   P0087 - 008 - Implausible Signal - Intermittent
                        Fault Frequency: 29
                        Mileage: 165100 km
                        Date: 2016.03.18
                        Time: 16:50:07
                        RPM: 2084 /min
                        Load: 69.0 %
                        Speed: 55.0 km/h
                        Temperature: 91.0C
                        Temperature: 28.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.351 V
                   P0087 - 002 - Lower Limit Exceeded - MIL ON
                        Fault Status: 11100010
                        Mileage: 165109 km
                        Date: 2016.03.19
                        Time: 08:41:52
                        RPM: 3155 /min
                        Load: 11.8 %
                        Speed: 88.0 km/h
                        Temperature: 92.0C
                        Temperature: 15.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.097 V
    001112 - Evap System Purge Control Valve (N80): Short to Ground
                   P0458 - 002 - Lower Limit Exceeded - MIL ON
                        Mileage: 165644 km
                        RPM: 1406 /min
                        Load: 36.5 %
                        Temperature: 51.0C
                        Temperature: 33.0C
                        Voltage: 12.446 V
    005173 - Secondary Air Pump Relay (J299): Short to Ground
                   P1435 - 002 - Lower Limit Exceeded - MIL ON
                        Mileage: 165644 km
                        RPM: 1406 /min
                        Load: 36.5 %
                        Temperature: 51.0C
                        Temperature: 33.0C
                        Voltage: 13.462 V
    004763 - Fuel Pressure Regulator Valve; Bank 2 (N276): Open Circuit
                   P129B - 004 - No Signal/Communication - Intermittent - MIL ON
                        Fault Status: 10100100
                        Mileage: 165644 km
                        RPM: 466 /min
                        Load: 97.6 %
                        Temperature: 32.0C
                        Temperature: 33.0C
                        Voltage: 11.303 V
    000258 - Mass Air Flow Sensor (G70): Signal too Low
                   P0102 - 002 - Lower Limit Exceeded - MIL ON
                        Mileage: 165644 km
                        RPM: 1071 /min
                        Load: 20.8 %
                        Temperature: 51.0C
                        Temperature: 33.0C
                        Voltage: 12.192 V
    000268 - Mass Air Flow Sensor (G246): Signal too Low
                   P010C - 002 - Lower Limit Exceeded - MIL ON
                        Mileage: 165644 km
                        RPM: 1071 /min
                        Load: 20.8 %
                        Temperature: 51.0C
                        Temperature: 33.0C
                        Voltage: 12.192 V
    009217 - EVAP Leak Detection Pump Control Circuit: Short to GND
                   P2401 - 002 - Lower Limit Exceeded - MIL ON
                        Mileage: 165644 km
                        Date: 2016.03.27
                        Time: 09:25:58
                        RPM: 1126 /min
                        Load: 38.4 %
                        Speed: 4.0 km/h
                        Temperature: 51.0C
                        Temperature: 33.0C
                        Voltage: 14.351 V
                   P0300 - 001 - Upper Limit Exceeded - MIL ON
                        Fault Status: 11100001
                        Mileage: 165645 km
                        Date: 2016.03.27
                        Time: 09:26:51
                        RPM: 3015 /min
                        Load: 51.0 %
                        Speed: 38.0 km/h
                        Temperature: 54.0C
                        Temperature: 30.0C
                        Voltage: 14.224 V
    000771 - Cylinder 3: Misfire Detected
                   P0303 - 001 - Upper Limit Exceeded - MIL ON
                        Mileage: 165645 km
                        Date: 2016.03.27
                        Time: 09:26:51
                        RPM: 3015 /min
                        Load: 51.0 %
                        Speed: 38.0 km/h
                        Temperature: 54.0C
                        Temperature: 30.0C
                        Voltage: 14.224 V
    000770 - Cylinder 2: Misfire Detected
                   P0302 - 001 - Upper Limit Exceeded - MIL ON
                        Mileage: 165645 km
                        Date: 2016.03.27
                        Time: 09:26:51
                        RPM: 3015 /min
                        Load: 51.0 %
                        Speed: 38.0 km/h
                        Temperature: 54.0C
                        Temperature: 30.0C
                        Voltage: 14.224 V
    008852 - Fuel Pressure Regulator Valve (N276): Open Circuit
                   P2294 - 004 - No Signal/Communication - Intermittent - MIL ON
                        Mileage: 165647 km
                        Date: 2016.03.27
                        Time: 10:50:44
                        RPM: 1720 /min
                        Load: 14.9 %
