Hi all
My 2016 Passat had the nice option to close the sunroof (and any open windows) if I held in the lock button of the remote.
I got a letter from my dealer that they wanted to deactivate the closing of the sunroof because apparently it did not sense if something was in the way for it to close.
I kinda liked this option, so I opted not to have this done. But then there was a fault with the ad-blue system in the car, I got a message on the dashboard that indicated an error and the car would not start in 1000 km. So, I took it to the dealer with explicit instructions not to implement the sunroof recall.
Well, for the week it took them to figure out the ad-blue error, they ran the sunroof change anyway.
So, now I want to figure out a way to get it back the way it was. I did manage to take an auto scan before the car went in, but didn't take a map/measurement file.
From the below printouts it can be seen that byte 1 of Address 09 Cent. Elect. has changed from 0xD3 to 0x97.
I've tried to change this setting to it's previous value but the sunroof does still not close when I hold in the lock button of the remote.
Is there any way to figure out what bit 6 means (was set before but not after the dealer change)
Same for bit 2, was not set before, but set after the dealer change
Autoscan before dealer change
Autoscan after dealer change
Map and measurement
Wednesday,13,July,2016,17:19:26:37953
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZ3CZGE111716 License Plate: HUS26-ADBLUE
Mileage: 5487km-3409mi Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 42 44 52 55
5F 69 6C 6D
VIN: WVWZZZ3CZGE111716 Mileage: 5487km-3409miles
Address 01: Engine (J623-CUAA) Labels: 03N-906-026-CUA.clb
Part No SW: 03N 906 026 E HW: 03N 907 309
Component: R4 2,0L EDC H23 1754
Revision: A1H23---
Coding: 0125001A047605083000
Shop #: WSC 05311 115 00108
ASAM Dataset: EV_ECM20BTD01103N906026E 001002
ROD: N/A
VCID: 2D5116FF7C857F56E5-8078
No ASAM data for: "EV_ECM20BTD01103N906026E" (VW48)
17159 - ROD - Unknown Error Code
- 00 [032]
28653 - ROD - Unknown Error Code
- 00 [237]
Mileage: 5305 km
Date: 2016.07.07
Time: 11:30:46
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0DL 300 011 H HW: 0BH 927 711 F
Component: GSG DQ500 H10 5206
Revision: 00H10V01
ROD: EV_TCMDQ500021_AU21.rod
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62985000000206
Coding: 0FEC6B8F54210B6D077E070141C969F0D62AD0E0E08296F5186250F8C209
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
VCID: 7AFBEDA3FD4B18EE30-802E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0382216770
Coding: 0F00000F03
Shop #: WSC 05311 000 00108
ASAM Dataset: EV_KessyHellaMQBAB 004032
ROD: EV_KessyHellaMQBAB_SK48.rod
VCID: 3A7B2DA3BDCBD8EE70-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G1 907 044 J HW: 5G1 907 044 J
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020124204101011015500C0010190A
ASAM Dataset: EV_ACClimaBHBVW37X 005137
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 2F6D0CF776890D46D7-807A
Slave 1:
263682 - Exterior Air Quality/Humidity Sensor
B137A 31 [008] - No Signal
Fault Frequency: 96
Reset counter: 249
Mileage: 575 km
Date: 2016.01.23
Time: 10:01:04
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86582610151862
Coding: 00D31C46C2C102FF57C44014001C57281C80000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 030590478A81592663-8056
Slave 1:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150819 042 0607
Serial number: 151015205536
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S2Y15M11D02H00M17S35
Coding: 90A8DD
Slave 3:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 22 07 2015 10000953
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391529609172
Coding: 0071151911
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 4487535BCF0F9E1E1A-8010
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 3200678A59FFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3467039B9FAF2E9EAA-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 19101541350728
ROD: EV_DRCONTITEMIC.rod
VCID: 377D34978ED9C5868F-8062
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPMNLCUL
Coding: 88CCC000008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X_VW48.rod
VCID: 7F0D1CB7E6693DC607-802A
Subsystem 1 - Part No SW: ----------- HW: 454 001 710 15
Serial number: 3576U00000098B14B61G
Subsystem 2 - Part No SW: ----------- HW: 454 001 710 15
Serial number: 3586U000000D6B14B61J
