Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 51
Thread: Updated to Release 19.6 and Having Trouble? Read This Thread
  1. #41
    Jun 2014
    Swansea, UK
    Quote Originally Posted by Andy View Post
    4) Start up VCDS (it may have already started at the end of the installation, which is fine). If VCDS won't start up at all after updating, make sure that Zone Alarm or your virus scanner are not blocking/quarantining the file. Make sure it says Release 18.9 at the top of the screen. If says an older version then something didn't go right. Check the shortcut on your desktop to make sure it's for Release 19.6. If needed, exit out of VCDS then repeat steps 1-3.
    I'm guessing that should be 19.6 now?
    Apparently I should put something witty or profound in here...
  2. Likes Uwe liked this post
  3. #42
    Quote Originally Posted by Mike@Gendan View Post
    Fixed it for him.
  4. Likes Mike@Gendan, Andy liked this post
  5. #43
    Verified VCDS User bobbik's Avatar
    Oct 2015
    Thursday,18,July,2019,11:33:50:22340
    VCDS Version: 19.6.1.0
    Workshop Code: 000 11618 000000
    Gateway Installation List:  3Q0 907 530 L
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    3C-Lane Change -- Status: Cannot be reached 0100
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    D8-LED HeadL. Pwr Left -- Status: INTERFACE NOT COMPATIBLE
    D9-LED HeadL. Pwr Right -- Status: INTERFACE NOT COMPATIBLE
    Does it mean my interface is too obsolete?
  6. #44
    Quote Originally Posted by bobbik View Post
    There are at least four control modules in that car that your "legacy" interface can't communicate with. So yes, an interface upgrade would be recommended.
  7. Likes Eric liked this post
  8. #45
    Apr 2017
    India
    Recently, I had upgraded to a new laptop that runs Windows 10 64 bit version. I installed VCDS version 19.6.1. When I launch VCDS from desktop shortcut, the program does not launch. Following are the checks I have performed.
    1. When I check the task manager, the program is not listed in the processes.
    2. Tried running the program in Administrator mode.
    3. Tried troubleshooting compatibility issues and ran in Win8 and Win7 compatibility modes.
    4. Checked that firewall has been configured to allow VCDS.
    5. Added VCDS.exe as an exception in the antivirus software.
    None of these work. Any pointers to what could be the problem?
    Thanks in advance.
    Edit: I have the Hex-V2 interface with a 3-VIN license.
  9. #46
    Quote Originally Posted by graaja View Post
    At this point, I think there are more people running Windows 10 and the x64 version of VCDS than any other combination, so there has to be something peculiar about your computer.
    Try the "Install 32-bit EXE on 64-bit System" option in the installer to see if that helps.
    If that still doesn't work, I would suggest uninstalling and and all bloatware and nannyware that came pre-installed on this computer.
  10. #47
    Apr 2017
    India
    That solved the problem. VCDS now works.
    Thanks a lot for the solution.
  11. Likes Uwe, Andy, PetrolDave liked this post
  12. #48
    Aug 2019
    Russia
    Possible bug?
    Hello!
    I have a problem with latest version of VCDS (19.6.1). When I try to access some of control modules of my car (for example, ABS and steering angle sensor), the error balloon above "Advanced ID" button is shown: "Vehicle is unsupported". Every other button stays disabled.
    I know about legacy interfaces and 2019+ cars... BUT! My car is 2013 Polo sedan (russian market model), my interface is HEX-USB+CAN, OS is Windows 10 x64. When I've reinstalled previous version (19.6.0 - thank God I kept distro) - all work fine again.
    Here is the log from the "Advanced ID" window (sorry don't know how exactly it's called):
    Wednesday,21,August,2019,20:57:06:05202
    VCDS Version: 19.6.1.0 (x64)
                    Address 03: ABS Brakes
    Control Module Part Number: 6R0 907 379 AQ
      Component and/or Version: ABS9.0 front  H01 0003
               Software Coding: 50DD2F64212504C10A18F472845720000000
                Work Shop Code: WSC 01530
                          VCID: 0D115EF2DC450C27E2-8058
    Advanced Identification/FAZIT
         Serial number: --------------
         Identification: BPA-085
         Date: 08.08.13
         Manufacturer number: 0040
         Test stand number: 2660
    Flash Status
         Programming Attempts(application): 1/0
         Flash Date: 00.01.01
    Misc.
         Hardware number: 6R0 907 379 AQ
         Workshop System Name: J104
         ASAM Dataset: EV_Brake1ABS90BOSCH
         ASAM Dataset Revision: 003017
    VCDS Info:
           Labels: Redir Fail!
