Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: passat abs pump replacment
    Verified VCDS-Lite User
    Aug 2016
    I have 2001 Passat tdi sport, I had to replace the abs pump... Now I cant bleed the brakes..
    I bought the registered version of vcds lite with the hope it will help.
    Am not sure if the pump in comuicating with the ecu.
    edit: if I run a output test, nothing happens, dash beeps, that's it
    I did do a scan and it returned:
     Saturday, 06 August 2016, 13:25:19:3906
     Chassis Type: 3B - VW Passat B5
     Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58 ,75,76,77
     Address 01: Engine Labels: 038-906-019-AVF.LBL
     Controller: 038 906 019 EP
     Component: 1,9l R4 EDC G000SG 1442
     Coding: 00002
     Shop #: WSC 05314
     VCID: 69A531E50061
     WVWZZZ3BZ2E154738 VWZ7Z0A4011569
     18057 - Powertrain Data Bus: Missing Message from ABS Controller
     P1649 - 35-10 - - - Intermittent
     Readiness: N/A
     Address 03: ABS Brakes Labels: 8E0-614-111-ASR.LBL
     Controller: 3B0 614 111
     Component: ABS/ASR 5.3 FRONT D00
     Coding: 00012
     Shop #: WSC 02325
     VCID: D3D9730D32ED
    Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
     Controller: 3B2 907 044 J
     Component: CLIMATRONIC B5GP 0003
     Coding: 17000
     Shop #: WSC 05311
     VCID: 292571E5C0E1
     37-10 - Faulty - Intermittent
    Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
     Controller: 1C0 909 605 B
     Component: 0A AIRBAG VW51 04 02
     Coding: 12353
     Shop #: WSC 05311
     VCID: 233963CDA2CD
     00532 - Supply Voltage B+
    Address 17: Instruments Labels: 3B0-920-xx5-17.LBL
     Controller: 3B0 920 926 A
     Component: KOMBI+WEGFAHRSP VDO V01
     Coding: 05415
     Shop #: WSC 00700
     VCID: 223766C9BDD7
    Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
     Controller: 6N0 909 901
     Component: Gateway K<->CAN 0001
     Coding: 00006
     Shop #: WSC 05314
     VCID: F093DC81A3BB
    Address 46: Central Conv. Labels: 1C0-959-799.LBL
     Controller: 1C0 959 799 B
     Component: 0M KomfortgerŠt HLO 0003
     Coding: 00258
     Shop #: WSC 05311
     VCID: 361FAA99015F
     01131 - Control Circuit for Turn Signals
     25-10 - Unknown Switch Condition - Intermittent
     27-00 - Implausible Signal
    Address 56: Radio Labels: 1J0-035-18x-56.LBL
     Controller: 1J0 035 186 D
     Component: RADIO SON 0003
     Coding: 05403
     Shop #: WSC 05311
     VCID: 263F7AD9D1FF
     00853 - Loudspeaker(s); Rear
     End --------------------------------------------------------------------------------------------------
    Any help would be much appreciated
    Moving to Car Repair Support.
    Please tell us exactly what parts you replaced. Just the pump? Is this ABS control module the original one?
  3. Likes joe67 liked this post
    Aug 2016
    Just replaced the whole unit. So I guess both.. from a scrap car
    Aug 2016
    i fitted the original module today, still getting nothing from output test
    if i click abs then output test on vcds lite, the dash still beeps and lights flash, nothing else happens..
    edit:
    going other internet posts, it says to try abs>>basic settings>> group 001 then go
    000,001,002,003 etc etc when i press go i get ERROR group 001(002 etc) no available
    Aug 2016
    should the output test and basic settings work on this model... scratching my head at the moment
    In order to know what functions that old ABS system should theoretically support, one would need to have a look at the old repair documentation for these cars, and I don't have that handy at the moment.
    I don't suppose you saved and scan data from the old module while you were playing with it? If so, it would be good to post that for comparison purposes.
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 1728
    Coding: 04255
    Something is telling me that this ecu is looking for ESP..........when trolling the kind auto-scans of the world via cross check.
    Nope should be ASR........
    8E0-614-111AQ and part # is right by legacy.
    New controller is 8E0-998-375J
    Try this
    Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
    Part No: 3B0 614 111 Component: ABS/ASR 5.3 FRONT D00
    Coding: 00022 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Try This
    Coding: 00021<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Try This
    Coding: 00032<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Try This
    Vehicle Identification No. WVWZZZ3BZ2E154738
    Model passat squareback
    PA
    Date of production 13.08.2001
    Year 2002
    Sales type 3B6262
    Engine Code AVF
    Transmission Code FRK
    Axle drive 6S
    Equipment RN
    Roof color A1
    Exterior color / Paint Code A1 / 041
  9. #8
    Aug 2016
    Not sure what you mean by try this??
    @uwe the scan in first post if from module attached to replacement abs, do you want scan results from replacement abs with original module now attached?
  10. #9
    Yes, it would be good to see what the original module was, in order to determine if the replacement is compatible.
  11. Likes Jack@European_Parts liked this post
  12. #10
    According to the VIN and research I did above, the part is compatible, however, it would be good to know what the coding was of the old module.......
