2015 Golf GTI (US) 2.0T 6MT maps
Andy
Sector 7G
HC424490
Wednesday,10,August,2016,15:35:53:29905
VCDS Version: 16.8.0.3 (x64)  HEX-NET CB: 0.4323.4
Data version: 20160803 DS255
VIN: 3VW5T7AU6FM007769   License Plate:
Mileage: 24811km-15416mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
VIN: 3VW5T7AU6FM007769   Mileage: 24811km-15416miles
Address 01: Engine (J623-CNTA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0006
   Revision: --H13---
   Coding: 091900122424000F1000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C1B87FB477FE6222C-8078
15128 - Cylinder 2
          P0302 00 [096] - Misfire Detected
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51184000000712
   Coding: 01FA6BA134200973007E020681CC2980D62C9000408194B400430050C006
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: 44CBCF5BCFEF0E62C4-8010
   Revision: 00021000    Serial number: 0328646360
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_VW37.rod
   VCID: 3A37B1A3BD2B4892AE-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   ROD: EV_ACManueBHBVW37X.rod
   VCID: 362FA5938933ACF24A-8062
   Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
   Component: BCM PQ37BOSCH 026 0097
   Revision: --------    Serial number: 86580805140110
   Coding: 00110A464041A26969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00145
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 43C9CC47CAE1095AFD-8016
   Component: WWS    140212  042 0581
   Serial number:         140528153750
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M02D19H17M22S34S9
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO2889941F
   Coding: 181801
                    Fault Frequency: 104
                    Reset counter: 165
                    Mileage: 22792 km
                    Date: 2016.07.14
                    Time: 18:20:37
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM008N6F
   VCID: 51E5F60F009DEBCA7F-8004
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140000SQA409
   Coding: 303331
   Subsystem 2 - Part No SW: -----------    HW: 480 001 004 14
   Serial number: 357000000005C5BC5F0.
   Subsystem 3 - Part No SW: -----------    HW: 480 001 504 14
   Serial number: 35800000000A7A146F0Q
   Subsystem 4 - Part No SW: -----------    HW: 480 401 504 14
   Serial number: 3510002A3157E9D35353
   Subsystem 5 - Part No SW: -----------    HW: 480 400 104 14
   Serial number: 3520002B9153FB920361
   Subsystem 6 - Part No SW: -----------    HW: 480 402 103 14
   Serial number: 3550002C7142B1B071F1
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 103 14
   Serial number: 3560002C7142B1B131A.
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140418400747
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 044B0F5B8F6FCE6284-8050
   Part No SW: 5G6 920 970 C    HW: 5G6 920 970 C
   Component: KOMBI         316 2210
   Coding: 0BAD09122980CF0502087E00000000
   VCID: 3023938B6B5782C210-8064
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 26051410001453
   Coding: 0101000820085900EF00002A080F00000001000000000000000000000000
   Shop #: WSC 00066 790 07030
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti.rod
   VCID: 3FC1C0B7A6096DBA99-806A
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27140000323690064081
   Coding: 28FFFF
66565 - Diagnostic Databus
          U1202 00 [008] - Malfunction
                    Reset counter: 126
                    Mileage: 24418 km
                    Date: 2016.07.25
                    Time: 14:57:48
                    Supply voltage: Terminal 30: 13.7 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 14000109707001
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_VW37.rod
   VCID: 342B9F9B9F4FBEE274-8060
   Serial number: 140514060505KN
   Coding: 003E13200000040000000000
   VCID: 40C3C34BDBF71242E0-8014
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000002377991
   Coding: 011000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 158
                    Mileage: 24218 km
                    Date: 2016.07.22
                    Time: 13:55:42
   Coding: 9102
   VCID: 352DA29F9435A7EA43-8060
21760 - Databus
                    Reset counter: 54
                    Mileage: 22785 km
                    Date: 2016.07.14
                    Time: 18:02:52
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.00 V
                    Temperature: 46.0 °C
                    KFC: 55
                    KFA: 00 00
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 13.16 V
                    uAdSensI_SwitchedKl30_xdu16: 13.16 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H30 0042
   Serial number: VWZ8Z1EC40128HS
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001005
   ROD: EV_AMPMst11CALPI.rod
   VCID: 63892CC76A21695ADD-8036
   Serial number: 130514060504AB
   Coding: 003E13200C00040000000000
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000002591268
   Coding: 191000
   Coding: 021A01000B000400
   Shop #: WSC 54321 444 54321
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     013 0645
   Serial number: V7B02704140077
   Coding: 027300000000000021220002001800001F0203340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 648B2FDB6F2F6E6224-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS5003R3
          B11CF 53 [009] - Deactivated
                    Reset counter: 54
                    Mileage: 22785 km
                    Date: 2016.07.14
                    Time: 18:02:26
                    Voltage terminal 30: 13.2 V
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Coding: 02730002C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 02470943957BC052B6-8056
9457664 - Function limitation due to excessive temperature
          B1050 00 [008] -  -
                    Reset counter: 81
                    Mileage: 24418 km
                    Date: 2016.07.25
                    Time: 16:10:03
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 125
                    Mileage: 1048574 km
                    Time: 00:00:00
   Component: SAS-GEN 2     H06 0013
   Serial number: 140325201352
   VCID: 6B9944E782F1211A65-803E
End----------(Elapsed Time: 01:12, VBatt start/end: 12.3V/12.2V)-----------
Andy
Sector 7G
HC424490
01-Engine Adp:
;SW:5G0-906-259-A   HW:06K-907-425-B ---  Engine
;Component:2.0l R4 TFSI  H13 0006, Coding:091900122424000F1000
;EV_ECM20TFS0205G0906259A,001008,EV_ECM20TFS0205G0906259A.rod
;Wednesday,10,August,2016,13:55:59:29905
;VCDS Version: Release 16.8.0 (x64)  Data version: 20160803 DS255
;VCID: 2C1B87FB477FE6222C-8078
IDE00001-Production mode,00 00 00
IDE00259-Idle RPM correction,0 /min
IDE01945-Engine run-in oil pressure,not active
IDE02332-Deactivate production mode,00 00 00
IDE04158-Activation of start-stop function,not active
IDE04617-Protective function,Enabled
IDE06425-Roller test bench mode: functional,not activated
IDE06726-Timing deviation after chain replacement: intake bank 1,-0.19 °
IDE06728-Timing deviation after chain replacement: exhaust bank 1,-2.19 °
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °
IDE06734-Timing deviation: current value intake bank 1,-0.13 °
IDE06736-Timing deviation: current value exhaust bank 1,0.00 °
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,5
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,3
IDE06742-Chain elongation: initial values valid: intake bank 1,active
IDE06744-Chain elongation: initial values valid: exhaust bank 1,not active
Elapsed Time: 00:04
Andy
Sector 7G
HC424490
03-ABS ADP:
;SW:5Q0-907-379-K   HW:5Q0-907-379-F ---  ABS Brakes
;Component:ESC           H31 0371, Coding:01FA6BA134200973007E020681CC2980D62C9000408194B400430050C006
;EV_Brake1UDSContiMK100ESP,033001,EV_Brake1UDSContiMK100ESP_VW37.rod
;Wednesday,10,August,2016,13:56:35:29905
;VCID: 44CBCF5BCFEF0E62C4-8010
IDE00252-Brake system vacuum pump,5
IDE00820-Activating and deactivating all development messages,0
IDE03659-Roller test bench mode,Manual activation: possible
IDE04456-Brake disk drying,Weak
IDE04508-Hydraulic brake booster,8
IDE04643-Overboost in brake system,activated
IDE04765-Counter steer support,Strong
IDE04774-Vehicle and trailer stabilization,not activated
IDE04939-Tire pressure monitoring display,2
IDE04949-Engine drag torque control,activated
IDE04951-Brake booster,4
IDE04952-Braking torque boost for distance regulation,3
IDE05055-Hydraulic brake assistant,normal
IDE05057-Brake prefill,activated
IDE05161-Straight ahead brake stabilization,activated
IDE05337-IDE05337-Starting vibration reduction-,Strong
IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated
IDE07006-Tire pressure monitoring display: tire selection,2
IDE07565-ABS in lower speed range,activated
IDE07848-Thresholds for brake performance,activated
MAS00122-Electronic Stability Program,not activated
MAS00194-tbd,Standard
MAS00970-Running manufacturer number,activated
MAS01299-Offroad,0
MAS02080-XCP calibration protocol,not activated
MAS02138-Hill-start assistant,normal
ENG118148-Developer_Function_1,0
Elapsed Time: 00:10
Andy
Sector 7G
HC424490
05-Acc/Start ADP:
;SW:5Q0-959-435-A   HW:5Q0-959-435 ---  Acc/Start Auth.
;Component:VWKESSYMQB    021 0604, Coding:030C0C
;EV_KessyHellaMQBAB,002011,EV_KessyHellaMQBAB_VW37.rod
;Wednesday,10,August,2016,13:57:50:29905
;VCID: 3A37B1A3BD2B4892AE-806E
IDE04159-Deactivation of start-stop function,not active
Elapsed Time: 00:43
Andy
Sector 7G
HC424490
08-HVAC MWB:
;SW:5G0-907-426-N   HW:5G0-907-426-N ---  Auto HVAC
;Component:AC Manuell    H01 0705, Coding:00020004200100000000000000000000
;EV_ACManueBHBVW37X,003019,EV_ACManueBHBVW37X.rod
;Wednesday,10,August,2016,13:59:01:29905
;VCID: 362FA5938933ACF24A-8062
IDE00001-Production mode,Deactivating
IDE01067-Retention of driver's seat heater level,active
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore
IDE01479-Gear ratio of engine - A/C compressor,0.00
IDE01483-Blower voltage for voice operation,not activated
IDE01488-Retrofitting of parking heater without CAN,not installed
IDE01503-Runtime for compressor run-in basic setting,60 s
IDE02155-Reset all counters,not activated
IDE03176-Duration of compressor run in,0 s
IDE03251-Stop release for start-stop function,According to function requirements
IDE06425-Roller test bench mode: functional,not active
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min
IDE06545-Blower voltage for production routines,6.0 V
IDE06546-Interior target temperature for production routines,22 °C
IDE06547-Air distribution for production routines,No effect
IDE06593-Recirculation air for production routines,No effect
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,active
IDE07948-Retention of frt.pass. seat heater level,not active
IDE80007-Analysis 7,00000000 00000000
IDE80008-Analysis 8,active
ENG122844-ENG101574-dimming_characteristic_1-X1,0
ENG122844-ENG99557-dimming_characteristic_1-X2,6
ENG122844-ENG102140-dimming_characteristic_1-X3,40
ENG122844-ENG102936-dimming_characteristic_1-X4,60
ENG122844-ENG103548-dimming_characteristic_1-X5,80
ENG122844-ENG113992-dimming_characteristic_1-X6,100
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %
ENG122845-ENG101574-dimming_characteristic_2-X1,0
ENG122845-ENG99557-dimming_characteristic_2-X2,6
ENG122845-ENG102140-dimming_characteristic_2-X3,40
ENG122845-ENG102936-dimming_characteristic_2-X4,60
ENG122845-ENG103548-dimming_characteristic_2-X5,80
ENG122845-ENG113992-dimming_characteristic_2-X6,100
ENG122845-ENG99777-dimming_characteristic_2-Y1,0 %
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 %
ENG122845-ENG100773-dimming_characteristic_2-Y3,40 %
ENG122845-ENG100631-dimming_characteristic_2-Y4,60 %
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 %
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %
ENG122846-ENG101574-dimming_characteristic_3-X1,0
ENG122846-ENG99557-dimming_characteristic_3-X2,6
ENG122846-ENG102140-dimming_characteristic_3-X3,40
ENG122846-ENG102936-dimming_characteristic_3-X4,60
ENG122846-ENG103548-dimming_characteristic_3-X5,80
ENG122846-ENG113992-dimming_characteristic_3-X6,100
ENG122846-ENG99777-dimming_characteristic_3-Y1,0 %
ENG122846-ENG100480-dimming_characteristic_3-Y2,6 %
ENG122846-ENG100773-dimming_characteristic_3-Y3,40 %
ENG122846-ENG100631-dimming_characteristic_3-Y4,60 %
ENG122846-ENG102174-dimming_characteristic_3-Y5,80 %
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %
ENG122847-ENG101574-dimming_characteristic_4-X1,0
ENG122847-ENG99557-dimming_characteristic_4-X2,6
ENG122847-ENG102140-dimming_characteristic_4-X3,40
ENG122847-ENG102936-dimming_characteristic_4-X4,60
ENG122847-ENG103548-dimming_characteristic_4-X5,80
ENG122847-ENG113992-dimming_characteristic_4-X6,100
ENG122847-ENG99777-dimming_characteristic_4-Y1,0 %
ENG122847-ENG100480-dimming_characteristic_4-Y2,6 %
ENG122847-ENG100773-dimming_characteristic_4-Y3,40 %
ENG122847-ENG100631-dimming_characteristic_4-Y4,60 %
ENG122847-ENG102174-dimming_characteristic_4-Y5,80 %
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %
ENG122848-ENG101574-dimming_characteristic_5-X1,0
ENG122848-ENG99557-dimming_characteristic_5-X2,10
ENG122848-ENG102140-dimming_characteristic_5-X3,50
ENG122848-ENG102936-dimming_characteristic_5-X4,100
ENG122848-ENG103548-dimming_characteristic_5-X5,220
ENG122848-ENG113992-dimming_characteristic_5-X6,253
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %
ENG122849-illumination index grain rotary knob,search illumination
Elapsed Time: 00:10
Andy
Sector 7G
HC424490
A customer reported some Adaptation Channels not showing up in his similar cluster so here's a very old 17 Adp map from when I first got the car using Beta 14.7.2:
;SW:5G6-920-970-C   HW:5G6-920-970-C ---  Instruments
;Component:KOMBI         316 2210	 Coding:0BAD09122980CF0502086A00000000
;EV_DashBoardVDDMQBAB	8031	EV_DashBoardVDDMQBAB_AU37.rod
;Tuesday	19	August	2014	10:23:39:23603
;VCDS Version: Beta 14.7.2 (x64)  Data version: 20140714
;VCID: 3064C0666B7F60BA33-8065
Activating and deactivating all development messages	not active
Cylinder shut-off	Display
Day	19 d
Day counter	70 d
Deactivate seat belt warning	No
Digital speedometer	Display
Display correction of consumption and operating range; gas	100%
Display correction of consumptions and operating range	100%
Display depiction	Version 1
Distance	101 km
Driving profile for range remaining LPG	8.0 l/100km
Driving profiled for range remaining	9.4 l/100km
Driving profiled for range remaining CNG	8.0 kg/100 km
ESI: Distance driven from inspection	101 km
ESI: Maximum value km-driving distance/inspection	30000 km
ESI: Maximum value of time between inspections	730 d
ESI: Minimum value km-driving distance/inspection	15000 km
ESI: Minimum value of time between inspections	365 d
ESI: Oil quality	poor oil quality
ESI: Resetting ESI	no warning
ESI: Soot entry	0 km
ESI: Time from inspection	70 d
FIX: Distance covered since last mileage-dependent inspection	100 km
FIX: Maximum time until next time-dependent inspection	730 d
FIX: Reset value for next mileage-dependent inspection	32200 km
FIX: Reset value for next mileage-dependent inspections	730 d
FIX: Time since last time-dependent inspection	70 d
Fix:Max. distance until next mileage-related inspection	32200 km
Hour	10 H
Ignition active message; actuator	Driver door
Language version	US English
Lap counter	Display
(1)-MFA3-Reset-MFI button RESET / OK	Manual reset; not possible
(2)-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset
(3)-MFA3-Reset-Refuel detection gas	MFA3-Reset
(4)-MFA3-Reset-MFA3-Reset_automatic_electric	MFA3-Reset
Minute	23 min
Month	8 mon
No-voltage display	No display
(1)-Offset for tank calibration values-Offset sensor 1	-12.8 l
(2)-Offset for tank calibration values-Offset sensor 2	12.7 l
(3)-Offset for tank calibration values-Offset sensor 3	12.7 l
(4)-Offset for tank calibration values-Offset sensor 4	12.7 l
(5)-Offset for tank calibration values-Complete tank calibration	-12.8 l
Oil temperature display	On
Roller test bench mode; functional	not activated
Service notification in days	30 d
(1)-Service-key settings-p_write_delay_time	40 s
(2)-Service-key settings-p_write_delay_speed	20 km/h
(3)-Service-key settings-p_write_distance	20 km
(4)-Service-key settings-p_forcewrite_qual_time	10 s
(5)-Service-key settings-p_main_switch_keyless	On
(6)-Service-key settings-p_main_switch_Basic	On
(7)-Service-key settings-p_deactivate_SK_Function	On
SIA: maximum value of distance to service	16100 km
SIA: Maximum value of timet o service	365 d
SIE: thermal load	700 km
Source for synchronization of time	GPS
(1)-Speed warning-	not active
(2)-Speed warning-Unit	Miles per hour
(3)-Speed warning-Speed	0
Trip recorder	not installed
(1)-Units adjusted-Temperature	Degrees Fahrenheit
(2)-Units adjusted-Distance	miles
(3)-Units adjusted-Speed	Miles per hour
(4)-Units adjusted-Pressure	psi
(5)-Units adjusted-Volume	gallons (US)
(6)-Units adjusted-Time	12h AM_PM
(7)-Units adjusted-Date	mm_dd_yy
(8)-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Miles per gallon (US)
(9)-Units adjusted-Operating range consumption; CNG (compressed natural gas)	kg per 100 km
(10)-Units adjusted-Average consumption; electric drive	kWh per 100 km
Vehicle Positioning System Interface Control Module	not installed
Year	2014 yr
(1)-Total operating range gas-State	active
(2)-Total operating range gas-selection_consumption_factor	consumption_factor_CAN
(3)-Total operating range gas-consumption_profile	consumption_profile_calculation
(4)-Total operating range gas-consumption_factor	0
BAP_Debug_Mode_Release	not_released
(1)-Configuration of Development CAN-Messages-Block 1	OFF
(2)-Configuration of Development CAN-Messages-Block 2	OFF
(3)-Configuration of Development CAN-Messages-Block 3	OFF
(4)-Configuration of Development CAN-Messages-Block 4	OFF
(5)-Configuration of Development CAN-Messages-Block 5	OFF
(6)-Configuration of Development CAN-Messages-Block 6	OFF
(7)-Configuration of Development CAN-Messages-Block 7	OFF
(8)-Configuration of Development CAN-Messages-Block 8	OFF
(9)-Configuration of Development CAN-Messages-Block 9	OFF
(10)-Configuration of Development CAN-Messages-Block 10	OFF
(11)-Configuration of Development CAN-Messages-Block 11	OFF
(12)-Configuration of Development CAN-Messages-Block 12	OFF
(13)-Configuration of Development CAN-Messages-Block 13	OFF
(14)-Configuration of Development CAN-Messages-Block 14	OFF
(15)-Configuration of Development CAN-Messages-Block 15	OFF
(16)-Configuration of Development CAN-Messages-Block 16	OFF
(17)-Configuration of Development CAN-Messages-Block 17	OFF
(18)-Configuration of Development CAN-Messages-Block 18	OFF
(19)-Configuration of Development CAN-Messages-Block 19	OFF
(20)-Configuration of Development CAN-Messages-Block 20	OFF
(21)-Configuration of Development CAN-Messages-Block 21	OFF
(22)-Configuration of Development CAN-Messages-Block 22	OFF
(23)-Configuration of Development CAN-Messages-Block 23	OFF
(24)-Configuration of Development CAN-Messages-Block 24	OFF
(25)-Configuration of Development CAN-Messages-Block 25	OFF
(26)-Configuration of Development CAN-Messages-Block 26	OFF
(27)-Configuration of Development CAN-Messages-Block 27	OFF
(28)-Configuration of Development CAN-Messages-Block 28	OFF
(29)-Configuration of Development CAN-Messages-Block 29	OFF
(30)-Configuration of Development CAN-Messages-Block 30	OFF
(31)-Configuration of Development CAN-Messages-Block 31	OFF
(32)-Configuration of Development CAN-Messages-Block 32	OFF
(33)-Configuration of Development CAN-Messages-Block 33	OFF
(34)-Configuration of Development CAN-Messages-Block 34	OFF
(35)-Configuration of Development CAN-Messages-Block 35	OFF
(36)-Configuration of Development CAN-Messages-Block 36	OFF
(37)-Configuration of Development CAN-Messages-Block 37	OFF
(38)-Configuration of Development CAN-Messages-Block 38	OFF
(39)-Configuration of Development CAN-Messages-Block 39	OFF
defuel_threshold	45 l
(1)-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0
(2)-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0
(3)-dimming_characteristic_curve_adjustment_clock_dial_day-X2	32
(4)-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0
(5)-dimming_characteristic_curve_adjustment_clock_dial_day-X3	66
(6)-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0
(7)-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96
(8)-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	5
(9)-dimming_characteristic_curve_adjustment_clock_dial_day-X5	DC
(10)-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	14
(11)-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64
(1)-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0
(2)-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2
(3)-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A
(4)-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2
(5)-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32
(6)-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	17
(7)-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64
(8)-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	32
(9)-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96
(10)-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	46
(11)-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64
(1)-dimming_characteristic_curve_adjustment_gauge-X1	0
(2)-dimming_characteristic_curve_adjustment_gauge-Y1	3
(3)-dimming_characteristic_curve_adjustment_gauge-X2	0A
(4)-dimming_characteristic_curve_adjustment_gauge-Y2	3
(5)-dimming_characteristic_curve_adjustment_gauge-X3	32
(6)-dimming_characteristic_curve_adjustment_gauge-Y3	8
(7)-dimming_characteristic_curve_adjustment_gauge-X4	64
(8)-dimming_characteristic_curve_adjustment_gauge-Y4	20
(9)-dimming_characteristic_curve_adjustment_gauge-X5	DC
(10)-dimming_characteristic_curve_adjustment_gauge-Y5	55
(11)-dimming_characteristic_curve_adjustment_gauge-X6	FD
(12)-dimming_characteristic_curve_adjustment_gauge-Y6	64
(1)-dimming_characteristic_curve_adjustment_indicator_lights-X1	0
(2)-dimming_characteristic_curve_adjustment_indicator_lights-Y1	5
(3)-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A
(4)-dimming_characteristic_curve_adjustment_indicator_lights-Y2	5
(5)-dimming_characteristic_curve_adjustment_indicator_lights-X3	32
(6)-dimming_characteristic_curve_adjustment_indicator_lights-Y3	0C
(7)-dimming_characteristic_curve_adjustment_indicator_lights-X4	64
(8)-dimming_characteristic_curve_adjustment_indicator_lights-Y4	17
(9)-dimming_characteristic_curve_adjustment_indicator_lights-X5	96
(10)-dimming_characteristic_curve_adjustment_indicator_lights-Y5	32
(11)-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD
(12)-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64
(1)-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00
(2)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00
(3)-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32
(4)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0E
(5)-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64
(6)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 41
(7)-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8
(8)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8
(9)-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4
(10)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD
(1)-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0
(2)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	1
(3)-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A
(4)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	1
(5)-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32
(6)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	7
(7)-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64
(8)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	12
(9)-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	96
(10)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1E
(11)-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD
(12)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64
Gas_functionality	not active
