Saturday,02,July,2016,17:14:03:63946
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: xxxxxxxxxxxxxxxxxx License Plate:
Mileage: 31024km-19277mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 75 A9
VIN: xxxxxxxxxxxxxxxxxx Mileage: 31024km-19277miles
Address 01: Engine (J623-CXCA) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0006
Revision: --H13---
Coding: 091D00324424002F1000
Shop #: WSC 00066 790 00202
ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
ROD: EV_ECM20TFS0205G0906259A_VW37.rod
VCID: 2C79FD4947F2FD5EF2-8078
Readiness: 1010 1101
Part No SW: 0D9 300 041 T HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4511
Revision: 05853104 Serial number: TFK01412101379
ROD: EV_TCMDQ250021_AU37.rod
VCID: 2977045D4800E87609-807C
No fault Found:
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 53454000000334
Coding: 01FA6BA13427096F0080020681C32980D62C9000408194B410430050C005
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 47B3A2E5FE543E06FF-8012
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0356326553
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A55CB11BDA653EE70-806E
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000000000010000000
ROD: EV_ACManueBHBVW37X_SE37.rod
VCID: 46ADAFE1F95E270E04-8012
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86580601151384
Coding: 00111A464041A26969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00206
ROD: EV_BCMBOSCH_AU37.rod
VCID: 4AB59BD1ED46C36EE0-801E
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141205 043 0581
Serial number: 150211015942
Coding: 0E4DFD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y14M11D26H22M52S13
Coding: 06A8DD
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H02 0003
Serial number: 0000FST0001WOUF00000
Coding: 181801
No fault Found:
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391433812357
Coding: 0031151011
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 3D5FC00DAC8864D655-8068
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 14121403271837
Coding: 01201200FE033B
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3851D11983AA41FE86-806C
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM01SKSC
VCID: 51878CBD0010F0B6A1-8004
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1500029IVO0Q
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 000 612 14
Serial number: 35700000000A30543210
Subsystem 3 - Part No SW: ----------- HW: 480 000 612 14
Serial number: 35800000000597303213
Subsystem 4 - Part No SW: ----------- HW: 480 401 311 14
Serial number: 3510002BB188FC11D06C
Subsystem 5 - Part No SW: ----------- HW: 480 401 311 14
Serial number: 35200029D188FC109327
Subsystem 6 - Part No SW: ----------- HW: 480 402 511 14
Serial number: 3550002B718B3A749314
Subsystem 7 - Part No SW: ----------- HW: 480 402 511 14
Serial number: 3560002B718B3A7261DA
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141218400156
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 042975E98FE2D51E5A-8050
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BAD091A2980CF0502887A011000000000000000
VCID: 6BFB3E55827C3A66BB-803E
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 16011510000552
Coding: 0101000820085900FF00002A1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07029
ROD: EV_GatewConti.rod
VCID: 72C52331A556EBAE78-8026
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H10 0101
Serial number: 29140002882510035044
Coding: 29FFFF
No fault Found:
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000015223004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3449E5299FC2A59EAA-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 12011506050B9W
Coding: 003E13200000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 40A1B9F9DB7A093E3E-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Serial number: 00000000000000594835
Coding: 011000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 3753D2258EB44E868F-8062
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 3001150605063O
Coding: 003E13200400040000000000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3FA3BA05A68476C647-806A
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Serial number: 00000000000000432560
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
ROD: EV_HeadlRegulVWAFS_SE26.rod
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B00401151412
Coding: 027300000000000021220002001800001F0203340100010002
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 64E955696FA2751EFA-8030
NO fault Found:
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730002C2823A017F1E06000000
Shop #: WSC 00066 790 00123
ROD: EV_OCULowMQB.rod
VCID: 43ABB6F5CA6C122623-8016
No fault Found:
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 141125201646
End-------------------------(Elapsed Time: 03:54)--------------------------