Subsystem 3 - Part No SW: ----------- HW: 454 801 410 15
Component: SideSensor_Dr 301 0148
Serial number: 3516RA88FA108000000G
Subsystem 4 - Part No SW: ----------- HW: 454 801 610 15
Component: SideSensor_Pr 301 0148
Serial number: 3526RCEDCC308000000V
Subsystem 5 - Part No SW: ----------- HW: 454 800 310 15
Component: FrontSensor_D 304 0149
Serial number: 3556VDE9ADA08000000+
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 AM HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0205
Revision: FF034034 Serial number: 20151022501153
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7BF5E8A7F27121E62B-802E
Part No SW: 3G0 920 791 A HW: 3G0 920 791 A
Component: KOMBI 410 1340
Coding: 07A40818BF80000801886B011000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009048
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 275DE4D75E7955061F-8072
Address 18: Aux. Heat (J364) Labels: 5Q0-963-272.clb
Part No SW: 5Q0 963 272 E HW: 5Q0 963 272 E
Component: STH-MQB 007 0072
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS_VW37.rod
VCID: 387F37AB83C7CAFE86-806C
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001257932
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 14101510520556
Coding: 0B0300345F017300FB00025A9C0F00010001070000000000000000000000
ROD: EV_GatewConti.rod
VCID: 79F9F2AFF84D13F639-802C
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H17 0040
Serial number: 29150002102930095434
Coding: 2FFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 7195618103
Inverter power receptacle:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H56 0033
Serial number: 0149334
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00015.09.15
Coding: 0301
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 4A9B7D63ED2B486EE0-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 15000146744004
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E9CA8FA03D5BB681-8024
Component: TSG FS 020 0041
Serial number: 140715BGE09817
Coding: 003F1B208000020000001000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 43855047CA01992623-8016
Address 44: Steering Assist (J500) Labels: 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000461669
Coding: 01000010005001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_SK48.rod
VCID: 3B7528A7B2F1E1E66B-806E
Component: TSG BFS 020 0041
Serial number: 160715BGG0671A
Coding: 003F11208000020000001000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 428B5543D51B902E28-8016
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 03A202000F210200
Shop #: WSC 05311 000 08193
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
VCID: 3F8D5CB7A6E9FDC647-806A
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Part No SW: 3G0 035 043 C HW: 3G0 035 043
Component: MU-H-N-EU H50 0343
Serial number: A683J0FB001155
Coding: 02840201FF00000051110001000808001F0100E401200000DE
ROD: EV_MUHig4CGen2HBAS_VW48.rod
VCID: 1C37CB3B173F86DE82-8048
Media Player Position 1:
Radio Tuner - Digital:
Subsystem 2 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU303XC3
Engine Control Module 2:
Subsystem 3 - Part No SW: ----------- HW: -----------
Component: ------------- --- ----
Seat Adjustment Driver Side:
Subsystem 4 - Part No SW: V03 959 800 QN HW: -----------
Component: ECE 2016 --- 0134
Air Conditioning Compressor:
Diesel Pump Control Unit:
Door Electronics Driver Side:
Subsystem 7 - Part No SW: ----------- HW: -----------
Brake Assistance:
Subsystem 8 - Part No SW: ----------- HW: -----------
Interior Monitoring:
Subsystem 9 - Part No SW: ----------- HW: -----------
Sound System:
Door Electronics Rear Left:
Subsystem 12 - Part No SW: ----------- HW: -----------
Subsystem 13 - Part No SW: ----------- HW: -----------
Subsystem 14 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1012
Address 69: Trailer (J345) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0383172914
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella_SE26.rod
656138 - Bulb for Right Tail Light on Trailer
C10F4 15 [008] - Open or Short to Plus
Fault Frequency: 9
Reset counter: 40
Mileage: 4656 km
Date: 2016.06.21
Time: 11:19:28
656650 - Bulb for Right Turn Signal on Trailer
C10F6 15 [008] - Open or Short to Plus
Reset counter: 40
Mileage: 4656 km
Date: 2016.06.21
Time: 11:19:28
Address 6C: Back-up Cam. (J772) Labels: None
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 0184020163002017000040
Shop #: WSC 05311 115 00063
