We have retrofitted xenons into a caddy with levelling sensor, lights work ok but no bi-xenon or dynamic lighting (everything range module related) when trying to code it just returns a 31 request out of range error, it is definitely wired correctly as it can see and communicate with the module and 2 slave module, see attached scan
Can anyone help
Can anyone help
Saturday,30,July,2016,11:19:30:44719
VCDS Version: 16.6.0.2 (x64)
Data version: 20160602 DS251
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 57 77
VIN: WV1ZZZ2KZ Mileage: 57130km-35498miles
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
57-TV Tuner -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 NF HW: 03L 907 309 R
Component: R4 2,0L EDC H25 0660
Revision: 42H25--- Serial number: 00000000000000
Coding: 00190012040500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01103L906018NF 003001
ROD: EV_ECM20TDI01103L906018NF.rod
VCID: 7BFFC3A0F24BCF9B8C-802E
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 433C600D092803FEC20B06E49020C082300000
Shop #: WSC 35110 377 08192
VCID: 7CFDC0BCFF45C8A385-8028
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 BG HW: 7N0 907 426 BG
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004002
VCID: 7AF1C6A4FD71F69397-802E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AC HW: 5K0 937 087 AC
Component: BCM PQ35 H+ 122 0174
Revision: BF122001
Coding: 491A0A3A8021106A08C800809400116C03D57408524D8120E48000000049
VCID: 76E9D294C16992F3F3-8022
Subsystem 1 - Part No: 1T2 955 119 A
Component: Wischer 05101 26 0512
Coding: 009795
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02A H07 0013
Revision: -------- Serial number: 003HL00EDV3G
Coding: 000000000000000000000000000000003241
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 356B159894EFD9EB3A-8060
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BB HW: 5K0 953 549 D
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KHB000X0
Coding: 108A040000
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 71E3E188A007B5CB26-8024
Subsystem 1 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H04 0103
Serial number: 29150002170070035476
Coding: A4FFFF
Part No SW: 2K0 920 975 L HW: 2K0 920 975 L
Component: KOMBI H05 0705
Coding: 481801
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 397319A8B8F73D8BDE-806C
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 111012F2000252
Coding: 358001
VCID: 74EDE89CD71580E3CD-8020
Fault Status: 00110100
Reset counter: 86
Mileage: 56756 km
Date: 2016.07.25
Time: 16:28:34
00467 - TV Tuner (R78)
Fault Frequency: 53
Reset counter: 101
Mileage: 56756 km
Date: 2016.07.25
Time: 16:22:59
01304 - Radio
Reset counter: 86
Mileage: 56756 km
Date: 2016.07.25
Time: 16:28:34
Component: IMMO H05 0705
VCID: 6AD1F6E48DD1461367-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H04 5238
Revision: AB001001 Serial number: VWZ6Z7J4300041
Coding: 00000200000000800013
VCID: 37771F9086E32BFB28-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 48956C6C3B1D540351-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 140 3305
Revision: 00H22000
VCID: 37771F9046E32BFB28-8062
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 47976F5036035B7B58-8012
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 37771F908EE32BFB28-8062
Subsystem 1 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 3F0000
Subsystem 2 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 320000
13636352 - Control module not coded
U1013 00 [137] - -
Reset counter: 61
Mileage: 57139 km
Date: 2016.07.30
Time: 11:15:30
5276144 - Power Output Module for Left Headlamp
C1081 F0 [137] - Not Coded
Reset counter: 61
Mileage: 57139 km
Date: 2016.07.30
Time: 11:15:30
5276400 - Power Output Module for Right Headlamp
C1082 F0 [137] - Not Coded
Reset counter: 61
Mileage: 57139 km
Date: 2016.07.30
Time: 11:15:30
5275220 - Headlight
Reset counter: 61
Mileage: 57139 km
Date: 2016.07.30
Time: 11:15:30
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 57: TV Tuner
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663635282
Coding: 0201010000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 02:32)--------------------------
