Results 1 to 10 of 16
Thread: 2017 Audi Q7 4M - Adaptations, Coding & Modifications
    Jul 2016
    I just received a new 2017 Audi Q7 4M with Prestige Package and has the following options 21'' Rims, Drivers Assistance, Adaptive Chassis, Cold Weather, Towing Packages, Rear Seat Entertainment Preparation, Rear Side Airbags and Night Vision Assistant. I would like to have this post only have confirmed Adaptations and Long Coding and Access Codes that have been verified to work on the Audi Q7 4M model. Here are some modifications I made that work.
    Mods Completed: 2017 Audi Q7
    Enable ACC Default Distance In MMI (VCDS 16.6 or newer required) - Allows you set the default distance
    1. Auto Dist. Reg 13
    2. Adaptation - 10
    3. Select "Distance basic setting option" in dropdown
    4. Select "On" from New value drop down
    Disable Seat Belt Chime - Disables seat belt reminder
    1. Instruments 17
    2. Adaption 10
    3. In drop down menu choose Deactivate seat belt chime
    4. Change Deactivate seat belt from NO to YES
    Needle Sweep In Virtual Cockpit
    1. Instruments 17
    2. Coding 07
    3. Long coding
    4. Byte 1
    5. Bit 0 activate/check
    Enable lap timer
    1. Instruments 17
    2. Coding 07
    3. Long coding
    4. Byte 1
    5. Bit 3 activate/check
    Combine the park assist 360 camera view with the OPS (Optical Parking Sensors) In the display
    1. Instruments 09 - Adaptation
    2. ORIGINAL - UDS Adaptation Channel: IDE01170-Visual display for park assist
    Stored value with OPS display
    2. MOD - UDS Adaptation Channel: IDE01170-Visual display for park assist
    Stored value with OPS 360
    Change the Parking Assist shutdown speed threshold - Camera will stay on until 12-MPH instead of 6-MPH
    3. ORIGINAL - UDS Adaptation Channel: IDE03782-Switch-off speed for parking assist
    Stored value 10
    3. MOD - UDS Adaptation Channel: IDE03782-Switch-off speed for parking assist
    Stored value 20 - (20 IS MAX VALUE ACCEPTED = 12MPH)
    Change ventilated seat cooling fan speeds for each of the 3 setting - Max increase is 10% over the default setting - You can hear and feel the difference especially stage 3, I increased all by 10%
    4. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01366-Seat ventilation; micro adjust.-Stage 3
    Stored value 0 %
    4. MOD - UDS Adaptation Channel: IDE10322-MAS01366-Seat ventilation; micro adjust.-Stage 3
    Stored value 10 % - (10% IS MAX VALUE)
    5. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01365-Seat ventilation; micro adjust.-Stage 2
    Stored value 0 %
    5. MOD - UDS Adaptation Channel: IDE10322-MAS01365-Seat ventilation; micro adjust.-Stage 2
    6. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01364-Seat ventilation; micro adjust.-Stage 1
    Stored value 0 %
    6. MOD - UDS Adaptation Channel: IDE10322-MAS01364-Seat ventilation; micro adjust.-Stage 1
    Modifies the threshold of when the lane assist shuts off due to no steering input by the driver - I would like be able to remove the deactivation completely if possible.
    1. Frt Sens. Drv. Assist A5 - Adaptation
    2. ORIGINAL - UDS Adaptation Channel: IDE05984-Directional stabilization assist driver inact deactiv threshold
    Stored value Medium
    2. MOD - UDS Adaptation Channel: IDE05984-Directional stabilization assist driver inact deactiv threshold
    Stored value Late
    I'm not sure about this one, I believe it make lane assist that keeps you centered move the wheel with more force - I didn't feel too much difference - I have to test drive some more to confirm
    3. ORIGINAL - UDS Adaptation Channel: IDE05986-Directional stab. assist.; intensity; power steering support
    Stored value Medium
    3. MOD - UDS Adaptation Channel: IDE05986-Directional stab. assist.; intensity; power steering support
    Stored value Strong
    Share any mods that you've done with Ross-Tech Tool or any physical modifications or improvements that you've made to the New 2017 Q7 4M
  2. Likes Uwe, Eric, Boki Ar liked this post
  3. #2
    Mar 2016
    Great Stuff JOEREZ. You have covered a load I uncovered also.