Illumination_algorithm	terminal_58xd_log_bus_parkinglight
init_fuel_algorithm	No
(1)-outside_temperature-p_time_constant_pt1	40 s
(2)-outside_temperature-p_time_constant_slow_damping	2
(3)-outside_temperature-P_speed_threshold	20 km/h
(4)-outside_temperature-p_tendency_threshold	1.0 °C
(5)-outside_temperature-p_kmt_at_delta	25 °C
(6)-outside_temperature-p_blocking_time_after_v_bigger_0	15 s
(7)-outside_temperature-p_storage_time_engine_off	180 min
(8)-outside_temperature-p_mileage_after_v_bigger_0	5.0 km
(9)-outside_temperature-p_ice_warning_exit_temperature	6 °C
(10)-outside_temperature-p_ice_warning_entry_temperature	4 °C
(11)-outside_temperature-p_tendency_damping	15 s
Picture_Upload_Download	not active
Service_Key_Clear_All_Counter	Yes
(1)-time_parameter_display-tDDWUP	0
(2)-time_parameter_display-tDD15_on	0
(3)-time_parameter_display-tDD15_off	0.3
(4)-time_parameter_display-hmi_t_Dreiter_ms	2
(5)-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s
(6)-time_parameter_display-hmi_t_UhrTimeout_ms	10 s
(7)-time_parameter_display-hmi_t_MenuTimeout_ms	255 s
(8)-time_parameter_display-hmi_t_TWSAnz_ms	3 s
(9)-time_parameter_display-hmi_t_NextWarning_ms	6 s
(10)-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s
(11)-time_parameter_display-hmi_t_P1Pause_ms	20 s
(12)-time_parameter_display-hmi_t_P2Pause_ms	900 s
(13)-time_parameter_display-hmi_t_Quit_ms	10 s
(14)-time_parameter_display-hmi_t_FondGurt	30 s
(15)-time_parameter_display-hmi_t_USZ	0.20 s
(16)-time_parameter_display-hmi_t_FTuerAUF	300 ms
(17)-time_parameter_display-rollierblockgroesse	3
... and here's a much more recent map using 16.8.0.1
;Component:KOMBI         316 2210	 Coding:0BAD09122980CF0502087E00000000
;EV_DashBoardVDDMQBAB	8031	EV_DashBoardVDDMQBAB_VW37.rod
;Thursday	4	August	2016	11:41:43:29905
;VCDS Version: Release 16.8.0 (x64)  Data version: 20160801 DS254
;VCID: 3023938B6B5782C212-8064
IDE00295-Oil temperature display	On
IDE00301-Distance	24653 km
IDE00342-ESI: Resetting ESI	no warning
IDE00343-Language version	US English
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset; not possible
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset
IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro	MFA3-Reset
IDE00499-Display correction of consumptions and operating range	100%
IDE00500-Hour	11 H
IDE00501-Minute	41 min
IDE00502-Year	2016 yr
IDE00503-Month	8 mon
IDE00504-Day	4 d
IDE00510-ESI: distance driven from inspection	1951 km
IDE00511-ESI: time from inspection	23 d
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km
IDE00514-ESI: maximum value of time between inspections	730 d
IDE00515-ESI: oil quality	poor oil quality
IDE00517-ESI: soot entry	0 km
IDE00518-ESI: thermal load	3000 km
IDE00711-Trip recorder	not installed
IDE00819-Day counter	785 d
IDE00820-Activating and deactivating all development messages	not active
IDE00827-ESI: minimum value of time between inspections	365 d
IDE01153-SIA: maximum value of distance to service	16100 km
IDE01154-SIA: maximum value of time to service	365 d
IDE02489-Display depiction	Version 2
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	12.7 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l
IDE03329-Driving profiled for range remaining	8.9 l/100km
IDE03346-IDE00301-Units adjusted-Distance	miles
IDE03346-MAS01230-Units adjusted-Date	mm_dd_yy
IDE03346-MAS01456-Units adjusted-Speed	Miles per hour
IDE03346-MAS02201-Units adjusted-Temperature	Degrees Fahrenheit
IDE03346-MAS02957-Units adjusted-Time	12h AM_PM
IDE03346-MAS03032-Units adjusted-Volume	gallons (US)
IDE03346-MAS03034-Units adjusted-Pressure	psi
IDE03346-MAS05637-Units adjusted-Operating range consumption; CNG (compressed natural gas)	kg per 100 km
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Miles per gallon (US)
IDE03346-MAS05875-Units adjusted-Average consumption; electric drive	kWh per 100 km
IDE03348-MAS01456-Speed warning-Speed	20
IDE03348-MAS01561-Speed warning-Unit	Miles per hour
IDE03348-IDE03348-Speed warning-	not active
IDE03349-FIX: Max. distance until next mileage-related inspection	32200 km
IDE03350-FIX: Maximum time until next time-dependent inspection	730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection	1900 km
IDE03352-FIX: Time since last time-dependent inspection	23 d
IDE03372-Source for synchronization of time	internal clock
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km
IDE03867-Deactivate seat belt warning	No
IDE04169-Display correction of consumption and operating range; gas	100%
IDE05930-Service notification in days	30 d
IDE05931-FIX: Reset value for next mileage-dependent inspection	32200 km
IDE05932-FIX: Reset value for next time-dependent inspections	730 d
IDE05971-Vehicle Positioning System Interface Control Module	not installed
IDE06425-Roller test bench mode; functional	not activated
IDE06588-Ignition active message; actuator	Driver door
IDE06922-No-voltage display	No display
IDE07221-Cylinder shut-off	Display
IDE08140-Driving profiled for range remaining CNG	8.0 kg/100 km
IDE08247-Driving profile for range remaining LPG	8.0 l/100km
MAS03555-Lap counter	Display
MAS03685-Digital speedometer	Display
ENG117917-BAP_Debug_Mode_Release	not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF
ENG119875-defuel_threshold	45 l
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	32
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	66
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	DC
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	5
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	14
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	17
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	32
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	46
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	32
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	64
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	3
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	3
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	8
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	20
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	55
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	96
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	5
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	5
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	0C
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	17
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	32
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0E
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 41
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	96
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	1
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	1
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	7
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1E
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64
ENG119874-Gas_functionality	not active
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light
ENG119882-init_fuel_algorithm	No
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2
ENG119825-Picture_Upload_Download	not active
ENG119876-Service_Key_Clear_All_Counter	Yes
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	30 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.20 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.6
ENG109442-ENG103975-time_parameter_display-tDD15_on	0
ENG109442-ENG100026-time_parameter_display-tDDWUP	0
ENG112418-ENG112412-Total operating range gas-consumption_factor	0.008
ENG112418-ENG112411-Total operating range gas-consumption_profile	consumption_profile_calculation
ENG112418-ENG112410-Total operating range gas-selection_consumption_factor	consumption_factor_CAN
ENG112418-ENG99298-Total operating range gas-State	active
Elapsed Time: 00:22
Letting Notepad count lines in the above data, it looks like 16.8 has one more than 14.7.2 did.
Andy
Sector 7G
HC424490
I grabbed a Micro-CAN and did an Adaptation map of 17 with Release 15.7.4:
;Component:KOMBI         316 2210, Coding:0BAD09122980CF0502087E00000000
;EV_DashBoardVDDMQBAB,008031,EV_DashBoardVDDMQBAB_AU37.rod
;Friday,19,August,2016,10:23:38:56866
;VCDS Version: Release 15.7.4 (x64)  Data version: 20160216
;VCID: 3041EA926BFD71BECE-8064
Activating and deactivating all development messages,not active
Cylinder shut-off,Display
Day,19 d
Day counter,800 d
Deactivate seat belt warning,No
Digital speedometer,Display
Display correction of consumption and operating range; gas,100 %
Display correction of consumptions and operating range,100 %
Display depiction,Version 2
Distance,25017 km
Driving profile for range remaining LPG,8.0 l/100km
Driving profiled for range remaining,9.3 l/100km
Driving profiled for range remaining CNG,8.0 kg/100 km
ESI: distance driven from inspection,2315 km
ESI: maximum value km-driving distance/inspection,30000 km
ESI: maximum value of time between inspections,730 d
ESI: minimum value km-driving distance/inspection,15000 km
ESI: minimum value of time between inspections,365 d
ESI: oil quality,poor oil quality
ESI: Resetting ESI,no warning
ESI: soot entry,0 km
ESI: thermal load,4100 km
ESI: time from inspection,38 d
FIX: Distance covered since last mileage-dependent inspection,2300 km
FIX: Max. distance until next mileage-related inspection,32200 km
FIX: Maximum time until next time-dependent inspection,730 d
FIX: Reset value for next mileage-dependent inspection,32200 km
FIX: Reset value for next mileage-dependent inspections,730 d
FIX: Time since last time-dependent inspection,38 d
Hour,10 H
Ignition active message; actuator,Driver door
Language version,US English
Lap counter,Display
(1)-MFA3-Reset-MFI button RESET / OK,Manual reset; not possible
(2)-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
(3)-MFA3-Reset-Refuel detection gas,MFA3-Reset
(4)-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
Minute,23 min
Month,8 mon
No-voltage display,No display
(1)-Offset for tank calibration values-Offset sensor 1,-12.8 l
(2)-Offset for tank calibration values-Offset sensor 2,12.7 l
(3)-Offset for tank calibration values-Offset sensor 3,12.7 l
(4)-Offset for tank calibration values-Offset sensor 4,12.7 l
(5)-Offset for tank calibration values-Complete tank calibration,-12.8 l
Oil temperature display,On
Roller test bench mode; functional,not activated
Service notification in days,30 d
(1)-Service-key settings-p_write_delay_time,40 s
(2)-Service-key settings-p_write_delay_speed,20 km/h
(3)-Service-key settings-p_write_distance,20 km
(4)-Service-key settings-p_forcewrite_qual_time,10 s
(5)-Service-key settings-p_main_switch_keyless,On
(6)-Service-key settings-p_main_switch_Basic,On
(7)-Service-key settings-p_deactivate_SK_Function,On
SIA: maximum value of distance to service,16100 km
SIA: maximum value of time to service,365 d
Source for synchronization of time,internal clock
(1)-Speed warning-,not active
(2)-Speed warning-Unit,Miles per hour
(3)-Speed warning-Speed,20
Trip recorder,not installed
(1)-Units adjusted-Temperature,Degrees Fahrenheit
(2)-Units adjusted-Distance,miles
(3)-Units adjusted-Speed,Miles per hour
(4)-Units adjusted-Pressure,psi
(5)-Units adjusted-Volume,gallons (US)
(6)-Units adjusted-Time,12h AM_PM
(7)-Units adjusted-Date,mm_dd_yy
(8)-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US)
(9)-Units adjusted-Operating range consumption; CNG (compressed natural gas),kg per 100 km
(10)-Units adjusted-Average consumption; electric drive,kWh per 100 km
Vehicle Positioning System Interface Control Module,not installed
Year,2016 yr
(1)-Total operating range gas-State,active
(2)-Total operating range gas-selection_consumption_factor,consumption_factor_CAN
(3)-Total operating range gas-consumption_profile,consumption_profile_calculation
(4)-Total operating range gas-consumption_factor,0.008
BAP_Debug_Mode_Release,not_released
(1)-Configuration of Development CAN-Messages-Block 1,OFF
(2)-Configuration of Development CAN-Messages-Block 2,OFF
(3)-Configuration of Development CAN-Messages-Block 3,OFF
(4)-Configuration of Development CAN-Messages-Block 4,OFF
(5)-Configuration of Development CAN-Messages-Block 5,OFF
(6)-Configuration of Development CAN-Messages-Block 6,OFF
(7)-Configuration of Development CAN-Messages-Block 7,OFF
(8)-Configuration of Development CAN-Messages-Block 8,OFF
(9)-Configuration of Development CAN-Messages-Block 9,OFF
(10)-Configuration of Development CAN-Messages-Block 10,OFF
(11)-Configuration of Development CAN-Messages-Block 11,OFF
(12)-Configuration of Development CAN-Messages-Block 12,OFF
(13)-Configuration of Development CAN-Messages-Block 13,OFF
(14)-Configuration of Development CAN-Messages-Block 14,OFF
(15)-Configuration of Development CAN-Messages-Block 15,OFF
(16)-Configuration of Development CAN-Messages-Block 16,OFF
(17)-Configuration of Development CAN-Messages-Block 17,OFF
(18)-Configuration of Development CAN-Messages-Block 18,OFF
(19)-Configuration of Development CAN-Messages-Block 19,OFF
(20)-Configuration of Development CAN-Messages-Block 20,OFF
(21)-Configuration of Development CAN-Messages-Block 21,OFF
(22)-Configuration of Development CAN-Messages-Block 22,OFF
(23)-Configuration of Development CAN-Messages-Block 23,OFF
(24)-Configuration of Development CAN-Messages-Block 24,OFF
(25)-Configuration of Development CAN-Messages-Block 25,OFF
(26)-Configuration of Development CAN-Messages-Block 26,OFF
(27)-Configuration of Development CAN-Messages-Block 27,OFF
(28)-Configuration of Development CAN-Messages-Block 28,OFF
(29)-Configuration of Development CAN-Messages-Block 29,OFF
(30)-Configuration of Development CAN-Messages-Block 30,OFF
(31)-Configuration of Development CAN-Messages-Block 31,OFF
(32)-Configuration of Development CAN-Messages-Block 32,OFF
(33)-Configuration of Development CAN-Messages-Block 33,OFF
(34)-Configuration of Development CAN-Messages-Block 34,OFF
(35)-Configuration of Development CAN-Messages-Block 35,OFF
(36)-Configuration of Development CAN-Messages-Block 36,OFF
(37)-Configuration of Development CAN-Messages-Block 37,OFF
(38)-Configuration of Development CAN-Messages-Block 38,OFF
(39)-Configuration of Development CAN-Messages-Block 39,OFF
defuel_threshold,45 l
(1)-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
(2)-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
(3)-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32
(4)-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
(5)-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66
(6)-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
(7)-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
(8)-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
(9)-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
(10)-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14
(11)-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
(1)-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
(2)-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02
(3)-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
(4)-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02
(5)-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32
(6)-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,17
(7)-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64
(8)-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,32
(9)-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96
(10)-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,46
(11)-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
(1)-dimming_characteristic_curve_adjustment_gauge-X1,00
(2)-dimming_characteristic_curve_adjustment_gauge-Y1,03
(3)-dimming_characteristic_curve_adjustment_gauge-X2,0A
(4)-dimming_characteristic_curve_adjustment_gauge-Y2,03
(5)-dimming_characteristic_curve_adjustment_gauge-X3,32
(6)-dimming_characteristic_curve_adjustment_gauge-Y3,08
(7)-dimming_characteristic_curve_adjustment_gauge-X4,64
(8)-dimming_characteristic_curve_adjustment_gauge-Y4,20
(9)-dimming_characteristic_curve_adjustment_gauge-X5,DC
(10)-dimming_characteristic_curve_adjustment_gauge-Y5,55
(11)-dimming_characteristic_curve_adjustment_gauge-X6,FD
(12)-dimming_characteristic_curve_adjustment_gauge-Y6,64
(1)-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
(2)-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05
(3)-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
(4)-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05
(5)-dimming_characteristic_curve_adjustment_indicator_lights-X3,32
(6)-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C
(7)-dimming_characteristic_curve_adjustment_indicator_lights-X4,64
(8)-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17
(9)-dimming_characteristic_curve_adjustment_indicator_lights-X5,96
(10)-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32
(11)-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
(12)-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
(1)-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
(2)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
(3)-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
(4)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E
(5)-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
(6)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41
(7)-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
(8)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
(9)-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
(10)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
(1)-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
(2)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01
(3)-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
(4)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01
(5)-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32
(6)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07
(7)-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64
(8)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12
(9)-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96
(10)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E
(11)-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
(12)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
Gas_functionality,not active
(1)-Illumination_algorithm-Scale_switching_algorithm,parking_light
(2)-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight
init_fuel_algorithm,No
(1)-outside_temperature-p_time_constant_pt1,40 s
(2)-outside_temperature-p_time_constant_slow_damping,2.0
(3)-outside_temperature-P_speed_threshold,20 km/h
(4)-outside_temperature-p_tendency_threshold,1.0 °C
(5)-outside_temperature-p_kmt_at_delta,25 °C
(6)-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
(7)-outside_temperature-p_storage_time_engine_off,180 min
(8)-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
(9)-outside_temperature-p_ice_warning_exit_temperature,6 °C
(10)-outside_temperature-p_ice_warning_entry_temperature,4 °C
(11)-outside_temperature-p_tendency_damping,15 s
Picture_Upload_Download,not active
Service_Key_Clear_All_Counter,Yes
(1)-time_parameter_display-tDDWUP,0.0
(2)-time_parameter_display-tDD15_on,0.0
(3)-time_parameter_display-tDD15_off,0.6
(4)-time_parameter_display-hmi_t_Dreiter_ms,2.0
(5)-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
(6)-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
(7)-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
(8)-time_parameter_display-hmi_t_TWSAnz_ms,3 s
(9)-time_parameter_display-hmi_t_NextWarning_ms,6 s
(10)-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
(11)-time_parameter_display-hmi_t_P1Pause_ms,20 s
(12)-time_parameter_display-hmi_t_P2Pause_ms,900 s
(13)-time_parameter_display-hmi_t_Quit_ms,10 s
(14)-time_parameter_display-hmi_t_FondGurt,30 s
(15)-time_parameter_display-hmi_t_USZ,0.20 s
(16)-time_parameter_display-hmi_t_FTuerAUF,300 ms
(17)-time_parameter_display-rollierblockgroesse,3
Next, I started up Release 16.8.0.3 and let it update the firmware in the Micro-CAN and ran an Adaptation map of 17 with 16.8.0.3:
;EV_DashBoardVDDMQBAB,008031,EV_DashBoardVDDMQBAB_VW37.rod
;Friday,19,August,2016,10:26:22:56866
;VCID: 3041EA926BFD71C210-8064
IDE00295-Oil temperature display,On
IDE00301-Distance,25017 km
IDE00342-ESI: Resetting ESI,no warning
IDE00343-Language version,US English
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset
IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,10 H
IDE00501-Minute,25 min
IDE00502-Year,2016 yr
IDE00503-Month,8 mon
IDE00504-Day,19 d
IDE00510-ESI: distance driven from inspection,2315 km
IDE00511-ESI: time from inspection,38 d
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
IDE00514-ESI: maximum value of time between inspections,730 d
IDE00515-ESI: oil quality,poor oil quality
IDE00517-ESI: soot entry,0 km
IDE00518-ESI: thermal load,4100 km
IDE00711-Trip recorder,not installed
IDE00819-Day counter,800 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,365 d
IDE01153-SIA: maximum value of distance to service,16100 km
IDE01154-SIA: maximum value of time to service,365 d
IDE02489-Display depiction,Version 2
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
IDE03329-Driving profiled for range remaining,9.3 l/100km
IDE03346-IDE00301-Units adjusted-Distance,miles
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Fahrenheit
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM
IDE03346-MAS03032-Units adjusted-Volume,gallons (US)
IDE03346-MAS03034-Units adjusted-Pressure,psi
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US)
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km
IDE03348-MAS01456-Speed warning-Speed,20
IDE03348-MAS01561-Speed warning-Unit,Miles per hour
IDE03348-IDE03348-Speed warning-,not active
IDE03349-FIX: Max. distance until next mileage-related inspection,32200 km
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,2300 km
IDE03352-FIX: Time since last time-dependent inspection,38 d
IDE03372-Source for synchronization of time,internal clock
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE04169-Display correction of consumption and operating range: gas,100 %
IDE05930-Service notification in days,30 d
IDE05931-FIX: Reset value for next mileage-dependent inspection,32200 km
IDE05932-FIX: Reset value for next time-dependent inspections,730 d
IDE05971-Vehicle Positioning System Interface Control Module,not installed
IDE06588-Ignition active message: actuator,Driver door
IDE06922-No-voltage display,No display
IDE07221-Cylinder shut-off,Display
IDE08140-Driving profiled for range remaining CNG,8.0 kg/100 km
IDE08247-Driving profile for range remaining LPG,8.0 l/100km
MAS03555-Lap counter,Display
MAS03685-Digital speedometer,Display
ENG117917-BAP_Debug_Mode_Release,not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
ENG119875-defuel_threshold,45 l
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,17
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,32
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,46
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,08
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,20
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
ENG119874-Gas_functionality,not active
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light
ENG119882-init_fuel_algorithm,No
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0
ENG119825-Picture_Upload_Download,not active
ENG119876-Service_Key_Clear_All_Counter,Yes
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.6
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.0
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.0
ENG112418-ENG112412-Total operating range gas-consumption_factor,0.008
ENG112418-ENG112411-Total operating range gas-consumption_profile,consumption_profile_calculation
ENG112418-ENG112410-Total operating range gas-selection_consumption_factor,consumption_factor_CAN
ENG112418-ENG99298-Total operating range gas-State,active
Elapsed Time: 00:40
DV52
C?ID=194404
Uwe: I did the same thing as Andy with my BCM: compared an admap using ver14.7 with an admap using ver16.8.