           ROD: ERROR - EV_Brake1ABS90BOSCH 003017 (VN75)
    Of course, I will post full scan if needed.
  13. #49
    Yes, please do post a full scan, including the VIN as reported by VCDS.
  14. #50
    Aug 2019
    Russia
    Ok, nevermind, here's a bunch of errors mainly in BCM and Discover Media Need to find a time to kill most of them ("echoes" of retrofitting ...
    Wednesday,21,August,2019,20:40:26:05202
    VIN: XW8ZZZ61ZEG021496   License Plate:
    Chassis Type: 61-VW25 (7E0)
    Scan: 01 03 04 09 15 17 19 25 37 44 56 5F 77
    VIN: XW8ZZZ61ZEG021496   Mileage: 69210km-43005miles
    Address 01: Engine
       Part No SW: 6R0 907 379 AQ    HW: 6R0 907 379 AQ
       Component: ABS9.0 front  H01 0003
       Shop #: WSC 01530 935 00200
       ASAM Dataset: EV_Brake1ABS90BOSCH 003017
       ROD: EV_Brake1ABS90BOSCH_VW25.rod
       Part No SW: 6R0 959 654     HW: 6R0 959 654
       Component: LENKW.SENSOR  H07 0070
       Serial number: 20111813470008
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF3093EE1E327BFEB-802A
    1140738 - Steering angle sensor
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:01
                        Voltage terminal 15: 11.20 V
                        Voltage terminal 30: 11.40 V
                        Terminal 15 status: On
       Part No SW: 7E0 937 090     HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0736
       Revision: B9080001    Serial number: 0771 029160357
       Coding: 62904ABF08A10840000800002C0B049000C0414F60040000200000000000
       VCID: 68DF4F669B67890F31-803C
       Subsystem 1 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29170001546230087311
       Coding: A5FFFF
    03303 - Response Closing Status of Rear Left Door
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 20:14:00
    01516 - Terminal 30; Left
                        Fault Status: 01101011
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:02
    00927 - Terminal 30 (Right)
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:02
    01748 - Switch for Tiptronic in Steering Wheel (E438); Up
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:02
    01749 - Switch for Tiptronic in Steering Wheel (E439); Down
                014 - Defective
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:02
       Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
       Component: VW10AirbagU05 H10 0020
       Revision: --------    Serial number: 003GW00LMTVP
       Coding: 003035
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4999AAE2E8AD50070E-801C
       Part No SW: 6R0 920 870 FX    HW: 6R0 920 870 FX
       Component: KOMBI         H04 0709
       Coding: 140E00
       Shop #: WSC 00180 935 00000
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 102F4786CB7721CF09-8044
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0736
       Revision: B9080001
       Coding: 002200
       Component: IMMO          H04 0709
       VCID: 6ADB356E8D6BBB1F27-803E
    Address 37: Navigation
    Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
       Part No SW: 6RU 909 144 J    HW: 6RU 909 144 J
       Component: EPS_ECU       H18 0401
       Coding: 0000
       ASAM Dataset: EV_SteerAssisUDSNSK 005005
       ROD: EV_SteerAssisUDSNSK.rod
       VCID: 62CB5D4E755BE35FEF-8036
    Address 56: Radio
       Part No SW: 5C0 035 684 D    HW: 5C0 035 684
       Component: MU-S-NS-US    H22 0468
       Serial number: VWZAZ2S0252925
       Coding: 02570001FF00000011110004000908001F0100C4002001004E
       Shop #: WSC 00046 123 12345
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 2643015E59F35F7FC3-8072
       Subsystem 1 - Part No SW: 5NA 919 866 J    HW: -----------
       Component: ECE2 2019/20  --- 1115
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:00
                        Voltage terminal 30: 11.3 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
    13697024 - Component Protection
              U1100 00 [009] - No Basic Setting
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:00
    15361024 - Component Protection
              U1101 00 [009] - Active
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:00
    0009 - Antenna for Satellite Radio
              B10F4 13 [009] - Open Circuit
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 20:15:43
                        Voltage terminal 30: 11.4 V
                        SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                        SDARS_tuner_status_2-Channel selection for satellite radio: 0
                        SDARS_tuner_status_2-Audio Signal: Not available
                        SDARS_tuner_status_2-Antenna current: 1 mA
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
    7178 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:03
                        BAP-BAP_Function_ID: 02
    0003 - Antenna 2 for radio
              B111A 13 [009] - Open Circuit
                        Reset counter: 29
                        Mileage: 69219 km
                        Date: 2019.08.21
                        Time: 18:54:00
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 2 for radio-Reception level antenna 2: 0 dBV
    Address 77: Telephone
    End-------------------------(Elapsed Time: 02:09)--------------------------
