Release 16.8 discussion thread (what's new, etc.)
DV52
C?ID=194404
Hey Andy: Just loaded and tried the ver 16.8 - and I got to say that the admap facility "runs like a cut cat". The last line on my latest BCM map (which had 1,791 lines of script) said "Elapsed Time: 01:58". Wow!! I'm salivating at the thought of the next release which I fully expect will be a TARDIS-like time!! Kudos to the software/hardware speed-junkies at RT - they certainly are Olympic standard (elite) athletes - without the EPOs!!
But enough of the hagiography and to more mundane matters- which is the real purpose of my post:
First question - here's a screen-shot from my BCM admap process:
I notice that on many (though, not all) of the control modules in my mk7 (including the BCM) the lines printed in the report don't align with the second "Channel" number in parentheses (i.e. 2822 in the picture). If I'm not asking RT to divulge secret info - what is the second number and why is there (sometimes?) a difference in the recorded channel numbers? Incidentally, this new feature is a great improvement - it helps the user understand where the polling process is and how much more time is needed for completion! Nice new font -too!!
Second question: I note that the structure of the adaptation channels have altered. It seems that there are now basically three new nomenclatures used (not sure there could be more). Here's an example of each (from my BCM in this case) that I have chosen for no particular reason other than it shows the new descriptors:
  1. IDE02332-Deactivate production mode (this channel is from the ECU)
  2. IDE05145-ENG115986-Light configuration-Lasttyp 6
  3. ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14
  4. MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1
Can your explain (in single syllable words - please) how I should read the "ENG", "MAS" and "IDE" labels, what do the numbers mean and why do some channels have just one new label (i.e. "IDE" alone as in (1) above) and others have two (i.e. "IDE" and "ENG" as in (2) above)? Also and just out of curiosity - why was this done (it now makes it difficult to (easily) compare admaps from previous versions with post 16.8 release)? I read in another post that Sebastian mentioned that the reason was "future-proofing" (I think - but this could be wrong?), but my addled mind couldn't quite grasp the reasoning!!
PS: Third question - can you provide a brief synopsis of the new directory structure that is used - seems like the new Beta version no longer likes to live in the "Beta" subdirectory (I accepted the default directory structure when loading)!
IDEnnnnn, MASnnnnn, and ENGnnnnn are factory identifiers for various data objects. We are showing them now because the old scheme of arbitrarily assigned location numbers was unmanageable and could not ensure consistency between dataset builds.
16.8.0 is not a Beta. It's a Release. :)
DV52
C?ID=194404
Uwe: My bad (about the Beta assertion)-sorry.
So by "data object" I assume that you mean a relational mapping point. Is there any detailed (or, even general) information about the IDE/MAS/ENG tags that is accessible by the average john-doe, or is this steeped in the usual mantel of VW secrecy (is the public's understanding of these numbers as stupefying as the illusive SA numbers)?
If there is, I've not seen it.
DV52
C?ID=194404
Uwe: OK thanks - then I'd like to tentatively ask one last question which I stress is posed with the greatest respect and is (hopefully) crafted in the most polite manner: if the new information regarding the IDE/MAS/ENG tags is "secret VW stuff" which past history has proven is unlikely to be devulged to john-doe in the foreseeable future, why include the data on the admaps? To clarify my question, and again I don't mean to offend in asking - what value does this information provide to the cable user if he/she can't (and is unlikely to ever be able to) decode?
Andy
Sector 7G
HC424490
I split this conversation off from the "Updated to Release 16.8 and Having Trouble? Read This Thread " thread.
Eric
HC800000
They're not so much a code (which is decoded right under your eyes as VCDS gives you the matching clear text in the channel description), as a reference point that's hopefully going to be universal going forward, across languages, future datasets and even possibly controllers. For instance, Andy and I were conferring during our lunch "break" yesterday, that we should check what the IDE/MAS/etc are for manifold pressure and typical gasser performance stuff on both our cars, which apart from being gasoline and force fed, are pretty different (GTI/S4). Wouldn't it be great if typing in the same IDE in measuring blocks just returns your manifold pressure no matter the engine, dataset, VCDS language? Like the measuring block 115 in old times... Adaptation is going to be a little more restricted because it's become highly controller-specific, but I think it will be nice to just tell people "enter IDExxxxx-MASxxxxx in the box" instead of "(123)-Leuchte 4321-Refill blinker fluid actuator Front Left" or whatever :), and not be at the mercy of a description change that would negate your search in a future dataset or different VCDS language.
DV52
C?ID=194404
^^^ ^^ Eric: You make a compelling point!! I've re-looked at my latest BCM admap and there does appear to be a "structure" to the new tags - which as you say, may be universal across all VAG vehicles. For example, for the Leuchte-set for the DRLs
LEFT DRL
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4
RIGHT DRL
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5
Clearly, the 1st tag is the Parent identifier and the second tag is the Child identifier. The Parent tag number appears to be sequential with the Leuchte-set number (i.e. the last digit in the descriptor which has a range of 1-35). Oddly, the child number sequence doesn't appear to be sequential - there are missing numbers - why?
Also interesting, there appears to be an imbedded relationship in the Child tag number across adaptation channels: for example the same "child" number is used for the two adaptation channels shown below;
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5
I've long suspected that there is a connection between "Leuchte" and "Light configuration" channels, but I could never understand the nature of the connection - the same child number kind-of confirms my suspicion but doesn't add any light (pun intended) on what the connection is!
And even more oddly, the missing child numbers in the Leuchte do appear (sometimes) in the matching light configuration channels. For example the child number - ENG115949 is missing from the LEFT DRL Leuchte-set, but it does appear in the matching "light configuration" channel below:
IDE05145-ENG115949-Light configuration-BAP Bitposition 4
Very curious behaviour indeed and much to learn!!
mabnz
New Zealand
C?ID=279595
I've not read the rest of the thread, but since upgrading from 15.7.4 to 16.8, the descriptions of some (most?) adaptions has changed.
It's gone from English text to German, i.e
static AFS light-Upper speed threshold
to
static AFS light-Obere Geschwindigkeitsschwelle
Previously, most descriptions in the main (most used) modules was English. Is this expected, or have I incorrectly installed some language files?
to
It is not expected.
PS: Is this the module in question?
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 8658230416004Q
   Coding: 0F011A46C24722FB0FA44086B10C17280800000000000000000000000000
   Shop #: WSC 59986 001 1048576
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 8346C07C0A32E426E3-80D6
Andy
Sector 7G
HC424490
I just ran an Adp map of the 09 module in my MQB with 16.8.0.1 :
;SW:5Q0-937-087-K   HW:5Q0-937-087-K ---  Cent. Elect.
;Component:BCM PQ37BOSCH 026 0097	 Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc	12003	EV_BCMBOSCH_VW37.rod
;Thursday	4	August	2016	10:32:34:29905
;VCDS Version: Release 16.8.0 (x64)  Data version: 20160801 DS254
;VCID: 43C9CC47CAE1095AFF-8016
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Innenbeleuchtung	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active
IDE00001-ENG99061-Production mode-Zugangskontrolle	not active
IDE00002-Transport mode	active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition	not active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	0 ms
IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen	not active
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant	0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active
IDE01550-Service position	170.49 °
IDE02152-Characteristics in production mode	0 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	0 s
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	0.0 s
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	50%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	50%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	50%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	Enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle; offset	-63.75 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.00 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.00 °C
IDE03638-ENG116676-static AFS light-Obere Geschwindigkeitsschwelle	40.00 km/h
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.00 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °
IDE03638-ENG116675-static AFS light-Untere Geschwindigkeitsschwelle	0.00 km/h
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.00 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	180 °
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken	not active
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	4
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	MFG
IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.1
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00%
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	not active
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus	active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	not active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik	not active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	active
IDE05142-ENG116706-Access control-Autounlock NAR	active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active
IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern	not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung	not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung	not active
IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion	not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster	0.00 s
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschließfunktion	active
IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung	not active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Immer
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden	Immer
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe	not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active
IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum	Freigabe_Softtouch
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Einzeltuerentriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10	0
IDE05145-ENG116082-Light configuration-BAP Bitposition 11	0
IDE05145-ENG116101-Light configuration-BAP Bitposition 12	0
IDE05145-ENG116120-Light configuration-BAP Bitposition 13	0
IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0
IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0
IDE05145-ENG116177-Light configuration-BAP Bitposition 16	0
IDE05145-ENG116196-Light configuration-BAP Bitposition 17	0
IDE05145-ENG116215-Light configuration-BAP Bitposition 18	0
IDE05145-ENG116234-Light configuration-BAP Bitposition 19	0
IDE05145-ENG115911-Light configuration-BAP Bitposition 2	48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20	0
IDE05145-ENG116272-Light configuration-BAP Bitposition 21	0
IDE05145-ENG116291-Light configuration-BAP Bitposition 22	0
IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0
IDE05145-ENG116329-Light configuration-BAP Bitposition 24	0
IDE05145-ENG116348-Light configuration-BAP Bitposition 25	0
IDE05145-ENG116367-Light configuration-BAP Bitposition 26	0
IDE05145-ENG116386-Light configuration-BAP Bitposition 27	0
IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0
IDE05145-ENG116424-Light configuration-BAP Bitposition 29	FF
IDE05145-ENG115930-Light configuration-BAP Bitposition 3	4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0
IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0
IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0
IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0
IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0
IDE05145-ENG115949-Light configuration-BAP Bitposition 4	3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5	44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8	0
IDE05145-ENG116044-Light configuration-BAP Bitposition 9	30
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	minimize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	minimize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	minimize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	minimize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	minimize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	minimize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	minimize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	minimize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	minimize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	minimize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	minimize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	minimize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	minimize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	minimize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	minimize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	minimize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	minimize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0	100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1	100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10	1
IDE05145-ENG116086-Light configuration-Dimmwert AB 11	75
IDE05145-ENG116105-Light configuration-Dimmwert AB 12	104
IDE05145-ENG116124-Light configuration-Dimmwert AB 13	125
IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15	96
IDE05145-ENG116181-Light configuration-Dimmwert AB 16	47
IDE05145-ENG116200-Light configuration-Dimmwert AB 17	0
IDE05145-ENG116219-Light configuration-Dimmwert AB 18	127
IDE05145-ENG116238-Light configuration-Dimmwert AB 19	56
IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100
IDE05145-ENG116257-Light configuration-Dimmwert AB 20	1
IDE05145-ENG116276-Light configuration-Dimmwert AB 21	0
IDE05145-ENG116295-Light configuration-Dimmwert AB 22	48
IDE05145-ENG116314-Light configuration-Dimmwert AB 23	0
IDE05145-ENG116333-Light configuration-Dimmwert AB 24	2
IDE05145-ENG116352-Light configuration-Dimmwert AB 25	56
IDE05145-ENG116371-Light configuration-Dimmwert AB 26	1
IDE05145-ENG116390-Light configuration-Dimmwert AB 27	88
IDE05145-ENG116409-Light configuration-Dimmwert AB 28	1
IDE05145-ENG116428-Light configuration-Dimmwert AB 29	72
IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100
IDE05145-ENG116447-Light configuration-Dimmwert AB 30	78
IDE05145-ENG116466-Light configuration-Dimmwert AB 31	78
IDE05145-ENG116485-Light configuration-Dimmwert AB 32	124
IDE05145-ENG116504-Light configuration-Dimmwert AB 33	78
IDE05145-ENG116523-Light configuration-Dimmwert AB 34	0
IDE05145-ENG115953-Light configuration-Dimmwert AB 4	127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5	127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6	127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7	127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8	127
IDE05145-ENG116048-Light configuration-Dimmwert AB 9	49
IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11	126
IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18	127
IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2	0
IDE05145-ENG116261-Light configuration-Dimmwert CD 20	0
IDE05145-ENG116280-Light configuration-Dimmwert CD 21	0
IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23	0
IDE05145-ENG116337-Light configuration-Dimmwert CD 24	0
IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3	0
IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4	0
IDE05145-ENG115976-Light configuration-Dimmwert CD 5	0
IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8	127
IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10	112
IDE05145-ENG116094-Light configuration-Dimmwert EF 11	113
IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13	64
IDE05145-ENG116151-Light configuration-Dimmwert EF 14	113
IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17	72
IDE05145-ENG116227-Light configuration-Dimmwert EF 18	47
IDE05145-ENG116246-Light configuration-Dimmwert EF 19	49
IDE05145-ENG115923-Light configuration-Dimmwert EF 2	26
IDE05145-ENG116265-Light configuration-Dimmwert EF 20	1
IDE05145-ENG116284-Light configuration-Dimmwert EF 21	96
IDE05145-ENG116303-Light configuration-Dimmwert EF 22	48
IDE05145-ENG116322-Light configuration-Dimmwert EF 23	96
IDE05145-ENG116341-Light configuration-Dimmwert EF 24	82
IDE05145-ENG116360-Light configuration-Dimmwert EF 25	1
IDE05145-ENG116379-Light configuration-Dimmwert EF 26	126
IDE05145-ENG116398-Light configuration-Dimmwert EF 27	1
IDE05145-ENG116417-Light configuration-Dimmwert EF 28	112
IDE05145-ENG116436-Light configuration-Dimmwert EF 29	112
IDE05145-ENG115942-Light configuration-Dimmwert EF 3	26
IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33	32
IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4	127
IDE05145-ENG115980-Light configuration-Dimmwert EF 5	127
IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8	49
IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22	1
IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28	127
IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30	92
IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8	44
IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	0
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	FE
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	0
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	8
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	FE
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	5C
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	1
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	0
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	FE
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	0
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	0
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	1
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	0
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	0
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	1
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	0
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	0
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	1
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	0
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	FE
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	0
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	1
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	1
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	1
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	0
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	34
IDE05145-ENG115873-Light configuration-Lasttyp 0	12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten
IDE05145-ENG116100-Light configuration-Lasttyp 12	not active
IDE05145-ENG116119-Light configuration-Lasttyp 13	2 - Shutter; Diagnosesensierung für 'LED low'
IDE05145-ENG116138-Light configuration-Lasttyp 14	not active
IDE05145-ENG116157-Light configuration-Lasttyp 15	not active
IDE05145-ENG116214-Light configuration-Lasttyp 18	not active
IDE05145-ENG116233-Light configuration-Lasttyp 19	not active
IDE05145-ENG115910-Light configuration-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20	not active
IDE05145-ENG116271-Light configuration-Lasttyp 21	5 - LED Abblendlicht
IDE05145-ENG116290-Light configuration-Lasttyp 22	not active
IDE05145-ENG116328-Light configuration-Lasttyp 24	not active
IDE05145-ENG116366-Light configuration-Lasttyp 26	not active
IDE05145-ENG116404-Light configuration-Lasttyp 28	not active
IDE05145-ENG115929-Light configuration-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116461-Light configuration-Lasttyp 31	not active
IDE05145-ENG116480-Light configuration-Lasttyp 32	not active
IDE05145-ENG116499-Light configuration-Lasttyp 33	not active
IDE05145-ENG116518-Light configuration-Lasttyp 34	not active
IDE05145-ENG115948-Light configuration-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8	not active
IDE05145-ENG116043-Light configuration-Lasttyp 9	44 - LED Fußraum- oder -Innenleuchte
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	only_if_closed
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	only_if_closed
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	only_if_closed
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	only_if_closed
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	only_if_closed
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	only_if_closed
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	only_if_closed
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	Always
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	only_if_closed
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	Always
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	Always
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	only_if_closed
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	254
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	104
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	129
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	1
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	224
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	224
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	128
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	241
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	1
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	112
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	1
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	20
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	40
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	0
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	1
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	128
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	1
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	11
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	0
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	0
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	72
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	47
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	20
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	78
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	112
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	248
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	112
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	0
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	112
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	52
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	0
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	92
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	0
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	0
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	0
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	1
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	0
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	51
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	35
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	255
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	0
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	0
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	0
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	0
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	0
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	254
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	0
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	1
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	0
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	0
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	255
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	16
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	241
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	96
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	4
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	224
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	255
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	0
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	233
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	128
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	176
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	128
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	135
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	1
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	78
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	110
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	166
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	0
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	168
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	169
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	160
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	171
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	172
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	0
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	0
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	255
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	16
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	117
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	47
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	80
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	241
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	1
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	131
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	212
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	8
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	212
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	156
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	1
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	226
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	128
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	1
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	204
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	16
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	8
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	252
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	160
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	8
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	8
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	131
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	16
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	254
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	9
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	254
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	1
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	1
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	9
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	254
IDE05145-ENG115941-Light configuration-Lichtfunktion F3	10
IDE05145-ENG115979-Light configuration-Lichtfunktion F5	10
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	254
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	255
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	255
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	51
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	7
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	230
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	1
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	13
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	136
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	255
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	1
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	16
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	241
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	85
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	160
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	211
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	138
