Hi everyone!
I know, this topic is about dq250. But, someone has performed the procedure for DQ200 (DSG/0AM)? The procedure is available in http://wiki.ross-tech.com/wiki/index.php/7-Speed_Direct_Shift_Gearbox_(DSG/0AM). Because I can not. The screen of the procedure is different and does not appear the space to insert the group number (060).
This is also valid for Golf Mk7 equipped with 0AM?
Below are some screens of the procedure I tried to perform:
Thank you very much!
VCDS Version: Release 15.7.0 Running on Windows 7 x86
Data version: 20150820
Wednesday,03,August,2016,12:43:43:04550
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWHD6AU2EW299555 Mileage: 40249km-25009miles
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 CT HW: 04E 907 309 A
Component: R4 1.4l TFS H08 9199
Revision: WAH08---
Coding: 01250032232405082000
Shop #: WSC 08099 002 1048576
ASAM Dataset: EV_ECM14TFS01104E906016CT 002008
ROD: EV_ECM14TFS01104E906016G.rod
VCID: 760632D7C1C8A5A2EFA243-8022
Part No SW: 0CW 300 046 B HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5112
Revision: 00043014 Serial number: CU501401187025
ROD: EV_TCMDQ200021_AU37.rod
VCID: 399CF9EBB0560ADAC20020-806C
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 60354000001494
Coding: 01FA6AA124291175037C060541C82980562488C0608294F300220038C202
VCID: 7B1023E3FAEAF8CA90EC1A-802E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00020004200100011005000000101000
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 389AFCEF8B5C13D23D0E3D-806C
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011403400380
Coding: 00001842C24102FB0BA44080B10403081000000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 791C39EBF0D6CADA828060-802C
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140129 042 0551
Serial number: 140131223213
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M02D13H19M54S24S9
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140230DED
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000058683570
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331403700790
Coding: 0031051011
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 3E96EAF7A9782DE2F752FB-806A
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R04GR7J
VCID: 416C910BD886521A8AB098-8014
Subsystem 1 - Part No SW: ----------- HW: 480 002 901 14
Serial number: 35767000000710E09E0U
Subsystem 2 - Part No SW: ----------- HW: 480 002 901 14
Serial number: 3586700000063D58BE03
Subsystem 3 - Part No SW: ----------- HW: 480 400 302 14
Serial number: 3516502B112AB1B5311.
Subsystem 4 - Part No SW: ----------- HW: 480 400 302 14
Serial number: 3526502A113013F3635V
Subsystem 5 - Part No SW: ----------- HW: 480 402 801 14
Serial number: 3556502A112AB1B3A1AB
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0135
Revision: FF027027 Serial number: 20140131500155
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F6897F3AE7224EAFC44EE-806A
Part No SW: 5G0 920 861 HW: 5G0 920 861
Component: KOMBI 204 3390
Coding: 07A419082380000800082A00040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_SK37.rod
VCID: 66266297916855225FC233-8032
Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1164
Revision: -------- Serial number: 0001561104
Coding: 030100042B085700EF0002481C0F00010001000000000000000000000000
ROD: EV_GatewLear.rod
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H16 0038
Serial number: 29140000092060124045
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6895112503
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 27011401101230
Coding: 003B0220D000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 406A940FD38C5B1285BE95-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000001763780
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 0103
ROD: EV_SteerAssisMQB.rod
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 26011403111040
Coding: 003B0220DE00040000800000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000001772684
Coding: 190000
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 040 0421
Serial number: V1C00502142144
Coding: 02730000FF00000021220001001800001F0100040100010001
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 27B82F9356E28C2AA4B4E6-8072
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H51 0022
Serial number: VWZ8Z9NJ703WSV
End-------------------------(Elapsed Time: 03:27)--------------------------