Had to strip-off the "object tags" from the latest ver SW and also remove the parentheses from the old version admap. Wow.....very different results - some spanking new channels appeared (which is good), but alarmingly, some lost channels too (which is bad). A small number of discrepancies are due to old English channel descriptors that for some reason are now German, bit not sure what to make of the analysis - results are HERE
Not sure if anyone at RT has done a similar exercise (Andy's mk7, perhaps?) , but I would be interested in hearing the results if so- please
PS: details of the control module follows:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011234701612
Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
Shop #: WSC 00028 028 00025
Andy
Sector 7G
HC424490
Wow, this took FOREVER (the better part of half an hour) but I ran a channel map in 09 using a Micro-CAN with 15.7.4:
;SW:5Q0-937-087-K   HW:5Q0-937-087-K ---  Cent. Elect.
;Component:BCM PQ37BOSCH 026 0097, Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc,012003,EV_BCMBOSCH_AU37.rod
;Monday,22,August,2016,08:17:55:53578
;VCID: 43ABB579CA44922623-8016
(1)-Access control-Funk bei Klemme 15 ein,active
(2)-Access control-Notschließfunktion,active
(3)-Access control-automatisches Verriegeln bei Geschwindigkeit,active
(4)-Access control-automatisches Entriegeln,active
(5)-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
(6)-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung
(7)-Access control-CAN Wecken bei Softtouchbetaetigung,active
(8)-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
(9)-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
(10)-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
(11)-Access control-Valet Parking,not active
(12)-Access control-Direkter Auswurf des Heckdeckels,active
(13)-Access control-ZV entriegelt auch Heckdeckel,active
(14)-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
(15)-Access control-Autolock Autounlock wirkt auf Heck,active
(16)-Access control-ZV Heck nur direkt auswerfen,not active
(17)-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
(18)-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
(19)-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
(20)-Access control-ZV-Entriegelung nach Seitencrash,not active
(21)-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
(22)-Access control-Elektrische Laderaumabdeckung,not active
(23)-Access control-Menuesteuerung Tuerentriegelung,active
(24)-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
(25)-Access control-Autounlock NAR,active
(26)-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
(27)-Access control-Softtouch-Betaetigung senden,Always
(28)-Access control-Servoheck Schlossansteuerung,Always
(29)-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
(30)-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
(31)-Access control-Vorrastenhaenger_Freigabe,not active
(32)-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
(33)-Access control-Deaktivierung_Laderaumschliessung_extern,not active
(34)-Access control-LS_Taster_Togglefunktion,not active
(35)-Access control-Nutzfahrzeug_Schliessung,not active
(36)-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
(37)-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
(1)-Access control 2-Komfortbedienung global,active
(2)-Access control 2-Comfort opening,active
(3)-Access control 2-Comfort closing,active
(4)-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
(5)-Access control 2-Nachsaven_nach_Verdecklauf,not active
(6)-Access control 2-Funk Komfort schliessen,active
(7)-Access control 2-Funk Komfort oeffnen,active
(8)-Access control 2-Schliesszylinder Komfort oeffnen,not active
(9)-Access control 2-Schliesszylinder Komfort schliessen,active
(10)-Access control 2-SAD Richtung Komfortoeffnen,Open
(11)-Access control 2-SAD Komfort schliessen,active
(12)-Access control 2-SAD Komfort oeffnen,active
(13)-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
(14)-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
(15)-Access control 2-Regenschliessen_ein_aus,active
(16)-Access control 2-Regenschliessen_art,Permanent
(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active
(18)-Access control 2-Spiegelverstellung Synchron,not active
(19)-Access control 2-Kessy Komfort oeffnen,not active
(20)-Access control 2-Kessy Komfort schliessen,active
(21)-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
(22)-Access control 2-Menuesteuerung Spiegelabsenkung,active
(23)-Access control 2-Funk Spiegelanklappen,not active
(24)-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key
(25)-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active
(26)-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
(27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
(28)-Access control 2-Menuesteuerung Regenschliessen,active
(29)-Access control 2-SAD PreCrash Konturschliessen,not active
(30)-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
(31)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
(32)-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
(33)-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light
(34)-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active
(35)-Access control 2-Signalisierung_Spiegelanklappung,not active
(36)-Access control 2-Virtuelles_Pedal,not active
(37)-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
(38)-Access control 2-easycloselight_aktiv,not active
(39)-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active
(1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
(2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
(3)-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
(4)-Acknowledgement signals-Optical feedback during locking,Decelerate
(5)-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
(6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
(7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
(8)-Acknowledgement signals-Akustische Rueckmeldung global,active
(9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
(10)-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
(11)-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
(1)-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
(2)-After-run for park light-Bedingungen zur Standlichtbegrenzung,not active
(3)-After-run for park light-Bedingungen zur Parklichtbegrenzung,not active
(4)-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x1 Stunden
(5)-After-run for park light-Standlicht-Nachlaufzeit,30 min
(6)-After-run for park light-Standlicht-Verfügbarkeit,0 s
Alternating park position 1,7.49 °
Alternating park position 2,29.49 °
(1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %
(2)-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %
(3)-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %
(4)-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
(5)-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
(6)-Ambient lighting-Innenlichtinszenierung,Enabled
(1)-Anti-theft device-Alarmsignal,frequency modulated
(2)-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
(3)-Anti-theft device-DWA Alarmverzoegerung,not active
(4)-Anti-theft device-DWA Camper Modus,not active
(5)-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
(6)-Anti-theft device-Sirenen Alarmzahl,1 Alarm
(7)-Anti-theft device-Akustischer Alarm Signalhorn,active
(1)-Assistance light functions-Notbremsanzeige NBA,not active
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
(3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
(4)-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,active
(5)-Assistance light functions-Fernlichtassistent Reset,not active
(6)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
(7)-Assistance light functions-Assistenzfahrlicht bei Regen,active
(8)-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis
(9)-Assistance light functions-LS_Error_Ausgabe,not active
(10)-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
(11)-Assistance light functions-AFL Zeitverzoegerung,2000 ms
(12)-Assistance light functions-Lichtsensorempfindlichkeit,normal
(1)-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
(2)-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
(3)-Auxiliary functions-Signalhorn ohne KL15,active
(4)-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
Characteristics in production mode,0 ms
(1)-Comfort illumination-Coming Home Verbaustatus,automatic
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
(3)-Comfort illumination-Menueeinstellung Cominghome,10 s
(4)-Comfort illumination-Coming Home Leuchten,Low beam
(5)-Comfort illumination-Coming-home Einschaltereignis,Driver door
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
(7)-Comfort illumination-Leaving-Home Verbausstatus,Enabled
(8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
(9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx
(1)-Convert. top oper.-Komfortbedienung Verdeck global,active
(2)-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
(3)-Convert. top oper.-Komfortbedienung Verdeck schließen,active
(4)-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
(5)-Convert. top oper.-Verdeck schließen via Schließzylinder,active
(6)-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
(7)-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
(8)-Convert. top oper.-Verdeck oeffnen via Kessy,active
(9)-Convert. top oper.-Verdeck schließen via Kessy,active
(10)-Convert. top oper.-Doppelpuls nur Verdeck,active
(11)-Convert. top oper.-Verdeck mit Schiebedach,not active
(12)-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
(13)-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
(14)-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
(15)-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active
(16)-Convert. top oper.-Remote Lock Unlock Timer s1,0 s
(17)-Convert. top oper.-Remote Lock Unlock Timer s3,0.000 ms
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
(8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
Deactivate production mode,0
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
(3)-Driving light and parking light-Standlicht aus,active
(4)-Driving light and parking light-Parklicht ueber LSS aktiviert,not active
(5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active
(6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
(7)-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
(8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
(9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
(10)-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
(11)-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
(12)-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
(14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
(3)-Dyn. turn signal modes-ZV_Blinken_zu,not active
(4)-Dyn. turn signal modes-ZV_Blinken_auf,not active
(5)-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
(8)-Dyn. turn signal modes-Taxialarmblinken,not active
(9)-Dyn. turn signal modes-Panikblinken,not active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
(13)-Dyn. turn signal modes-Richtungs_blinken_links,not active
(14)-Dyn. turn signal modes-ABBA_Blinken,not active
(15)-Dyn. turn signal modes-Crashblinken,not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
(18)-Dyn. turn signal modes-Emergency_alert_blinken,not active
(1)-Energy management-Energy_Management_Adaptation,Energy management active
(2)-Energy management-Praediktives_Energiemanagement,not active
(1)-Head area heater-blower_speed,0
(2)-Head area heater-Temperature,-3
(1)-Int. light; 2nd generation-Aufloesung Dimmzeit,0.10 s
(2)-Int. light; 2nd generation-weicher Farbwechsel,not active
(3)-Int. light; 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
(4)-Int. light; 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
(5)-Int. light; 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
(6)-Int. light; 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
(7)-Int. light; 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
(8)-Int. light; 2nd generation-Dachbeleuchtung mehrfarbig,not active
(9)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
(10)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
(11)-Int. light; 2nd generation-BAP Farbwert Farbe 1,2
(12)-Int. light; 2nd generation-BAP Farbwert Farbe 2,3
(13)-Int. light; 2nd generation-BAP Farbwert Farbe 3,1
(14)-Int. light; 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
(15)-Int. light; 2nd generation-Defaultwert Ambienteprofil Dach,80 %
(16)-Int. light; 2nd generation-Defaultwert Ambienteprofil Farbe,2
(17)-Int. light; 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
(18)-Int. light; 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
(19)-Int. light; 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
(20)-Int. light; 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
(21)-Int. light; 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
(22)-Int. light; 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
(23)-Int. light; 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
(24)-Int. light; 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
(25)-Int. light; 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
(26)-Int. light; 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
(27)-Int. light; 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
(28)-Int. light; 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
(29)-Int. light; 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
(30)-Int. light; 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
(31)-Int. light; 2nd generation-Rotwert Farbe 1,0
(32)-Int. light; 2nd generation-Gruenwert Farbe 1,0
(33)-Int. light; 2nd generation-Blauwert Farbe 1,0
(34)-Int. light; 2nd generation-Rotwert Farbe 2,0
(35)-Int. light; 2nd generation-Gruenwert Farbe 2,0
(36)-Int. light; 2nd generation-Blauwert Farbe 2,0
(37)-Int. light; 2nd generation-Rotwert Farbe 3,0
(38)-Int. light; 2nd generation-Gruenwert Farbe 3,0
(39)-Int. light; 2nd generation-Blauwert Farbe 3,0
(1)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed
(2)-Interior light; light configuration-Ambiente_Lautsprecher,not installed
(3)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
(4)-Interior light; light configuration-Cockpitbeleuchtung,not installed
(5)-Interior light; light configuration-Mittelkonsolenbeleuchtung,not installed
(6)-Interior light; light configuration-Dachbeleuchtung,not installed
(7)-Interior light; light configuration-Panoramaschiebedachbeleuchtung,not installed
(8)-Interior light; light configuration-Foot well lighting,installed
(9)-Interior light; light configuration-Farbwahl ueber HMI,not installed
(10)-Interior light; light configuration-Farbwahl ueber Fahrprofil,not installed
(11)-Interior light; light configuration-LIN-Dachkonsole lokal aktivierbar,not active
(12)-Interior light; light configuration-Ambientemenue mit globalem aus,not active
(13)-Interior light; light configuration-Ambientemenue mit alle Zonen,not active
(14)-Interior light; light configuration-Ambient_Farbliste_HMI,not active
(15)-Interior light; light configuration-Frei_Farbwahl_ueber_HMI,not active
(1)-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
(2)-Interior lighting-KL30G ohne PWM,not active
(3)-Interior lighting-KL58 Einschalten mit Rampe,not active
(4)-Interior lighting-KL58 Verriegelungsausschalten,not active
(5)-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
(6)-Interior lighting-Suchbeleuchtung Festwert,100 %
(1)-Light configuration-Lasttyp 0,12 - Blinkleuchten
(2)-Light configuration-BAP Bitposition 0,34
(3)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Light configuration-Lichtfunktion A 0,2
(5)-Light configuration-Lichtfunktion B 0,0
(6)-Light configuration-Dimmwert AB 0,100
(7)-Light configuration-Lichtansteuerung HD AB 0,Always
(8)-Light configuration-Lichtfunktion C 0,0
(9)-Light configuration-Lichtfunktion D 0,0
(10)-Light configuration-Dimmwert CD 0,0
(11)-Light configuration-Dimming Direction CD 0,maximize
(12)-Light configuration-Lichtfunktion E 0,0
(13)-Light configuration-Lichtfunktion F 0,0
(14)-Light configuration-Dimmwert EF 0,0
(15)-Light configuration-Dimming Direction EF 0,maximize
(16)-Light configuration-Lichtfunktion G 0,0
(17)-Light configuration-Lichtfunktion H 0,0
(18)-Light configuration-Dimmwert GH 0,0
(19)-Light configuration-Dimming Direction GH 0,maximize
(20)-Light configuration-Lasttyp 1,12 - Blinkleuchten
(21)-Light configuration-BAP Bitposition 1,3E
(22)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
(23)-Light configuration-Lichtfunktion A 1,4
(24)-Light configuration-Lichtfunktion B 1,0
(25)-Light configuration-Dimmwert AB 1,100
(26)-Light configuration-Lichtansteuerung HD AB 1,Always
(27)-Light configuration-Lichtfunktion C 1,0
(28)-Light configuration-Lichtfunktion D 1,0
(29)-Light configuration-Dimmwert CD 1,0
(30)-Light configuration-Dimming Direction CD 1,maximize
(31)-Light configuration-Lichtfunktion E 1,0
(32)-Light configuration-Lichtfunktion F 1,0
(33)-Light configuration-Dimmwert EF 1,0
(34)-Light configuration-Dimming Direction EF 1,maximize
(35)-Light configuration-Lichtfunktion G 1,0
(36)-Light configuration-Lichtfunktion H 1,0
(37)-Light configuration-Dimmwert GH 1,0
(38)-Light configuration-Dimming Direction GH 1,maximize
(39)-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
(40)-Light configuration-BAP Bitposition 2,48
(41)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
(42)-Light configuration-Lichtfunktion A 2,20
(43)-Light configuration-Lichtfunktion B 2,0
(44)-Light configuration-Dimmwert AB 2,100
(45)-Light configuration-Lichtansteuerung HD AB 2,Always
(46)-Light configuration-Lichtfunktion C 2,0
(47)-Light configuration-Lichtfunktion D 2,0
(48)-Light configuration-Dimmwert CD 2,0
(49)-Light configuration-Dimming Direction CD 2,minimize
(50)-Light configuration-Lichtfunktion E 2,8
(51)-Light configuration-Lichtfunktion F 2,9
(52)-Light configuration-Dimmwert EF 2,26
(53)-Light configuration-Dimming Direction EF 2,maximize
(54)-Light configuration-Lichtfunktion G 2,0
(55)-Light configuration-Lichtfunktion H 2,0
(56)-Light configuration-Dimmwert GH 2,0
(57)-Light configuration-Dimming Direction GH 2,maximize
(58)-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
(59)-Light configuration-BAP Bitposition 3,4C
(60)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C
(61)-Light configuration-Lichtfunktion A 3,20
(62)-Light configuration-Lichtfunktion B 3,0
(63)-Light configuration-Dimmwert AB 3,100
(64)-Light configuration-Lichtansteuerung HD AB 3,Always
(65)-Light configuration-Lichtfunktion C 3,0
(66)-Light configuration-Lichtfunktion D 3,0
(67)-Light configuration-Dimmwert CD 3,0
(68)-Light configuration-Dimming Direction CD 3,minimize
(69)-Light configuration-Lichtfunktion E 3,8
(70)-Light configuration-Lichtfunktion F3,10
(71)-Light configuration-Dimmwert EF 3,26
(72)-Light configuration-Dimming Direction EF 3,maximize
(73)-Light configuration-Lichtfunktion G 3,0
(74)-Light configuration-Lichtfunktion H 3,0
(75)-Light configuration-Dimmwert GH 3,0
(76)-Light configuration-Dimming Direction GH 3,maximize
(77)-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
(78)-Light configuration-BAP Bitposition 4,3A