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	47
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	48
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	255
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	212
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	1
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	112
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	160
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	44
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	18.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	16.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	18.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	16.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	38.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	36.00 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	38.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	36.00 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	54.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	52.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	54.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	52.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100%
IDE06425-Roller test bench mode; functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
IDE07356-Position during interval mode	31.49 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit
IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung	not active
IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung	not active
IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer	Faktor fuer x1 Stunden
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min
IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit	0 s
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	active
IDE08542-ENG128459-Access control 2-easycloselight_aktiv	not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by convenience operation via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	not active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art	Permanent
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	Via ZV-Absicherung Light
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	not active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	not active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	not active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active
IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung	not active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	not active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	not active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crashblinken	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panikblinken	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxialarmblinken	not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE09731-ENG125014-Int. light; 2nd generation-Aufloesung Dimmzeit	0.10 s
IDE09731-ENG125024-Int. light; 2nd generation-BAP Farbwert Farbe 1	2
IDE09731-ENG125025-Int. light; 2nd generation-BAP Farbwert Farbe 2	3
IDE09731-ENG125026-Int. light; 2nd generation-BAP Farbwert Farbe 3	1
IDE09731-ENG126827-Int. light; 2nd generation-Blauwert Farbe 1	0
IDE09731-ENG126830-Int. light; 2nd generation-Blauwert Farbe 2	0
IDE09731-ENG126833-Int. light; 2nd generation-Blauwert Farbe 3	0
IDE09731-ENG125018-Int. light; 2nd generation-Cockpitbeleuchtung mehrfarbig	not active
IDE09731-ENG125021-Int. light; 2nd generation-Dachbeleuchtung mehrfarbig	not active
IDE09731-ENG125028-Int. light; 2nd generation-Defaultwert Ambienteprofil Dach	80%
IDE09731-ENG125029-Int. light; 2nd generation-Defaultwert Ambienteprofil Farbe	2
IDE09731-ENG125027-Int. light; 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%
IDE09731-ENG125641-Int. light; 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active
IDE09731-ENG125644-Int. light; 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125640-Int. light; 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active
IDE09731-ENG125642-Int. light; 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active
IDE09731-ENG125643-Int. light; 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125645-Int. light; 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG125639-Int. light; 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	not active
IDE09731-ENG126826-Int. light; 2nd generation-Gruenwert Farbe 1	0
IDE09731-ENG126829-Int. light; 2nd generation-Gruenwert Farbe 2	0
IDE09731-ENG126832-Int. light; 2nd generation-Gruenwert Farbe 3	0
IDE09731-ENG125634-Int. light; 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active
IDE09731-ENG125637-Int. light; 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125633-Int. light; 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	not active
IDE09731-ENG125635-Int. light; 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active
IDE09731-ENG125636-Int. light; 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125638-Int. light; 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG126824-Int. light; 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active
IDE09731-ENG125017-Int. light; 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active
IDE09731-ENG125019-Int. light; 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active
IDE09731-ENG125020-Int. light; 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active
IDE09731-ENG125023-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active
IDE09731-ENG125022-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active
IDE09731-ENG126825-Int. light; 2nd generation-Rotwert Farbe 1	0
IDE09731-ENG126828-Int. light; 2nd generation-Rotwert Farbe 2	0
IDE09731-ENG126831-Int. light; 2nd generation-Rotwert Farbe 3	0
IDE09731-ENG125016-Int. light; 2nd generation-Tuertafelbeleuchtung mehrfarbig	active
IDE09731-ENG125015-Int. light; 2nd generation-weicher Farbwechsel	not active
IDE09732-ENG02312-Interior light; light configuration-Ambient_Farbliste_HMI	not active
IDE09732-ENG115870-Interior light; light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed
IDE09732-ENG115871-Interior light; light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed
IDE09732-ENG115872-Interior light; light configuration-Ambiente_Lautsprecher	not installed
IDE09732-ENG126836-Interior light; light configuration-Ambientemenue mit alle Zonen	not active
IDE09732-ENG126835-Interior light; light configuration-Ambientemenue mit globalem aus	not active
IDE09732-ENG125646-Interior light; light configuration-Cockpitbeleuchtung	not installed
IDE09732-ENG125648-Interior light; light configuration-Dachbeleuchtung	not installed
IDE09732-ENG125651-Interior light; light configuration-Farbwahl ueber Fahrprofil	not installed
IDE09732-ENG125650-Interior light; light configuration-Farbwahl ueber HMI	not installed
IDE09732-ENG02313-Interior light; light configuration-Frei_Farbwahl_ueber_HMI	not active
IDE09732-ENG114629-Interior light; light configuration-Fussraumbeleuchtung	installed
IDE09732-ENG126834-Interior light; light configuration-LIN-Dachkonsole lokal aktivierbar	not active
IDE09732-ENG125647-Interior light; light configuration-Mittelkonsolenbeleuchtung	not installed
IDE09732-ENG125649-Interior light; light configuration-Panoramaschiebedachbeleuchtung	not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%
IDE10298-Alternating park position 1	7.49 °
IDE10299-Alternating park position 2	29.49 °
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement	not active
MAS05055-lower turn position	31.49 °
MAS05056-upper turn position	170.49 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active
MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1	0 s
MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3	0.000 ms
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active
ENG122934-erase_error_table	55 00 00
ENG122933-error_mask	0 bit
ENG117283-Frontwaschfunktion	10
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00%
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00%
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.00%
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.00%
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.00%
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.00%
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.00%
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.00%
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.00%
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	2.00%
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	2.00%
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	6.00%
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	10.00%
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	80.00%
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	100 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	160 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	200 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	260 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
ENG99457-ENG117394-Kopfraumheizung-blower_speed	0
ENG99457-ENG98971-Kopfraumheizung-Temperature	-3
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	nicht aktiv
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	nicht aktiv
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	nicht aktiv
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	nicht aktiv
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	nicht aktiv
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	nicht aktiv
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	nicht aktiv
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter; Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Fernlicht links
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	nicht aktiv
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	nicht aktiv
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	nicht aktiv
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	nicht aktiv
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	nicht aktiv
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	nicht aktiv
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter; Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Fernlicht rechts
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	nicht aktiv
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	nicht aktiv
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	nicht aktiv
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	nicht aktiv
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	nicht aktiv
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	nicht aktiv
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	127
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	6 - LED Lichtmodul
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	nicht aktiv
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	nicht aktiv
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	nicht aktiv
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	nicht aktiv
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	nicht aktiv
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	nicht aktiv
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	nicht aktiv
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	127
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	6 - LED Lichtmodul
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	nicht aktiv
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	nicht aktiv
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	nicht aktiv
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	nicht aktiv
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	nicht aktiv
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	nicht aktiv
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	nicht aktiv
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	nicht aktiv
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	nicht aktiv
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	nicht aktiv
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	nicht aktiv
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	nicht aktiv
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	nicht aktiv
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	nicht aktiv
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	nicht aktiv
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	nicht aktiv
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	nicht aktiv
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	nicht aktiv
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	nicht aktiv
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	nicht aktiv
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	nicht aktiv
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	nicht aktiv
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	nicht aktiv
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	nicht aktiv
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	nicht aktiv
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	nicht aktiv
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	nicht aktiv
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	nicht aktiv
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	nicht aktiv
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	nicht aktiv
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	nicht aktiv
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	0
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	0
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	not active
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	nicht aktiv
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	nicht aktiv
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	nicht aktiv
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	nicht aktiv
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	nicht aktiv
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	nicht aktiv
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	nicht aktiv
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	nicht aktiv
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	0
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	0
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	not active
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	nicht aktiv
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	nicht aktiv
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	nicht aktiv
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	nicht aktiv
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	nicht aktiv
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	nicht aktiv
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	nicht aktiv
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	nicht aktiv
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	nicht aktiv
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	nicht aktiv
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	nicht aktiv
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	nicht aktiv
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	nicht aktiv
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	nicht aktiv
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	nicht aktiv
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	28
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	14 - kombinierte Blink- Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Bremslicht
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	Blinken links Hellphase
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Blinken links Dunkelphase
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	nicht aktiv
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	nicht aktiv
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	nicht aktiv
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	nicht aktiv
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	28
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	14 - kombinierte Blink- Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Bremslicht
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	Blinken rechts Hellphase
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Blinken rechts Dunkelphase
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	nicht aktiv
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	nicht aktiv
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	nicht aktiv
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	nicht aktiv
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Bremslicht
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	nicht aktiv
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	nicht aktiv
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	nicht aktiv
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	nicht aktiv
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	nicht aktiv
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	nicht aktiv
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	nicht aktiv
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	28
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	9 - allgemeine Glühlampe 27W; auch H15
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	nicht aktiv
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	nicht aktiv
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	nicht aktiv
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	nicht aktiv
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	nicht aktiv
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	nicht aktiv
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	nicht aktiv
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	28
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	9 - allgemeine Glühlampe 27W; auch H15
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	nicht aktiv
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	nicht aktiv
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	nicht aktiv
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	nicht aktiv
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	nicht aktiv
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	nicht aktiv
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	nicht aktiv
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	100
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	18 - 2* 5W
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	nicht aktiv
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	nicht aktiv
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	nicht aktiv
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	nicht aktiv
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	nicht aktiv
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	nicht aktiv
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	nicht aktiv
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	127
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	47
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	1 - LED Tagfahrlichtmodul Versorgung
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	nicht aktiv
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	nicht aktiv
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	nicht aktiv
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	nicht aktiv
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	nicht aktiv
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	nicht aktiv
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	nicht aktiv
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	0
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	not active
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	nicht aktiv
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	nicht aktiv
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	nicht aktiv
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	nicht aktiv
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	nicht aktiv
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	nicht aktiv
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	nicht aktiv
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	nicht aktiv
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	9 - allgemeine Glühlampe 27W; auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	nicht aktiv
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	nicht aktiv
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	nicht aktiv
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	nicht aktiv
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	nicht aktiv
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	nicht aktiv
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	nicht aktiv
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W; auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	nicht aktiv
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	nicht aktiv
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	nicht aktiv
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	nicht aktiv
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	nicht aktiv
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	nicht aktiv
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	nicht aktiv
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	minimize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	26
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Tagfahrlicht
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	nicht aktiv
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	nicht aktiv
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	nicht aktiv
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	nicht aktiv
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	nicht aktiv
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Fussraumlicht
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	nicht aktiv
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	nicht aktiv
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	nicht aktiv
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	nicht aktiv
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	nicht aktiv
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	nicht aktiv
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	nicht aktiv
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	nicht aktiv
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	nicht aktiv
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	nicht aktiv
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	nicht aktiv
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	nicht aktiv
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	nicht aktiv
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	nicht aktiv
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	nicht aktiv
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	nicht aktiv
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	nicht aktiv
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	nicht aktiv
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	nicht aktiv
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	nicht aktiv
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	nicht aktiv
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	nicht aktiv
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	nicht aktiv
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	nicht aktiv
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	nicht aktiv
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	nicht aktiv
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	nicht aktiv
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	nicht aktiv
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	nicht aktiv
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	nicht aktiv
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	nicht aktiv
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	nicht aktiv
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	nicht aktiv
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	nicht aktiv
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	nicht aktiv
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	nicht aktiv
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	nicht aktiv
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	nicht aktiv
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	nicht aktiv
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	minimize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	26
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Tagfahrlicht
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	nicht aktiv
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	nicht aktiv
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	nicht aktiv
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	Parklicht rechts
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	nicht aktiv
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	nicht aktiv
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Tagfahrlicht
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	nicht aktiv
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	nicht aktiv
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	nicht aktiv
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	nicht aktiv
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	nicht aktiv
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Tagfahrlicht
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	nicht aktiv
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	nicht aktiv
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	nicht aktiv
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	Parklicht rechts
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	nicht aktiv
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	nicht aktiv
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	nicht aktiv
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	nicht aktiv
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	nicht aktiv
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	nicht aktiv
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	nicht aktiv
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	nicht aktiv
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	nicht aktiv
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	nicht aktiv
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	nicht aktiv
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	nicht aktiv
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	nicht aktiv
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	nicht aktiv
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	26
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	35
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	36 - LED Kleinleistung
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	nicht aktiv
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	nicht aktiv
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	nicht aktiv
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	nicht aktiv
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	nicht aktiv
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	nicht aktiv
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	27
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	3F
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	36 - LED Kleinleistung
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Parklicht rechts
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	nicht aktiv
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	nicht aktiv
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	nicht aktiv
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	nicht aktiv
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	nicht aktiv
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	nicht aktiv
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	nicht aktiv
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	nicht aktiv
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	nicht aktiv
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	nicht aktiv
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	nicht aktiv
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	nicht aktiv
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	nicht aktiv
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	nicht aktiv
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung	not active
ENG122927-RLS_close_glazing	2.00 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s
ENG122929-RLS_LIN_Communication	4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	500 lx
ENG122930-RLS_tunel_gateway_recognize	5 s
ENG122935-RLS_Washer_Front	15 s
ENG122926-RLS_wiper_position_parking	15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute	40
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute	60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30
Here's a really old 09 map from when I first got the car, using 14.7.2
;SW:5Q0-937-087-K   HW:5Q0-937-087-K ---  Cent. Elect.