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 77FDF497CE5905864F-8022
Address 6D: Trunk Elect. (J605) Labels: None
Part No SW: 5Q0 959 107 G HW: 5Q0 959 107 G
Component: HDSG-Modul H12 0250
Revision: -------- Serial number: 30297875100000
Coding: 0288
ASAM Dataset: EV_DeckLidCONTIAU736 001011
ROD: EV_DeckLidCONTIAU736_SK48.rod
VCID: 3C772BBBB7FFE6DE62-8068
End-------------------------(Elapsed Time: 06:18)--------------------------
Thursday,28,July,2016,11:09:48:37953
Mileage: 5603km-3481mi Repair Order:
5F 69 6C 6D
VIN: WVWZZZ3CZGE111716 Mileage: 5603km-3481miles
Component: R4 2.0l BTD H23 2114
Revision: A1H23---
Shop #: WSC 00602 002 1048576
ASAM Dataset: EV_ECM20BTD01103N906026E 001004
ROD: N/A
Readiness: 0010 0001
Revision: 00H10V01
Coding: 0F00000F03
Revision: 00001K10
Slave 1:
Reset counter: 37
Mileage: 5576 km
Date: 2016.07.20
Time: 15:16:47
Coding: 00971C46C2C102FF57C44014001C57281C80000000000000000000000000
Slave 1:
Slave 2:
Coding: 90A8DD
Slave 3:
Coding: 0071151911
Coding: 0410
Shop #: WSC 00213 213 00000
Coding: 9309
Coding: 2FFFFF
Coding: 0301
Coding: E02400
Coding: E02400
Coding: E02400
Coding: E02400
Brake Assistance:
Sound System:
Coding: 0288
End-------------------------(Elapsed Time: 06:13)--------------------------
Map and measurement
;SW:5Q0-937-086-AK HW:5Q0-937-086-AK --- Cent. Elect.
;Component:BCM PQ37BOSCH 028 0162, Coding:00971C46C2C102FF57C44014001C57281C80000000000000000000000000
;EV_BodyContrModul1UDSBosc,015002,EV_BCMBOSCH_AU37.rod
;Friday,29,July,2016,08:39:46:37953
;VCDS Version: Release 15.7.4 (x64) Data version: 20160216
;VCID: 030590478A81592663-8056
(1)-Access control-Funk bei Klemme 15 ein,not active
(2)-Access control-Notschließfunktion,active
(3)-Access control-automatisches Verriegeln bei Geschwindigkeit,not active
(4)-Access control-automatisches Entriegeln,active
(5)-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
(6)-Access control-ZV Tuerentriegelung,Globale Entriegelung
(7)-Access control-CAN Wecken bei Softtouchbetaetigung,active
(8)-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
(9)-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
(10)-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
(11)-Access control-Valet Parking,not active
(12)-Access control-Direkter Auswurf des Heckdeckels,active
(13)-Access control-ZV entriegelt auch Heckdeckel,active
(14)-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
(15)-Access control-Autolock Autounlock wirkt auf Heck,active
(16)-Access control-ZV Heck nur direkt auswerfen,not active
(17)-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
(18)-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
(19)-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
(20)-Access control-ZV-Entriegelung nach Seitencrash,not active
(21)-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
(22)-Access control-Elektrische Laderaumabdeckung,active
(23)-Access control-Menuesteuerung Tuerentriegelung,active
(24)-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
(25)-Access control-Autounlock NAR,not active
(26)-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
(27)-Access control-Softtouch-Betaetigung senden,Always
(28)-Access control-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu
(29)-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
(30)-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
(31)-Access control-Vorrastenhaenger_Freigabe,not active
(32)-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
(33)-Access control-Deaktivierung_Laderaumschliessung_extern,not active
(34)-Access control-LS_Taster_Togglefunktion,not active
(35)-Access control-Nutzfahrzeug_Schliessung,not active
(36)-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
(37)-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
(1)-Access control 2-Komfortbedienung global,active
(2)-Access control 2-Comfort opening,active
(3)-Access control 2-Comfort closing,active
(4)-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
(5)-Access control 2-Nachsaven_nach_Verdecklauf,not active
(6)-Access control 2-Funk Komfort schliessen,active
(7)-Access control 2-Funk Komfort oeffnen,active
(8)-Access control 2-Schliesszylinder Komfort oeffnen,not active
(9)-Access control 2-Schliesszylinder Komfort schliessen,not active
(10)-Access control 2-SAD Richtung Komfortoeffnen,tilting
(11)-Access control 2-SAD Komfort schliessen,not active
(12)-Access control 2-SAD Komfort oeffnen,not active