(79)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49
(80)-Light configuration-Lichtfunktion A 4,20
(81)-Light configuration-Lichtfunktion B 4,0
(82)-Light configuration-Dimmwert AB 4,127
(83)-Light configuration-Lichtansteuerung HD AB 4,Always
(84)-Light configuration-Lichtfunktion C 4,0
(85)-Light configuration-Lichtfunktion D 4,0
(86)-Light configuration-Dimmwert CD 4,0
(87)-Light configuration-Dimming Direction CD 4,minimize
(88)-Light configuration-Lichtfunktion E 4,8
(89)-Light configuration-Lichtfunktion F 4,9
(90)-Light configuration-Dimmwert EF 4,127
(91)-Light configuration-Dimming Direction EF 4,maximize
(92)-Light configuration-Lichtfunktion G 4,0
(93)-Light configuration-Lichtfunktion H 4,0
(94)-Light configuration-Dimmwert GH 4,0
(95)-Light configuration-Dimming Direction GH 4,maximize
(96)-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
(97)-Light configuration-BAP Bitposition 5,44
(98)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B
(99)-Light configuration-Lichtfunktion A 5,20
(100)-Light configuration-Lichtfunktion B 5,0
(101)-Light configuration-Dimmwert AB 5,127
(102)-Light configuration-Lichtansteuerung HD AB 5,Always
(103)-Light configuration-Lichtfunktion C 5,0
(104)-Light configuration-Lichtfunktion D 5,0
(105)-Light configuration-Dimmwert CD 5,0
(106)-Light configuration-Dimming Direction CD 5,minimize
(107)-Light configuration-Lichtfunktion E 5,8
(108)-Light configuration-Lichtfunktion F5,10
(109)-Light configuration-Dimmwert EF 5,127
(110)-Light configuration-Dimming Direction EF 5,maximize
(111)-Light configuration-Lichtfunktion G 5,0
(112)-Light configuration-Lichtfunktion H 5,0
(113)-Light configuration-Dimmwert GH 5,0
(114)-Light configuration-Dimming Direction GH 5,maximize
(115)-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht
(116)-Light configuration-BAP Bitposition 6,36
(117)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
(118)-Light configuration-Lichtfunktion A 6,11
(119)-Light configuration-Lichtfunktion B 6,15
(120)-Light configuration-Dimmwert AB 6,127
(121)-Light configuration-Lichtansteuerung HD AB 6,Always
(122)-Light configuration-Lichtfunktion C 6,0
(123)-Light configuration-Lichtfunktion D 6,0
(124)-Light configuration-Dimmwert CD 6,0
(125)-Light configuration-Dimming Direction CD 6,maximize
(126)-Light configuration-Lichtfunktion E 6,0
(127)-Light configuration-Lichtfunktion F 6,0
(128)-Light configuration-Dimmwert EF 6,0
(129)-Light configuration-Dimming Direction EF 6,maximize
(130)-Light configuration-Lichtfunktion G 6,0
(131)-Light configuration-Lichtfunktion H 6,0
(132)-Light configuration-Dimmwert GH 6,0
(133)-Light configuration-Dimming Direction GH 6,maximize
(134)-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht
(135)-Light configuration-BAP Bitposition 7,40
(136)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
(137)-Light configuration-Lichtfunktion A 7,12
(138)-Light configuration-Lichtfunktion B 7,15
(139)-Light configuration-Dimmwert AB 7,127
(140)-Light configuration-Lichtansteuerung HD AB 7,Always
(141)-Light configuration-Lichtfunktion C 7,0
(142)-Light configuration-Lichtfunktion D 7,0
(143)-Light configuration-Dimmwert CD 7,0
(144)-Light configuration-Dimming Direction CD 7,maximize
(145)-Light configuration-Lichtfunktion E 7,0
(146)-Light configuration-Lichtfunktion F 7,0
(147)-Light configuration-Dimmwert EF 7,0
(148)-Light configuration-Dimming Direction EF 7,maximize
(149)-Light configuration-Lichtfunktion G 7,0
(150)-Light configuration-Lichtfunktion H 7,0
(151)-Light configuration-Dimmwert GH 7,1
(152)-Light configuration-Dimming Direction GH 7,maximize
(153)-Light configuration-Lasttyp 8,1 - LED Tagfahrlichtmodul Versorgung
(154)-Light configuration-BAP Bitposition 8,00
(155)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,00
(156)-Light configuration-Lichtfunktion A 8,238
(157)-Light configuration-Lichtfunktion B 8,0
(158)-Light configuration-Dimmwert AB 8,45
(159)-Light configuration-Lichtansteuerung HD AB 8,Always
(160)-Light configuration-Lichtfunktion C 8,1
(161)-Light configuration-Lichtfunktion D 8,156
(162)-Light configuration-Dimmwert CD 8,0
(163)-Light configuration-Dimming Direction CD 8,maximize
(164)-Light configuration-Lichtfunktion E 8,0
(165)-Light configuration-Lichtfunktion F 8,1
(166)-Light configuration-Dimmwert EF 8,36
(167)-Light configuration-Dimming Direction EF 8,maximize
(168)-Light configuration-Lichtfunktion G 8,0
(169)-Light configuration-Lichtfunktion H 8,0
(170)-Light configuration-Dimmwert GH 8,0
(171)-Light configuration-Dimming Direction GH 8,maximize
(173)-Light configuration-BAP Bitposition 9,00
(174)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,01
(175)-Light configuration-Lichtfunktion A 9,3
(176)-Light configuration-Lichtfunktion B 9,0
(177)-Light configuration-Dimmwert AB 9,0
(178)-Light configuration-Lichtansteuerung HD AB 9,Always
(179)-Light configuration-Lichtfunktion C 9,0
(180)-Light configuration-Lichtfunktion D 9,218
(181)-Light configuration-Dimmwert CD 9,0
(182)-Light configuration-Dimming Direction CD 9,maximize
(183)-Light configuration-Lichtfunktion E 9,54
(184)-Light configuration-Lichtfunktion F 9,254
(185)-Light configuration-Dimmwert EF 9,77
(186)-Light configuration-Dimming Direction EF 9,maximize
(187)-Light configuration-Lichtfunktion G 9,0
(188)-Light configuration-Lichtfunktion H 9,73
(189)-Light configuration-Dimmwert GH 9,0
(190)-Light configuration-Dimming Direction GH 9,maximize
(191)-Light configuration-Lasttyp 10,not active
(192)-Light configuration-BAP Bitposition 10,00
(193)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,01
(194)-Light configuration-Lichtfunktion A 10,0
(195)-Light configuration-Lichtfunktion B 10,0
(196)-Light configuration-Dimmwert AB 10,0
(197)-Light configuration-Lichtansteuerung HD AB 10,Always
(198)-Light configuration-Lichtfunktion C 10,0
(199)-Light configuration-Lichtfunktion D 10,1
(200)-Light configuration-Dimmwert CD 10,0
(201)-Light configuration-Dimming Direction CD 10,maximize
(202)-Light configuration-Lichtfunktion E 10,0
(203)-Light configuration-Lichtfunktion F 10,0
(204)-Light configuration-Dimmwert EF 10,0
(205)-Light configuration-Dimming Direction EF 10,maximize
(206)-Light configuration-Lichtfunktion G 10,0
(207)-Light configuration-Lichtfunktion H 10,1
(208)-Light configuration-Dimmwert GH 10,1
(209)-Light configuration-Dimming Direction GH 10,maximize
(210)-Light configuration-Lasttyp 11,not active
(211)-Light configuration-BAP Bitposition 11,00
(212)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00
(213)-Light configuration-Lichtfunktion A 11,255
(214)-Light configuration-Lichtfunktion B 11,0
(215)-Light configuration-Dimmwert AB 11,99
(216)-Light configuration-Lichtansteuerung HD AB 11,Always
(217)-Light configuration-Lichtfunktion C 11,111
(218)-Light configuration-Lichtfunktion D 11,1
(219)-Light configuration-Dimmwert CD 11,0
(220)-Light configuration-Dimming Direction CD 11,maximize
(221)-Light configuration-Lichtfunktion E 11,0
(222)-Light configuration-Lichtfunktion F 11,0
(223)-Light configuration-Dimmwert EF 11,48
(224)-Light configuration-Dimming Direction EF 11,minimize
(225)-Light configuration-Lichtfunktion G 11,1
(226)-Light configuration-Lichtfunktion H 11,0
(227)-Light configuration-Dimmwert GH 11,0
(228)-Light configuration-Dimming Direction GH 11,maximize
(229)-Light configuration-Lasttyp 12,not active
(230)-Light configuration-BAP Bitposition 12,00
(231)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,6F
(232)-Light configuration-Lichtfunktion A 12,1
(233)-Light configuration-Lichtfunktion B 12,0
(234)-Light configuration-Dimmwert AB 12,0
(235)-Light configuration-Lichtansteuerung HD AB 12,Always
(236)-Light configuration-Lichtfunktion C 12,0
(237)-Light configuration-Lichtfunktion D 12,176
(238)-Light configuration-Dimmwert CD 12,1
(239)-Light configuration-Dimming Direction CD 12,maximize
(240)-Light configuration-Lichtfunktion E 12,0
(241)-Light configuration-Lichtfunktion F 12,0
(242)-Light configuration-Dimmwert EF 12,1
(243)-Light configuration-Dimming Direction EF 12,maximize
(244)-Light configuration-Lichtfunktion G 12,0
(245)-Light configuration-Lichtfunktion H 12,229
(246)-Light configuration-Dimmwert GH 12,1
(247)-Light configuration-Dimming Direction GH 12,maximize
(248)-Light configuration-Lasttyp 13,not active
(249)-Light configuration-BAP Bitposition 13,00
(250)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,01
(251)-Light configuration-Lichtfunktion A 13,55
(252)-Light configuration-Lichtfunktion B 13,1
(253)-Light configuration-Dimmwert AB 13,119
(254)-Light configuration-Lichtansteuerung HD AB 13,only_if_closed
(255)-Light configuration-Lichtfunktion  C 13,254
(256)-Light configuration-Lichtfunktion D 13,1
(257)-Light configuration-Dimmwert CD 13,0
(258)-Light configuration-Dimming Direction CD 13,maximize
(259)-Light configuration-Lichtfunktion E 13,0
(260)-Light configuration-Lichtfunktion F 13,0
(261)-Light configuration-Dimmwert EF 13,48
(262)-Light configuration-Dimming Direction EF 13,minimize
(263)-Light configuration-Lichtfunktion G 13,1
(264)-Light configuration-Lichtfunktion H 13,0
(265)-Light configuration-Dimmwert GH 13,0
(266)-Light configuration-Dimming Direction GH 13,maximize
(267)-Light configuration-Lasttyp 14,not active
(268)-Light configuration-BAP Bitposition 14,00
(269)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,01
(270)-Light configuration-Lichtfunktion A 14,1
(271)-Light configuration-Lichtfunktion B 14,0
(272)-Light configuration-Dimmwert AB 14,0
(273)-Light configuration-Lichtansteuerung HD AB 14,Always
(274)-Light configuration-Lichtfunktion C 14,0
(275)-Light configuration-Lichtfunktion D 14,1
(276)-Light configuration-Dimmwert CD 14,0
(277)-Light configuration-Dimming Direction CD 14,maximize
(278)-Light configuration-Lichtfunktion E 14,16
(279)-Light configuration-Lichtfunktion F 14,0
(280)-Light configuration-Dimmwert EF 14,0
(281)-Light configuration-Dimming Direction EF 14,maximize
(282)-Light configuration-Lichtfunktion G 14,0
(283)-Light configuration-Lichtfunktion H 14,77
(284)-Light configuration-Dimmwert GH 14,1
(285)-Light configuration-Dimming Direction GH 14,maximize
(287)-Light configuration-BAP Bitposition 15,00
(288)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,01
(289)-Light configuration-Lichtfunktion A 15,58
(290)-Light configuration-Lichtfunktion B 15,0
(291)-Light configuration-Dimmwert AB 15,9
(292)-Light configuration-Lichtansteuerung HD AB 15,Always
(293)-Light configuration-Lichtfunktion C 15,50
(294)-Light configuration-Lichtfunktion D 15,0
(295)-Light configuration-Dimmwert CD 15,0
(296)-Light configuration-Dimming Direction CD 15,maximize
(297)-Light configuration-Lichtfunktion E 15,0
(298)-Light configuration-Lichtfunktion F 15,0
(299)-Light configuration-Dimmwert EF 15,0
(300)-Light configuration-Dimming Direction EF 15,maximize
(301)-Light configuration-Lichtfunktion G 15,0
(302)-Light configuration-Lichtfunktion H 15,1
(303)-Light configuration-Dimmwert GH 15,0
(304)-Light configuration-Dimming Direction GH 15,maximize
(306)-Light configuration-BAP Bitposition 16,00
(307)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00
(308)-Light configuration-Lichtfunktion A 16,241
(309)-Light configuration-Lichtfunktion B 16,0
(310)-Light configuration-Dimmwert AB 16,47
(311)-Light configuration-Lichtansteuerung HD AB 16,Always
(312)-Light configuration-Lichtfunktion C 16,0
(313)-Light configuration-Lichtfunktion D 16,96
(314)-Light configuration-Dimmwert CD 16,0
(315)-Light configuration-Dimming Direction CD 16,maximize
(316)-Light configuration-Lichtfunktion E 16,1
(317)-Light configuration-Lichtfunktion F 16,0
(318)-Light configuration-Dimmwert EF 16,0
(319)-Light configuration-Dimming Direction EF 16,maximize
(320)-Light configuration-Lichtfunktion G 16,0
(321)-Light configuration-Lichtfunktion H 16,67
(322)-Light configuration-Dimmwert GH 16,1
(323)-Light configuration-Dimming Direction GH 16,maximize
(325)-Light configuration-BAP Bitposition 17,00
(326)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,FF
(327)-Light configuration-Lichtfunktion A 17,1
(328)-Light configuration-Lichtfunktion  B 17,0
(329)-Light configuration-Dimmwert AB 17,16
(330)-Light configuration-Lichtansteuerung HD AB 17,only_if_closed
(331)-Light configuration-Lichtfunktion C 17,1
(332)-Light configuration-Lichtfunktion D 17,144
(333)-Light configuration-Dimmwert CD 17,1
(334)-Light configuration-Dimming Direction CD 17,maximize
(335)-Light configuration-Lichtfunktion E 17,194
(336)-Light configuration-Lichtfunktion F 17,1
(337)-Light configuration-Dimmwert EF 17,39
(338)-Light configuration-Dimming Direction EF 17,maximize
(339)-Light configuration-Lichtfunktion G 17,0
(340)-Light configuration-Lichtfunktion H 17,1
(341)-Light configuration-Dimmwert GH 17,0
(342)-Light configuration-Dimming Direction GH 17,maximize
(344)-Light configuration-BAP Bitposition 18,01
(345)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,00
(346)-Light configuration-Lichtfunktion A 18,14
(347)-Light configuration-Lichtfunktion B 18,0
(348)-Light configuration-Dimmwert AB 18,13
(349)-Light configuration-Lichtansteuerung HD AB 18,Always
(350)-Light configuration-Lichtfunktion C 18,85
(351)-Light configuration-Lichtfunktion D 18,0
(352)-Light configuration-Dimmwert CD 18,0
(353)-Light configuration-Dimming Direction CD 18,maximize
(354)-Light configuration-Lichtfunktion E 18,131
(355)-Light configuration-Lichtfunktion F 18,0
(356)-Light configuration-Dimmwert EF 18,16
(357)-Light configuration-Dimming Direction EF 18,minimize
(358)-Light configuration-Lichtfunktion G 18,1
(359)-Light configuration-Lichtfunktion H 18,224
(360)-Light configuration-Dimmwert GH 18,1
(361)-Light configuration-Dimming Direction GH 18,maximize
(362)-Light configuration-Lasttyp 19,not active
(363)-Light configuration-BAP Bitposition 19,00
(364)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,FE
(365)-Light configuration-Lichtfunktion A 19,1
(366)-Light configuration-Lichtfunktion B 19,0
(367)-Light configuration-Dimmwert AB 19,56
(368)-Light configuration-Lichtansteuerung HD AB 19,only_if_closed
(369)-Light configuration-Lichtfunktion C 19,0
(370)-Light configuration-Lichtfunktion D 19,144
(371)-Light configuration-Dimmwert CD 19,0
(372)-Light configuration-Dimming Direction CD 19,maximize
(373)-Light configuration-Lichtfunktion E 19,211
(374)-Light configuration-Lichtfunktion F 19,1
(375)-Light configuration-Dimmwert EF 19,49
(376)-Light configuration-Dimming Direction EF 19,minimize
(377)-Light configuration-Lichtfunktion G 19,0
(378)-Light configuration-Lichtfunktion H 19,0
(379)-Light configuration-Dimmwert GH 19,0
(380)-Light configuration-Dimming Direction GH 19,maximize
(381)-Light configuration-Lasttyp 20,not active
(382)-Light configuration-BAP Bitposition 20,00
(383)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,00
(384)-Light configuration-Lichtfunktion A 20,62
(385)-Light configuration-Lichtfunktion B 20,0
(386)-Light configuration-Dimmwert AB 20,74
(387)-Light configuration-Lichtansteuerung HD AB 20,only_if_closed
(388)-Light configuration-Lichtfunktion C 20,1
(389)-Light configuration-Lichtfunktion D 20,0
(390)-Light configuration-Dimmwert CD 20,0
(391)-Light configuration-Dimming Direction CD 20,maximize
(392)-Light configuration-Lichtfunktion E 20,212
(393)-Light configuration-Lichtfunktion F 20,254
(394)-Light configuration-Dimmwert EF 20,1
(395)-Light configuration-Dimming Direction EF 20,maximize
(396)-Light configuration-Lichtfunktion G 20,0
(397)-Light configuration-Lichtfunktion H 20,16
(398)-Light configuration-Dimmwert GH 20,0
(399)-Light configuration-Dimming Direction GH 20,maximize
(400)-Light configuration-Lasttyp 21,5 - LED Abblendlicht
(401)-Light configuration-BAP Bitposition 21,00
(402)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,00
(403)-Light configuration-Lichtfunktion A 21,0
(404)-Light configuration-Lichtfunktion B 21,0
(405)-Light configuration-Dimmwert AB 21,0
(406)-Light configuration-Lichtansteuerung HD AB 21,Always
(407)-Light configuration-Lichtfunktion C 21,0
(408)-Light configuration-Lichtfunktion D 21,48
(409)-Light configuration-Dimmwert CD 21,0
(410)-Light configuration-Dimming Direction CD 21,maximize
(411)-Light configuration-Lichtfunktion E 21,156
(412)-Light configuration-Lichtfunktion F 21,0
(413)-Light configuration-Dimmwert EF 21,96
(414)-Light configuration-Dimming Direction EF 21,maximize
(415)-Light configuration-Lichtfunktion G 21,0
(416)-Light configuration-Lichtfunktion H 21,241
(417)-Light configuration-Dimmwert GH 21,0
(418)-Light configuration-Dimming Direction GH 21,maximize
(419)-Light configuration-Lasttyp 22,not active
(420)-Light configuration-BAP Bitposition 22,00
(421)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,01
(422)-Light configuration-Lichtfunktion A 22,1
(423)-Light configuration-Lichtfunktion B 22,0
(424)-Light configuration-Dimmwert AB 22,112
(425)-Light configuration-Lichtansteuerung HD AB 22,Always
(426)-Light configuration-Lichtfunktion C 22,0
(427)-Light configuration-Lichtfunktion D 22,112
(428)-Light configuration-Dimmwert CD 22,0
(429)-Light configuration-Dimming Direction CD 22,maximize
(430)-Light configuration-Lichtfunktion E 22,1
(431)-Light configuration-Lichtfunktion F 22,0
(432)-Light configuration-Dimmwert EF 22,112
(433)-Light configuration-Dimming Direction EF 22,maximize
(434)-Light configuration-Lichtfunktion G 22,0
(435)-Light configuration-Lichtfunktion H 22,13
(436)-Light configuration-Dimmwert GH 22,1
(437)-Light configuration-Dimming Direction GH 22,maximize
(439)-Light configuration-BAP Bitposition 23,00
(440)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00
(441)-Light configuration-Lichtfunktion A 23,5
(442)-Light configuration-Lichtfunktion B 23,0
(443)-Light configuration-Dimmwert AB 23,48
(444)-Light configuration-Lichtansteuerung HD AB 23,Always
(445)-Light configuration-Lichtfunktion C 23,0
(446)-Light configuration-Lichtfunktion D 23,48
(447)-Light configuration-Dimmwert CD 23,0
(448)-Light configuration-Dimming Direction CD 23,maximize
(449)-Light configuration-Lichtfunktion E 23,98
(450)-Light configuration-Lichtfunktion F 23,1
(451)-Light configuration-Dimmwert EF 23,96
(452)-Light configuration-Dimming Direction EF 23,maximize
(453)-Light configuration-Lichtfunktion G 23,0
(454)-Light configuration-Lichtfunktion H 23,208
(455)-Light configuration-Dimmwert GH 23,0
(456)-Light configuration-Dimming Direction GH 23,maximize
(457)-Light configuration-Lasttyp 24,not active
(458)-Light configuration-BAP Bitposition 24,00
(459)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00
(460)-Light configuration-Lichtfunktion A 24,1
(461)-Light configuration-Lichtfunktion B 24,0
(462)-Light configuration-Dimmwert AB 24,17
(463)-Light configuration-Lichtansteuerung HD AB 24,only_if_closed
(464)-Light configuration-Lichtfunktion C 24,0
(465)-Light configuration-Lichtfunktion D 24,112
(466)-Light configuration-Dimmwert CD 24,1
(467)-Light configuration-Dimming Direction CD 24,maximize
(468)-Light configuration-Lichtfunktion E 24,48
(469)-Light configuration-Lichtfunktion F 24,0
(470)-Light configuration-Dimmwert EF 24,1