;Component:BCM PQ37BOSCH 026 0097, Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc,012003,EV_BCMBOSCH_SE37.rod
;Monday,18,August,2014,20:25:50:23603
;VCDS Version: Beta 14.7.2 (x64)  Data version: 20140714
;VCID: 438E9FAACAC9EB22DE-8016
(1)-A/C heater function via remote control-Anzahl zulaessiger Remotestarts,2
(2)-A/C heater function via remote control-RemoteStart Betrieb Dauer,10 min
(1)-Access control-Funk bei Klemme 15 ein,not active
(2)-Access control-Notschließfunktion,active
(3)-Access control-automatisches Verriegeln bei Geschwindigkeit,active
(4)-Access control-automatisches Entriegeln,active
(5)-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
(6)-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung
(7)-Access control-CAN Wecken bei Softtouchbetaetigung,active
(8)-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
(9)-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
(10)-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
(11)-Access control-Valet Parking,not active
(12)-Access control-Direkter Auswurf des Heckdeckels,active
(13)-Access control-ZV entriegelt auch Heckdeckel,active
(14)-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
(15)-Access control-Autolock Autounlock wirkt auf Heck,active
(16)-Access control-ZV Heck nur direkt auswerfen,not active
(17)-Access control-Manuelle ZV Variantenprogrammierung,not active
(18)-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
(19)-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
(20)-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
(21)-Access control-ZV-Entriegelung nach Seitencrash,not active
(22)-Access control-Elektrische Laderaumabdeckung,not active
(23)-Access control-Menuesteuerung Tuerentriegelung,active
(24)-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
(25)-Access control-Autounlock NAR,active
(26)-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
(27)-Access control-Softtouch-Betätigung senden,Always
(28)-Access control-Servoheck Schlossansteuerung,Always
(29)-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
(1)-Access control 2-Komfortbedienung global,active
(2)-Access control 2-Comfort opening,not active
(3)-Access control 2-Comfort closing,active
(4)-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
(5)-Access control 2-Nachsaven_nach_Verdecklauf,not active
(6)-Access control 2-Funk Komfort schliessen,not active
(7)-Access control 2-Funk Komfort oeffnen,not active
(8)-Access control 2-Schliesszylinder Komfort oeffnen,not active
(9)-Access control 2-Schliesszylinder Komfort schliessen,active
(10)-Access control 2-SAD Richtung Komfortoeffnen,tilting
(11)-Access control 2-SAD Komfort schliessen,active
(12)-Access control 2-SAD Komfort oeffnen,active
(13)-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
(14)-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
(15)-Access control 2-Regenschliessen_ein_aus,not active
(16)-Access control 2-Regenschliessen_art,once
(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active
(18)-Access control 2-Spiegelverstellung Synchron,not active
(19)-Access control 2-Kessy Komfort oeffnen,No
(20)-Access control 2-Kessy Komfort schliessen,Yes
(21)-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,No
(22)-Access control 2-Menuesteuerung Spiegelabsenkung,not active
(23)-Access control 2-Funk Spiegelanklappen,not active
(24)-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key
(25)-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active
(26)-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
(27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active
(28)-Access control 2-Menuesteuerung Regenschliessen,not active
(29)-Access control 2-SAD PreCrash Konturschliessen,not active
(30)-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
(31)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
(32)-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
(33)-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light
(34)-Access control 2-Profilfunktion für Anklappung der Außenspiegel,not active
(35)-Access control 2-Signalisierung_Spiegelanklappung,not active
(36)-Access control 2-Virtuelles_Pedal,not active
(37)-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
(1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln,No
(2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln,Yes
(3)-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
(4)-Acknowledgement signals-Optical feedback during locking,Decelerate
(5)-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
(6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
(7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
(8)-Acknowledgement signals-Akustische Rueckmeldung global,active
(9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
Activating and deactivating all development messages,not active
(1)-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
(2)-After-run for park light-Standlicht-Nachlaufzeit,30 min
Alternating park position 1,7.494498 °
Alternating park position 2,29.494476 °
(1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %
(2)-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %
(3)-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %
(4)-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
(5)-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
(6)-Ambient lighting-Innenlichtinszenierung,Enabled
(7)-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled
(1)-Anti-theft device-Alarmsignal,frequency modulated
(2)-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
(3)-Anti-theft device-DWA Alarmverzoegerung,not active
(4)-Anti-theft device-DWA Camper Modus,not active
(5)-Anti-theft device-Überwachung Innenentriegelungshebel,not active
(6)-Anti-theft device-Sirenen Alarmzahl,1 Alarm
(7)-Anti-theft device-Akustischer Alarm Signalhorn,active
(1)-Assistance light functions-Notbremsanzeige NBA,not active
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent,not installed
(3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
(4)-Assistance light functions-Fernlichtassistent Reset,not active
(5)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
(6)-Assistance light functions-Assistenzfahrlicht bei Regen,active
(7)-Assistance light functions-AFL Zeitverzoegerung,2000 ms
(8)-Assistance light functions-Lichtsensorempfindlichkeit,normal
(1)-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
(2)-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
(3)-Auxiliary functions-Signalhorn ohne KL15,active
(4)-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
(5)-Auxiliary functions-Menuesteuerung Garagentoroeffner,not active
(1)-Characteristic curve-x0,0 lx
(2)-Characteristic curve-X1,2000 lx
(3)-Characteristic curve-X2,4000 lx
(4)-Characteristic curve-X3,6000 lx
(5)-Characteristic curve-X4,8000 lx
(6)-Characteristic curve-X5,10200 lx
(7)-Characteristic curve-y1_0,0
(8)-Characteristic curve-y1_1,40
(9)-Characteristic curve-y1_2,90
(10)-Characteristic curve-y1_3,140
(11)-Characteristic curve-y1_4,190
(12)-Characteristic curve-y1_5,245
(13)-Characteristic curve-y2_0,0
(14)-Characteristic curve-y2_1,60
(15)-Characteristic curve-y2_2,110
(16)-Characteristic curve-y2_3,160
(17)-Characteristic curve-y2_4,210
(18)-Characteristic curve-y2_5,255
Characteristics in production mode,0 ms
(1)-Comfort illumination-Coming Home Verbaustatus,automatic
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
(3)-Comfort illumination-Menueeinstellung Cominghome,10 s
(4)-Comfort illumination-Coming Home Leuchten,Low beam
(5)-Comfort illumination-Coming-home Einschaltereignis,Driver door
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,2
(7)-Comfort illumination-Leaving-Home Verbausstatus,Enabled
(8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
(9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung,116
(1)-Convert. top oper.-Komfortbedienung Verdeck global,active
(2)-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
(3)-Convert. top oper.-Komfortbedienung Verdeck schließen,active
(4)-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
(5)-Convert. top oper.-Verdeck schließen via Schließzylinder,active
(6)-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
(7)-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
(8)-Convert. top oper.-Verdeck oeffnen via Kessy,active
(9)-Convert. top oper.-Verdeck schließen via Kessy,active
(10)-Convert. top oper.-Doppelpuls nur Verdeck,active
(11)-Convert. top oper.-Verdeck mit Schiebedach,not active
(12)-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
(13)-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
(8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
Deactivate production mode,0
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
(3)-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus,active
(4)-Driving light and parking light-Parklicht ueber LSS aktiviert,not active
(5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active
(6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,not active
(7)-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
(8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
(9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
(10)-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
(11)-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
(12)-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
(14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
(3)-Dyn. turn signal modes-ZV_Blinken_zu,not active
(4)-Dyn. turn signal modes-ZV_Blinken_auf,not active
(5)-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
(8)-Dyn. turn signal modes-Taxialarmblinken,not active
(9)-Dyn. turn signal modes-Panikblinken,not active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
(13)-Dyn. turn signal modes-Richtungs_blinken_links,not active
(14)-Dyn. turn signal modes-ABBA_Blinken,not active
(15)-Dyn. turn signal modes-Crashblinken,not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
Energy management,active
(1)-Head area heater-blower_speed,0
(2)-Head area heater-Temperature,-3
(1)-Int. light; 2nd generation-Aufloesung Dimmzeit,0.10 s
(2)-Int. light; 2nd generation-weicher Farbwechsel,not active
(3)-Int. light; 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
(4)-Int. light; 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
(5)-Int. light; 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
(6)-Int. light; 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
(7)-Int. light; 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
(8)-Int. light; 2nd generation-Dachbeleuchtung mehrfarbig,not active
(9)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
(10)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
(11)-Int. light; 2nd generation-BAP Farbwert Farbe 1,2
(12)-Int. light; 2nd generation-BAP Farbwert Farbe 2,3
(13)-Int. light; 2nd generation-BAP Farbwert Farbe 3,1
(14)-Int. light; 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
(15)-Int. light; 2nd generation-Defaultwert Ambienteprofil Dach,80 %
(16)-Int. light; 2nd generation-Defaultwert Ambienteprofil Farbe,2
(17)-Int. light; 2nd generation-Helligkeit Türtafelbeleuchtung nicht berechnen,not active
(18)-Int. light; 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
(19)-Int. light; 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
(20)-Int. light; 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
(21)-Int. light; 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
(22)-Int. light; 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
(23)-Int. light; 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
(24)-Int. light; 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
(25)-Int. light; 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
(26)-Int. light; 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
(27)-Int. light; 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
(28)-Int. light; 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
(29)-Int. light; 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
(30)-Int. light; 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
(1)-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active
(2)-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
(3)-Interior lighting-KL30G ohne PWM,not active
(4)-Interior lighting-KL58 Einschalten mit Rampe,not active
(5)-Interior lighting-KL58 Verriegelungsausschalten,not active
(6)-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
(7)-Interior lighting-Suchbeleuchtung Festwert,100 %
(1)-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s
(2)-LED bar setting values-Sperrzeit,0 s
(3)-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms
(4)-LED bar setting values-Filterzeit Anpassung,3000 ms
(5)-LED bar setting values-Maximale Helligkeitsdifferenz,25
(6)-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx
(7)-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx
(8)-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 W/m²
(1)-Light configuration-Lasttyp 0,12 - Blinkleuchten
(2)-Light configuration-BAP Bitposition 0,34
(3)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Light configuration-Lichtfunktion A 0,2
(5)-Light configuration-Lichtfunktion B 0,0
(6)-Light configuration-Dimmwert AB 0,100
(7)-Light configuration-Lichtansteuerung HD AB 0,Always
(8)-Light configuration-Lichtfunktion C 0,0
(9)-Light configuration-Lichtfunktion D 0,0
(10)-Light configuration-Dimmwert CD 0,0
(11)-Light configuration-Dimming Direction CD 0,maximize
(12)-Light configuration-Lichtfunktion E 0,0
(13)-Light configuration-Lichtfunktion F 0,0
(14)-Light configuration-Dimmwert EF 0,0
(15)-Light configuration-Dimming Direction EF 0,maximize
(16)-Light configuration-Lichtfunktion G 0,0
(17)-Light configuration-Lichtfunktion H 0,0
(18)-Light configuration-Dimmwert GH 0,0
(19)-Light configuration-Dimming Direction GH 0,maximize
(20)-Light configuration-Lasttyp 1,12 - Blinkleuchten
(21)-Light configuration-BAP Bitposition 1,3E
(22)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
(23)-Light configuration-Lichtfunktion A 1,4
(24)-Light configuration-Lichtfunktion B 1,0
(25)-Light configuration-Dimmwert AB 1,100
(26)-Light configuration-Lichtansteuerung HD AB 1,Always
(27)-Light configuration-Lichtfunktion C 1,0
(28)-Light configuration-Lichtfunktion D 1,0
(29)-Light configuration-Dimmwert CD 1,0
(30)-Light configuration-Dimming Direction CD 1,maximize
(31)-Light configuration-Lichtfunktion E 1,0
(32)-Light configuration-Lichtfunktion F 1,0
(33)-Light configuration-Dimmwert EF 1,0
(34)-Light configuration-Dimming Direction EF 1,maximize
(35)-Light configuration-Lichtfunktion G 1,0
(36)-Light configuration-Lichtfunktion H 1,0
(37)-Light configuration-Dimmwert GH 1,0
(38)-Light configuration-Dimming Direction GH 1,maximize
(39)-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
(40)-Light configuration-BAP Bitposition 2,48
(41)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
(42)-Light configuration-Lichtfunktion A 2,20
(43)-Light configuration-Lichtfunktion B 2,0
(44)-Light configuration-Dimmwert AB 2,100
(45)-Light configuration-Lichtansteuerung HD AB 2,Always
(46)-Light configuration-Lichtfunktion C 2,6
(47)-Light configuration-Lichtfunktion D 2,0
(48)-Light configuration-Dimmwert CD 2,0
(49)-Light configuration-Dimming Direction CD 2,minimize
(50)-Light configuration-Lichtfunktion E 2,8
(51)-Light configuration-Lichtfunktion F 2,9
(52)-Light configuration-Dimmwert EF 2,26
(53)-Light configuration-Dimming Direction EF 2,maximize
(54)-Light configuration-Lichtfunktion G 2,0
(55)-Light configuration-Lichtfunktion H 2,0
(56)-Light configuration-Dimmwert GH 2,0
(57)-Light configuration-Dimming Direction GH 2,maximize
(58)-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
(59)-Light configuration-BAP Bitposition 3,4C
(60)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C
(61)-Light configuration-Lichtfunktion A 3,20
(62)-Light configuration-Lichtfunktion B 3,0
(63)-Light configuration-Dimmwert AB 3,100
(64)-Light configuration-Lichtansteuerung HD AB 3,Always
(65)-Light configuration-Lichtfunktion C 3,7
(66)-Light configuration-Lichtfunktion D 3,0