(13)-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
(14)-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
(15)-Access control 2-Regenschliessen_ein_aus,not active
(16)-Access control 2-Regenschliessen_art,once
(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active
(18)-Access control 2-Spiegelverstellung Synchron,active
(19)-Access control 2-Kessy Komfort oeffnen,not active
(20)-Access control 2-Kessy Komfort schliessen,active
(21)-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
(22)-Access control 2-Menuesteuerung Spiegelabsenkung,not active
(23)-Access control 2-Funk Spiegelanklappen,not active
(24)-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key
(25)-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active
(26)-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
(27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
(28)-Access control 2-Menuesteuerung Regenschliessen,not active
(29)-Access control 2-SAD PreCrash Konturschliessen,not active
(30)-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
(31)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
(32)-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
(33)-Access control 2-Remote_Unlock_Lock,not_active
(34)-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active
(35)-Access control 2-Signalisierung_Spiegelanklappung,active
(36)-Access control 2-Virtuelles_Pedal,not active
(37)-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
(38)-Access control 2-easycloselight_aktiv,not active
(39)-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active
(1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
(2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active
(3)-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
(4)-Acknowledgement signals-Optical feedback during locking,Decelerate
(5)-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
(6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
(7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active
(8)-Acknowledgement signals-Akustische Rueckmeldung global,not active
(9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
(10)-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
(11)-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
Activating and deactivating all development messages,not active
(1)-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
(2)-After-run for park light-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement
(3)-After-run for park light-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement
(4)-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten
(5)-After-run for park light-Standlicht-Nachlaufzeit,30 min
(6)-After-run for park light-Standlicht-Verfügbarkeit,24 s
Alternating park position 1,8.30 °
Alternating park position 2,24.89 °
(1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %
(2)-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %
(3)-Ambient lighting-Defaultwert Ambienteprofil Vorn,10 %
(4)-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
(5)-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
(6)-Ambient lighting-Innenlichtinszenierung,not enabled
(1)-Ambientelicht Farbliste-Rotwert Farbe 4,E1
(2)-Ambientelicht Farbliste-Gruenwert Farbe 4,E1
(3)-Ambientelicht Farbliste-Blauwert Farbe 4,E1
(4)-Ambientelicht Farbliste-Rotwert Farbe 5,E1
(5)-Ambientelicht Farbliste-Gruenwert Farbe 5,E1
(6)-Ambientelicht Farbliste-Blauwert Farbe 5,E1
(7)-Ambientelicht Farbliste-Rotwert Farbe 6,E1
(8)-Ambientelicht Farbliste-Gruenwert Farbe 6,E1
(9)-Ambientelicht Farbliste-Blauwert Farbe 6,E1
(10)-Ambientelicht Farbliste-Rotwert Farbe 7,E1
(11)-Ambientelicht Farbliste-Gruenwert Farbe 7,E1
(12)-Ambientelicht Farbliste-Blauwert Farbe 7,E1
(13)-Ambientelicht Farbliste-Rotwert Farbe 8,E1
(14)-Ambientelicht Farbliste-Gruenwert Farbe 8,E1
(15)-Ambientelicht Farbliste-Blauwert Farbe 8,E1
(16)-Ambientelicht Farbliste-Rotwert Farbe 9,E1
(17)-Ambientelicht Farbliste-Gruenwert Farbe 9,E1
(18)-Ambientelicht Farbliste-Blauwert Farbe 9,E1
(19)-Ambientelicht Farbliste-Rotwert Farbe 10,E1
(20)-Ambientelicht Farbliste-Gruenwert Farbe 10,E1
(21)-Ambientelicht Farbliste-Blauwert Farbe 10,E1
(1)-Anti-theft device-Alarmsignal,frequency modulated
(2)-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung
(3)-Anti-theft device-DWA Alarmverzoegerung,not active
(4)-Anti-theft device-DWA Camper Modus,not active
(5)-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
