- Jul 9, 2014
- 16
- 2
- Springfield, VA
- C?ID=152533
I've seen references to updated software for the transmission computer on the early T1s. Having an 04 V10 I would assume there were some updates at some point. However, from what I see in VCDS no updates have ever been done on ours. Here's what the "Advanced ID" shows:
If you have an 04 V10 I'd be interested to compare notes here.
Thanks!
PS: Here's a complete auto scan of the truck:
(I've fixed some of the faults since then...)
If there's newer firmware available I'd like to get it installed, but if not I don't want to pay for an hour of dealer shop time.
-Jason
Address 02: Auto Trans
Control Module Part Number: 09D 927 750 BB
Component and/or Version: AL 600 6Q 0467
Software Coding: 0012342
Work Shop Code: WSC 31414
VCID: 6FAE13917F8FEE4697-5184
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Software
P0210
Misc.
VCDS Info:
Labels: 09D-927-750.lbl
Thanks!
Friday,29,January,2016,18:36:10:04834
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVGHH77L24D080156 License Plate: TOUAREG
Mileage: 248960km-154696mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGHH77L24D080156 Mileage: 248960km-154696miles
Address 01: Engine Labels: None
Part No SW: 070 997 016 R HW: 028 101 172 9
Component: V10 5,0L EDCG000AGMª2813
Revision: 5KO3 Serial number: VWZ3Z0D7195417
Coding: 0060575
Shop #: WSC 09460 444 53328
VCID: 291A3D8981EBC07606-5184
19456 - Glow Plug Indictor Light (K29)
P3000 - 000 - Malfunction Message from Instrument Cluster
Torque: 0.0 Nm
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001100
Temperature: -1.8°C
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 BB
Component: AL 600 6Q 0467
Coding: 0012342
Shop #: WSC 31414 000 00000
VCID: 6FAE13917F8FEE4698-5184
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0022785
VCID: 3A38F2C5744D7BEE7F-5184
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: Kessy 6400
Coding: 0131304
VCID: 2F2ED391BF0FAE46D8-5184
Component: ELV XXXX
8 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
00956 - Key 2
00183 - Interior Access/Start Authorization Antenna 1 (R138)
00087 - Terminal 30 for Starting Relevant Consumers
Part No: 7L0 959 760
Component: Sitzverstellung 0701
VCID: 77BE2BF107DFA68640-5184
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0030020
Shop #: WSC 09446 444 59218
VCID: 3522E1F95D53949692-5184
00229 - Refrigerant Pressure
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 L
Component: 2703
Coding: 0120284
Shop #: WSC 09460 444 124813
VCID: 45C291390DB3041602-5184
01517 - Control Module for Trailer/Towing Sensor (J345)
014 - Defective
013 - Check DTC Memory
02196 - Fuse for Control Module for Power Supply to Vehicle Battery (S287)
Address 11: Engine II Labels: None
Component: V10 5,0L EDCG000AGSª2813
Coding: 0060575
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00020858
Coding: 0012341
VCID: 23062FA1E3C71A264C-5184
Subsystem 1 - Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
Fault Status: 00101001
Reset counter: 39
Date: 2063.15.31
Time: 31:60:00
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000032
VCID: 40CC802D1291213E31-5184
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 980 P
Component: KOMBIINSTRUMENT RB8 2935
Coding: 0005111
Shop #: WSC 09454 444 82910
01304 - Radio
Address 18: Aux. Heat Labels: 7L6-819-008.lbl
Part No: 7L6 819 008 B
Component: Standheizung E1MAC 0235
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 09446 444 58779
VCID: 70AC10ED62B1F1BE81-5184
01304 - Radio
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 04444C3D4609FD1E55-5184
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F4EC3D12FEF9EC608-5184
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000003
VCID: 668076B550752F0EEB-5184
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 B
Component: SG-Quersperre 5018
VCID: 373EEBF1475F668680-5184
02053 - Control Module for Transfer Case (J646)
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 3620E6F540559F8E9B-5184
Address 37: Navigation Labels: 7L6-919-887-CD.lbl
Part No: 7L6 919 887 D
Component: Navigation 0628
VCID: 47DE9B3137BF1606F0-5184
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: 679E7BB1577F3606D0-5184
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 G
Component: 2N HSG 3213
Coding: 0000085
VCID: 40CC802D1291213E31-4B1E
Subsystem 1 - Part No: 7L0 959 701 B
Subsystem 2 - Part No: 7L0 959 702 B
Subsystem 3 - Part No: 7L0 959 703 B
Subsystem 4 - Part No: 7L0 959 704 B
00131 - Outside Door Handle Illumination/mirror Light Driver Side
00487 - Rear Left Outside Door Handle Central Locking Button (E371)
007 - Short to Ground
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 466
Component: 12K-AUDIOVERST 0108
VCID: 71AA15E969BBF8B68E-5184
00464 - Control Module with Display for Radio and Navigation (J503)
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 A
Component: Radio 0628
Coding: 0024067
Shop #: WSC 09807 444 00987
VCID: 312AD5E9A93BB8B6CE-5184
Address 65: Tire Pressure Labels: 7L6-907-273.lbl
Part No: 7L6 907 273
Component: Reifendruckueberw. 0052
Coding: 0110390
VCID: 75A221F91DD3D49652-5184
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
VCID: 383CE8CD4A4169FE89-5184
02579 - Trailer; Left Brake Lamps (M65)
02580 - Trailer; Right Brake Lamps (M66)
00576 - Terminal 15
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 G
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009268.03
VCID: 3B36F7C17B7742E664-5184
Address 76: Park Assist Labels: None
Part No: 7L0 919 283 E
Component: 0E Einparkhilfe 0907
End-------------------------(Elapsed Time: 08:50)--------------------------
-Jason