(471)-Light configuration-Dimming Direction EF 24,maximize
(472)-Light configuration-Lichtfunktion G 24,0
(473)-Light configuration-Lichtfunktion H 24,211
(474)-Light configuration-Dimmwert GH 24,0
(475)-Light configuration-Dimming Direction GH 24,maximize
(477)-Light configuration-BAP Bitposition 25,00
(478)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,01
(479)-Light configuration-Lichtfunktion A 25,58
(480)-Light configuration-Lichtfunktion B 25,0
(481)-Light configuration-Dimmwert AB 25,120
(482)-Light configuration-Lichtansteuerung HD AB 25,Always
(483)-Light configuration-Lichtfunktion C 25,0
(484)-Light configuration-Lichtfunktion D 25,1
(485)-Light configuration-Dimmwert CD 25,0
(486)-Light configuration-Dimming Direction CD 25,maximize
(487)-Light configuration-Lichtfunktion E 25,0
(488)-Light configuration-Lichtfunktion F 25,0
(489)-Light configuration-Dimmwert EF 25,1
(490)-Light configuration-Dimming Direction EF 25,maximize
(491)-Light configuration-Lichtfunktion G 25,0
(492)-Light configuration-Lichtfunktion H 25,74
(493)-Light configuration-Dimmwert GH 25,0
(494)-Light configuration-Dimming Direction GH 25,maximize
(495)-Light configuration-Lasttyp 26,not active
(496)-Light configuration-BAP Bitposition 26,00
(497)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00
(498)-Light configuration-Lichtfunktion A 26,0
(499)-Light configuration-Lichtfunktion B 26,0
(500)-Light configuration-Dimmwert AB 26,1
(501)-Light configuration-Lichtansteuerung HD AB 26,Always
(502)-Light configuration-Lichtfunktion C 26,0
(503)-Light configuration-Lichtfunktion D 26,78
(504)-Light configuration-Dimmwert CD 26,0
(505)-Light configuration-Dimming Direction CD 26,maximize
(506)-Light configuration-Lichtfunktion E 26,1
(507)-Light configuration-Lichtfunktion F 26,0
(508)-Light configuration-Dimmwert EF 26,126
(509)-Light configuration-Dimming Direction EF 26,minimize
(510)-Light configuration-Lichtfunktion G 26,255
(511)-Light configuration-Lichtfunktion H 26,47
(512)-Light configuration-Dimmwert GH 26,0
(513)-Light configuration-Dimming Direction GH 26,maximize
(515)-Light configuration-BAP Bitposition 27,00
(516)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00
(517)-Light configuration-Lichtfunktion A 27,0
(518)-Light configuration-Lichtfunktion B 27,0
(519)-Light configuration-Dimmwert AB 27,24
(520)-Light configuration-Lichtansteuerung HD AB 27,only_if_closed
(521)-Light configuration-Lichtfunktion C 27,0
(522)-Light configuration-Lichtfunktion D 27,1
(523)-Light configuration-Dimmwert CD 27,0
(524)-Light configuration-Dimming Direction CD 27,maximize
(525)-Light configuration-Lichtfunktion E 27,0
(526)-Light configuration-Lichtfunktion F 27,0
(527)-Light configuration-Dimmwert EF 27,1
(528)-Light configuration-Dimming Direction EF 27,maximize
(529)-Light configuration-Lichtfunktion G 27,0
(530)-Light configuration-Lichtfunktion H 27,109
(531)-Light configuration-Dimmwert GH 27,0
(532)-Light configuration-Dimming Direction GH 27,maximize
(533)-Light configuration-Lasttyp 28,not active
(534)-Light configuration-BAP Bitposition 28,00
(535)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,01
(536)-Light configuration-Lichtfunktion A 28,72
(537)-Light configuration-Lichtfunktion B 28,0
(538)-Light configuration-Dimmwert AB 28,1
(539)-Light configuration-Lichtansteuerung HD AB 28,Always
(540)-Light configuration-Lichtfunktion C 28,0
(541)-Light configuration-Lichtfunktion D 28,0
(542)-Light configuration-Dimmwert CD 28,0
(543)-Light configuration-Dimming Direction CD 28,maximize
(544)-Light configuration-Lichtfunktion E 28,0
(545)-Light configuration-Lichtfunktion F 28,0
(546)-Light configuration-Dimmwert EF 28,112
(547)-Light configuration-Dimming Direction EF 28,maximize
(548)-Light configuration-Lichtfunktion G 28,0
(549)-Light configuration-Lichtfunktion H 28,255
(550)-Light configuration-Dimmwert GH 28,127
(551)-Light configuration-Dimming Direction GH 28,minimize
(553)-Light configuration-BAP Bitposition 29,FF
(554)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,00
(555)-Light configuration-Lichtfunktion A 29,47
(556)-Light configuration-Lichtfunktion B 29,0
(557)-Light configuration-Dimmwert AB 29,8
(558)-Light configuration-Lichtansteuerung HD AB 29,only_if_closed
(559)-Light configuration-Lichtfunktion C 29,0
(560)-Light configuration-Lichtfunktion D 29,139
(561)-Light configuration-Dimmwert CD 29,0
(562)-Light configuration-Dimming Direction CD 29,maximize
(563)-Light configuration-Lichtfunktion E 29,16
(564)-Light configuration-Lichtfunktion F 29,0
(565)-Light configuration-Dimmwert EF 29,32
(566)-Light configuration-Dimming Direction EF 29,maximize
(567)-Light configuration-Lichtfunktion G 29,0
(568)-Light configuration-Lichtfunktion H 29,212
(569)-Light configuration-Dimmwert GH 29,0
(570)-Light configuration-Dimming Direction GH 29,maximize
(572)-Light configuration-BAP Bitposition 30,00
(573)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,FE
(574)-Light configuration-Lichtfunktion A 30,78
(575)-Light configuration-Lichtfunktion B 30,0
(576)-Light configuration-Dimmwert AB 30,78
(577)-Light configuration-Lichtansteuerung HD AB 30,Always
(578)-Light configuration-Lichtfunktion C 30,0
(579)-Light configuration-Lichtfunktion D 30,158
(580)-Light configuration-Dimmwert CD 30,0
(581)-Light configuration-Dimming Direction CD 30,maximize
(582)-Light configuration-Lichtfunktion E 30,0
(583)-Light configuration-Lichtfunktion F 30,0
(584)-Light configuration-Dimmwert EF 30,0
(585)-Light configuration-Dimming Direction EF 30,maximize
(586)-Light configuration-Lichtfunktion G 30,0
(587)-Light configuration-Lichtfunktion H 30,0
(588)-Light configuration-Dimmwert GH 30,0
(589)-Light configuration-Dimming Direction GH 30,maximize
(590)-Light configuration-Lasttyp 31,not active
(591)-Light configuration-BAP Bitposition 31,00
(592)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00
(593)-Light configuration-Lichtfunktion A 31,32
(594)-Light configuration-Lichtfunktion B 31,0
(595)-Light configuration-Dimmwert AB 31,78
(596)-Light configuration-Lichtansteuerung HD AB 31,Always
(597)-Light configuration-Lichtfunktion C 31,0
(598)-Light configuration-Lichtfunktion D 31,177
(599)-Light configuration-Dimmwert CD 31,0
(600)-Light configuration-Dimming Direction CD 31,maximize
(601)-Light configuration-Lichtfunktion E 31,1
(602)-Light configuration-Lichtfunktion F 31,254
(603)-Light configuration-Dimmwert EF 31,0
(604)-Light configuration-Dimming Direction EF 31,maximize
(605)-Light configuration-Lichtfunktion G 31,0
(606)-Light configuration-Lichtfunktion H 31,1
(607)-Light configuration-Dimmwert GH 31,126
(608)-Light configuration-Dimming Direction GH 31,minimize
(610)-Light configuration-BAP Bitposition 32,00
(611)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,01
(612)-Light configuration-Lichtfunktion A 32,24
(613)-Light configuration-Lichtfunktion B 32,1
(614)-Light configuration-Dimmwert AB 32,24
(615)-Light configuration-Lichtansteuerung HD AB 32,Always
(616)-Light configuration-Lichtfunktion C 32,1
(617)-Light configuration-Lichtfunktion D 32,208
(618)-Light configuration-Dimmwert CD 32,0
(619)-Light configuration-Dimming Direction CD 32,maximize
(620)-Light configuration-Lichtfunktion E 32,24
(621)-Light configuration-Lichtfunktion F 32,1
(622)-Light configuration-Dimmwert EF 32,0
(623)-Light configuration-Dimming Direction EF 32,maximize
(624)-Light configuration-Lichtfunktion G 32,0
(625)-Light configuration-Lichtfunktion H 32,32
(626)-Light configuration-Dimmwert GH 32,0
(627)-Light configuration-Dimming Direction GH 32,maximize
(628)-Light configuration-Lasttyp 33,not active
(629)-Light configuration-BAP Bitposition 33,00
(630)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,01
(631)-Light configuration-Lichtfunktion A 33,32
(632)-Light configuration-Lichtfunktion B 33,0
(633)-Light configuration-Dimmwert AB 33,78
(634)-Light configuration-Lichtansteuerung HD AB 33,Always
(635)-Light configuration-Lichtfunktion C 33,0
(636)-Light configuration-Lichtfunktion D 33,215
(637)-Light configuration-Dimmwert CD 33,0
(638)-Light configuration-Dimming Direction CD 33,maximize
(639)-Light configuration-Lichtfunktion E 33,0
(640)-Light configuration-Lichtfunktion F 33,0
(641)-Light configuration-Dimmwert EF 33,96
(642)-Light configuration-Dimming Direction EF 33,minimize
(643)-Light configuration-Lichtfunktion G 33,0
(644)-Light configuration-Lichtfunktion H 33,0
(645)-Light configuration-Dimmwert GH 33,0
(646)-Light configuration-Dimming Direction GH 33,maximize
(647)-Light configuration-Lasttyp 34,not active
(648)-Light configuration-BAP Bitposition 34,00
(649)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,01
(650)-Light configuration-Lichtfunktion A 34,0
(651)-Light configuration-Lichtfunktion B 34,0
(652)-Light configuration-Dimmwert AB 34,0
(653)-Light configuration-Lichtansteuerung HD AB 34,Always
(654)-Light configuration-Lichtfunktion C 34,0
(655)-Light configuration-Lichtfunktion D 34,234
(656)-Light configuration-Dimmwert CD 34,0
(657)-Light configuration-Dimming Direction CD 34,maximize
(658)-Light configuration-Lichtfunktion E 34,208
(659)-Light configuration-Lichtfunktion F 34,0
(660)-Light configuration-Dimmwert EF 34,0
(661)-Light configuration-Dimming Direction EF 34,maximize
(662)-Light configuration-Lichtfunktion G 34,255
(663)-Light configuration-Lichtfunktion H 34,208
(664)-Light configuration-Dimmwert GH 34,0
(665)-Light configuration-Dimming Direction GH 34,maximize
lower turn position,31.49 °
Position during interval mode,31.49 °
(1)-Production mode-Scheinwerferreinigung,not active
(2)-Production mode-Frontwischer deaktivieren,not active
(3)-Production mode-Heckwischer,not active
(4)-Production mode-Interior lighting,not active
(5)-Production mode-Aussenbeleuchtung,not active
(6)-Production mode-Access control,not active
(7)-Production mode-Virtuel_pedal,not active
Read parameter address,FE 00 00
(1)-Rear Window Wiper-Komfortwischen Heck,active
(2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
(3)-Rear Window Wiper-Automatisches Heckwischen,not active
(4)-Rear Window Wiper-Traenenwischen Heck,active
(5)-Rear Window Wiper-Heckwischer Weiterlauf,not active
(6)-Rear Window Wiper-Kein automatisches Abparken,not active
(7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
(8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
(9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
(10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
(11)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
(12)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
(13)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
Roller test bench mode; functional,not active
(1)-Seat fan charac. curve-Level_1_Sitz,25 %
(2)-Seat fan charac. curve-Level_1_Lehne,30 %
(3)-Seat fan charac. curve-Level_2_Sitz,25 %
(4)-Seat fan charac. curve-Level_2_Lehne,30 %
(5)-Seat fan charac. curve-Level_3_Sitz,53 %
(6)-Seat fan charac. curve-Level_3_Lehne,58 %
(7)-Seat fan charac. curve-Level_4_Sitz,53 %
(8)-Seat fan charac. curve-Level_4_Lehne,58 %
(9)-Seat fan charac. curve-Level_5_Sitz,80 %
(10)-Seat fan charac. curve-Level_5_Lehne,85 %
(11)-Seat fan charac. curve-Level_6_Sitz,80 %
(12)-Seat fan charac. curve-Level_6_Lehne,85 %
(1)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,16.00 °C
(2)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.00 °C
(3)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,16.00 °C
(4)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.00 °C
(5)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.00 °C
(6)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C
(7)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.00 °C
(8)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C
(9)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.00 °C
(10)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C
(11)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.00 °C
(12)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C
(13)-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s
(14)-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C
Service position,170.49 °
(1)-static AFS light-bei Rueckwaertsfahrt,both sides
(2)-static AFS light-Vorschrift,ECE R119
(3)-static AFS light-Lower speed threshold,0.00 km/h
(4)-static AFS light-Upper speed threshold,40.00 km/h
(5)-static AFS light-Steering wheel angle; offset,-63.75 °
(6)-static AFS light-Unterer Lenkradwinkel,180 °
(7)-static AFS light-Oberer Lenkradwinkel,120 °
(8)-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
(9)-static AFS light-Maximaltemperatur,100.00 °C
(10)-static AFS light-obere Grenztemperatur,95.00 °C
(11)-static AFS light-untere Grenztemperatur,80.00 °C
Transport mode,active
(1)-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
(2)-Turn signal control-Komfortblinken Blinkzyklen,4
(3)-Turn signal control-Sonderfunktionen,not enabled
(4)-Turn signal control-Signalprioritaet fuer Blinker,MFG
(5)-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
(6)-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
(7)-Turn signal control-Komfortblinken,active
(8)-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %
(9)-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
(10)-Turn signal control-Abbruch Komfortblinken,not active
upper turn position,170.49 °
(1)-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active
(2)-Window heater-Temperaturabhaengige Einschaltzeit FSH,active
(3)-Window heater-FSH Automatik,not active
(4)-Window heater-Heckscheibenheizung Zeitwert,600 s
(5)-Window heater-Running time of heated front window,240 s
(6)-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
(7)-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
(1)-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
(2)-Windshield wiper-SRA Verzoegerungszeit,0 ms
(3)-Windshield wiper-SRA Waschzeit,0 ms
(4)-Windshield wiper-SRA Einweichpausenzeit,0 ms
(5)-Windshield wiper-SRA Nachwaschzeit,0 ms
(6)-Windshield wiper-SRA Pausenzeit,0 ms
(7)-Windshield wiper-SRA bei Waschwassermangel,not active
(8)-Windshield wiper-Frontwischer Referenzlauf,active
(9)-Windshield wiper-Variable Regensensoraktivierung,not active
(10)-Windshield wiper-Wischer stop bei KL15 aus,not active
(11)-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
(12)-Windshield wiper-Regensensor aktivieren,Deactivating
(13)-Windshield wiper-Menuesteuerung Frontwischer,not active
(14)-Windshield wiper-Frontwischer Notlaufprogramm,active
(15)-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
(16)-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
(17)-Windshield wiper-Traenenwischen Front Status,not active
(18)-Windshield wiper-Washer_Tipwiping_Variant,0
(19)-Windshield wiper-Adaptives Nachwischen bei SRA,not active
(20)-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
(21)-Windshield wiper-Tippendes_Frontwaschen,not active
(22)-Windshield wiper-Frontwischer_Abtauposition,not active
(1)-Writing parameter-Parameter address,FE 00 00
(2)-Writing parameter-Value,130
erase_error_table,55 00 00
error_mask,0 bit
Frontwaschfunktion,10
(1)-Innenbeleuchtung Abdimmen-x0,0 ms
(2)-Innenbeleuchtung Abdimmen-X1,200 ms
(3)-Innenbeleuchtung Abdimmen-X2,400 ms
(4)-Innenbeleuchtung Abdimmen-X3,600 ms
(5)-Innenbeleuchtung Abdimmen-X4,800 ms
(6)-Innenbeleuchtung Abdimmen-X5,1000 ms
(7)-Innenbeleuchtung Abdimmen-X6,1200 ms
(8)-Innenbeleuchtung Abdimmen-x7,1400 ms
(9)-Innenbeleuchtung Abdimmen-x8,1600 ms
(10)-Innenbeleuchtung Abdimmen-x9,1800 ms
(11)-Innenbeleuchtung Abdimmen-x10,2000 ms
(12)-Innenbeleuchtung Abdimmen-y0,100.00 %
(13)-Innenbeleuchtung Abdimmen-Y1,72.00 %
(14)-Innenbeleuchtung Abdimmen-Y2,48.00 %
(15)-Innenbeleuchtung Abdimmen-Y3,33.00 %
(16)-Innenbeleuchtung Abdimmen-Y4,18.00 %
(17)-Innenbeleuchtung Abdimmen-Y5,12.00 %
(18)-Innenbeleuchtung Abdimmen-Y6,8.00 %
(19)-Innenbeleuchtung Abdimmen-y7,6.00 %
(20)-Innenbeleuchtung Abdimmen-y8,4.00 %
(21)-Innenbeleuchtung Abdimmen-y9,2.00 %
(22)-Innenbeleuchtung Abdimmen-y10,0.00 %
(1)-Innenbeleuchtung Fotosensor-x0,0
(2)-Innenbeleuchtung Fotosensor-X1,50
(3)-Innenbeleuchtung Fotosensor-X2,100
(4)-Innenbeleuchtung Fotosensor-X3,200
(5)-Innenbeleuchtung Fotosensor-X4,253
(6)-Innenbeleuchtung Fotosensor-X5,0
(7)-Innenbeleuchtung Fotosensor-X6,0
(8)-Innenbeleuchtung Fotosensor-x7,0
(9)-Innenbeleuchtung Fotosensor-x8,0
(10)-Innenbeleuchtung Fotosensor-x9,0
(11)-Innenbeleuchtung Fotosensor-x10,0
(12)-Innenbeleuchtung Fotosensor-y0,0 lx
(13)-Innenbeleuchtung Fotosensor-Y1,50 lx
(14)-Innenbeleuchtung Fotosensor-Y2,100 lx
(15)-Innenbeleuchtung Fotosensor-Y3,200
(16)-Innenbeleuchtung Fotosensor-Y4,500
(17)-Innenbeleuchtung Fotosensor-Y5,0
(18)-Innenbeleuchtung Fotosensor-Y6,0 lx
(19)-Innenbeleuchtung Fotosensor-y7,0 lx
(20)-Innenbeleuchtung Fotosensor-y8,0 lx
(21)-Innenbeleuchtung Fotosensor-y9,0 lx
(22)-Innenbeleuchtung Fotosensor-y10,0 lx
(1)-Innenbeleuchtung Hochdimmen-x0,0 ms
(2)-Innenbeleuchtung Hochdimmen-X1,200 ms
(3)-Innenbeleuchtung Hochdimmen-X2,400 ms
(4)-Innenbeleuchtung Hochdimmen-X3,600 ms
(5)-Innenbeleuchtung Hochdimmen-X4,800 ms
(6)-Innenbeleuchtung Hochdimmen-X5,1000 ms
(7)-Innenbeleuchtung Hochdimmen-X6,1200 ms
(8)-Innenbeleuchtung Hochdimmen-x7,1400 ms
(9)-Innenbeleuchtung Hochdimmen-x8,1600 ms
(10)-Innenbeleuchtung Hochdimmen-x9,1800 ms
(11)-Innenbeleuchtung Hochdimmen-x10,2000 ms
(12)-Innenbeleuchtung Hochdimmen-y0,0.00 %
(13)-Innenbeleuchtung Hochdimmen-Y1,1.00 %
(14)-Innenbeleuchtung Hochdimmen-Y2,3.00 %
(15)-Innenbeleuchtung Hochdimmen-Y3,5.00 %
(16)-Innenbeleuchtung Hochdimmen-Y4,11.00 %
(17)-Innenbeleuchtung Hochdimmen-Y5,22.00 %
(18)-Innenbeleuchtung Hochdimmen-Y6,40.00 %
(19)-Innenbeleuchtung Hochdimmen-y7,80.00 %
(20)-Innenbeleuchtung Hochdimmen-y8,95.00 %
(21)-Innenbeleuchtung Hochdimmen-y9,100.00 %
(22)-Innenbeleuchtung Hochdimmen-y10,100.00 %
(1)-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
(2)-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
(3)-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
(4)-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
(5)-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
(6)-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
(7)-Innenbeleuchtung KL 58xd log Bus-y0,10
(8)-Innenbeleuchtung KL 58xd log Bus-Y1,10
(9)-Innenbeleuchtung KL 58xd log Bus-Y2,100
(10)-Innenbeleuchtung KL 58xd log Bus-Y3,150
(11)-Innenbeleuchtung KL 58xd log Bus-Y4,220
(12)-Innenbeleuchtung KL 58xd log Bus-Y5,253
(1)-Innenbeleuchtung KL 58xd max-x0,0 lx
(2)-Innenbeleuchtung KL 58xd max-X1,8 lx
(3)-Innenbeleuchtung KL 58xd max-X2,200 lx
(4)-Innenbeleuchtung KL 58xd max-X3,300 lx
(5)-Innenbeleuchtung KL 58xd max-X4,500 lx
(6)-Innenbeleuchtung KL 58xd max-y0,16.00
(7)-Innenbeleuchtung KL 58xd max-Y1,16.00
(8)-Innenbeleuchtung KL 58xd max-Y2,100.00
(9)-Innenbeleuchtung KL 58xd max-Y3,100.00
(10)-Innenbeleuchtung KL 58xd max-Y4,100.00
(1)-Innenbeleuchtung KL 58xd min-x0,0 lx
(2)-Innenbeleuchtung KL 58xd min-X1,8 lx
(3)-Innenbeleuchtung KL 58xd min-X2,220 lx
(4)-Innenbeleuchtung KL 58xd min-X3,300 lx
(5)-Innenbeleuchtung KL 58xd min-X4,500 lx
(6)-Innenbeleuchtung KL 58xd min-y0,6.00
(7)-Innenbeleuchtung KL 58xd min-Y1,6.00
(8)-Innenbeleuchtung KL 58xd min-Y2,100.00