(67)-Light configuration-Dimmwert CD 3,0
(68)-Light configuration-Dimming Direction CD 3,minimize
(69)-Light configuration-Lichtfunktion E 3,8
(70)-Light configuration-Lichtfunktion F3,10
(71)-Light configuration-Dimmwert EF 3,26
(72)-Light configuration-Dimming Direction EF 3,maximize
(73)-Light configuration-Lichtfunktion G 3,0
(74)-Light configuration-Lichtfunktion H 3,0
(75)-Light configuration-Dimmwert GH 3,0
(76)-Light configuration-Dimming Direction GH 3,maximize
(77)-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
(78)-Light configuration-BAP Bitposition 4,3A
(79)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49
(80)-Light configuration-Lichtfunktion A 4,20
(81)-Light configuration-Lichtfunktion B 4,0
(82)-Light configuration-Dimmwert AB 4,127
(83)-Light configuration-Lichtansteuerung HD AB 4,Always
(84)-Light configuration-Lichtfunktion C 4,6
(85)-Light configuration-Lichtfunktion D 4,0
(86)-Light configuration-Dimmwert CD 4,0
(87)-Light configuration-Dimming Direction CD 4,minimize
(88)-Light configuration-Lichtfunktion E 4,8
(89)-Light configuration-Lichtfunktion F 4,9
(90)-Light configuration-Dimmwert EF 4,127
(91)-Light configuration-Dimming Direction EF 4,maximize
(92)-Light configuration-Lichtfunktion G 4,0
(93)-Light configuration-Lichtfunktion H 4,0
(94)-Light configuration-Dimmwert GH 4,0
(95)-Light configuration-Dimming Direction GH 4,maximize
(96)-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
(97)-Light configuration-BAP Bitposition 5,44
(98)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B
(99)-Light configuration-Lichtfunktion A 5,20
(100)-Light configuration-Lichtfunktion B 5,0
(101)-Light configuration-Dimmwert AB 5,127
(102)-Light configuration-Lichtansteuerung HD AB 5,Always
(103)-Light configuration-Lichtfunktion C 5,7
(104)-Light configuration-Lichtfunktion D 5,0
(105)-Light configuration-Dimmwert CD 5,0
(106)-Light configuration-Dimming Direction CD 5,minimize
(107)-Light configuration-Lichtfunktion E 5,8
(108)-Light configuration-Lichtfunktion F5,10
(109)-Light configuration-Dimmwert EF 5,127
(110)-Light configuration-Dimming Direction EF 5,maximize
(111)-Light configuration-Lichtfunktion G 5,0
(112)-Light configuration-Lichtfunktion H 5,0
(113)-Light configuration-Dimmwert GH 5,0
(114)-Light configuration-Dimming Direction GH 5,maximize
(115)-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht
(116)-Light configuration-BAP Bitposition 6,36
(117)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
(118)-Light configuration-Lichtfunktion A 6,11
(119)-Light configuration-Lichtfunktion B 6,15
(120)-Light configuration-Dimmwert AB 6,127
(121)-Light configuration-Lichtansteuerung HD AB 6,Always
(122)-Light configuration-Lichtfunktion C 6,0
(123)-Light configuration-Lichtfunktion D 6,0
(124)-Light configuration-Dimmwert CD 6,0
(125)-Light configuration-Dimming Direction CD 6,maximize
(126)-Light configuration-Lichtfunktion E 6,0
(127)-Light configuration-Lichtfunktion F 6,0
(128)-Light configuration-Dimmwert EF 6,0
(129)-Light configuration-Dimming Direction EF 6,maximize
(130)-Light configuration-Lichtfunktion G 6,0
(131)-Light configuration-Lichtfunktion H 6,0
(132)-Light configuration-Dimmwert GH 6,0
(133)-Light configuration-Dimming Direction GH 6,maximize
(134)-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht
(135)-Light configuration-BAP Bitposition 7,40
(136)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
(137)-Light configuration-Lichtfunktion A 7,12
(138)-Light configuration-Lichtfunktion B 7,15
(139)-Light configuration-Dimmwert AB 7,127
(140)-Light configuration-Lichtansteuerung HD AB 7,Always
(141)-Light configuration-Lichtfunktion C 7,0
(142)-Light configuration-Lichtfunktion D 7,0
(143)-Light configuration-Dimmwert CD 7,0
(144)-Light configuration-Dimming Direction CD 7,maximize
(145)-Light configuration-Lichtfunktion E 7,0
(146)-Light configuration-Lichtfunktion F 7,0
(147)-Light configuration-Dimmwert EF 7,0
(148)-Light configuration-Dimming Direction EF 7,maximize
(149)-Light configuration-Lichtfunktion G 7,0
(150)-Light configuration-Lichtfunktion H 7,0
(151)-Light configuration-Dimmwert GH 7,1
(152)-Light configuration-Dimming Direction GH 7,maximize
(153)-Light configuration-Lasttyp 8,3 - Xenon Abblendlicht
(154)-Light configuration-BAP Bitposition 8,00
(155)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,01
(156)-Light configuration-Lichtfunktion A 8,4
(157)-Light configuration-Lichtfunktion B 8,0
(158)-Light configuration-Dimmwert AB 8,0
(159)-Light configuration-Lichtansteuerung HD AB 8,Always
(160)-Light configuration-Lichtfunktion C 8,0
(161)-Light configuration-Lichtfunktion D 8,183
(162)-Light configuration-Dimmwert CD 8,0
(163)-Light configuration-Dimming Direction CD 8,maximize
(164)-Light configuration-Lichtfunktion E 8,0
(165)-Light configuration-Lichtfunktion F 8,0
(166)-Light configuration-Dimmwert EF 8,0
(167)-Light configuration-Dimming Direction EF 8,maximize
(168)-Light configuration-Lichtfunktion G 8,0
(169)-Light configuration-Lichtfunktion H 8,12
(170)-Light configuration-Dimmwert GH 8,1
(171)-Light configuration-Dimming Direction GH 8,maximize
(172)-Light configuration-Lasttyp 9,1 - LED Tagfahrlichtmodul Versorgung
(173)-Light configuration-BAP Bitposition 9,00
(174)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,01
(175)-Light configuration-Lichtfunktion A 9,1
(176)-Light configuration-Lichtfunktion B 9,0
(177)-Light configuration-Dimmwert AB 9,0
(178)-Light configuration-Lichtansteuerung HD AB 9,Always
(179)-Light configuration-Lichtfunktion C 9,0
(180)-Light configuration-Lichtfunktion D 9,144
(181)-Light configuration-Dimmwert CD 9,0
(182)-Light configuration-Dimming Direction CD 9,maximize
(183)-Light configuration-Lichtfunktion E 9,21
(184)-Light configuration-Lichtfunktion F 9,1
(185)-Light configuration-Dimmwert EF 9,28
(186)-Light configuration-Dimming Direction EF 9,minimize
(187)-Light configuration-Lichtfunktion G 9,0
(188)-Light configuration-Lichtfunktion H 9,0
(189)-Light configuration-Dimmwert GH 9,1
(190)-Light configuration-Dimming Direction GH 9,maximize
(191)-Light configuration-Lasttyp 10,36 - LED Kleinleistung
(192)-Light configuration-BAP Bitposition 10,00
(193)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00
(194)-Light configuration-Lichtfunktion A 10,192
(195)-Light configuration-Lichtfunktion B 10,0
(196)-Light configuration-Dimmwert AB 10,105
(197)-Light configuration-Lichtansteuerung HD AB 10,Always
(198)-Light configuration-Lichtfunktion C 10,1
(199)-Light configuration-Lichtfunktion D 10,176
(200)-Light configuration-Dimmwert CD 10,1
(201)-Light configuration-Dimming Direction CD 10,maximize
(202)-Light configuration-Lichtfunktion E 10,12
(203)-Light configuration-Lichtfunktion F 10,0
(204)-Light configuration-Dimmwert EF 10,0
(205)-Light configuration-Dimming Direction EF 10,maximize
(206)-Light configuration-Lichtfunktion G 10,0
(207)-Light configuration-Lichtfunktion H 10,0
(208)-Light configuration-Dimmwert GH 10,0
(209)-Light configuration-Dimming Direction GH 10,maximize
(210)-Light configuration-Lasttyp 11,not active
(211)-Light configuration-BAP Bitposition 11,00
(212)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00
(213)-Light configuration-Lichtfunktion A 11,0
(214)-Light configuration-Lichtfunktion B 11,0
(215)-Light configuration-Dimmwert AB 11,90
(216)-Light configuration-Lichtansteuerung HD AB 11,only_if_closed
(217)-Light configuration-Lichtfunktion C 11,1
(218)-Light configuration-Lichtfunktion D 11,0
(219)-Light configuration-Dimmwert CD 11,0
(220)-Light configuration-Dimming Direction CD 11,maximize
(221)-Light configuration-Lichtfunktion E 11,251
(222)-Light configuration-Lichtfunktion F 11,68
(223)-Light configuration-Dimmwert EF 11,48
(224)-Light configuration-Dimming Direction EF 11,minimize
(225)-Light configuration-Lichtfunktion G 11,1
(226)-Light configuration-Lichtfunktion H 11,0
(227)-Light configuration-Dimmwert GH 11,0
(228)-Light configuration-Dimming Direction GH 11,maximize
(229)-Light configuration-Lasttyp 12,1 - LED Tagfahrlichtmodul Versorgung
(230)-Light configuration-BAP Bitposition 12,00
(231)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,00
(232)-Light configuration-Lichtfunktion A 12,0
(233)-Light configuration-Lichtfunktion B 12,0
(234)-Light configuration-Dimmwert AB 12,75
(235)-Light configuration-Lichtansteuerung HD AB 12,only_if_closed
(236)-Light configuration-Lichtfunktion C 12,68
(237)-Light configuration-Lichtfunktion D 12,176
(238)-Light configuration-Dimmwert CD 12,1
(239)-Light configuration-Dimming Direction CD 12,maximize
(240)-Light configuration-Lichtfunktion E 12,0
(241)-Light configuration-Lichtfunktion F 12,0
(242)-Light configuration-Dimmwert EF 12,1
(243)-Light configuration-Dimming Direction EF 12,maximize
(244)-Light configuration-Lichtfunktion G 12,0
(245)-Light configuration-Lichtfunktion H 12,0
(246)-Light configuration-Dimmwert GH 12,0
(247)-Light configuration-Dimming Direction GH 12,maximize
(248)-Light configuration-Lasttyp 13,1 - LED Tagfahrlichtmodul Versorgung
(249)-Light configuration-BAP Bitposition 13,00
(250)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,01
(251)-Light configuration-Lichtfunktion A 13,1
(252)-Light configuration-Lichtfunktion B 13,0
(253)-Light configuration-Dimmwert AB 13,58
(254)-Light configuration-Lichtansteuerung HD AB 13,only_if_closed
(255)-Light configuration-Lichtfunktion  C 13,1
(256)-Light configuration-Lichtfunktion D 13,55
(257)-Light configuration-Dimmwert CD 13,1
(258)-Light configuration-Dimming Direction CD 13,maximize
(259)-Light configuration-Lichtfunktion E 13,247
(260)-Light configuration-Lichtfunktion F 13,0
(261)-Light configuration-Dimmwert EF 13,48
(262)-Light configuration-Dimming Direction EF 13,minimize
(263)-Light configuration-Lichtfunktion G 13,1
(264)-Light configuration-Lichtfunktion H 13,0
(265)-Light configuration-Dimmwert GH 13,0
(266)-Light configuration-Dimming Direction GH 13,maximize
(267)-Light configuration-Lasttyp 14,1 - LED Tagfahrlichtmodul Versorgung
(268)-Light configuration-BAP Bitposition 14,00
(269)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00
(270)-Light configuration-Lichtfunktion A 14,0
(271)-Light configuration-Lichtfunktion B 14,0
(272)-Light configuration-Dimmwert AB 14,111
(273)-Light configuration-Lichtansteuerung HD AB 14,only_if_closed
(274)-Light configuration-Lichtfunktion C 14,1
(275)-Light configuration-Lichtfunktion D 14,1
(276)-Light configuration-Dimmwert CD 14,0
(277)-Light configuration-Dimming Direction CD 14,maximize
(278)-Light configuration-Lichtfunktion E 14,1
(279)-Light configuration-Lichtfunktion F 14,0
(280)-Light configuration-Dimmwert EF 14,0
(281)-Light configuration-Dimming Direction EF 14,maximize
(282)-Light configuration-Lichtfunktion G 14,0
(283)-Light configuration-Lichtfunktion H 14,240
(284)-Light configuration-Dimmwert GH 14,0
(285)-Light configuration-Dimming Direction GH 14,maximize
(286)-Light configuration-Lasttyp 15,not active
(287)-Light configuration-BAP Bitposition 15,00
(288)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,01
(289)-Light configuration-Lichtfunktion A 15,58
(290)-Light configuration-Lichtfunktion B 15,0
(291)-Light configuration-Dimmwert AB 15,64
(292)-Light configuration-Lichtansteuerung HD AB 15,Always
(293)-Light configuration-Lichtfunktion C 15,1
(294)-Light configuration-Lichtfunktion D 15,58
(295)-Light configuration-Dimmwert CD 15,0
(296)-Light configuration-Dimming Direction CD 15,maximize
(297)-Light configuration-Lichtfunktion E 15,9
(298)-Light configuration-Lichtfunktion F 15,50
(299)-Light configuration-Dimmwert EF 15,115
(300)-Light configuration-Dimming Direction EF 15,minimize
(301)-Light configuration-Lichtfunktion G 15,0
(302)-Light configuration-Lichtfunktion H 15,0
(303)-Light configuration-Dimmwert GH 15,0
(304)-Light configuration-Dimming Direction GH 15,maximize
(305)-Light configuration-Lasttyp 16,not active
(306)-Light configuration-BAP Bitposition 16,00
(307)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,92
(308)-Light configuration-Lichtfunktion A 16,16
(309)-Light configuration-Lichtfunktion B 16,0
(310)-Light configuration-Dimmwert AB 16,34
(311)-Light configuration-Lichtansteuerung HD AB 16,only_if_closed
(312)-Light configuration-Lichtfunktion C 16,0
(313)-Light configuration-Lichtfunktion D 16,16
(314)-Light configuration-Dimmwert CD 16,0
(315)-Light configuration-Dimming Direction CD 16,maximize
(316)-Light configuration-Lichtfunktion E 16,5
(317)-Light configuration-Lichtfunktion F 16,0
(318)-Light configuration-Dimmwert EF 16,72
(319)-Light configuration-Dimming Direction EF 16,maximize
(320)-Light configuration-Lichtfunktion G 16,0
(321)-Light configuration-Lichtfunktion H 16,208
(322)-Light configuration-Dimmwert GH 16,0
(323)-Light configuration-Dimming Direction GH 16,maximize
(325)-Light configuration-BAP Bitposition 17,00
(326)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00
(327)-Light configuration-Lichtfunktion A 17,80
(328)-Light configuration-Lichtfunktion  B 17,0
(329)-Light configuration-Dimmwert AB 17,83
(330)-Light configuration-Lichtansteuerung HD AB 17,Always
(331)-Light configuration-Lichtfunktion C 17,1
(332)-Light configuration-Lichtfunktion D 17,1
(333)-Light configuration-Dimmwert CD 17,0
(334)-Light configuration-Dimming Direction CD 17,maximize
(335)-Light configuration-Lichtfunktion E 17,16
(336)-Light configuration-Lichtfunktion F 17,0
(337)-Light configuration-Dimmwert EF 17,72
(338)-Light configuration-Dimming Direction EF 17,maximize
(339)-Light configuration-Lichtfunktion G 17,0
(340)-Light configuration-Lichtfunktion H 17,255
(341)-Light configuration-Dimmwert GH 17,0
(342)-Light configuration-Dimming Direction GH 17,maximize
(343)-Light configuration-Lasttyp 18,not active
(344)-Light configuration-BAP Bitposition 18,00
(345)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,01
(346)-Light configuration-Lichtfunktion A 18,215
(347)-Light configuration-Lichtfunktion B 18,0
(348)-Light configuration-Dimmwert AB 18,5
(349)-Light configuration-Lichtansteuerung HD AB 18,Always
(350)-Light configuration-Lichtfunktion C 18,0
(351)-Light configuration-Lichtfunktion D 18,5
(352)-Light configuration-Dimmwert CD 18,0
(353)-Light configuration-Dimming Direction CD 18,maximize
(354)-Light configuration-Lichtfunktion E 18,0
(355)-Light configuration-Lichtfunktion F 18,0
(356)-Light configuration-Dimmwert EF 18,14
(357)-Light configuration-Dimming Direction EF 18,maximize
(358)-Light configuration-Lichtfunktion G 18,0
(359)-Light configuration-Lichtfunktion H 18,13
(360)-Light configuration-Dimmwert GH 18,85
(361)-Light configuration-Dimming Direction GH 18,maximize
(363)-Light configuration-BAP Bitposition 19,01
(364)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,01
(365)-Light configuration-Lichtfunktion A 19,0
(366)-Light configuration-Lichtfunktion B 19,0
(367)-Light configuration-Dimmwert AB 19,0
(368)-Light configuration-Lichtansteuerung HD AB 19,Always
(369)-Light configuration-Lichtfunktion C 19,0
(370)-Light configuration-Lichtfunktion D 19,0
(371)-Light configuration-Dimmwert CD 19,0
(372)-Light configuration-Dimming Direction CD 19,maximize
(373)-Light configuration-Lichtfunktion E 19,0
(374)-Light configuration-Lichtfunktion F 19,0
(375)-Light configuration-Dimmwert EF 19,0
(376)-Light configuration-Dimming Direction EF 19,maximize
(377)-Light configuration-Lichtfunktion G 19,0
(378)-Light configuration-Lichtfunktion H 19,251
(379)-Light configuration-Dimmwert GH 19,1
(380)-Light configuration-Dimming Direction GH 19,maximize
(381)-Light configuration-Lasttyp 20,not active
(382)-Light configuration-BAP Bitposition 20,00
(383)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,00
(384)-Light configuration-Lichtfunktion A 20,0
(385)-Light configuration-Lichtfunktion B 20,0
(386)-Light configuration-Dimmwert AB 20,0
(387)-Light configuration-Lichtansteuerung HD AB 20,Always
(388)-Light configuration-Lichtfunktion C 20,0
(389)-Light configuration-Lichtfunktion D 20,62
(390)-Light configuration-Dimmwert CD 20,0
(391)-Light configuration-Dimming Direction CD 20,maximize
