Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2005 Volkswagen Golf GLS 1.9 TDI - Driver side door - CanBus issues
    Please see fluke products and YouTube videos are all over on how to use.....
    Best tool you will ever buy for the money.......when it comes to electrical unknown troubleshooting.
    Cheap to buy at any Home Depot store in USA.
    When not familiar.....
    Do a quick VCDS test......unplug all door modules and plug one in at a time...........then trying com looking for a sub system, just to see if any come online.
  2. Likes jakematic liked this post
  3. #12
    Mar 2014
    Brighton, MI
    Quote Originally Posted by KraftwerkTurbo View Post
    Google 'tone generator'. Seems to be sending square or sine wave (10V?)
    "Anyway the sender had to be electrically attached to the wire (using ground) or to a pair of wires with clip on connectors. The receiver did indeed use a magnetic induction probe. You could pick up the tone when close to the wire bundle and it would get louder when held right on the insulation of the correct wire or pair."
    Haven't used one before, but seems a good tool to have. Will check availability.
    Seems a great tool (not having to take insulation of wire to check, or even proximity test). Ordered.
  4. #13
    Do some basic tests outside the car to become familiar with how it will respond.
    In the meantime don't forget to try isolating with VCDS like I added above in subsystems.
    It's not like you don't have it to try............
  5. #14
    Mar 2014
    Brighton, MI
    Just to be clear:
    1) unplug all 4 (or 5 with hatch) door modules
    2) Start VAGcom
    3) 46 convenience group
    4) check codes
    5) plug in one door module (not driver door), check codes.
    Or measuring blocks to 'look for sub systems' to 'come online'?
  6. #15
    One at a time just to see........All door modules.
    If you get a com with one report back.
    The main screen in VCDS 0x46 will tell you....
  7. #16
    United States
    How to determine the 'color code' of original unit?
    How to specify the 'compatible' part number if it is hidden?
    The index or color codes are located on the box and receipt when purchasing new control modules from the VW Dealer but identifying one without a box or receipt is possible when they communicate. After the issue(s) are corrected and the modules are online and communicating you will see additional information as shown in my 2002 Gti example:
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 C
    Component: 1J Komfortgerát HLO 0003
    Coding: 00064
    Shop #: WSC 00001
    VCID: 3776AB28150ADCA6653-4B32
    Component: 1J Tőrsteuer.FS KLO 0002
    Component: 1J Tőrsteuer.BF KLO 0002
    .. and this is a 2003 Jetta Vr6 4 door example. (We sold that car a long time ago so the scan clip is from 2007!):
    Component: 1H Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 00066
    Part No: 1C1959801A
    Component: 1H Tőrsteuer.FS KLO 0004
    Part No: 1C1959802A
    Component: 1H Tőrsteuer.BF KLO 0004
    Part No: 1C0959811A
    Component: 1H Tőrsteuer.HL KLO 0004
    Part No: 1C0959812A
    Component: 1H Tőrsteuer.HR KLO 0004
  8. Likes Uwe liked this post