(9)-Innenbeleuchtung KL 58xd min-Y3,100.00
(10)-Innenbeleuchtung KL 58xd min-Y4,100.00
(1)-Innenbeleuchtung KL 58xd PWM-x0,0
(2)-Innenbeleuchtung KL 58xd PWM-X1,10
(3)-Innenbeleuchtung KL 58xd PWM-X2,50
(4)-Innenbeleuchtung KL 58xd PWM-X3,100
(5)-Innenbeleuchtung KL 58xd PWM-X4,220
(6)-Innenbeleuchtung KL 58xd PWM-X5,253
(7)-Innenbeleuchtung KL 58xd PWM-y0,2.00 %
(8)-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %
(9)-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %
(10)-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %
(11)-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %
(12)-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
(1)-Innenbeleuchtung KL 58xs max-x0,0 lx
(2)-Innenbeleuchtung KL 58xs max-X1,8 lx
(3)-Innenbeleuchtung KL 58xs max-X2,50 lx
(4)-Innenbeleuchtung KL 58xs max-X3,500 lx
(5)-Innenbeleuchtung KL 58xs max-y0,100.00
(6)-Innenbeleuchtung KL 58xs max-Y1,100.00
(7)-Innenbeleuchtung KL 58xs max-Y2,100.00
(8)-Innenbeleuchtung KL 58xs max-Y3,100.00
(1)-Innenbeleuchtung KL 58xs min-x0,0 lx
(2)-Innenbeleuchtung KL 58xs min-X1,8 lx
(3)-Innenbeleuchtung KL 58xs min-X2,50 lx
(4)-Innenbeleuchtung KL 58xs min-X3,500 lx
(5)-Innenbeleuchtung KL 58xs min-y0,6.00
(6)-Innenbeleuchtung KL 58xs min-Y1,6.00
(7)-Innenbeleuchtung KL 58xs min-Y2,100.00
(8)-Innenbeleuchtung KL 58xs min-Y3,100.00
(1)-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
(2)-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
(3)-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
(4)-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
(5)-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
(6)-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
(1)-Innenbeleuchtung KL 58xt max-x0,0 lx
(2)-Innenbeleuchtung KL 58xt max-X1,8 lx
(3)-Innenbeleuchtung KL 58xt max-X2,50 lx
(4)-Innenbeleuchtung KL 58xt max-X3,500 lx
(5)-Innenbeleuchtung KL 58xt max-y0,100.00
(6)-Innenbeleuchtung KL 58xt max-Y1,100.00
(7)-Innenbeleuchtung KL 58xt max-Y2,100.00
(8)-Innenbeleuchtung KL 58xt max-Y3,100.00
(1)-Innenbeleuchtung KL 58xt min-x0,0 lx
(2)-Innenbeleuchtung KL 58xt min-X1,8 lx
(3)-Innenbeleuchtung KL 58xt min-X2,50 lx
(4)-Innenbeleuchtung KL 58xt min-X3,500 lx
(5)-Innenbeleuchtung KL 58xt min-y0,6.00
(6)-Innenbeleuchtung KL 58xt min-Y1,6.00
(7)-Innenbeleuchtung KL 58xt min-Y2,100.00
(8)-Innenbeleuchtung KL 58xt min-Y3,100.00
(1)-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
(2)-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
(3)-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
(4)-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
(5)-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
(6)-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
(1)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
(2)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms
(3)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms
(4)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms
(5)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms
(6)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
(7)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
(8)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
(9)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00
(10)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
(1)-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
(2)-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
(3)-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
(7)-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
(1)-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37
(3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E
(4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam
(5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell
(6)-Leuchte10SHUTTER LB23-Dimmwert AB 10,127
(7)-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
(8)-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
(9)-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
(10)-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
(11)-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
(12)-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
(13)-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
(14)-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
(15)-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
(16)-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
(17)-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
(18)-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
(19)-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
(1)-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41
(3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F
(4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam
(5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell
(6)-Leuchte11SHUTTER RB22-Dimmwert AB 11,127
(7)-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
(8)-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
(9)-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
(10)-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
(11)-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
(12)-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
(13)-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
(14)-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
(15)-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
(16)-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
(17)-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
(18)-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
(19)-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
(1)-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul
(2)-Leuchte12NL LB45-Lampendefektbitposition 12,38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
(4)-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12,not active
(6)-Leuchte12NL LB45-Dimmwert AB 12,127
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
(8)-Leuchte12NL LB45-Lichtfunktion C 12,not active
(9)-Leuchte12NL LB45-Lichtfunktion D 12,not active
(10)-Leuchte12NL LB45-Dimmwert CD 12,0
(11)-Leuchte12NL LB45-Dimming Direction CD 12,maximize
(12)-Leuchte12NL LB45-Lichtfunktion E 12,not active
(13)-Leuchte12NL LB45-Lichtfunktion F 12,not active
(14)-Leuchte12NL LB45-Dimmwert EF 12,0
(15)-Leuchte12NL LB45-Dimming Direction EF 12,maximize
(16)-Leuchte12NL LB45-Lichtfunktion G 12,not active
(17)-Leuchte12NL LB45-Lichtfunktion H 12,not active
(18)-Leuchte12NL LB45-Dimmwert GH 12,0
(19)-Leuchte12NL LB45-Dimming Direction GH 12,maximize
(1)-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul
(2)-Leuchte13NL RB5-Lampendefektbitposition 13,42
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
(4)-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13,not active
(6)-Leuchte13NL RB5-Dimmwert AB 13,127
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
(8)-Leuchte13NL RB5-Lichtfunktion C 13,not active
(9)-Leuchte13NL RB5-Lichtfunktion D 13,not active
(10)-Leuchte13NL RB5-Dimmwert CD 13,0
(11)-Leuchte13NL RB5-Dimming Direction CD 13,maximize
(12)-Leuchte13NL RB5-Lichtfunktion E 13,not active
(13)-Leuchte13NL RB5-Lichtfunktion F 13,not active
(14)-Leuchte13NL RB5-Dimmwert EF 13,0
(15)-Leuchte13NL RB5-Dimming Direction EF 13,maximize
(16)-Leuchte13NL RB5-Lichtfunktion G 13,not active
(17)-Leuchte13NL RB5-Lichtfunktion H 13,not active
(18)-Leuchte13NL RB5-Dimmwert GH 13,0
(19)-Leuchte13NL RB5-Dimming Direction GH 13,maximize
(1)-Leuchte15AL RB44-Lasttyp 15,not active
(2)-Leuchte15AL RB44-Lampendefektbitposition 15,00
(3)-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
(4)-Leuchte15AL RB44-Lichtfunktion A 15,not active
(5)-Leuchte15AL RB44-Lichtfunktion B 15,not active
(6)-Leuchte15AL RB44-Dimmwert AB 15,0
(7)-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
(8)-Leuchte15AL RB44-Lichtfunktion C 15,not active
(9)-Leuchte15AL RB44-Lichtfunktion D 15,not active
(10)-Leuchte15AL RB44-Dimmwert CD 15,0
(11)-Leuchte15AL RB44-Dimming Direction CD 15,maximize
(12)-Leuchte15AL RB44-Lichtfunktion E 15,not active
(13)-Leuchte15AL RB44-Lichtfunktion F 15,not active
(14)-Leuchte15AL RB44-Dimmwert EF 15,0
(15)-Leuchte15AL RB44-Dimming Direction EF 15,maximize
(16)-Leuchte15AL RB44-Lichtfunktion G 15,not active
(17)-Leuchte15AL RB44-Lichtfunktion H 15,not active
(18)-Leuchte15AL RB44-Dimmwert GH 15,0
(19)-Leuchte15AL RB44-Dimming Direction GH 15,maximize
(1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active
(2)-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00
(3)-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00
(4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active
(5)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0
(7)-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
(8)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
(9)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
(10)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
(11)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
(12)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
(13)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
(14)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
(15)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
(16)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
(17)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
(18)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
(19)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
(1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active
(2)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00
(3)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00
(4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active
(5)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active
(6)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0
(7)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
(8)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
(9)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
(10)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
(11)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
(12)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
(13)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
(14)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
(15)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
(16)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
(17)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
(18)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
(19)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
(1)-Leuchte18BLK HLA60-Lasttyp 18,not active
(2)-Leuchte18BLK HLA60-Lampendefektbitposition 18,00
(3)-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00
(4)-Leuchte18BLK HLA60-Lichtfunktion A 18,not active
(5)-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
(6)-Leuchte18BLK HLA60-Dimmwert AB 18,0
(7)-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
(8)-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
(9)-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
(10)-Leuchte18BLK HLA60-Dimmwert CD 18,0
(11)-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
(12)-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
(13)-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
(14)-Leuchte18BLK HLA60-Dimmwert EF 18,0
(15)-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
(16)-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
(17)-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
(18)-Leuchte18BLK HLA60-Dimmwert GH 18,0
(19)-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
(1)-Leuchte19BLK HRC31-Lasttyp 19,not active
(2)-Leuchte19BLK HRC31-Lampendefektbitposition 19,00
(3)-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00
(4)-Leuchte19BLK HRC31-Lichtfunktion A 19,not active
(5)-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
(6)-Leuchte19BLK HRC31-Dimmwert AB 19,0
(7)-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
(8)-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
(9)-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
(10)-Leuchte19BLK HRC31-Dimmwert CD 19,0
(11)-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
(12)-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
(13)-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
(14)-Leuchte19BLK HRC31-Dimmwert EF 19,0
(15)-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
(16)-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
(17)-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
(18)-Leuchte19BLK HRC31-Dimmwert GH 19,0
(19)-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
(1)-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
(2)-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
(3)-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
(4)-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
(5)-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
(6)-Leuchte1BLK VRB20-Dimmwert AB 1,100
(7)-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
(8)-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
(9)-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 1,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
(13)-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
(14)-Leuchte1BLK VRB20-Dimmwert EF 1,0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
(17)-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
(18)-Leuchte1BLK VRB20-Dimmwert GH 1,0
(19)-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
(1)-Leuchte20BR LA71-Lasttyp 20,14 - kombinierte Blink- Bremsleuchten
(2)-Leuchte20BR LA71-Lampendefektbitposition 20,13
(3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D
(4)-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
(5)-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase
(6)-Leuchte20BR LA71-Dimmwert AB 20,100
(7)-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
(8)-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase
(9)-Leuchte20BR LA71-Lichtfunktion D 20,not active
(10)-Leuchte20BR LA71-Dimmwert CD 20,0
(11)-Leuchte20BR LA71-Dimming Direction CD 20,minimize
(12)-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte20BR LA71-Lichtfunktion F 20,not active
(14)-Leuchte20BR LA71-Dimmwert EF 20,28
(15)-Leuchte20BR LA71-Dimming Direction EF 20,maximize
(16)-Leuchte20BR LA71-Lichtfunktion G 20,not active
(17)-Leuchte20BR LA71-Lichtfunktion H 20,not active
(18)-Leuchte20BR LA71-Dimmwert GH 20,0
(19)-Leuchte20BR LA71-Dimming Direction GH 20,maximize
(1)-Leuchte21BR RC8-Lasttyp 21,14 - kombinierte Blink- Bremsleuchten
(2)-Leuchte21BR RC8-Lampendefektbitposition 21,23
(3)-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E
(4)-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
(5)-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase
(6)-Leuchte21BR RC8-Dimmwert AB 21,100
(7)-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
(8)-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase
(9)-Leuchte21BR RC8-Lichtfunktion D 21,not active
(10)-Leuchte21BR RC8-Dimmwert CD 21,0
(11)-Leuchte21BR RC8-Dimming Direction CD 21,minimize
(12)-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte21BR RC8-Lichtfunktion F 21,not active
(14)-Leuchte21BR RC8-Dimmwert EF 21,28
(15)-Leuchte21BR RC8-Dimming Direction EF 21,maximize
(16)-Leuchte21BR RC8-Lichtfunktion G 21,not active
(17)-Leuchte21BR RC8-Lichtfunktion H 21,not active
(18)-Leuchte21BR RC8-Dimmwert GH 21,0
(19)-Leuchte21BR RC8-Dimming Direction GH 21,maximize
(1)-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
(2)-Leuchte22BR MA57-Lampendefektbitposition 22,29
(3)-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
(4)-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
(5)-Leuchte22BR MA57-Lichtfunktion B 22,not active
(6)-Leuchte22BR MA57-Dimmwert AB 22,100
(7)-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
(8)-Leuchte22BR MA57-Lichtfunktion C 22,not active
(9)-Leuchte22BR MA57-Lichtfunktion D 22,not active
(10)-Leuchte22BR MA57-Dimmwert CD 22,0
(11)-Leuchte22BR MA57-Dimming Direction CD 22,maximize
(12)-Leuchte22BR MA57-Lichtfunktion E 22,not active
(13)-Leuchte22BR MA57-Lichtfunktion F 22,not active
(14)-Leuchte22BR MA57-Dimmwert EF 22,0
(15)-Leuchte22BR MA57-Dimming Direction EF 22,maximize
(16)-Leuchte22BR MA57-Lichtfunktion G 22,not active
(17)-Leuchte22BR MA57-Lichtfunktion H 22,not active
(18)-Leuchte22BR MA57-Dimmwert GH 22,0
(19)-Leuchte22BR MA57-Dimming Direction GH 22,maximize
(1)-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
(3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
(4)-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte23SL HLC10-Lichtfunktion B 23,not active
(6)-Leuchte23SL HLC10-Dimmwert AB 23,28
(7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
(8)-Leuchte23SL HLC10-Lichtfunktion C 23,not active
(9)-Leuchte23SL HLC10-Lichtfunktion D 23,not active
(10)-Leuchte23SL HLC10-Dimmwert CD 23,0
(11)-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
(12)-Leuchte23SL HLC10-Lichtfunktion E 23,not active
(13)-Leuchte23SL HLC10-Lichtfunktion F 23,not active
(14)-Leuchte23SL HLC10-Dimmwert EF 23,0
(15)-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
(16)-Leuchte23SL HLC10-Lichtfunktion G 23,not active
(17)-Leuchte23SL HLC10-Lichtfunktion H 23,not active
(18)-Leuchte23SL HLC10-Dimmwert GH 23,0
(19)-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
(1)-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
(3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
(4)-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte24SL HRA65-Lichtfunktion B 24,not active
(6)-Leuchte24SL HRA65-Dimmwert AB 24,28
(7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
(8)-Leuchte24SL HRA65-Lichtfunktion C 24,not active
(9)-Leuchte24SL HRA65-Lichtfunktion D 24,not active
(10)-Leuchte24SL HRA65-Dimmwert CD 24,0
(11)-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
(12)-Leuchte24SL HRA65-Lichtfunktion E 24,not active
(13)-Leuchte24SL HRA65-Lichtfunktion F 24,not active
(14)-Leuchte24SL HRA65-Dimmwert EF 24,0
(15)-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
(16)-Leuchte24SL HRA65-Lichtfunktion G 24,not active
(17)-Leuchte24SL HRA65-Lichtfunktion H 24,not active
(18)-Leuchte24SL HRA65-Dimmwert GH 24,0
(19)-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
(1)-Leuchte25KZL HA59-Lasttyp 25,18 - 2* 5W
(2)-Leuchte25KZL HA59-Lampendefektbitposition 25,28
(3)-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
(4)-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte25KZL HA59-Lichtfunktion B 25,not active
(6)-Leuchte25KZL HA59-Dimmwert AB 25,100
(7)-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
(8)-Leuchte25KZL HA59-Lichtfunktion C 25,not active
(9)-Leuchte25KZL HA59-Lichtfunktion D 25,not active
(10)-Leuchte25KZL HA59-Dimmwert CD 25,0
(11)-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
(12)-Leuchte25KZL HA59-Lichtfunktion E 25,not active
(13)-Leuchte25KZL HA59-Lichtfunktion F 25,not active
(14)-Leuchte25KZL HA59-Dimmwert EF 25,0
(15)-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
(16)-Leuchte25KZL HA59-Lichtfunktion G 25,not active
(17)-Leuchte25KZL HA59-Lichtfunktion H 25,not active
(18)-Leuchte25KZL HA59-Dimmwert GH 25,0
(19)-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