    You can find my thread here: http://www.vwaudiforum.co.uk/forum/s...Q7-(4M)-Coding
    I found the OPS one also but never changed it...
    Jul 2016
    Allows you to change the Heated Seats Plus or Minus 5 degrees in each stage
    2. ORIGINAL - UDS Adaptation Channel: IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1
    Stored value 0 C ( 5 DEGREES + OR - IS MAX VALUE)
    3. ORIGINAL - UDS Adaptation Channel: IDE10321-MAS01364-Seat heater: micro adjust.-Stage 2
    4. ORIGINAL - UDS Adaptation Channel: IDE10321-MAS01364-Seat heater: micro adjust.-Stage 3
    Allows the Air Re-circulation button to recall the last state, So if the button is pressed on it will stay on default until turned off.
    1. 08 Auto HVAC
    2. MOD - UDS Adaptation Channel: IDE01476-Store recirculation air setting for terminal 15 off
    Stored value save
  5. Likes Eric, Uwe, Boki Ar liked this post
  6. #4
    Jul 2016
    Seat Symmetry:
    I have memory seats, just on the drivers side.
    Anyone who tries this code respond if it works - I used another program to do it and compared the long coding afterwards to reveal two bits changed in two modules
    Under Vehicle Settings - Seats - Front Passengers Seat you'll now see Adjust Seat Position, when clicked your driver seat controls will move passenger seat. There will also be an option to Align / Drivers Seat you press and hold the Set Now button and it begins to align passenger seat to drivers seat.
    Module 06
    Byte 2
    Check Bit 5
    Byte 6
    Check Bit 1
    Module 36
    Byte 2
    Check Bit 5
    Byte 6
    Check Bit 1
  7. Likes Boki Ar liked this post
  8. #5
    Mar 2016
    Quote Originally Posted by JOEREZ View Post
    Seat Symmetry:
    Module 06
    Byte 2
    Check Bit 5
    Byte 6
    Check Bit 1
    Module 36
    Byte 2
    Check Bit 5
    Byte 6
    Check Bit 1
    I can confirm that coding works JoeRez.
    Andy
  9. Likes Uwe, Boki Ar liked this post
  10. #6
    Verified VCDS User BGB's Avatar
    Mar 2016
    Norway
    Is it possible to deactivate the rear wiper when the rain sensor is on?
  11. Likes Bobdhd liked this post
  12. #7
    Mar 2016
    Norway
    Quote Originally Posted by BGB View Post
    Anyone?
    I dont have the car here so I haven't checked but maybe it is in the adaptation list in 09 or can I be so lucky that we can find it under long coding?
  13. #8
    Mar 2016
    Anyone?
    Had a quick look through Adaption Maps of 09 and 46... couldnt see anything that jumped out relating to that sadly.. might be long coding...
  14. Likes BGB liked this post
  15. #9
    Mar 2016
    Norway
    Quote Originally Posted by andyhud View Post
    Thank you so much for looking!
  16. #10
    Mar 2018
    On my B8 S5, I enabled the display in the DIS to show what gear the car was in, which was especially helpful when needing to downshift via the steering wheel paddles. I’ve found that the coding is the same for the 2018 Q7 and wanted to pass it along to add to the other great coding shares.
    a. [02 – Auto Trans]
    b. [Adaptation – 10]
    c. Select “Single Gear Display” from top channel drop down menu
    d. “Select “D on/S on” from New Value drop down menu
    e. Select “Do It!”
    f. Note: You may have to select “Do It! A few times to save the change.
  17. Likes Uwe liked this post