                        Speed: 63.0 km/h
                        Temperature: 64.0C
                        Temperature: 35.0C
                        Voltage: 14.351 V
    000769 - Cylinder 1: Misfire Detected
                   P0301 - 001 - Upper Limit Exceeded - MIL ON
                        Mileage: 165652 km
                        Date: 2016.03.28
                        Time: 05:34:50
                        RPM: 770 /min
                        Load: 34.5 %
                        Speed: 5.0 km/h
                        Temperature: 25.0C
                        Temperature: 24.0C
                        Voltage: 14.097 V
    000773 - Cylinder 5: Misfire Detected
                   P0305 - 008 - Implausible Signal - MIL ON
                        Fault Status: 11101000
                        Mileage: 165652 km
                        Date: 2016.03.28
                        Time: 05:35:33
                        RPM: 1905 /min
                        Load: 37.2 %
                        Speed: 35.0 km/h
                        Temperature: 32.0C
                        Temperature: 25.0C
                        Voltage: 14.351 V
    Readiness: 0000 1001
       Part No SW: 09D 927 750 BR    HW: 09D 927 750 BR
       Component: AL 750 6A           0915
       Revision: 00H49000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
                013 - Check DTC Memory
                        Reset counter: 0
                        Date: 2005.09.20
                        Time: 12:00:00
    Address 03: ABS Brakes        Labels: 4L0-910-517.lbl
       Part No SW: 4L0 910 517 E    HW: 4L0 614 517 E
       Component: ESP ALLRAD MK25E1   0140
       Revision: 00H45001
       Coding: 0021553
                        Fault Status: 01101101
                        Reset counter: 167
                        Mileage: 165644 km
                        Date: 2016.03.27
                        Time: 09:25:48
                        Count: 64
                        Count: 13569
                        Count: 8196
                        Count: 43264
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.lbl
       Part No SW: 4L0 910 729 R    HW: 4E0 035 729 A
       Component: Interfacebox    H43 1600
       Revision: 00000000    Serial number: 354CL067501339
       Coding: 0000003
       Part No: 4L0 910 609
       Component: E0380 BedienteilH01 0050
                        Reset counter: 227
                        Mileage: 157473 km
                        Date: 2015.12.24
                        Time: 05:25:29
    02849 - Control Module for Lane Change Assistance (J769)
                        Reset counter: 211
                        Mileage: 165673 km
                        Date: 2016.03.28
                        Time: 17:53:33
                        Reset counter: 202
                        Mileage: 165339 km
                        Date: 2016.03.23
                        Time: 18:01:58
    Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D0631280D7
       Coding: F7F3FE7F347A02
                        Reset counter: 227
                        Mileage: 157473 km
                        Date: 2015.12.24
                        Time: 05:03:56
       Part No SW: 4L0 910 158     HW: 4L0 919 158 D
       Component: KLIMABETAETIGUNGH05 0040
       Revision: 00---006    Serial number: 00000000014930
       Coding: 0000006
    00003 - Control Module
                        Fault Status: 00100011
                        Fault Frequency: 11
                        Mileage: 124044 km
                        Date: 2013.12.13
                        Time: 21:56:17
    Address 34: Level Control        Labels: None
       Part No SW: 4L0 910 553 A    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7470
       Revision: --H03001    Serial number: 15.1528-0082.2
       Coding: 0015520
    01577 - Turn-Off due to Over-Temp
                        Fault Status: 00100001
                        Reset counter: 207
                        Mileage: 163368 km
                        Date: 2016.03.05
                        Time: 14:05:24
                        Error Code: 68
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
       Component: MNS US          H45 1100
       Revision: 00000000    Serial number: 306C9067500421
    02927 - DVD Read Error
                000 -  -  - Intermittent
                        Fault Frequency: 9
                        Reset counter: 185
                        Mileage: 162578 km
                        Date: 2016.03.04
                        Time: 17:33:00
                        Hex Value: 0x56ED
                        Hex Value: 0x0FC5
                        Hex Value: 0x0401
                        Hex Value: 0x0000
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00-00000
       Coding: 0051915
                        Reset counter: 165
                        Mileage: 155790 km
                        Date: 2015.10.08
                        Time: 22:20:20
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 A    HW: 4L0 035 223 A
       Component: DSP-High AU716  H02 0090
       Revision: PROD_01     Serial number: 00000000205110
       Coding: 0000026