(1)-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte26NSL LA72-Lampendefektbitposition 26,00
(3)-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,47
(4)-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte26NSL LA72-Lichtfunktion B 26,not active
(6)-Leuchte26NSL LA72-Dimmwert AB 26,127
(7)-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
(8)-Leuchte26NSL LA72-Lichtfunktion C 26,not active
(9)-Leuchte26NSL LA72-Lichtfunktion D 26,not active
(10)-Leuchte26NSL LA72-Dimmwert CD 26,0
(11)-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
(12)-Leuchte26NSL LA72-Lichtfunktion E 26,not active
(13)-Leuchte26NSL LA72-Lichtfunktion F 26,not active
(14)-Leuchte26NSL LA72-Dimmwert EF 26,0
(15)-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
(16)-Leuchte26NSL LA72-Lichtfunktion G 26,not active
(17)-Leuchte26NSL LA72-Lichtfunktion H 26,not active
(18)-Leuchte26NSL LA72-Dimmwert GH 26,0
(19)-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
(1)-Leuchte27NSL RC6-Lasttyp 27,not active
(2)-Leuchte27NSL RC6-Lampendefektbitposition 27,00
(3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00
(4)-Leuchte27NSL RC6-Lichtfunktion A 27,not active
(5)-Leuchte27NSL RC6-Lichtfunktion B 27,not active
(6)-Leuchte27NSL RC6-Dimmwert AB 27,0
(7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
(8)-Leuchte27NSL RC6-Lichtfunktion C 27,not active
(9)-Leuchte27NSL RC6-Lichtfunktion D 27,not active
(10)-Leuchte27NSL RC6-Dimmwert CD 27,0
(11)-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
(12)-Leuchte27NSL RC6-Lichtfunktion E 27,not active
(13)-Leuchte27NSL RC6-Lichtfunktion F 27,not active
(14)-Leuchte27NSL RC6-Dimmwert EF 27,0
(15)-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
(16)-Leuchte27NSL RC6-Lichtfunktion G 27,not active
(17)-Leuchte27NSL RC6-Lichtfunktion H 27,not active
(18)-Leuchte27NSL RC6-Dimmwert GH 27,0
(19)-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
(1)-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
(3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
(4)-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
(5)-Leuchte28RFL LC11-Lichtfunktion B 28,not active
(6)-Leuchte28RFL LC11-Dimmwert AB 28,100
(7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
(8)-Leuchte28RFL LC11-Lichtfunktion C 28,not active
(9)-Leuchte28RFL LC11-Lichtfunktion D 28,not active
(10)-Leuchte28RFL LC11-Dimmwert CD 28,0
(11)-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
(12)-Leuchte28RFL LC11-Lichtfunktion E 28,not active
(13)-Leuchte28RFL LC11-Lichtfunktion F 28,not active
(14)-Leuchte28RFL LC11-Dimmwert EF 28,0
(15)-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
(16)-Leuchte28RFL LC11-Lichtfunktion G 28,not active
(17)-Leuchte28RFL LC11-Lichtfunktion H 28,not active
(18)-Leuchte28RFL LC11-Dimmwert GH 28,0
(19)-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
(1)-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
(3)-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
(4)-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
(5)-Leuchte29RFL RA64-Lichtfunktion B 29,not active
(6)-Leuchte29RFL RA64-Dimmwert AB 29,100
(7)-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
(8)-Leuchte29RFL RA64-Lichtfunktion C 29,not active
(9)-Leuchte29RFL RA64-Lichtfunktion D 29,not active
(10)-Leuchte29RFL RA64-Dimmwert CD 29,0
(11)-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
(12)-Leuchte29RFL RA64-Lichtfunktion E 29,not active
(13)-Leuchte29RFL RA64-Lichtfunktion F 29,not active
(14)-Leuchte29RFL RA64-Dimmwert EF 29,0
(15)-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
(16)-Leuchte29RFL RA64-Lichtfunktion G 29,not active
(17)-Leuchte29RFL RA64-Lichtfunktion H 29,not active
(18)-Leuchte29RFL RA64-Dimmwert GH 29,0
(19)-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
(1)-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte2SL VLB10-Lampendefektbitposition 2,48
(3)-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A
(4)-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights
(5)-Leuchte2SL VLB10-Lichtfunktion B 2,not active
(6)-Leuchte2SL VLB10-Dimmwert AB 2,100
(7)-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
(8)-Leuchte2SL VLB10-Lichtfunktion C 2,not active
(9)-Leuchte2SL VLB10-Lichtfunktion D 2,not active
(10)-Leuchte2SL VLB10-Dimmwert CD 2,0
(11)-Leuchte2SL VLB10-Dimming Direction CD 2,minimize
(12)-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(14)-Leuchte2SL VLB10-Dimmwert EF 2,26
(15)-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
(16)-Leuchte2SL VLB10-Lichtfunktion G 2,not active
(17)-Leuchte2SL VLB10-Lichtfunktion H 2,not active
(18)-Leuchte2SL VLB10-Dimmwert GH 2,0
(19)-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
(1)-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung
(2)-Leuchte30FR LC72-Lampendefektbitposition 30,00
(3)-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02
(4)-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light
(5)-Leuchte30FR LC72-Lichtfunktion B 30,not active
(6)-Leuchte30FR LC72-Dimmwert AB 30,89
(7)-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
(8)-Leuchte30FR LC72-Lichtfunktion C 30,not active
(9)-Leuchte30FR LC72-Lichtfunktion D 30,not active
(10)-Leuchte30FR LC72-Dimmwert CD 30,0
(11)-Leuchte30FR LC72-Dimming Direction CD 30,maximize
(12)-Leuchte30FR LC72-Lichtfunktion E 30,not active
(13)-Leuchte30FR LC72-Lichtfunktion F 30,not active
(14)-Leuchte30FR LC72-Dimmwert EF 30,0
(15)-Leuchte30FR LC72-Dimming Direction EF 30,maximize
(16)-Leuchte30FR LC72-Lichtfunktion G 30,not active
(17)-Leuchte30FR LC72-Lichtfunktion H 30,not active
(18)-Leuchte30FR LC72-Dimmwert GH 30,0
(19)-Leuchte30FR LC72-Dimming Direction GH 30,maximize
(1)-Leuchte31AMBL 1C61-Lasttyp 31,not active
(2)-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
(3)-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00
(4)-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active
(5)-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
(6)-Leuchte31AMBL 1C61-Dimmwert AB 31,0
(7)-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
(8)-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
(9)-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
(10)-Leuchte31AMBL 1C61-Dimmwert CD 31,0
(11)-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
(12)-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
(13)-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
(14)-Leuchte31AMBL 1C61-Dimmwert EF 31,0
(15)-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
(16)-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
(17)-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
(18)-Leuchte31AMBL 1C61-Dimmwert GH 31,0
(19)-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
(1)-Leuchte32AMBL 2C35-Lasttyp 32,not active
(2)-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
(3)-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00
(4)-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active
(5)-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
(6)-Leuchte32AMBL 2C35-Dimmwert AB 32,0
(7)-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
(8)-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
(9)-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
(10)-Leuchte32AMBL 2C35-Dimmwert CD 32,0
(11)-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
(12)-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
(13)-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
(14)-Leuchte32AMBL 2C35-Dimmwert EF 32,0
(15)-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
(16)-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
(17)-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
(18)-Leuchte32AMBL 2C35-Dimmwert GH 32,0
(19)-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
(1)-Leuchte33AMBL 3C36-Lasttyp 33,not active
(2)-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
(3)-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00
(4)-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active
(5)-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
(6)-Leuchte33AMBL 3C36-Dimmwert AB 33,0
(7)-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
(8)-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
(9)-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
(10)-Leuchte33AMBL 3C36-Dimmwert CD 33,0
(11)-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
(12)-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
(13)-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
(14)-Leuchte33AMBL 3C36-Dimmwert EF 33,0
(15)-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
(16)-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
(17)-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
(18)-Leuchte33AMBL 3C36-Dimmwert GH 33,0
(19)-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
(1)-Leuchte34AMBL 4C37-Lasttyp 34,not active
(2)-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
(3)-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00
(4)-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active
(5)-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
(6)-Leuchte34AMBL 4C37-Dimmwert AB 34,0
(7)-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
(8)-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
(9)-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
(10)-Leuchte34AMBL 4C37-Dimmwert CD 34,0
(11)-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
(12)-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
(13)-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
(14)-Leuchte34AMBL 4C37-Dimmwert EF 34,0
(15)-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
(16)-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
(17)-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
(18)-Leuchte34AMBL 4C37-Dimmwert GH 34,0
(19)-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
(1)-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
(3)-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C
(4)-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights
(5)-Leuchte3SL VRB21-Lichtfunktion B 3,not active
(6)-Leuchte3SL VRB21-Dimmwert AB 3,100
(7)-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
(8)-Leuchte3SL VRB21-Lichtfunktion C 3,not active
(9)-Leuchte3SL VRB21-Lichtfunktion D 3,not active
(10)-Leuchte3SL VRB21-Dimmwert CD 3,0
(11)-Leuchte3SL VRB21-Dimming Direction CD 3,minimize
(12)-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right
(14)-Leuchte3SL VRB21-Dimmwert EF 3,26
(15)-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3,not active
(17)-Leuchte3SL VRB21-Lichtfunktion H 3,not active
(18)-Leuchte3SL VRB21-Dimmwert GH 3,0
(19)-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
(1)-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
(3)-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49
(4)-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights
(5)-Leuchte4TFL LB4-Lichtfunktion B 4,not active
(6)-Leuchte4TFL LB4-Dimmwert AB 4,127
(7)-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
(8)-Leuchte4TFL LB4-Lichtfunktion C 4,not active
(9)-Leuchte4TFL LB4-Lichtfunktion D 4,not active
(10)-Leuchte4TFL LB4-Dimmwert CD 4,0
(11)-Leuchte4TFL LB4-Dimming Direction CD 4,minimize
(12)-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(14)-Leuchte4TFL LB4-Dimmwert EF 4,127
(15)-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
(16)-Leuchte4TFL LB4-Lichtfunktion G 4,not active
(17)-Leuchte4TFL LB4-Lichtfunktion H 4,not active
(18)-Leuchte4TFL LB4-Dimmwert GH 4,0
(19)-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
(1)-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
(3)-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B
(4)-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights
(5)-Leuchte5 TFL RB32-Lichtfunktion B 5,not active
(6)-Leuchte5 TFL RB32-Dimmwert AB 5,127
(7)-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5,not active
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
(10)-Leuchte5 TFL RB32-Dimmwert CD 5,0
(11)-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize
(12)-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right
(14)-Leuchte5 TFL RB32-Dimmwert EF 5,127
(15)-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
(16)-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
(17)-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
(18)-Leuchte5 TFL RB32-Dimmwert GH 5,0
(19)-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
(1)-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht
(2)-Leuchte6ABL LC5-Lampendefektbitposition 6,36
(3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
(4)-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
(5)-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6,127
(7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
(8)-Leuchte6ABL LC5-Lichtfunktion C 6,not active
(9)-Leuchte6ABL LC5-Lichtfunktion D 6,not active
(10)-Leuchte6ABL LC5-Dimmwert CD 6,0
(11)-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
(12)-Leuchte6ABL LC5-Lichtfunktion E 6,not active
(13)-Leuchte6ABL LC5-Lichtfunktion F 6,not active
(14)-Leuchte6ABL LC5-Dimmwert EF 6,0
(15)-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
(16)-Leuchte6ABL LC5-Lichtfunktion G 6,not active
(17)-Leuchte6ABL LC5-Lichtfunktion H 6,not active
(18)-Leuchte6ABL LC5-Dimmwert GH 6,0
(19)-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
(1)-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht
(2)-Leuchte7ABL RB1-Lampendefektbitposition 7,40
(3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
(4)-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
(5)-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7,127
(7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
(8)-Leuchte7ABL RB1-Lichtfunktion C 7,not active
(9)-Leuchte7ABL RB1-Lichtfunktion D 7,not active
(10)-Leuchte7ABL RB1-Dimmwert CD 7,0
(11)-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
(12)-Leuchte7ABL RB1-Lichtfunktion E 7,not active
(13)-Leuchte7ABL RB1-Lichtfunktion F 7,not active
(14)-Leuchte7ABL RB1-Dimmwert EF 7,0
(15)-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
(16)-Leuchte7ABL RB1-Lichtfunktion G 7,not active
(17)-Leuchte7ABL RB1-Lichtfunktion H 7,not active
(18)-Leuchte7ABL RB1-Dimmwert GH 7,0
(19)-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
(1)-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung
(2)-Leuchte8FL LB39-Lampendefektbitposition 8,35
(3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26
(4)-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte8FL LB39-Dimmwert AB 8,127
(7)-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
(8)-Leuchte8FL LB39-Lichtfunktion C 8,not active
(9)-Leuchte8FL LB39-Lichtfunktion D 8,not active
(10)-Leuchte8FL LB39-Dimmwert CD 8,0
(11)-Leuchte8FL LB39-Dimming Direction CD 8,maximize
(12)-Leuchte8FL LB39-Lichtfunktion E 8,not active
(13)-Leuchte8FL LB39-Lichtfunktion F 8,not active
(14)-Leuchte8FL LB39-Dimmwert EF 8,0
(15)-Leuchte8FL LB39-Dimming Direction EF 8,maximize
(16)-Leuchte8FL LB39-Lichtfunktion G 8,not active
(17)-Leuchte8FL LB39-Lichtfunktion H 8,not active
(18)-Leuchte8FL LB39-Dimmwert GH 8,0
(19)-Leuchte8FL LB39-Dimming Direction GH 8,maximize
(1)-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung
(2)-Leuchte9FL RB2-Lampendefektbitposition 9,3F
(3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27
(4)-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right
(6)-Leuchte9FL RB2-Dimmwert AB 9,127
(7)-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
(8)-Leuchte9FL RB2-Lichtfunktion C 9,not active
(9)-Leuchte9FL RB2-Lichtfunktion D 9,not active
(10)-Leuchte9FL RB2-Dimmwert CD 9,0
(11)-Leuchte9FL RB2-Dimming Direction CD 9,maximize
(12)-Leuchte9FL RB2-Lichtfunktion E 9,not active
(13)-Leuchte9FL RB2-Lichtfunktion F 9,not active
(14)-Leuchte9FL RB2-Dimmwert EF 9,0
(15)-Leuchte9FL RB2-Dimming Direction EF 9,maximize
(16)-Leuchte9FL RB2-Lichtfunktion G 9,not active
(17)-Leuchte9FL RB2-Lichtfunktion H 9,not active
(18)-Leuchte9FL RB2-Dimmwert GH 9,0
(19)-Leuchte9FL RB2-Dimming Direction GH 9,maximize
(1)-Leuchten14AL LB6-Lasttyp 14,not active
(2)-Leuchten14AL LB6-Lampendefektbitposition 14,00
(3)-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
(4)-Leuchten14AL LB6-Lichtfunktion A 14,not active
(5)-Leuchten14AL LB6-Lichtfunktion B 14,not active
(6)-Leuchten14AL LB6-Dimmwert AB 14,0
(7)-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
(8)-Leuchten14AL LB6-Lichtfunktion C 14,not active
(9)-Leuchten14AL LB6-Lichtfunktion D 14,not active
(10)-Leuchten14AL LB6-Dimmwert CD 14,0
(11)-Leuchten14AL LB6-Dimming Direction CD 14,maximize
(12)-Leuchten14AL LB6-Lichtfunktion E 14,not active
(13)-Leuchten14AL LB6-Lichtfunktion F 14,not active
(14)-Leuchten14AL LB6-Dimmwert EF 14,0
(15)-Leuchten14AL LB6-Dimming Direction EF 14,maximize
(16)-Leuchten14AL LB6-Lichtfunktion G 14,not active
(17)-Leuchten14AL LB6-Lichtfunktion H 14,not active
(18)-Leuchten14AL LB6-Dimmwert GH 14,0
(19)-Leuchten14AL LB6-Dimming Direction GH 14,maximize
(1)-LuB Lichtrouter Kennlinie 1-x0,0.00 %
(2)-LuB Lichtrouter Kennlinie 1-X1,5.00 %
(3)-LuB Lichtrouter Kennlinie 1-X2,50.00 %
(4)-LuB Lichtrouter Kennlinie 1-X3,75.00 %
(5)-LuB Lichtrouter Kennlinie 1-X4,110.00
(6)-LuB Lichtrouter Kennlinie 1-X5,126.50
(7)-LuB Lichtrouter Kennlinie 1-y0,0.00 %
(8)-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
(9)-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
(10)-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
(11)-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
(12)-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
(1)-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,not active
(2)-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active
RLS_close_glazing,2.00 s
(1)-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
(2)-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
(3)-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s
(4)-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
(1)-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12
(2)-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
(3)-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
(4)-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s
RLS_LIN_Communication,4 s
(1)-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
(2)-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
RLS_tunel_gateway_recognize,5 s
RLS_Washer_Front,15 s
RLS_wiper_position_parking,15 s
(1)-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
(2)-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
(3)-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
(4)-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
(5)-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
(6)-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
(7)-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
(8)-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
(9)-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
(10)-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
(1)-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40
(2)-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60
(3)-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30
... then I update the firmware to run a map with 16.8.0.3:
;SW:5Q0-937-087-K   HW:5Q0-937-087-K ---  Cent. Elect.