(392)-Light configuration-Lichtfunktion E 20,34
(393)-Light configuration-Lichtfunktion F 20,1
(394)-Light configuration-Dimmwert EF 20,0
(395)-Light configuration-Dimming Direction EF 20,maximize
(396)-Light configuration-Lichtfunktion G 20,0
(397)-Light configuration-Lichtfunktion H 20,0
(398)-Light configuration-Dimmwert GH 20,0
(399)-Light configuration-Dimming Direction GH 20,maximize
(400)-Light configuration-Lasttyp 21,not active
(401)-Light configuration-BAP Bitposition 21,00
(402)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,00
(403)-Light configuration-Lichtfunktion A 21,0
(404)-Light configuration-Lichtfunktion B 21,0
(405)-Light configuration-Dimmwert AB 21,0
(406)-Light configuration-Lichtansteuerung HD AB 21,Always
(407)-Light configuration-Lichtfunktion C 21,0
(408)-Light configuration-Lichtfunktion D 21,0
(409)-Light configuration-Dimmwert CD 21,0
(410)-Light configuration-Dimming Direction CD 21,maximize
(411)-Light configuration-Lichtfunktion E 21,0
(412)-Light configuration-Lichtfunktion F 21,0
(413)-Light configuration-Dimmwert EF 21,0
(414)-Light configuration-Dimming Direction EF 21,maximize
(415)-Light configuration-Lichtfunktion G 21,0
(416)-Light configuration-Lichtfunktion H 21,0
(417)-Light configuration-Dimmwert GH 21,0
(418)-Light configuration-Dimming Direction GH 21,maximize
(419)-Light configuration-Lasttyp 22,not active
(420)-Light configuration-BAP Bitposition 22,00
(421)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,00
(422)-Light configuration-Lichtfunktion A 22,0
(423)-Light configuration-Lichtfunktion B 22,0
(424)-Light configuration-Dimmwert AB 22,0
(425)-Light configuration-Lichtansteuerung HD AB 22,Always
(426)-Light configuration-Lichtfunktion C 22,0
(427)-Light configuration-Lichtfunktion D 22,0
(428)-Light configuration-Dimmwert CD 22,0
(429)-Light configuration-Dimming Direction CD 22,maximize
(430)-Light configuration-Lichtfunktion E 22,0
(431)-Light configuration-Lichtfunktion F 22,0
(432)-Light configuration-Dimmwert EF 22,11
(433)-Light configuration-Dimming Direction EF 22,maximize
(434)-Light configuration-Lichtfunktion G 22,68
(435)-Light configuration-Lichtfunktion H 22,1
(436)-Light configuration-Dimmwert GH 22,0
(437)-Light configuration-Dimming Direction GH 22,maximize
(439)-Light configuration-BAP Bitposition 23,00
(440)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,01
(441)-Light configuration-Lichtfunktion A 23,162
(442)-Light configuration-Lichtfunktion B 23,0
(443)-Light configuration-Dimmwert AB 23,80
(444)-Light configuration-Lichtansteuerung HD AB 23,Always
(445)-Light configuration-Lichtfunktion C 23,0
(446)-Light configuration-Lichtfunktion D 23,80
(447)-Light configuration-Dimmwert CD 23,0
(448)-Light configuration-Dimming Direction CD 23,maximize
(449)-Light configuration-Lichtfunktion E 23,1
(450)-Light configuration-Lichtfunktion F 23,0
(451)-Light configuration-Dimmwert EF 23,16
(452)-Light configuration-Dimming Direction EF 23,maximize
(453)-Light configuration-Lichtfunktion G 23,0
(454)-Light configuration-Lichtfunktion H 23,170
(455)-Light configuration-Dimmwert GH 23,1
(456)-Light configuration-Dimming Direction GH 23,maximize
(457)-Light configuration-Lasttyp 24,not active
(458)-Light configuration-BAP Bitposition 24,00
(459)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00
(460)-Light configuration-Lichtfunktion A 24,0
(461)-Light configuration-Lichtfunktion B 24,0
(462)-Light configuration-Dimmwert AB 24,1
(463)-Light configuration-Lichtansteuerung HD AB 24,Always
(464)-Light configuration-Lichtfunktion C 24,0
(465)-Light configuration-Lichtfunktion D 24,16
(466)-Light configuration-Dimmwert CD 24,0
(467)-Light configuration-Dimming Direction CD 24,maximize
(468)-Light configuration-Lichtfunktion E 24,145
(469)-Light configuration-Lichtfunktion F 24,0
(470)-Light configuration-Dimmwert EF 24,112
(471)-Light configuration-Dimming Direction EF 24,maximize
(472)-Light configuration-Lichtfunktion G 24,1
(473)-Light configuration-Lichtfunktion H 24,16
(474)-Light configuration-Dimmwert GH 24,0
(475)-Light configuration-Dimming Direction GH 24,maximize
(477)-Light configuration-BAP Bitposition 25,00
(478)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,00
(479)-Light configuration-Lichtfunktion A 25,212
(480)-Light configuration-Lichtfunktion B 25,0
(481)-Light configuration-Dimmwert AB 25,30
(482)-Light configuration-Lichtansteuerung HD AB 25,Always
(483)-Light configuration-Lichtfunktion C 25,1
(484)-Light configuration-Lichtfunktion D 25,112
(485)-Light configuration-Dimmwert CD 25,1
(486)-Light configuration-Dimming Direction CD 25,maximize
(487)-Light configuration-Lichtfunktion E 25,80
(488)-Light configuration-Lichtfunktion F 25,0
(489)-Light configuration-Dimmwert EF 25,1
(490)-Light configuration-Dimming Direction EF 25,maximize
(491)-Light configuration-Lichtfunktion G 25,0
(492)-Light configuration-Lichtfunktion H 25,0
(493)-Light configuration-Dimmwert GH 25,0
(494)-Light configuration-Dimming Direction GH 25,maximize
(495)-Light configuration-Lasttyp 26,not active
(496)-Light configuration-BAP Bitposition 26,00
(497)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00
(498)-Light configuration-Lichtfunktion A 26,0
(499)-Light configuration-Lichtfunktion B 26,0
(500)-Light configuration-Dimmwert AB 26,78
(501)-Light configuration-Lichtansteuerung HD AB 26,Always
(502)-Light configuration-Lichtfunktion C 26,0
(503)-Light configuration-Lichtfunktion D 26,0
(504)-Light configuration-Dimmwert CD 26,0
(505)-Light configuration-Dimming Direction CD 26,maximize
(506)-Light configuration-Lichtfunktion E 26,1
(507)-Light configuration-Lichtfunktion F 26,0
(508)-Light configuration-Dimmwert EF 26,78
(509)-Light configuration-Dimming Direction EF 26,maximize
(510)-Light configuration-Lichtfunktion G 26,0
(511)-Light configuration-Lichtfunktion H 26,1
(512)-Light configuration-Dimmwert GH 26,0
(513)-Light configuration-Dimming Direction GH 26,maximize
(515)-Light configuration-BAP Bitposition 27,FE
(516)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00
(517)-Light configuration-Lichtfunktion A 27,254
(518)-Light configuration-Lichtfunktion B 27,255
(519)-Light configuration-Dimmwert AB 27,1
(520)-Light configuration-Lichtansteuerung HD AB 27,Always
(521)-Light configuration-Lichtfunktion C 27,0
(522)-Light configuration-Lichtfunktion D 27,0
(523)-Light configuration-Dimmwert CD 27,0
(524)-Light configuration-Dimming Direction CD 27,maximize
(525)-Light configuration-Lichtfunktion E 27,0
(526)-Light configuration-Lichtfunktion F 27,1
(527)-Light configuration-Dimmwert EF 27,24
(528)-Light configuration-Dimming Direction EF 27,maximize
(529)-Light configuration-Lichtfunktion G 27,0
(530)-Light configuration-Lichtfunktion H 27,136
(531)-Light configuration-Dimmwert GH 27,0
(532)-Light configuration-Dimming Direction GH 27,maximize
(533)-Light configuration-Lasttyp 28,1 - LED Tagfahrlichtmodul Versorgung
(534)-Light configuration-BAP Bitposition 28,00
(535)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,00
(536)-Light configuration-Lichtfunktion A 28,0
(537)-Light configuration-Lichtfunktion B 28,0
(538)-Light configuration-Dimmwert AB 28,19
(539)-Light configuration-Lichtansteuerung HD AB 28,only_if_closed
(540)-Light configuration-Lichtfunktion C 28,1
(541)-Light configuration-Lichtfunktion D 28,72
(542)-Light configuration-Dimmwert CD 28,0
(543)-Light configuration-Dimming Direction CD 28,maximize
(544)-Light configuration-Lichtfunktion E 28,1
(545)-Light configuration-Lichtfunktion F 28,1
(546)-Light configuration-Dimmwert EF 28,0
(547)-Light configuration-Dimming Direction EF 28,maximize
(548)-Light configuration-Lichtfunktion G 28,0
(549)-Light configuration-Lichtfunktion H 28,0
(550)-Light configuration-Dimmwert GH 28,0
(551)-Light configuration-Dimming Direction GH 28,maximize
(553)-Light configuration-BAP Bitposition 29,00
(554)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,FF
(555)-Light configuration-Lichtfunktion A 29,255
(556)-Light configuration-Lichtfunktion B 29,255
(557)-Light configuration-Dimmwert AB 29,67
(558)-Light configuration-Lichtansteuerung HD AB 29,Always
(559)-Light configuration-Lichtfunktion C 29,0
(560)-Light configuration-Lichtfunktion D 29,239
(561)-Light configuration-Dimmwert CD 29,0
(562)-Light configuration-Dimming Direction CD 29,maximize
(563)-Light configuration-Lichtfunktion E 29,40
(564)-Light configuration-Lichtfunktion F 29,0
(565)-Light configuration-Dimmwert EF 29,42
(566)-Light configuration-Dimming Direction EF 29,maximize
(567)-Light configuration-Lichtfunktion G 29,0
(568)-Light configuration-Lichtfunktion H 29,16
(569)-Light configuration-Dimmwert GH 29,0
(570)-Light configuration-Dimming Direction GH 29,maximize
(571)-Light configuration-Lasttyp 30,not active
(572)-Light configuration-BAP Bitposition 30,00
(573)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00
(574)-Light configuration-Lichtfunktion A 30,132
(575)-Light configuration-Lichtfunktion B 30,0
(576)-Light configuration-Dimmwert AB 30,80
(577)-Light configuration-Lichtansteuerung HD AB 30,only_if_closed
(578)-Light configuration-Lichtfunktion C 30,254
(579)-Light configuration-Lichtfunktion D 30,78
(580)-Light configuration-Dimmwert CD 30,0
(581)-Light configuration-Dimming Direction CD 30,maximize
(582)-Light configuration-Lichtfunktion E 30,78
(583)-Light configuration-Lichtfunktion F 30,0
(584)-Light configuration-Dimmwert EF 30,61
(585)-Light configuration-Dimming Direction EF 30,maximize
(586)-Light configuration-Lichtfunktion G 30,0
(587)-Light configuration-Lichtfunktion H 30,0
(588)-Light configuration-Dimmwert GH 30,0
(589)-Light configuration-Dimming Direction GH 30,maximize
(590)-Light configuration-Lasttyp 31,not active
(591)-Light configuration-BAP Bitposition 31,00
(592)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00
(593)-Light configuration-Lichtfunktion A 31,0
(594)-Light configuration-Lichtfunktion B 31,0
(595)-Light configuration-Dimmwert AB 31,123
(596)-Light configuration-Lichtansteuerung HD AB 31,only_if_closed
(597)-Light configuration-Lichtfunktion C 31,0
(598)-Light configuration-Lichtfunktion D 31,0
(599)-Light configuration-Dimmwert CD 31,0
(600)-Light configuration-Dimming Direction CD 31,maximize
(601)-Light configuration-Lichtfunktion E 31,78
(602)-Light configuration-Lichtfunktion F 31,0
(603)-Light configuration-Dimmwert EF 31,80
(604)-Light configuration-Dimming Direction EF 31,maximize
(605)-Light configuration-Lichtfunktion G 31,0
(606)-Light configuration-Lichtfunktion H 31,118
(607)-Light configuration-Dimmwert GH 31,0
(608)-Light configuration-Dimming Direction GH 31,maximize
(609)-Light configuration-Lasttyp 32,not active
(610)-Light configuration-BAP Bitposition 32,00
(611)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00
(612)-Light configuration-Lichtfunktion A 32,5
(613)-Light configuration-Lichtfunktion B 32,0
(614)-Light configuration-Dimmwert AB 32,96
(615)-Light configuration-Lichtansteuerung HD AB 32,only_if_closed
(616)-Light configuration-Lichtfunktion C 32,1
(617)-Light configuration-Lichtfunktion D 32,248
(618)-Light configuration-Dimmwert CD 32,1
(619)-Light configuration-Dimming Direction CD 32,maximize
(620)-Light configuration-Lichtfunktion E 32,52
(621)-Light configuration-Lichtfunktion F 32,1
(622)-Light configuration-Dimmwert EF 32,0
(623)-Light configuration-Dimming Direction EF 32,minimize
(624)-Light configuration-Lichtfunktion G 32,0
(625)-Light configuration-Lichtfunktion H 32,52
(626)-Light configuration-Dimmwert GH 32,1
(627)-Light configuration-Dimming Direction GH 32,maximize
(628)-Light configuration-Lasttyp 33,not active
(629)-Light configuration-BAP Bitposition 33,00
(630)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00
(631)-Light configuration-Lichtfunktion A 33,0
(632)-Light configuration-Lichtfunktion B 33,0
(633)-Light configuration-Dimmwert AB 33,72
(634)-Light configuration-Lichtansteuerung HD AB 33,Always
(635)-Light configuration-Lichtfunktion C 33,1
(636)-Light configuration-Lichtfunktion D 33,0
(637)-Light configuration-Dimmwert CD 33,0
(638)-Light configuration-Dimming Direction CD 33,maximize
(639)-Light configuration-Lichtfunktion E 33,78
(640)-Light configuration-Lichtfunktion F 33,0
(641)-Light configuration-Dimmwert EF 33,118
(642)-Light configuration-Dimming Direction EF 33,maximize
(643)-Light configuration-Lichtfunktion G 33,0
(644)-Light configuration-Lichtfunktion H 33,0
(645)-Light configuration-Dimmwert GH 33,0
(646)-Light configuration-Dimming Direction GH 33,maximize
(648)-Light configuration-BAP Bitposition 34,00
(649)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00
(650)-Light configuration-Lichtfunktion A 34,0
(651)-Light configuration-Lichtfunktion B 34,0
(652)-Light configuration-Dimmwert AB 34,10
(653)-Light configuration-Lichtansteuerung HD AB 34,Always
(654)-Light configuration-Lichtfunktion C 34,1
(655)-Light configuration-Lichtfunktion D 34,0
(656)-Light configuration-Dimmwert CD 34,0
(657)-Light configuration-Dimming Direction CD 34,maximize
(658)-Light configuration-Lichtfunktion E 34,0
(659)-Light configuration-Lichtfunktion F 34,0
(660)-Light configuration-Dimmwert EF 34,9
(661)-Light configuration-Dimming Direction EF 34,minimize
(662)-Light configuration-Lichtfunktion G 34,0
(663)-Light configuration-Lichtfunktion H 34,128
(664)-Light configuration-Dimmwert GH 34,0
(665)-Light configuration-Dimming Direction GH 34,maximize
lower turn position,31.494474 °
No display,5 s
(1)-No display-p_n_regenlichtschwelle_high,12 s
(2)-No display-p_n_regenlichtschwelle_low,6
(3)-No display-p_lx_regenlichtschwelle,6000 lx
(4)-No display-p_t_regenlicht,30 s
Position during interval mode,31.494474 °
(1)-Production mode-Scheinwerferreinigung,Deactivating
(2)-Production mode-Frontwischer deaktivieren,Deactivating
(3)-Production mode-Heckwischer,Deactivating
(4)-Production mode-Interior lighting,Deactivating
(5)-Production mode-Aussenbeleuchtung,Deactivating
(6)-Production mode-Access control,Deactivating
(7)-Production mode-Virtuel_pedal,Deactivating
Read parameter address,FE 00 00
(1)-Rear Window Wiper-Komfortwischen Heck,active
(2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
(3)-Rear Window Wiper-Automatisches Heckwischen,not active
(4)-Rear Window Wiper-Traenenwischen Heck,active
(5)-Rear Window Wiper-Heckwischer Weiterlauf,not active
(6)-Rear Window Wiper-Kein automatisches Abparken,not active
(7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
(8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
(9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
(10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
Roller test bench mode; functional,not active
(1)-Seat fan charac. curve-Stage 1,25 %
(2)-Seat fan charac. curve-Stage 1,30 %
(3)-Seat fan charac. curve-Stage 2,25 %
(4)-Seat fan charac. curve-Stage 2,30 %
(5)-Seat fan charac. curve-Stage 3,53 %
(6)-Seat fan charac. curve-Stage 3,58 %
(7)-Seat fan charac. curve-Stage 4,53 %
(8)-Seat fan charac. curve-Stage 4,58 %
(9)-Seat fan charac. curve-Stage 5,80 %
(10)-Seat fan charac. curve-Stage 5,85 %
(11)-Seat fan charac. curve-Stage 6,80 %
(12)-Seat fan charac. curve-Stage 6,85 %
(1)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,16.00 °C
(2)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.00 °C
(3)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,16.00 °C
(4)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.00 °C
(5)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.00 °C
(6)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,38.00 °C
(7)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.00 °C
(8)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,38.00 °C
(9)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.00 °C
(10)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C
(11)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.00 °C
(12)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C
(13)-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s
(14)-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C
Service position,170.494336 °
