Results 1 to 10 of 11
Thread: VCDS update 16.8.0
    Verified Coal Cracker
    Mar 2014
    Wilkes-Barre, PA
    VCDS update 16.8.0
    Yesterday I tried to update VCDS to 008.0 and it downloads the update to 99% they stops and times out.
    Did this 3 times.
    Today i tried again and I get "VAG-Com could not connect to update server."
    Anybody else having this problem? Before I say it's my netbook?
    Thank You!
    Good Luck
    "008.0" is a cosmetic bug in 15.7. It should be 1608.0.
    99% and stops is usually some nanny-ware interfering. What virus scanner are you using?
    Work-around: Go to our download page to download and install the new version manually.
    Mar 2014
    Wilkes-Barre, PA
    I turned off my anti virus protection and download finished all is good.
    My brother who is the PC tech upgraded my memory and installed a different virus protection called Avast last week.
    So that's why and thanks Uwe.
    Good Luck
  6. #4
    Stoke on Trent, England
    As I said in my other post Help, no response from (CAN) Gateway
    I did the update today. I have Avast Pro running all the time and it installs no problem I don't have to disable it.
    New User Keith
    A suggestion Keith - by having two live threads running on the same subject you're splitting the replies/help.
    Why not let this thread die and use only the other thread so you get all the information in one place?
    Dallas (McKinney) ,TX ,USA
    Same thing happen to me 2 days ago. I have Norton, but was not problem as Norton asked me should I trust it.I just click trust this software and went all way to installation.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  9. Likes Uwe liked this post
  10. #7
    Mar 2014
    Wilkes-Barre, PA
    At least Norton asked you. That is good.
    Good Luck
  11. Likes Jack@European_Parts liked this post
  12. #8
    Aug 2016
    Newry, NI
    I have Avast Internet Security and I had to switched off while installing and installed OK
    now when I restart the PC and open VCDS 16.8.0 will not open until I disable AVAST
    Any suggestion?
  13. #9
    Administrator Andy's Avatar
    Sector 7G
    Try adding VCDS as an exception in Avast as explained here:
    http://forums.ross-tech.com/showthre...ll=1#post69028
  14. Likes Uwe liked this post
  15. #10
    Aug 2016
    Newry, NI
    Hello
    I have done that and now is working perfect
    Thanks Andy
    https://www.avast.com/faq.php?article=AVKB168#idt_03
  16. Likes Bruce, Uwe liked this post