                        Fault Status: 00111011
                        Reset counter: 209
                        Mileage: 165638 km
                        Date: 2016.03.26
                        Time: 18:52:32
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000007731
       Shop #: WSC 08166 444 00177
       Part No: 4F0 915 105 D
       Component: von VA0  2603131260
       Coding: 344630393135313035442056413032363033313331323630
                        Fault Frequency: 85
                        Mileage: 124562 km
                        Date: 2013.12.26
                        Time: 16:04:40
    Address 62: Door,Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Coding: 0051722
                        Reset counter: 228
                        Mileage: 128378 km
                        Date: 2014.04.04
                        Time: 15:03:53
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 4E0 907 383 H    HW: 4E0 907 383 G
       Component: Anhaenger     H08 0080
       Revision: 2A002002    Serial number: 00000116067289
       Coding: 0200000000000000
       Shop #: WSC 08166 444 09063
    02579 - Trailer; Left Brake Lamps (M65)
                        Fault Status: 11101010
                        Reset counter: 121
                        Mileage: 164761 km
                        Date: 2016.03.08
                        Time: 11:54:48
    02580 - Trailer; Right Brake Lamps (M66)
                        Reset counter: 121
                        Mileage: 164761 km
                        Date: 2016.03.08
                        Time: 11:54:48
    Address 6C: Back-up Cam.        Labels: 4L0-910-441.lbl
       Part No SW: 4L0 910 441     HW: 4L0 907 441
       Component: J772__Rearview      0020
       Revision: --H10---    Serial number: 525PA8-J631307
       Coding: 1010001
    03006 - Back-up Camera System not calibrated
                        Reset counter: 138
                            Invalid
                            Invalid
                            Invalid
    Please sir, before anything else, take the engine ecu out and apart to inspect for water ingress.
    If corrosion is present and you need an ecu with data transfer we can help.
    You absolutely must check this first, to rule out the fact there could be nothing possibly wrong under the hood.
    This is a common issue......
    Jun 2016
    USA (Alabama)
    The ECU physically looks good from the outside, the bottom panel is nice and shiny. Never the less I will remove it. How do I remove the ECU Connector retainer "bolts"...? The manual says to use a heat gun to loosen up the thread locker used at the factory and then use vice grips to twist out the bolts. I'm tempted to carefully grind the heads off.....
    Jun 2016
    USA (Alabama)
    Here are picture of the ECU, it has the usual oxidation and stuff on the top side, but the underside looks pretty good.
  7. Likes Uwe, Jack@European_Parts liked this post
    What about after the rear cover is removed and be careful doing it?
    It can always be resealed.
    If dry and clean I recommend bagging the controller when putting it back with air snorkel tube.
  9. #8
    Jun 2016
    USA (Alabama)
    I will try and use a dremel and slot the head of the tamper-proof screws. Then I will remove the brackets around the large multi-pin connectors, and test the gray/black wire going to J271 Relay terminal 30 for continuity. If all checks out okay....I'll will post the results and go from there with your guidance. Thank You Jack.
  10. #9
    Your welcome .......and FYI that rotted torx screw is a sign water is present.
    Often the power supply driver gets wiped in these MED9 units which switch's the consumer and power supply relays.
    It additionally bothers me that 0x09 is not present after quick review.....
    Please post more data from the JPPSG format.
    The white PR code tag from the spare tire trunk area, and or service books first page.
    According to what I see in the microfilm it should have these central electrics.
    4F0910279J
    Control unit 2 4F0907280B
    or
    4F0910289F
    Control unit 2 4L0910290A
    Vehicle data
    Vehicle Identification No. WA1AV94L47D009991
    Model audi q7 qu. 4.2
    AQ7
    Date of production 03.04.2006
    Year 2007
    Sales type 4LB5EL
    Engine Code BAR
    Transmission Code HPH
    Axle drive 6A
    Equipment CB
    Roof color Q4
    Exterior color / Paint Code Q4 / Y7G
    Based on this I would want to know the status of the Ignition switch and all terminal relays.
  11. #10
    Jun 2016
    USA (Alabama)
    More to do but here is where I'm at right now. I managed to remove the brackets holding the harness to the ECM. I then checked the continuity of the 0.5mm gray/black wire going from J271 Relay socket terminal 30 to the ECM Connector T94 at position #69...I read 1 ohm resistance which to me is perfect. So at least I know the wire is good. I'm posting a couple more pictures as an FYI.
    Jack...I will not carefully try and remove the back cover of the ECM and report back. I will also post the JPPSG requirements....
  12. Likes Uwe, Jack@European_Parts liked this post
