Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 52
Thread: Updated to Release 19.6 and Having Trouble? Read This Thread
    Mar 2015
    Italy
    Hi I installed the new vcds version 18.2 on windows 10 pro, but it gives me problems of installing the micro-can, I understand that it does not install the driver.
    It gives me error of usb interface not found.
    I tried to install on another pc with windows xp and installed the driver correctly.
    How can I solve the problem with the PC that has windows 10 pro?
    Thanks for your help
  2. #12
    What happens if you run DPINST.EXE in your VCDS folder?
  3. #13
    Mar 2015
    Italy
    with the inserted cable it gives me error, without cable correctly install the drivers
  4. #14
    Mar 2015
    Italy
    please help me: rolleyes:
  5. #15
    So drivers installed correctly?
    Plug in the cable. Find it in Device manager and post a screen-shot of its Properties sheet.
  6. #16
    Mar 2015
    Italy
    Double-click on 'Ross-Tech uCAN-h' and post what you see there.
  8. #18
    Mar 2015
    Italy
    Microsoft recommends the following:
    Code 28 "The drivers for this device are not installed. (Code 28)"
    Recommended Resolution
    Reinstall the device driver manually
    From Start, search for device manager and select Device Manager from the results.
    Right-click the device in the list.
    Select Uninstall from the menu that appears.
    After the device is uninstalled, choose Action on the menu bar.
    Select Scan for hardware changes to reinstall the driver.
    Note You may be prompted to provide the path of the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s website.
    If that doesn't work, try some of this:
    https://www.techcrises.com/how-to/fi...alled-code-28/
    Start at section 3).
  10. #20
    Mar 2015
    Italy
    thanks but unfortunately I have not solved, the correct drivers where can I find them?
    but DPInst.EXE should not install the drivers?
    thank you