(1)-static AFS light-bei Rueckwaertsfahrt,both sides
(2)-static AFS light-Vorschrift,ECE R119
(3)-static AFS light-Lower speed threshold,0.0 km/h
(4)-static AFS light-Upper speed threshold,40.0 km/h
(5)-static AFS light-Steering wheel angle; offset,-63.75 °
(6)-static AFS light-Unterer Lenkradwinkel,180 °
(7)-static AFS light-Oberer Lenkradwinkel,120 °
(8)-static AFS light-Abdimmgeschwindigkeit,50.0 %/s
(9)-static AFS light-Maximaltemperatur,100.0 °C
(10)-static AFS light-obere Grenztemperatur,95.0 °C
(11)-static AFS light-untere Grenztemperatur,80.0 °C
Transport mode,active
(1)-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
(2)-Turn signal control-Komfortblinken Blinkzyklen,3
(3)-Turn signal control-Sonderfunktionen,not enabled
(4)-Turn signal control-Signalprioritaet fuer Blinker,MFG
(5)-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separate
(6)-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
(7)-Turn signal control-Komfortblinken,active
(8)-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.0 %
(9)-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.100 %
upper turn position,170.494336 °
(1)-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active
(2)-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value
(3)-Window heater-Heckscheibenheizung Zeitwert,600 s
(4)-Window heater-Running time of heated front window,240 s
(5)-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C
(6)-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C
(1)-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
(2)-Windshield wiper-SRA Verzoegerungszeit,0 ms
(3)-Windshield wiper-SRA Waschzeit,0 ms
(4)-Windshield wiper-SRA Einweichpausenzeit,0 ms
(5)-Windshield wiper-SRA Nachwaschzeit,0 ms
(6)-Windshield wiper-SRA Pausenzeit,0 ms
(7)-Windshield wiper-SRA bei Waschwassermangel,not active
(8)-Windshield wiper-Frontwischer Referenzlauf,active
(9)-Windshield wiper-Variable Regensensoraktivierung,not active
(10)-Windshield wiper-Wischer stop bei KL15 aus,not active
(11)-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
(12)-Windshield wiper-Regensensor aktivieren,Deactivating
(13)-Windshield wiper-Menuesteuerung Frontwischer,not active
(14)-Windshield wiper-Frontwischer Notlaufprogramm,active
(15)-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
(16)-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
(17)-Windshield wiper-Traenenwischen Front Status,not active
(18)-Windshield wiper-Adaptives Nachwischen bei SRA,not active
(19)-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
(1)-Writing parameter-Parameter address,FE 00 00
(2)-Writing parameter-Value,130
erase_error_table,5570560
error_mask,0
Frontwaschfunktion,10
(1)-Innenbeleuchtung Abdimmen-x0,0 ms
(2)-Innenbeleuchtung Abdimmen-X1,200 ms
(3)-Innenbeleuchtung Abdimmen-X2,400 ms
(4)-Innenbeleuchtung Abdimmen-X3,600 ms
(5)-Innenbeleuchtung Abdimmen-X4,800 ms
(6)-Innenbeleuchtung Abdimmen-X5,1000 ms
(7)-Innenbeleuchtung Abdimmen-X6,1200 ms
(8)-Innenbeleuchtung Abdimmen-x7,1400 ms
(9)-Innenbeleuchtung Abdimmen-x8,1600 ms
(10)-Innenbeleuchtung Abdimmen-x9,1800 ms
(11)-Innenbeleuchtung Abdimmen-x10,2000 ms
(12)-Innenbeleuchtung Abdimmen-y0,100.0 %
(13)-Innenbeleuchtung Abdimmen-Y1,72.0 %
(14)-Innenbeleuchtung Abdimmen-Y2,48.0 %
(15)-Innenbeleuchtung Abdimmen-Y3,33.0 %
(16)-Innenbeleuchtung Abdimmen-Y4,18.0 %
(17)-Innenbeleuchtung Abdimmen-Y5,12.0 %
(18)-Innenbeleuchtung Abdimmen-Y6,8.0 %
(19)-Innenbeleuchtung Abdimmen-y7,6.0 %
(20)-Innenbeleuchtung Abdimmen-y8,4.0 %
(21)-Innenbeleuchtung Abdimmen-y9,2.0 %
(22)-Innenbeleuchtung Abdimmen-y10,0.0 %
(1)-Innenbeleuchtung Fotosensor-x0,0
(2)-Innenbeleuchtung Fotosensor-X1,50
(3)-Innenbeleuchtung Fotosensor-X2,100
(4)-Innenbeleuchtung Fotosensor-X3,200
(5)-Innenbeleuchtung Fotosensor-X4,253
(6)-Innenbeleuchtung Fotosensor-X5,0
(7)-Innenbeleuchtung Fotosensor-X6,0
(8)-Innenbeleuchtung Fotosensor-x7,0
(9)-Innenbeleuchtung Fotosensor-x8,0
(10)-Innenbeleuchtung Fotosensor-x9,0
(11)-Innenbeleuchtung Fotosensor-x10,0
(12)-Innenbeleuchtung Fotosensor-y0,0 lx
(13)-Innenbeleuchtung Fotosensor-Y1,50 lx
(14)-Innenbeleuchtung Fotosensor-Y2,100 lx
(15)-Innenbeleuchtung Fotosensor-Y3,200 lx
(16)-Innenbeleuchtung Fotosensor-Y4,500 lx
(17)-Innenbeleuchtung Fotosensor-Y5,0 lx
(18)-Innenbeleuchtung Fotosensor-Y6,0 lx
(19)-Innenbeleuchtung Fotosensor-y7,0 lx
(20)-Innenbeleuchtung Fotosensor-y8,0 lx
(21)-Innenbeleuchtung Fotosensor-y9,0 lx
(22)-Innenbeleuchtung Fotosensor-y10,0 lx
(1)-Innenbeleuchtung Hochdimmen-x0,0 ms
(2)-Innenbeleuchtung Hochdimmen-X1,200 ms
(3)-Innenbeleuchtung Hochdimmen-X2,400 ms
(4)-Innenbeleuchtung Hochdimmen-X3,600 ms
(5)-Innenbeleuchtung Hochdimmen-X4,800 ms
(6)-Innenbeleuchtung Hochdimmen-X5,1000 ms
(7)-Innenbeleuchtung Hochdimmen-X6,1200 ms
(8)-Innenbeleuchtung Hochdimmen-x7,1400 ms
(9)-Innenbeleuchtung Hochdimmen-x8,1600 ms
(10)-Innenbeleuchtung Hochdimmen-x9,1800 ms
(11)-Innenbeleuchtung Hochdimmen-x10,2000 ms
(12)-Innenbeleuchtung Hochdimmen-y0,0.0 %
(13)-Innenbeleuchtung Hochdimmen-Y1,1.0 %
(14)-Innenbeleuchtung Hochdimmen-Y2,3.0 %
(15)-Innenbeleuchtung Hochdimmen-Y3,5.0 %
(16)-Innenbeleuchtung Hochdimmen-Y4,11.0 %
(17)-Innenbeleuchtung Hochdimmen-Y5,22.0 %
(18)-Innenbeleuchtung Hochdimmen-Y6,40.0 %
(19)-Innenbeleuchtung Hochdimmen-y7,80.0 %
(20)-Innenbeleuchtung Hochdimmen-y8,95.0 %
(21)-Innenbeleuchtung Hochdimmen-y9,100.0 %
(22)-Innenbeleuchtung Hochdimmen-y10,100.0 %
(1)-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %
(2)-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %
(3)-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %
(4)-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %
(5)-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %
(6)-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %
(7)-Innenbeleuchtung KL 58xd log Bus-y0,10
(8)-Innenbeleuchtung KL 58xd log Bus-Y1,10
(9)-Innenbeleuchtung KL 58xd log Bus-Y2,100
(10)-Innenbeleuchtung KL 58xd log Bus-Y3,150
(11)-Innenbeleuchtung KL 58xd log Bus-Y4,220
(12)-Innenbeleuchtung KL 58xd log Bus-Y5,253
(1)-Innenbeleuchtung KL 58xd max-x0,0 lx
(2)-Innenbeleuchtung KL 58xd max-X1,8 lx
(3)-Innenbeleuchtung KL 58xd max-X2,200 lx
(4)-Innenbeleuchtung KL 58xd max-X3,300 lx
(5)-Innenbeleuchtung KL 58xd max-X4,500 lx
(6)-Innenbeleuchtung KL 58xd max-y0,16.0 %
(7)-Innenbeleuchtung KL 58xd max-Y1,16.0 %
(8)-Innenbeleuchtung KL 58xd max-Y2,100.0 %
(9)-Innenbeleuchtung KL 58xd max-Y3,100.0 %
(10)-Innenbeleuchtung KL 58xd max-Y4,100.0 %
(1)-Innenbeleuchtung KL 58xd min-x0,0 lx
(2)-Innenbeleuchtung KL 58xd min-X1,8 lx
(3)-Innenbeleuchtung KL 58xd min-X2,220 lx
(4)-Innenbeleuchtung KL 58xd min-X3,300 lx
(5)-Innenbeleuchtung KL 58xd min-X4,500 lx
(6)-Innenbeleuchtung KL 58xd min-y0,6.0 %
(7)-Innenbeleuchtung KL 58xd min-Y1,6.0 %
(8)-Innenbeleuchtung KL 58xd min-Y2,100.0 %
(9)-Innenbeleuchtung KL 58xd min-Y3,100.0 %
(10)-Innenbeleuchtung KL 58xd min-Y4,100.0 %
(1)-Innenbeleuchtung KL 58xd PWM-x0,0
(2)-Innenbeleuchtung KL 58xd PWM-X1,10
(3)-Innenbeleuchtung KL 58xd PWM-X2,50
(4)-Innenbeleuchtung KL 58xd PWM-X3,100
(5)-Innenbeleuchtung KL 58xd PWM-X4,220
(6)-Innenbeleuchtung KL 58xd PWM-X5,253
(7)-Innenbeleuchtung KL 58xd PWM-y0,2.0 %
(8)-Innenbeleuchtung KL 58xd PWM-Y1,2.0 %
(9)-Innenbeleuchtung KL 58xd PWM-Y2,6.0 %
(10)-Innenbeleuchtung KL 58xd PWM-Y3,10.0 %
(11)-Innenbeleuchtung KL 58xd PWM-Y4,80.0 %
(12)-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %
(1)-Innenbeleuchtung KL 58xs max-x0,0 lx
(2)-Innenbeleuchtung KL 58xs max-X1,8 lx
(3)-Innenbeleuchtung KL 58xs max-X2,50 lx
(4)-Innenbeleuchtung KL 58xs max-X3,500 lx
(5)-Innenbeleuchtung KL 58xs max-y0,100.0 %
(6)-Innenbeleuchtung KL 58xs max-Y1,100.0 %
(7)-Innenbeleuchtung KL 58xs max-Y2,100.0 %
(8)-Innenbeleuchtung KL 58xs max-Y3,100.0 %
(1)-Innenbeleuchtung KL 58xs PWM-x0,0.0 %
(2)-Innenbeleuchtung KL 58xs PWM-X1,50.0 %
(3)-Innenbeleuchtung KL 58xs PWM-X2,100.0 %
(4)-Innenbeleuchtung KL 58xs PWM-y0,0.0 %
(5)-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %
(6)-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %
(1)-Innenbeleuchtung KL 58xt max-x0,0 lx
(2)-Innenbeleuchtung KL 58xt max-X1,8 lx
(3)-Innenbeleuchtung KL 58xt max-X2,50 lx
(4)-Innenbeleuchtung KL 58xt max-X3,500 lx
(5)-Innenbeleuchtung KL 58xt max-y0,100.0 %
(6)-Innenbeleuchtung KL 58xt max-Y1,100.0 %
(7)-Innenbeleuchtung KL 58xt max-Y2,100.0 %
(8)-Innenbeleuchtung KL 58xt max-Y3,100.0 %
(1)-Innenbeleuchtung KL 58xt min-x0,0 lx
(2)-Innenbeleuchtung KL 58xt min-X1,8 lx
(3)-Innenbeleuchtung KL 58xt min-X2,50 lx
(4)-Innenbeleuchtung KL 58xt min-X3,500 lx
(5)-Innenbeleuchtung KL 58xt min-y0,6.0 %
(6)-Innenbeleuchtung KL 58xt min-Y1,6.0 %
(7)-Innenbeleuchtung KL 58xt min-Y2,100.0 %
(8)-Innenbeleuchtung KL 58xt min-Y3,100.0 %
(1)-Innenbeleuchtung KL 58xt PWM-x0,0.0 %
(2)-Innenbeleuchtung KL 58xt PWM-X1,50.0 %
(3)-Innenbeleuchtung KL 58xt PWM-X2,100.0 %
(4)-Innenbeleuchtung KL 58xt PWM-y0,0.0 %
(5)-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %
(6)-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %
(1)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
(2)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms
(3)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms
(4)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms
(5)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms
(6)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %
(7)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0
(8)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0
(9)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.0
(10)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0
(1)-InnenbeleuchtungKL 58xs min-x0,0 lx
(2)-InnenbeleuchtungKL 58xs min-X1,8 lx
(3)-InnenbeleuchtungKL 58xs min-X2,50 lx
(4)-InnenbeleuchtungKL 58xs min-X3,500 lx
(5)-InnenbeleuchtungKL 58xs min-y0,6.0 %
(6)-InnenbeleuchtungKL 58xs min-Y1,6.0 %
(7)-InnenbeleuchtungKL 58xs min-Y2,100.0 %
(8)-InnenbeleuchtungKL 58xs min-Y3,100.0 %
(1)-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
(2)-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
(3)-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
(7)-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
(1)-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37
(3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E
(4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam
(5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell
(6)-Leuchte10SHUTTER LB23-Dimmwert AB 10,127
(7)-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
(8)-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
(9)-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
(10)-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
(11)-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
(12)-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
(13)-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
(14)-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
(15)-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
(16)-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
(17)-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
(18)-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
(19)-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
(1)-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41
(3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F
(4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam
(5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell
(6)-Leuchte11SHUTTER RB22-Dimmwert AB 11,127
(7)-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
(8)-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
(9)-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
(10)-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
(11)-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
(12)-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
(13)-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
(14)-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
(15)-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
(16)-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
(17)-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
(18)-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
(19)-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
(1)-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul
(2)-Leuchte12NL LB45-Lampendefektbitposition 12,38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
(4)-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12,not active
(6)-Leuchte12NL LB45-Dimmwert AB 12,127
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
(8)-Leuchte12NL LB45-Lichtfunktion C 12,not active
(9)-Leuchte12NL LB45-Lichtfunktion D 12,not active
(10)-Leuchte12NL LB45-Dimmwert CD 12,0
(11)-Leuchte12NL LB45-Dimming Direction CD 12,maximize
(12)-Leuchte12NL LB45-Lichtfunktion E 12,not active
(13)-Leuchte12NL LB45-Lichtfunktion F 12,not active
(14)-Leuchte12NL LB45-Dimmwert EF 12,0
(15)-Leuchte12NL LB45-Dimming Direction EF 12,maximize
(16)-Leuchte12NL LB45-Lichtfunktion G 12,not active
(17)-Leuchte12NL LB45-Lichtfunktion H 12,not active
(18)-Leuchte12NL LB45-Dimmwert GH 12,0
(19)-Leuchte12NL LB45-Dimming Direction GH 12,maximize
(1)-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul
(2)-Leuchte13NL RB5-Lampendefektbitposition 13,42
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
(4)-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13,not active
(6)-Leuchte13NL RB5-Dimmwert AB 13,127
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
(8)-Leuchte13NL RB5-Lichtfunktion C 13,not active
(9)-Leuchte13NL RB5-Lichtfunktion D 13,not active
(10)-Leuchte13NL RB5-Dimmwert CD 13,0
(11)-Leuchte13NL RB5-Dimming Direction CD 13,maximize
(12)-Leuchte13NL RB5-Lichtfunktion E 13,not active
(13)-Leuchte13NL RB5-Lichtfunktion F 13,not active
(14)-Leuchte13NL RB5-Dimmwert EF 13,0
(15)-Leuchte13NL RB5-Dimming Direction EF 13,maximize
(16)-Leuchte13NL RB5-Lichtfunktion G 13,not active
(17)-Leuchte13NL RB5-Lichtfunktion H 13,not active
(18)-Leuchte13NL RB5-Dimmwert GH 13,0
(19)-Leuchte13NL RB5-Dimming Direction GH 13,maximize
(1)-Leuchte15AL RB44-Lasttyp 15,not active
(2)-Leuchte15AL RB44-Lampendefektbitposition 15,00
(3)-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
(4)-Leuchte15AL RB44-Lichtfunktion A 15,not active
(5)-Leuchte15AL RB44-Lichtfunktion B 15,not active
(6)-Leuchte15AL RB44-Dimmwert AB 15,0
(7)-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
(8)-Leuchte15AL RB44-Lichtfunktion C 15,not active
(9)-Leuchte15AL RB44-Lichtfunktion D 15,not active
(10)-Leuchte15AL RB44-Dimmwert CD 15,0
(11)-Leuchte15AL RB44-Dimming Direction CD 15,maximize
(12)-Leuchte15AL RB44-Lichtfunktion E 15,not active
(13)-Leuchte15AL RB44-Lichtfunktion F 15,not active
(14)-Leuchte15AL RB44-Dimmwert EF 15,0
(15)-Leuchte15AL RB44-Dimming Direction EF 15,maximize
(16)-Leuchte15AL RB44-Lichtfunktion G 15,not active
(17)-Leuchte15AL RB44-Lichtfunktion H 15,not active
(18)-Leuchte15AL RB44-Dimmwert GH 15,0
(19)-Leuchte15AL RB44-Dimming Direction GH 15,maximize
(1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active
(2)-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00
(3)-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00
(4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active
(5)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0
(7)-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
(8)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
(9)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
(10)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
(11)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
(12)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
(13)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
(14)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
(15)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
(16)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
(17)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
(18)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
(19)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
(1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active
