Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 58
Thread: passat abs pump replacment
  1. #41
    It means go to the "green plug" ( Plug with 32b pins ) behind instrument cluster, because the gateway ( J533 ) is incorporated within the instrument cluster ( J285 ) and test of the 32 pins.
    PIN 19 is CAN high ( Color Orange/Black ) A 121
    PIN 20 is CAN low ( Color Orange/Brown ) A 122
    How hard is that?
    Now test the pins from the ABS plug back to the cluster green connector......also isolate any other modules on the tracks.
  2. Likes joe67 liked this post
  3. #42
    Verified VCDS-Lite User
    Aug 2016
    good man jack, thanks
  4. #43
    Aug 2016
    edit: deleted
  5. #44
    Aug 2016
    youll be pulling your hair out that this mate, bare with me lol
    clocks are removed and ready to test, multi meter needs a new battery now and need to get a decent length of wire to test end to end
    you mentioned "also isolate any other modules on the tracks" could you explain further please
  6. #45
    Nope I had my fill.......buy a book and read it.
    Please start with the dedicated section, "How to read WD"
  7. Likes joe67 liked this post
  8. #46
    Please refrain from PM......
    "The Church of Ross-tech helps those, who help themselves by means of RTFB"
    Failure to RTFB only hurts you........now if after you get a book and want to ask a question based on that repair manual, or you don't understand.......... I would be happy to help!
    Otherwise I am enabling you.........need to see some effort.
    Thank you!
  9. Likes mattylondon liked this post
  10. #47
    We also have a few videos here:
    http://forums.ross-tech.com/showthre...final-version)
  11. Likes Jack@European_Parts liked this post
  12. #48
    Aug 2016
    thanks mate, i did watch the first video a couple times, another one of you guys shared it earlier.. watching the video and looking at the diagram isnt working for me at the moment, am up against it at the moment..
    thanks for the help
  13. #49
    Seek a professional shop visit...........
  14. Likes ExcelAutos liked this post
  15. #50
    Aug 2016
    No way of getting the motor to them, I've phoned a few auto sparks , I've explained everything done and also said here.. They would still need to charge a call out, then to use there snap on or Bosch code reader then bill 50 a hour ontop of that , once got the multi meter problem sorted I'll do the continuity test on the two abs wires, orange and black , orange and and brown, if they are ok I'll replace the module , if there one with the same Bosch code forsale
