Results 1 to 10 of 13
Thread: CCS retrofit, hit a snag with the horn?!
    Jun 2014
    Hi guys, I'm a little new to all this so please be gentle with me!
    I bought VCDS on a whim a while back as my old dumb lead died which I used to use on an old MSA van so I thought I'd buy the full version as we have 4 VAG vehicles in the house, its proved very useful thus far!
    Anyway a friend with a VW Caddy (2k) asked if I could retrofit cruise control to his van and I agreed after a little research.
    We have fitted the correct stalk and also changed the steering wheel controller as the fitted version (1k0953549BT) was lowline and wouldnt support cruise control. It was replaced with a (1K0953549CB) midline which was listed as suitable on the ross tech wiki.
    I recoded the controller to suit the van but now we have a fault with the horn, its basically persistantly on. doing anything (button press/turn signal/flash/etc) will stop the horn briefly and then it will activate again.
    Having looked in measuring blocks on the steering controller the horn is showing as activated. All other functions work as they should.
    Only one thing to note is the van does not have a multi function display but if the controller is coded for cruise control on and display off it throws a code to say its incorrectly coded. Odd.
    Anway here is the full autoscan, which includes the appropriate code (00889) for the horn fault. It states intermittent, which it isn't really.. its only intermittent as intervention with any other stalk function resolves this issue breifly.
    We tried removing the airbag and taking the horn ground off just incase the apparent short was there, but no improvement.
    Any guidance would be most welcome!
    Please ignore the radio fault, thats something we've just discovered!
    VCDS Version: Release 12.12.2 (x64)
    Data version: 20140212
    Friday,13,June,2014,14:14:58:50713
    Chassis Type: 2K (1K0)
    Scan: 01 03 09 15 16 17 19 25 42 46 52 56
    VIN: WV1ZZZ2KZ8X082893   Mileage: 85650km/53220miles
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 PD    HW: 03G 906 021 AR
       Component: R4 1,9L EDC G000SG  1330
       Revision: --H07---    Serial number: VWX7Z0GN3NU01I
       Coding: 0000031
       Shop #: WSC 35110 377 00158
       VCID: 70EFD05563650A9E6B7-8025
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017106
       VCID: 3F8D43696EBBA5E6A2D-806A
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 01000007846815
       Coding: 00884F030004100047000000000000000008FB075C000100000000000000
       Shop #: WSC 35110 377 08192
       VCID: 6FEDD3297E5B156672D-803A
       Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 221107 021  0501
       Coding: 00038805
       Shop #: WSC 35110
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
       Component: 1D AIRBAG VW52  023 2400
       Revision: 04023000    Serial number: 0037TD0GKUWL
       Coding: 0012612
       VCID: 7DF1F961243777F6F01-8028
       Part No SW: 1K0 953 549 CB    HW: 1K0 953 549 CB
       Coding: 0001042
       Shop #: WSC 01279 785 00200
       VCID: 74E7DC45177D36BE8FF-8021
    00889 - Horn (H)
                007 - Short to Ground
       Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
       Component: KOMBIINSTRUMENT VDD 1212
       Revision: V0002000    Serial number: VWX7Z0GN3NU01I
       Coding: 0016401
       Shop #: WSC 00440 210 87084
       VCID: 2C5704258FCD2E7E17F-8079
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 281107F1002066
       Coding: 89801F020002027401
       VCID: 306F1055A3E54A9E2B7-8065
       Component: IMMO            VDD 1212
       Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
       Component: Tuer-SG         006 1206
       Coding: 0000560
       VCID: 387F28754B9592DE637-806D
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Coding: 808A0C087F2D8405485A030010C0
       VCID: 800F0095D3C59A1E1B7-80D5
       Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
       Coding: 0000560
       VCID: 39792D71709F8BD69C9-806C
       Part No SW: 1K0 035 186 AD    HW: 1K0 035 186 AD
       Component: Radio BVX       037 0048
       Revision: 00037000    Serial number: VWZ1Z2G6350737
       Coding: 0020200
       VCID: 68DFB8355BB5C25E337-803D
    Jun 2014
    So today we've removed the wheel and clock spring to see if the clockspring was at fault. It appears its not.
    With the wheel and clockspring removed the horn is still operating when either the SET- or RES+ buttons are pressed.
    On controller 16 in measuring blocks
    Group 03 Horn is showing as activated when Group 04 CCS-SET is either ACCEL or DELAY
    Remember this is with the wheel and clockspring removed.
    I'm leaning towards the steering wheel controller being faulty as I'm baffled as to how anything else could be causing this?
    I'd be very grateful for anyones input.
    Jun 2014
    The original controller was a 1K0-953-549-BT and was replaced with a 1K0-953-549-CB
    The only difference is the BT controller was SW Version 0100 and the new CB controller is SW Version 0101
    Would the SW version be an issue?
    Sep 2014
    HI
    Did you find what was reason for this? I'm just going to do this same exercise? so I'm curious.
    Jun 2014
    No, we did not solve it and I still cannot find a solution
    Tartu, Estonia
    I had a similar problem. Guy came with bought steering module, bough from a guy at our local vwclub. Originally the module was coded to have steering buttons, after i coded those out the horn also started to be on all time. It isn't problem with horn itself, cause i tested the module, while it was hanging and only wiring connected was the wiring from the car and iginition switch. Tried my old module, that didn't have the issue, but as it used different type of slip ring, the airbag wouldn't turn off.
    At the moment, car is driving around without horn relay connected.
    The world is my oyster...
  7. Likes Dana liked this post
    United States
    Quote Originally Posted by spesh View Post
    I do not suspect the SW version is the issue but 1K0-953-549-BT appears to supersede directly to 1K0-953-549-CC and that is the number shown by VIN using PartsLink24 as well. According to our Wiki page 1K0-953-549-CC is a Highline unit so that would be my personal recommendation based on the goofy horn operation you describe.
    The incorrect slip ring could cause issues as golfi_vend explained and 1K0-959-653-C appears to be compatible with the mentioned CC unit but you may want to take a look at the installed component to see which one is installed.
  9. Likes jakematic, Uwe liked this post
  10. #8
    Tartu, Estonia
    Forgot to add, that when i test-installed my old steering module, horn worked as it should. Seems like there is a hardware/software problem in some modules.
  11. #9
    Nov 2019
    Hi, I’m new to this forum and I was looking for help to install cruise control to 2009 VW caddy. I found this old thread and this horn issue worries me. The caddy I have has this same 1k0953549BT control module originally and 1k0953549CA or ...CB would be well available in ebay as used item, but will I run to horn troubles with it? 1k0953549CC modules are not that well available. Mostly only from China as new items and honestly I would trust more to an used item.
  12. #10
    May 2016
    My advise use CH if you have BT. Never had problem with this even if its highline. Just recode without mfsw.
    @sjs order from China is no problem all work like same. Many parts come from China and will be labeled as “made in Germany”