(2)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00
(3)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00
(4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active
(5)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active
(6)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0
(7)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
(8)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
(9)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
(10)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
(11)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
(12)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
(13)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
(14)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
(15)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
(16)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
(17)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
(18)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
(19)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
(1)-Leuchte18BLK HLA60-Lasttyp 18,not active
(2)-Leuchte18BLK HLA60-Lampendefektbitposition 18,00
(3)-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00
(4)-Leuchte18BLK HLA60-Lichtfunktion A 18,not active
(5)-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
(6)-Leuchte18BLK HLA60-Dimmwert AB 18,0
(7)-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
(8)-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
(9)-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
(10)-Leuchte18BLK HLA60-Dimmwert CD 18,0
(11)-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
(12)-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
(13)-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
(14)-Leuchte18BLK HLA60-Dimmwert EF 18,0
(15)-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
(16)-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
(17)-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
(18)-Leuchte18BLK HLA60-Dimmwert GH 18,0
(19)-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
(1)-Leuchte19BLK HRC31-Lasttyp 19,not active
(2)-Leuchte19BLK HRC31-Lampendefektbitposition 19,00
(3)-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00
(4)-Leuchte19BLK HRC31-Lichtfunktion A 19,not active
(5)-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
(6)-Leuchte19BLK HRC31-Dimmwert AB 19,0
(7)-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
(8)-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
(9)-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
(10)-Leuchte19BLK HRC31-Dimmwert CD 19,0
(11)-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
(12)-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
(13)-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
(14)-Leuchte19BLK HRC31-Dimmwert EF 19,0
(15)-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
(16)-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
(17)-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
(18)-Leuchte19BLK HRC31-Dimmwert GH 19,0
(19)-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
(1)-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
(2)-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
(3)-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
(4)-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
(5)-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
(6)-Leuchte1BLK VRB20-Dimmwert AB 1,100
(7)-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
(8)-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
(9)-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 1,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
(13)-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
(14)-Leuchte1BLK VRB20-Dimmwert EF 1,0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
(17)-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
(18)-Leuchte1BLK VRB20-Dimmwert GH 1,0
(19)-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
(1)-Leuchte20BR LA71-Lasttyp 20,14 - kombinierte Blink- Bremsleuchten
(2)-Leuchte20BR LA71-Lampendefektbitposition 20,13
(3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D
(4)-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
(5)-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase
(6)-Leuchte20BR LA71-Dimmwert AB 20,100
(7)-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
(8)-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase
(9)-Leuchte20BR LA71-Lichtfunktion D 20,not active
(10)-Leuchte20BR LA71-Dimmwert CD 20,0
(11)-Leuchte20BR LA71-Dimming Direction CD 20,minimize
(12)-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte20BR LA71-Lichtfunktion F 20,not active
(14)-Leuchte20BR LA71-Dimmwert EF 20,28
(15)-Leuchte20BR LA71-Dimming Direction EF 20,maximize
(16)-Leuchte20BR LA71-Lichtfunktion G 20,not active
(17)-Leuchte20BR LA71-Lichtfunktion H 20,not active
(18)-Leuchte20BR LA71-Dimmwert GH 20,0
(19)-Leuchte20BR LA71-Dimming Direction GH 20,maximize
(1)-Leuchte21BR RC8-Lasttyp 21,14 - kombinierte Blink- Bremsleuchten
(2)-Leuchte21BR RC8-Lampendefektbitposition 21,23
(3)-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E
(4)-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
(5)-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase
(6)-Leuchte21BR RC8-Dimmwert AB 21,100
(7)-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
(8)-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase
(9)-Leuchte21BR RC8-Lichtfunktion D 21,not active
(10)-Leuchte21BR RC8-Dimmwert CD 21,0
(11)-Leuchte21BR RC8-Dimming Direction CD 21,minimize
(12)-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte21BR RC8-Lichtfunktion F 21,not active
(14)-Leuchte21BR RC8-Dimmwert EF 21,28
(15)-Leuchte21BR RC8-Dimming Direction EF 21,maximize
(16)-Leuchte21BR RC8-Lichtfunktion G 21,not active
(17)-Leuchte21BR RC8-Lichtfunktion H 21,not active
(18)-Leuchte21BR RC8-Dimmwert GH 21,0
(19)-Leuchte21BR RC8-Dimming Direction GH 21,maximize
(1)-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
(2)-Leuchte22BR MA57-Lampendefektbitposition 22,29
(3)-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
(4)-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
(5)-Leuchte22BR MA57-Lichtfunktion B 22,not active
(6)-Leuchte22BR MA57-Dimmwert AB 22,100
(7)-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
(8)-Leuchte22BR MA57-Lichtfunktion C 22,not active
(9)-Leuchte22BR MA57-Lichtfunktion D 22,not active
(10)-Leuchte22BR MA57-Dimmwert CD 22,0
(11)-Leuchte22BR MA57-Dimming Direction CD 22,maximize
(12)-Leuchte22BR MA57-Lichtfunktion E 22,not active
(13)-Leuchte22BR MA57-Lichtfunktion F 22,not active
(14)-Leuchte22BR MA57-Dimmwert EF 22,0
(15)-Leuchte22BR MA57-Dimming Direction EF 22,maximize
(16)-Leuchte22BR MA57-Lichtfunktion G 22,not active
(17)-Leuchte22BR MA57-Lichtfunktion H 22,not active
(18)-Leuchte22BR MA57-Dimmwert GH 22,0
(19)-Leuchte22BR MA57-Dimming Direction GH 22,maximize
(1)-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
(3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
(4)-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte23SL HLC10-Lichtfunktion B 23,not active
(6)-Leuchte23SL HLC10-Dimmwert AB 23,28
(7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
(8)-Leuchte23SL HLC10-Lichtfunktion C 23,not active
(9)-Leuchte23SL HLC10-Lichtfunktion D 23,not active
(10)-Leuchte23SL HLC10-Dimmwert CD 23,0
(11)-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
(12)-Leuchte23SL HLC10-Lichtfunktion E 23,not active
(13)-Leuchte23SL HLC10-Lichtfunktion F 23,not active
(14)-Leuchte23SL HLC10-Dimmwert EF 23,0
(15)-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
(16)-Leuchte23SL HLC10-Lichtfunktion G 23,not active
(17)-Leuchte23SL HLC10-Lichtfunktion H 23,not active
(18)-Leuchte23SL HLC10-Dimmwert GH 23,0
(19)-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
(1)-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
(3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
(4)-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte24SL HRA65-Lichtfunktion B 24,not active
(6)-Leuchte24SL HRA65-Dimmwert AB 24,28
(7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
(8)-Leuchte24SL HRA65-Lichtfunktion C 24,not active
(9)-Leuchte24SL HRA65-Lichtfunktion D 24,not active
(10)-Leuchte24SL HRA65-Dimmwert CD 24,0
(11)-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
(12)-Leuchte24SL HRA65-Lichtfunktion E 24,not active
(13)-Leuchte24SL HRA65-Lichtfunktion F 24,not active
(14)-Leuchte24SL HRA65-Dimmwert EF 24,0
(15)-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
(16)-Leuchte24SL HRA65-Lichtfunktion G 24,not active
(17)-Leuchte24SL HRA65-Lichtfunktion H 24,not active
(18)-Leuchte24SL HRA65-Dimmwert GH 24,0
(19)-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
(1)-Leuchte25KZL HA59-Lasttyp 25,18 - 2* 5W
(2)-Leuchte25KZL HA59-Lampendefektbitposition 25,28
(3)-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
(4)-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte25KZL HA59-Lichtfunktion B 25,not active
(6)-Leuchte25KZL HA59-Dimmwert AB 25,100
(7)-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
(8)-Leuchte25KZL HA59-Lichtfunktion C 25,not active
(9)-Leuchte25KZL HA59-Lichtfunktion D 25,not active
(10)-Leuchte25KZL HA59-Dimmwert CD 25,0
(11)-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
(12)-Leuchte25KZL HA59-Lichtfunktion E 25,not active
(13)-Leuchte25KZL HA59-Lichtfunktion F 25,not active
(14)-Leuchte25KZL HA59-Dimmwert EF 25,0
(15)-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
(16)-Leuchte25KZL HA59-Lichtfunktion G 25,not active
(17)-Leuchte25KZL HA59-Lichtfunktion H 25,not active
(18)-Leuchte25KZL HA59-Dimmwert GH 25,0
(19)-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
(1)-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte26NSL LA72-Lampendefektbitposition 26,00
(3)-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,47
(4)-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte26NSL LA72-Lichtfunktion B 26,not active
(6)-Leuchte26NSL LA72-Dimmwert AB 26,127
(7)-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
(8)-Leuchte26NSL LA72-Lichtfunktion C 26,not active
(9)-Leuchte26NSL LA72-Lichtfunktion D 26,not active
(10)-Leuchte26NSL LA72-Dimmwert CD 26,0
(11)-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
(12)-Leuchte26NSL LA72-Lichtfunktion E 26,not active
(13)-Leuchte26NSL LA72-Lichtfunktion F 26,not active
(14)-Leuchte26NSL LA72-Dimmwert EF 26,0
(15)-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
(16)-Leuchte26NSL LA72-Lichtfunktion G 26,not active
(17)-Leuchte26NSL LA72-Lichtfunktion H 26,not active
(18)-Leuchte26NSL LA72-Dimmwert GH 26,0
(19)-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
(1)-Leuchte27NSL RC6-Lasttyp 27,not active
(2)-Leuchte27NSL RC6-Lampendefektbitposition 27,00
(3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00
(4)-Leuchte27NSL RC6-Lichtfunktion A 27,not active
(5)-Leuchte27NSL RC6-Lichtfunktion B 27,not active
(6)-Leuchte27NSL RC6-Dimmwert AB 27,0
(7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
(8)-Leuchte27NSL RC6-Lichtfunktion C 27,not active
(9)-Leuchte27NSL RC6-Lichtfunktion D 27,not active
(10)-Leuchte27NSL RC6-Dimmwert CD 27,0
(11)-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
(12)-Leuchte27NSL RC6-Lichtfunktion E 27,not active
(13)-Leuchte27NSL RC6-Lichtfunktion F 27,not active
(14)-Leuchte27NSL RC6-Dimmwert EF 27,0
(15)-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
(16)-Leuchte27NSL RC6-Lichtfunktion G 27,not active
(17)-Leuchte27NSL RC6-Lichtfunktion H 27,not active
(18)-Leuchte27NSL RC6-Dimmwert GH 27,0
(19)-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
(1)-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
(3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
(4)-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
(5)-Leuchte28RFL LC11-Lichtfunktion B 28,not active
(6)-Leuchte28RFL LC11-Dimmwert AB 28,100
(7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
(8)-Leuchte28RFL LC11-Lichtfunktion C 28,not active
(9)-Leuchte28RFL LC11-Lichtfunktion D 28,not active
(10)-Leuchte28RFL LC11-Dimmwert CD 28,0
(11)-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
(12)-Leuchte28RFL LC11-Lichtfunktion E 28,not active
(13)-Leuchte28RFL LC11-Lichtfunktion F 28,not active
(14)-Leuchte28RFL LC11-Dimmwert EF 28,0
(15)-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
(16)-Leuchte28RFL LC11-Lichtfunktion G 28,not active
(17)-Leuchte28RFL LC11-Lichtfunktion H 28,not active
(18)-Leuchte28RFL LC11-Dimmwert GH 28,0
(19)-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
(1)-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
(3)-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
(4)-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
(5)-Leuchte29RFL RA64-Lichtfunktion B 29,not active
(6)-Leuchte29RFL RA64-Dimmwert AB 29,100
(7)-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
(8)-Leuchte29RFL RA64-Lichtfunktion C 29,not active
(9)-Leuchte29RFL RA64-Lichtfunktion D 29,not active
(10)-Leuchte29RFL RA64-Dimmwert CD 29,0
(11)-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
(12)-Leuchte29RFL RA64-Lichtfunktion E 29,not active
(13)-Leuchte29RFL RA64-Lichtfunktion F 29,not active
(14)-Leuchte29RFL RA64-Dimmwert EF 29,0
(15)-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
(16)-Leuchte29RFL RA64-Lichtfunktion G 29,not active
(17)-Leuchte29RFL RA64-Lichtfunktion H 29,not active
(18)-Leuchte29RFL RA64-Dimmwert GH 29,0
(19)-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
(1)-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte2SL VLB10-Lampendefektbitposition 2,48
(3)-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A
(4)-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights
(5)-Leuchte2SL VLB10-Lichtfunktion B 2,not active
(6)-Leuchte2SL VLB10-Dimmwert AB 2,100
(7)-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
(8)-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen)
(9)-Leuchte2SL VLB10-Lichtfunktion D 2,not active
(10)-Leuchte2SL VLB10-Dimmwert CD 2,0
(11)-Leuchte2SL VLB10-Dimming Direction CD 2,minimize
(12)-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(14)-Leuchte2SL VLB10-Dimmwert EF 2,26
(15)-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
(16)-Leuchte2SL VLB10-Lichtfunktion G 2,not active
(17)-Leuchte2SL VLB10-Lichtfunktion H 2,not active
(18)-Leuchte2SL VLB10-Dimmwert GH 2,0
(19)-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
(1)-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung
(2)-Leuchte30FR LC72-Lampendefektbitposition 30,00
(3)-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02
(4)-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light
(5)-Leuchte30FR LC72-Lichtfunktion B 30,not active
(6)-Leuchte30FR LC72-Dimmwert AB 30,89
(7)-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
(8)-Leuchte30FR LC72-Lichtfunktion C 30,not active
(9)-Leuchte30FR LC72-Lichtfunktion D 30,not active
(10)-Leuchte30FR LC72-Dimmwert CD 30,0
(11)-Leuchte30FR LC72-Dimming Direction CD 30,maximize
(12)-Leuchte30FR LC72-Lichtfunktion E 30,not active
(13)-Leuchte30FR LC72-Lichtfunktion F 30,not active
(14)-Leuchte30FR LC72-Dimmwert EF 30,0
(15)-Leuchte30FR LC72-Dimming Direction EF 30,maximize
(16)-Leuchte30FR LC72-Lichtfunktion G 30,not active
(17)-Leuchte30FR LC72-Lichtfunktion H 30,not active
(18)-Leuchte30FR LC72-Dimmwert GH 30,0
(19)-Leuchte30FR LC72-Dimming Direction GH 30,maximize
(1)-Leuchte31AMBL 1C61-Lasttyp 31,not active
(2)-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
(3)-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00
(4)-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active
(5)-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
(6)-Leuchte31AMBL 1C61-Dimmwert AB 31,0
(7)-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
(8)-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
(9)-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
(10)-Leuchte31AMBL 1C61-Dimmwert CD 31,0
(11)-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
(12)-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
(13)-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
(14)-Leuchte31AMBL 1C61-Dimmwert EF 31,0
