Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: Updated to Release 19.6 and Having Trouble? Read This Thread
  1. #41
    Jun 2014
    Swansea, UK
    Quote Originally Posted by Andy View Post
    4) Start up VCDS (it may have already started at the end of the installation, which is fine). If VCDS won't start up at all after updating, make sure that Zone Alarm or your virus scanner are not blocking/quarantining the file. Make sure it says Release 18.9 at the top of the screen. If says an older version then something didn't go right. Check the shortcut on your desktop to make sure it's for Release 19.6. If needed, exit out of VCDS then repeat steps 1-3.
    I'm guessing that should be 19.6 now?
    Apparently I should put something witty or profound in here...
  2. Likes Uwe liked this post
  3. #42
    Quote Originally Posted by Mike@Gendan View Post
    Fixed it for him.
  4. Likes Mike@Gendan, Andy liked this post
  5. #43
    Verified VCDS User bobbik's Avatar
    Oct 2015
    Thursday,18,July,2019,11:33:50:22340
    VCDS Version: 19.6.1.0
    Workshop Code: 000 11618 000000
    Gateway Installation List:  3Q0 907 530 L
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    3C-Lane Change -- Status: Cannot be reached 0100
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    D8-LED HeadL. Pwr Left -- Status: INTERFACE NOT COMPATIBLE
    D9-LED HeadL. Pwr Right -- Status: INTERFACE NOT COMPATIBLE
    Does it mean my interface is too obsolete?
  6. #44
    Quote Originally Posted by bobbik View Post
    There are at least four control modules in that car that your "legacy" interface can't communicate with. So yes, an interface upgrade would be recommended.
  7. Likes Eric liked this post
  8. #45
    Apr 2017
    India
    Recently, I had upgraded to a new laptop that runs Windows 10 64 bit version. I installed VCDS version 19.6.1. When I launch VCDS from desktop shortcut, the program does not launch. Following are the checks I have performed.
    1. When I check the task manager, the program is not listed in the processes.
    2. Tried running the program in Administrator mode.
    3. Tried troubleshooting compatibility issues and ran in Win8 and Win7 compatibility modes.
    4. Checked that firewall has been configured to allow VCDS.
    5. Added VCDS.exe as an exception in the antivirus software.
    None of these work. Any pointers to what could be the problem?
    Thanks in advance.
    Edit: I have the Hex-V2 interface with a 3-VIN license.
  9. #46
    Quote Originally Posted by graaja View Post
    At this point, I think there are more people running Windows 10 and the x64 version of VCDS than any other combination, so there has to be something peculiar about your computer.
    Try the "Install 32-bit EXE on 64-bit System" option in the installer to see if that helps.
    If that still doesn't work, I would suggest uninstalling and and all bloatware and nannyware that came pre-installed on this computer.
  10. #47
    Apr 2017
    India
    That solved the problem. VCDS now works.
    Thanks a lot for the solution.
  11. Likes Uwe, Andy, PetrolDave liked this post