;Component:BCM PQ37BOSCH 026 0097, Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc,012003,EV_BCMBOSCH_VW37.rod
;Monday,22,August,2016,08:53:42:53578
;VCDS Version: Release 16.8.0 (x64)  Data version: 20160803 DS255
;VCID: 43ABB579CA44925AFD-8016
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active
IDE00001-ENG99061-Production mode-Access control,not active
IDE00002-Transport mode,active
IDE00820-Activating and deactivating all development messages,not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active
IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition,not active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms
IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen,not active
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
IDE01550-Service position,170.49 °
IDE02152-Characteristics in production mode,0 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
IDE02332-Deactivate production mode,0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,not active
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
IDE04923-ENG115774-Turn signal control-Komfortblinken,active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,4
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,not active
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik,not active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
IDE05142-ENG116621-Access control-automatisches Entriegeln,active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
IDE05142-ENG116706-Access control-Autounlock NAR,active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active
IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern,not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung,not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion,not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
IDE05142-ENG115755-Access control-Notschließfunktion,active
IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung,not active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always
IDE05142-ENG115758-Access control-Valet Parking,not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
IDE05143-MAS02985-Writing parameter-Value,130
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
IDE05144-Read parameter address,FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,00
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,00
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,00
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,00
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,00
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,00
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,00
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,00
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,00
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,00
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,00
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,00
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,FF
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,00
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,30
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,minimize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,minimize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,minimize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,minimize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,minimize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,minimize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,minimize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,minimize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,minimize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,minimize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,minimize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,minimize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,1
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,75
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,104
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,125
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,32
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,47
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,127
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,56
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,1
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,0
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,48
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,0
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,2
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,56
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,1
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,88
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,1
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,72
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,78
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,78
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,24
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,78
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,49
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,126
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,127
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,127
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,112
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,113
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,32
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,113
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,72
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,47
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,49
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,26
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,1
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,32
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,48
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,32
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,82
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,1
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,126
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,1
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,112
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,112
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,26
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,32
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,49
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,1
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,127
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,114
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,44
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,FE
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,00
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,08
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,FE
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,72
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,01
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,00
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,FE
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,00
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,00
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,01
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,01
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,01
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,00
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,FE
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,01
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,01
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,01
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,00
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,34
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten
IDE05145-ENG116100-Light configuration-Lasttyp 12,not active
IDE05145-ENG116119-Light configuration-Lasttyp 13,2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active
IDE05145-ENG116214-Light configuration-Lasttyp 18,not active
IDE05145-ENG116233-Light configuration-Lasttyp 19,not active
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20,not active
IDE05145-ENG116271-Light configuration-Lasttyp 21,5 - LED Abblendlicht
IDE05145-ENG116290-Light configuration-Lasttyp 22,not active
IDE05145-ENG116328-Light configuration-Lasttyp 24,not active
IDE05145-ENG116366-Light configuration-Lasttyp 26,not active
IDE05145-ENG116404-Light configuration-Lasttyp 28,not active
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8,not active
IDE05145-ENG116043-Light configuration-Lasttyp 9,44 - LED Fußraum- oder -Innenleuchte
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,only_if_closed
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,only_if_closed
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,only_if_closed
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,only_if_closed
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,only_if_closed
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,only_if_closed
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,only_if_closed
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,254
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,8
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,227
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,1
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,32
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,32
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,128
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,241
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,1
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,112
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,1
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,136
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,0
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,1
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,128
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,1
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,11
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,0
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,72
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,47
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,78
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,112
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,248
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,112
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,112
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,52
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,114
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,1
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,51
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,35
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,255
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,254
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,1
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,0
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,0
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,255
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,16
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,241
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,96
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,4
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,32
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,255
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,96
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,233
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,128
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,176
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,128
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,135
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,1
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,78
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,207
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,166
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,168
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,169
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,96
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,171
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,172
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,255
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,16
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,117
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,47
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,80
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,241
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,1
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,131
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,212
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,8
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,212
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,156
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,1
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,234
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,128
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,1
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,204
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,16
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,8
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,152
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,96
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,8
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,8
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,131
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,16
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,254
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,9
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,254
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,1
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,1
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,254
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,10
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,254
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,255
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,255
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,51
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,7
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,230
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,1
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,13
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,136
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,255
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,1
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,16
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,241
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,109
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,96
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,211
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,128
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,47
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,48
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,255
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,212
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,1
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,112
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,96
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,44
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,16.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,16.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.00 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.00 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %
IDE06425-Roller test bench mode: functional,not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
IDE07356-Position during interval mode,31.49 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung,not active
IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung,not active
IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x1 Stunden
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min
IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit,0 s
IDE08542-IDE02021-Access control 2-Comfort closing,active
IDE08542-IDE02022-Access control 2-Comfort opening,active
IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,not active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active
IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,not active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,0
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,0
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,0
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,0
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,0
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,0
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,0
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,0
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,0
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active
IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI,not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed
IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %
IDE10298-Alternating park position 1,7.49 °
IDE10299-Alternating park position 2,29.49 °
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement,not active
MAS05055-lower turn position,31.49 °
MAS05056-upper turn position,170.49 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1,0 s
MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3,0.000 ms
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active
ENG122934-erase_error_table,55 00 00
ENG122933-error_mask,0 bit
ENG117283-Frontwaschfunktion,10
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
ENG99457-ENG117394-Head area heater-blower_speed,0
ENG99457-ENG98971-Head area heater-Temperature,-3
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,28
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,14 - kombinierte Blink- Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,28
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,14 - kombinierte Blink- Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,18 - 2* 5W
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,47
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,0
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,0
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,35
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3F
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,not active
ENG122927-RLS_close_glazing,2.00 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s
ENG122929-RLS_LIN_Communication,4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
ENG122930-RLS_tunel_gateway_recognize,5 s
ENG122935-RLS_Washer_Front,15 s
ENG122926-RLS_wiper_position_parking,15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30
Elapsed Time: 03:58
Looks like 16.8 showed two extra lines compared to 15.7. I haven't gone through all of them to see exactly what though.
Andy
Sector 7G
HC424490
Since the customer reported these channels missing in 16.8.0.3:
Monday,22,August,2016,08:50:44:53578
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: 3VW5T7AU6FM007769   License Plate: UC-1574
UDS Adaptation Channel: (2)-Turn signal control-Komfortblinken Blinkzyklen
Stored value 4
UDS Adaptation Channel: (24)-Access control 2-Funk Spiegelanklappung Modus
Stored value by convenience operation via remote control key
versus:
Monday,22,August,2016,08:52:54:53578
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: 3VW5T7AU6FM007769   License Plate: 16804-UC
UDS Adaptation Channel: IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen
Stored value 4
UDS Adaptation Channel: IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus
Andy
Sector 7G
HC424490
Adp map of 09 using old slow EEPC with W10-64 and HN-USB:
;SW:5Q0-937-087-K   HW:5Q0-937-087-K ---  Cent. Elect.
;Component:BCM PQ37BOSCH 026 0097, Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc,012003,EV_BCMBOSCH_VW37.rod
;Tuesday,23,August,2016,07:25:16:58389
;VCDS Version: Release 16.8.0 (x64)  Data version: 20160803 DS255
;VCID: 43C9CC90CA71CD5AFD-8016
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active
IDE00001-ENG99061-Production mode-Access control,not active
IDE00002-Transport mode,active
IDE00820-Activating and deactivating all development messages,not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active
IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition,not active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms
IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen,not active
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
IDE01550-Service position,170.49 °
IDE02152-Characteristics in production mode,0 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
IDE02332-Deactivate production mode,0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,not active
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
IDE04923-ENG115774-Turn signal control-Komfortblinken,active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,4
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,not active
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik,not active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
IDE05142-ENG116621-Access control-automatisches Entriegeln,active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
IDE05142-ENG116706-Access control-Autounlock NAR,active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active
IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern,not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung,not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion,not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
IDE05142-ENG115755-Access control-Notschließfunktion,active
IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung,not active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always
IDE05142-ENG115758-Access control-Valet Parking,not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
IDE05143-MAS02985-Writing parameter-Value,130
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
IDE05144-Read parameter address,FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,00
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,00
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,00
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,00
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,00
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,00
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,00
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,00
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,00
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,00
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,00
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,FF
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,FB
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,FF
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,00
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,30
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,minimize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,minimize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,minimize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,minimize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,minimize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,minimize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,minimize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,minimize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,minimize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,minimize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,minimize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,minimize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,minimize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,minimize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,minimize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,minimize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,16
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,71
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,0
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,48
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,57
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,5
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,52
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,69
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,1
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,0
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,96
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,96
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,2
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,104
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,69
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,1
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,57
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,64
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,59
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,52
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,28
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,74
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,4
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,40
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,49
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,123
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,1
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,123
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,123
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,113
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,45
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,112
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,64
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,49
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,118
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,26
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,1
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,16
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,118
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,82
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,1
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,126
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,112
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,64
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,14
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,26
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,16
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,120
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,18
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,19
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,6
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,49
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,112
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,123
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,123
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,1
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,1
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,127
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,1
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,123
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,44
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,FB
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,00
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,FF
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,00
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,00
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,00
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,00
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,01
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,FB
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,FB
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,00
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,34
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active
IDE05145-ENG116100-Light configuration-Lasttyp 12,not active
IDE05145-ENG116119-Light configuration-Lasttyp 13,not active
IDE05145-ENG116176-Light configuration-Lasttyp 16,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG116195-Light configuration-Lasttyp 17,not active
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20,not active
IDE05145-ENG116271-Light configuration-Lasttyp 21,5 - LED Abblendlicht
IDE05145-ENG116290-Light configuration-Lasttyp 22,not active
IDE05145-ENG116328-Light configuration-Lasttyp 24,not active
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30,not active
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8,not active
IDE05145-ENG116043-Light configuration-Lasttyp 9,44 - LED Fußraum- oder -Innenleuchte
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,only_if_closed
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,only_if_closed
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,only_if_closed
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,only_if_closed
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,only_if_closed
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,only_if_closed
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,only_if_closed
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,only_if_closed
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,122
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,200
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,0
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,16
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,118
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,16
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,216
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,255
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,240
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,0
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,241
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,1
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,80
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,1
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,11
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,0
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,72
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,207
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,0
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,16
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,134
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,254
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,0
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,52
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,12
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,251
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,255
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,251
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,1
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,251
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,251
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,255
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,51
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,251
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,251
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,121
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,251
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,251
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,251
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,1
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,121
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,251
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,251
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,1
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,1
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,1
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,1
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,0
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,0
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,251
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,202
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,240
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,72
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,207
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,240
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,224
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,208
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,135
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,1
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,165
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,234
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,192
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,144
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,192
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,234
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,200
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,228
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,75
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,124
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,80
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,241
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,207
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,1
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,240
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,8
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,31
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,1
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,234
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,208
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,200
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,78
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,8
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,78
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,152
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,199
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,32
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,8
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,8
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,1
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,251
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,251
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,251
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,251
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,9
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,251
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,1
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,251
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,1
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,251
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,10
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,35
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,255
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,1
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,51
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,251
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,56
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,1
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,21
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,240
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,241
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,16
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,109
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,144
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,211
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,255
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,255
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,78
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,152
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,144
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,19
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,44
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,75
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,16.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,16.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.00 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.00 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %
IDE06425-Roller test bench mode: functional,not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
IDE07356-Position during interval mode,31.49 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung,not active
IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung,not active
IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x1 Stunden
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min
IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit,0 s
IDE08542-IDE02021-Access control 2-Comfort closing,active
IDE08542-IDE02022-Access control 2-Comfort opening,active
IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,not active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active
IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,not active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,0
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,0
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,0
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,0
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,0
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,0
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,0
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,0
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,0
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active
IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI,not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed
IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %
IDE10298-Alternating park position 1,7.49 °
IDE10299-Alternating park position 2,29.49 °
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement,not active
MAS05055-lower turn position,31.49 °
MAS05056-upper turn position,170.49 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1,0 s
MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3,0.000 ms
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active
ENG122934-erase_error_table,55 00 00
ENG122933-error_mask,0 bit
ENG117283-Frontwaschfunktion,10
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
ENG99457-ENG117394-Head area heater-blower_speed,0
ENG99457-ENG98971-Head area heater-Temperature,-3
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,28
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,14 - kombinierte Blink- Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,28
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,14 - kombinierte Blink- Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,18 - 2* 5W
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,47
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,0
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,0
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,35
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3F
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,not active
ENG122927-RLS_close_glazing,2.00 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s
ENG122929-RLS_LIN_Communication,4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
ENG122930-RLS_tunel_gateway_recognize,5 s
ENG122935-RLS_Washer_Front,15 s
ENG122926-RLS_wiper_position_parking,15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30
Elapsed Time: 03:53
Andy
Sector 7G
HC424490
So slow has these that fast does not have:
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active
IDE05145-ENG116442-Light configuration-Lasttyp 30,not active
Fast has these that slow does not have:
IDE05145-ENG116233-Light configuration-Lasttyp 19,not active
IDE05145-ENG116366-Light configuration-Lasttyp 26,not active
IDE05145-ENG116404-Light configuration-Lasttyp 28,not active
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active
Andy
Sector 7G
HC424490
16.8.0.5 seems to have "everything":
;SW:5Q0-937-087-K   HW:5Q0-937-087-K ---  Cent. Elect.
;Component:BCM PQ37BOSCH 026 0097, Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc,012003,EV_BCMBOSCH_VW37.rod
;Tuesday,30,August,2016,16:45:50:58389
;VCDS Version: Test 16.8.0 (x64)  Data version: 20160803 DS255
;VCID: 43C9CC90CA71CD5AFB-8016
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active
IDE00001-ENG99061-Production mode-Access control,not active
IDE00002-Transport mode,active
IDE00820-Activating and deactivating all development messages,not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active
IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition,not active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms
IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen,not active
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
IDE01550-Service position,170.49 °
IDE02152-Characteristics in production mode,0 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
IDE02332-Deactivate production mode,0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,not active
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
IDE04923-ENG115774-Turn signal control-Komfortblinken,active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,4
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,not active
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik,not active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
IDE05142-ENG116621-Access control-automatisches Entriegeln,active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
IDE05142-ENG116706-Access control-Autounlock NAR,active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active
IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern,not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung,not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion,not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
IDE05142-ENG115755-Access control-Notschließfunktion,active
IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung,not active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always
IDE05142-ENG115758-Access control-Valet Parking,not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
IDE05143-MAS02985-Writing parameter-Value,130
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
IDE05144-Read parameter address,FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,37
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,41
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,00
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,00
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,13
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,23
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,00
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,35
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,3F
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,minimize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,minimize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,minimize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,minimize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,127
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,127
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,0
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,0
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,28
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,28
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,127
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,89
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,26
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,28
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,28
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,26
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,1E
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,1F
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,00
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,00
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,3D
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3E
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,47
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,26
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,27
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116100-Light configuration-Lasttyp 12,6 - LED Lichtmodul
IDE05145-ENG116119-Light configuration-Lasttyp 13,6 - LED Lichtmodul
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active
IDE05145-ENG116176-Light configuration-Lasttyp 16,not active
IDE05145-ENG116195-Light configuration-Lasttyp 17,not active
IDE05145-ENG116214-Light configuration-Lasttyp 18,not active
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20,14 - kombinierte Blink- Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21,14 - kombinierte Blink- Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte
IDE05145-ENG116309-Light configuration-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116328-Light configuration-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116347-Light configuration-Lasttyp 25,18 - 2* 5W
IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG116385-Light configuration-Lasttyp 27,not active
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8,36 - LED Kleinleistung
IDE05145-ENG116043-Light configuration-Lasttyp 9,36 - LED Kleinleistung
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,13
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,14
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,0
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,0
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,8
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,8
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,8
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,2
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,4
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,9
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,10
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,3
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,5
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,0
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,0
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,8
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,8
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,8
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,8
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,8
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,8
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,9
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,10
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,16.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,16.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.00 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.00 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %
IDE06425-Roller test bench mode: functional,not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
IDE07356-Position during interval mode,31.49 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung,not active
IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung,not active
IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x1 Stunden
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min
IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit,0 s
IDE08542-IDE02021-Access control 2-Comfort closing,active
IDE08542-IDE02022-Access control 2-Comfort opening,active
IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,not active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active
IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,not active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,0
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,0
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,0
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,0
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,0
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,0
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,0
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,0
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,0
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active
IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI,not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed
IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %
IDE10298-Alternating park position 1,7.49 °
IDE10299-Alternating park position 2,29.49 °
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement,not active
MAS05055-lower turn position,31.49 °
MAS05056-upper turn position,170.49 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1,0 s
MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3,0.000 ms
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active
ENG122934-erase_error_table,55 00 00
ENG122933-error_mask,0 bit
ENG117283-Frontwaschfunktion,10
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
ENG99457-ENG117394-Head area heater-blower_speed,0
ENG99457-ENG98971-Head area heater-Temperature,-3
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,28
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,14 - kombinierte Blink- Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,28
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,14 - kombinierte Blink- Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,28
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,28
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,18 - 2* 5W
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,47
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,0
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,0
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,35
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3F
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,not active
ENG122927-RLS_close_glazing,2.00 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s
ENG122929-RLS_LIN_Communication,4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
ENG122930-RLS_tunel_gateway_recognize,5 s
ENG122935-RLS_Washer_Front,15 s
ENG122926-RLS_wiper_position_parking,15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30
Elapsed Time: 01:45
Andy
Sector 7G
HC424490
I have a recent AutoScan and channel maps for every module that I'll upload shortly. Posting this as a reminder to myself.