(15)-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
(16)-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
(17)-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
(18)-Leuchte31AMBL 1C61-Dimmwert GH 31,0
(19)-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
(1)-Leuchte32AMBL 2C35-Lasttyp 32,not active
(2)-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
(3)-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00
(4)-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active
(5)-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
(6)-Leuchte32AMBL 2C35-Dimmwert AB 32,0
(7)-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
(8)-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
(9)-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
(10)-Leuchte32AMBL 2C35-Dimmwert CD 32,0
(11)-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
(12)-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
(13)-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
(14)-Leuchte32AMBL 2C35-Dimmwert EF 32,0
(15)-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
(16)-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
(17)-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
(18)-Leuchte32AMBL 2C35-Dimmwert GH 32,0
(19)-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
(1)-Leuchte33AMBL 3C36-Lasttyp 33,not active
(2)-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
(3)-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00
(4)-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active
(5)-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
(6)-Leuchte33AMBL 3C36-Dimmwert AB 33,0
(7)-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
(8)-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
(9)-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
(10)-Leuchte33AMBL 3C36-Dimmwert CD 33,0
(11)-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
(12)-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
(13)-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
(14)-Leuchte33AMBL 3C36-Dimmwert EF 33,0
(15)-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
(16)-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
(17)-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
(18)-Leuchte33AMBL 3C36-Dimmwert GH 33,0
(19)-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
(1)-Leuchte34AMBL 4C37-Lasttyp 34,not active
(2)-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
(3)-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00
(4)-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active
(5)-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
(6)-Leuchte34AMBL 4C37-Dimmwert AB 34,0
(7)-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
(8)-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
(9)-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
(10)-Leuchte34AMBL 4C37-Dimmwert CD 34,0
(11)-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
(12)-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
(13)-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
(14)-Leuchte34AMBL 4C37-Dimmwert EF 34,0
(15)-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
(16)-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
(17)-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
(18)-Leuchte34AMBL 4C37-Dimmwert GH 34,0
(19)-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
(1)-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
(3)-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C
(4)-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights
(5)-Leuchte3SL VRB21-Lichtfunktion B 3,not active
(6)-Leuchte3SL VRB21-Dimmwert AB 3,100
(7)-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
(8)-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen)
(9)-Leuchte3SL VRB21-Lichtfunktion D 3,not active
(10)-Leuchte3SL VRB21-Dimmwert CD 3,0
(11)-Leuchte3SL VRB21-Dimming Direction CD 3,minimize
(12)-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right
(14)-Leuchte3SL VRB21-Dimmwert EF 3,26
(15)-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3,not active
(17)-Leuchte3SL VRB21-Lichtfunktion H 3,not active
(18)-Leuchte3SL VRB21-Dimmwert GH 3,0
(19)-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
(1)-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
(3)-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49
(4)-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights
(5)-Leuchte4TFL LB4-Lichtfunktion B 4,not active
(6)-Leuchte4TFL LB4-Dimmwert AB 4,127
(7)-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
(8)-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen)
(9)-Leuchte4TFL LB4-Lichtfunktion D 4,not active
(10)-Leuchte4TFL LB4-Dimmwert CD 4,0
(11)-Leuchte4TFL LB4-Dimming Direction CD 4,minimize
(12)-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(14)-Leuchte4TFL LB4-Dimmwert EF 4,127
(15)-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
(16)-Leuchte4TFL LB4-Lichtfunktion G 4,not active
(17)-Leuchte4TFL LB4-Lichtfunktion H 4,not active
(18)-Leuchte4TFL LB4-Dimmwert GH 4,0
(19)-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
(1)-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
(3)-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B
(4)-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights
(5)-Leuchte5 TFL RB32-Lichtfunktion B 5,not active
(6)-Leuchte5 TFL RB32-Dimmwert AB 5,127
(7)-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen)
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
(10)-Leuchte5 TFL RB32-Dimmwert CD 5,0
(11)-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize
(12)-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right
(14)-Leuchte5 TFL RB32-Dimmwert EF 5,127
(15)-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
(16)-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
(17)-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
(18)-Leuchte5 TFL RB32-Dimmwert GH 5,0
(19)-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
(1)-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht
(2)-Leuchte6ABL LC5-Lampendefektbitposition 6,36
(3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
(4)-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
(5)-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6,127
(7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
(8)-Leuchte6ABL LC5-Lichtfunktion C 6,not active
(9)-Leuchte6ABL LC5-Lichtfunktion D 6,not active
(10)-Leuchte6ABL LC5-Dimmwert CD 6,0
(11)-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
(12)-Leuchte6ABL LC5-Lichtfunktion E 6,not active
(13)-Leuchte6ABL LC5-Lichtfunktion F 6,not active
(14)-Leuchte6ABL LC5-Dimmwert EF 6,0
(15)-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
(16)-Leuchte6ABL LC5-Lichtfunktion G 6,not active
(17)-Leuchte6ABL LC5-Lichtfunktion H 6,not active
(18)-Leuchte6ABL LC5-Dimmwert GH 6,0
(19)-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
(1)-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht
(2)-Leuchte7ABL RB1-Lampendefektbitposition 7,40
(3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
(4)-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
(5)-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7,127
(7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
(8)-Leuchte7ABL RB1-Lichtfunktion C 7,not active
(9)-Leuchte7ABL RB1-Lichtfunktion D 7,not active
(10)-Leuchte7ABL RB1-Dimmwert CD 7,0
(11)-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
(12)-Leuchte7ABL RB1-Lichtfunktion E 7,not active
(13)-Leuchte7ABL RB1-Lichtfunktion F 7,not active
(14)-Leuchte7ABL RB1-Dimmwert EF 7,0
(15)-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
(16)-Leuchte7ABL RB1-Lichtfunktion G 7,not active
(17)-Leuchte7ABL RB1-Lichtfunktion H 7,not active
(18)-Leuchte7ABL RB1-Dimmwert GH 7,0
(19)-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
(1)-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung
(2)-Leuchte8FL LB39-Lampendefektbitposition 8,35
(3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26
(4)-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte8FL LB39-Dimmwert AB 8,127
(7)-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
(8)-Leuchte8FL LB39-Lichtfunktion C 8,not active
(9)-Leuchte8FL LB39-Lichtfunktion D 8,not active
(10)-Leuchte8FL LB39-Dimmwert CD 8,0
(11)-Leuchte8FL LB39-Dimming Direction CD 8,maximize
(12)-Leuchte8FL LB39-Lichtfunktion E 8,not active
(13)-Leuchte8FL LB39-Lichtfunktion F 8,not active
(14)-Leuchte8FL LB39-Dimmwert EF 8,0
(15)-Leuchte8FL LB39-Dimming Direction EF 8,maximize
(16)-Leuchte8FL LB39-Lichtfunktion G 8,not active
(17)-Leuchte8FL LB39-Lichtfunktion H 8,not active
(18)-Leuchte8FL LB39-Dimmwert GH 8,0
(19)-Leuchte8FL LB39-Dimming Direction GH 8,maximize
(1)-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung
(2)-Leuchte9FL RB2-Lampendefektbitposition 9,3F
(3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27
(4)-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right
(6)-Leuchte9FL RB2-Dimmwert AB 9,127
(7)-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
(8)-Leuchte9FL RB2-Lichtfunktion C 9,not active
(9)-Leuchte9FL RB2-Lichtfunktion D 9,not active
(10)-Leuchte9FL RB2-Dimmwert CD 9,0
(11)-Leuchte9FL RB2-Dimming Direction CD 9,maximize
(12)-Leuchte9FL RB2-Lichtfunktion E 9,not active
(13)-Leuchte9FL RB2-Lichtfunktion F 9,not active
(14)-Leuchte9FL RB2-Dimmwert EF 9,0
(15)-Leuchte9FL RB2-Dimming Direction EF 9,maximize
(16)-Leuchte9FL RB2-Lichtfunktion G 9,not active
(17)-Leuchte9FL RB2-Lichtfunktion H 9,not active
(18)-Leuchte9FL RB2-Dimmwert GH 9,0
(19)-Leuchte9FL RB2-Dimming Direction GH 9,maximize
(1)-Leuchten14AL LB6-Lasttyp 14,not active
(2)-Leuchten14AL LB6-Lampendefektbitposition 14,00
(3)-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
(4)-Leuchten14AL LB6-Lichtfunktion A 14,not active
(5)-Leuchten14AL LB6-Lichtfunktion B 14,not active
(6)-Leuchten14AL LB6-Dimmwert AB 14,0
(7)-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
(8)-Leuchten14AL LB6-Lichtfunktion C 14,not active
(9)-Leuchten14AL LB6-Lichtfunktion D 14,not active
(10)-Leuchten14AL LB6-Dimmwert CD 14,0
(11)-Leuchten14AL LB6-Dimming Direction CD 14,maximize
(12)-Leuchten14AL LB6-Lichtfunktion E 14,not active
(13)-Leuchten14AL LB6-Lichtfunktion F 14,not active
(14)-Leuchten14AL LB6-Dimmwert EF 14,0
(15)-Leuchten14AL LB6-Dimming Direction EF 14,maximize
(16)-Leuchten14AL LB6-Lichtfunktion G 14,not active
(17)-Leuchten14AL LB6-Lichtfunktion H 14,not active
(18)-Leuchten14AL LB6-Dimmwert GH 14,0
(19)-Leuchten14AL LB6-Dimming Direction GH 14,maximize
(1)-LuB Lichtrouter Kennlinie 1-x0,0.0 %
(2)-LuB Lichtrouter Kennlinie 1-X1,5.0 %
(3)-LuB Lichtrouter Kennlinie 1-X2,50.0 %
(4)-LuB Lichtrouter Kennlinie 1-X3,75.0 %
(5)-LuB Lichtrouter Kennlinie 1-X4,110.0 %
(6)-LuB Lichtrouter Kennlinie 1-X5,126.5 %
(7)-LuB Lichtrouter Kennlinie 1-y0,0.0 %
(8)-LuB Lichtrouter Kennlinie 1-Y1,6.0 %
(9)-LuB Lichtrouter Kennlinie 1-Y2,16.0 %
(10)-LuB Lichtrouter Kennlinie 1-Y3,30.0 %
(11)-LuB Lichtrouter Kennlinie 1-Y4,60.0 %
(12)-LuB Lichtrouter Kennlinie 1-Y5,100.0 %
RLS_close_glazing,2.0 s
(1)-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
(2)-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
(3)-RLS_lights_for_autobahn-p_t_autobahn_delay_on,9 s
(4)-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
RLS_LIN_Communication,4 s
(1)-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
(2)-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
RLS_Washer_Front,15 s
RLS_wiper_position_parking,15 s
(1)-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
(2)-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
(3)-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
(4)-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
(5)-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
(6)-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
(7)-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
(8)-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
(9)-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
(10)-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
(1)-Wischgeschwindigkeiten-Dauerwischen Stufe 1 Zyklen pro Minute,40
(2)-Wischgeschwindigkeiten-Dauerwischen Stufe 2 Zyklen pro Minute,60
(3)-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30
I've not read the rest of the thread, but since upgrading from 15.7.4 to 16.8, the descriptions of some (most?) adaptions has changed.
It's gone from English text to German, i.e
to
static AFS light-Obere Geschwindigkeitsschwelle
Previously, most descriptions in the main (most used) modules was English. Is this expected, or have I incorrectly installed some language files?
There's a Data Version update available now (to 20160803 / DS255) that should fix this.
DV52
C?ID=194404
I just ran an Adp map of the 09 module in my MQB with 16.8.0.1 :
;SW:5Q0-937-087-K   HW:5Q0-937-087-K ---  Cent. Elect.
;Component:BCM PQ37BOSCH 026 0097	 Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc	12003	EV_BCMBOSCH_VW37.rod
;Thursday	4	August	2016	10:32:34:29905
;VCDS Version: Release 16.8.0 (x64)  Data version: 20160801 DS254
;VCID: 43C9CC47CAE1095AFF-8016
Record Count = 1,893
Here's a really old 09 map from when I first got the car, using 14.7.2
;Component:BCM PQ37BOSCH 026 0097, Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc,012003,EV_BCMBOSCH_SE37.rod
;Monday,18,August,2014,20:25:50:23603
;VCDS Version: Beta 14.7.2 (x64)  Data version: 20140714
;VCID: 438E9FAACAC9EB22DE-8016
Record count 1,866
So, 27 new adaptation channels discovered!!
Dob
PS on my mk7, BCM record count for ver16.8.0 =1,783 vs record count for ver 14.7.0 = 1,747 ! So, 36 new adaptation channels that were previously lurking!
Andy
Sector 7G
HC424490
As a sanity check, please try running maps multiple times with 16.8.0.3 to make sure it's consistent.
DV52
C?ID=194404
Andy: I don't like doing "sanity checks" because the exercise has the no-win objective of questioning the doer's sanity (it's a simple case of ignorance is bliss - better not to go-there IMO)!! But because you asked, I did a number of admap runs for the BCM in my car - details of which are below
;SW:5Q0-937-084-N   HW:5Q0-937-084-N ---  Cent. Elect.
;Component:BCM MQBAB M   H14 0106, Coding:03001842C24102FB0FA4400000040308100A000000000000000000000000
;EV_BCMCONTI,010001,EV_BCMBOSCH_VW37.rod
;Sunday,07,August,2016,11:17:44:16808
;VCDS Version: Release 16.8.0 (x64)  Data version: 20160803 DS255
;VCID: 43C68A64CAD4705AFD-8016
It's Sunday here, so rather than spend time at my local church listening to some activated nut-job preach to me about fire and brimstone and eternal damnation, I decided to stay at home and parse the data through MS Access. The results are in a spreadsheet HERE. Interesting results indeed for the consistency of channel settings across admap runs (i.e. ID 239, 379, 548, 551, 638 and 554 in the spreadsheet to name just a few). Not surprisingly, all of the variations in settings across admap runs are related to the mysterious (to me, at least) Light configuration channels. I've found in the past that the stability of these channel settings when polled can be questionable - but only for the Lighting configuration channels that are not correlated to their twin Leuchte channels (which is all exterior lamps except those in the headlight assemblies - excluding the main beam lamps). But I have no idea why this should be so -perhaps someone here can elaborate? Anyhow, I'm not concerned by the behaviour of these settings, but a problem shared is a problem abrogated!!!
PS: Does RT provide absolution for not attending Sunday mass?
Andy
Sector 7G
HC424490
VAG-Dave
Scotland
HC806344
Ok just done a full scan & admap on my car using the latest data packages etc.
Good points;
nice & fast,
shows more info on the slave modules in scan reports.
Bad points:
why is the writing in the "select channel" box on the admap screen so small?...like half the previous size making it difficult to read the long channel names
Can you post a screen-shot? What Window Size do you have set on the Options screen? I'm thinking perhaps that control isn't scaling properly?
