I have 2001 Passat tdi sport, I had to replace the abs pump... Now I cant bleed the brakes..
I bought the registered version of vcds lite with the hope it will help.
Am not sure if the pump in comuicating with the ecu.
edit: if I run a output test, nothing happens, dash beeps, that's it
I did do a scan and it returned:
Any help would be much appreciated
VCDS-Lite Version: Release 1.2
Saturday, 06 August 2016, 13:25:19:3906
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58 ,75,76,77
Address 01: Engine Labels: 038-906-019-AVF.LBL
Controller: 038 906 019 EP
Component: 1,9l R4 EDC G000SG 1442
Coding: 00002
Shop #: WSC 05314
VCID: 69A531E50061
WVWZZZ3BZ2E154738 VWZ7Z0A4011569
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.LBL
Controller: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 02325
VCID: D3D9730D32ED
Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
Controller: 3B2 907 044 J
Component: CLIMATRONIC B5GP 0003
Coding: 17000
Shop #: WSC 05311
VCID: 292571E5C0E1
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 B
Component: 0A AIRBAG VW51 04 02
Coding: 12353
Shop #: WSC 05311
VCID: 233963CDA2CD
00532 - Supply Voltage B+
Address 17: Instruments Labels: 3B0-920-xx5-17.LBL
Controller: 3B0 920 926 A
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05415
Shop #: WSC 00700
VCID: 223766C9BDD7
01316 - ABS Control Module
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Coding: 00006
Shop #: WSC 05314
VCID: F093DC81A3BB
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 B
Component: 0M Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
VCID: 361FAA99015F
01131 - Control Circuit for Turn Signals
25-10 - Unknown Switch Condition - Intermittent
27-00 - Implausible Signal
Address 56: Radio Labels: 1J0-035-18x-56.LBL
Controller: 1J0 035 186 D
Component: RADIO SON 0003
Coding: 05403
Shop #: WSC 05311
VCID: 263F7AD9D1FF
00853 - Loudspeaker(s); Rear
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