(6)-Anti-theft device-Sirenen Alarmzahl,10 Alarme
(7)-Anti-theft device-Akustischer Alarm Signalhorn,not active
(1)-Assistance light functions-Notbremsanzeige NBA,active
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
(3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
(4)-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active
(5)-Assistance light functions-Fernlichtassistent Reset,active
(6)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
(7)-Assistance light functions-Assistenzfahrlicht bei Regen,active
(8)-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL
(9)-Assistance light functions-LS_Error_Ausgabe,active
(10)-Assistance light functions-Fahrlicht_Hinweis_mehrfach,active
(11)-Assistance light functions-AFL Zeitverzoegerung,2000 ms
(12)-Assistance light functions-Lichtsensorempfindlichkeit,normal
(1)-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
(2)-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
(3)-Auxiliary functions-Signalhorn ohne KL15,active
(4)-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
(1)-Button in center console-Funktion Taster 1,Start-stop
(2)-Button in center console-Funktion Taster 2,GTE
(3)-Button in center console-Funktion Taster 3,Driving program
(4)-Button in center console-Funktion Taster 4,Steering wheel heater
Characteristics in production mode,2000 ms
(1)-Comfort illumination-Coming Home Verbaustatus,manual
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
(3)-Comfort illumination-Menueeinstellung Cominghome,10 s
(4)-Comfort illumination-Coming Home Leuchten,Low beam
(5)-Comfort illumination-Coming-home Einschaltereignis,Driver door
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
(7)-Comfort illumination-Leaving-Home Verbausstatus,Enabled
(8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
(9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx
(1)-Convert. top oper.-Komfortbedienung Verdeck global,active
(2)-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
(3)-Convert. top oper.-Komfortbedienung Verdeck schließen,active
(4)-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
(5)-Convert. top oper.-Verdeck schließen via Schließzylinder,active
(6)-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
(7)-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
(8)-Convert. top oper.-Verdeck oeffnen via Kessy,active
(9)-Convert. top oper.-Verdeck schließen via Kessy,active
(10)-Convert. top oper.-Doppelpuls nur Verdeck,active
(11)-Convert. top oper.-Verdeck mit Schiebedach,not active
(12)-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
(13)-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
(14)-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
(15)-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,active
(16)-Convert. top oper.-Remote Lock Unlock Timer s1,80 s
(17)-Convert. top oper.-Remote Lock Unlock Timer s3,20.000 ms
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
(8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
Deactivate production mode,0
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
(3)-Driving light and parking light-Standlicht aus,active
(4)-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
(5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active
(6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
(7)-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
(8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
(9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
(10)-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
(11)-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
(12)-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
(14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
(3)-Dyn. turn signal modes-ZV_Blinken_zu,not active
(4)-Dyn. turn signal modes-ZV_Blinken_auf,not active
(5)-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
(8)-Dyn. turn signal modes-Taxialarmblinken,not active
(9)-Dyn. turn signal modes-Panikblinken,not active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
(13)-Dyn. turn signal modes-Richtungs_blinken_links,not active
(14)-Dyn. turn signal modes-ABBA_Blinken,not active
(15)-Dyn. turn signal modes-Crashblinken,not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
(18)-Dyn. turn signal modes-Emergency_alert_blinken,not active
(1)-Energy management-Energy_Management_Adaptation,Energy management active
(2)-Energy management-Praediktives_Energiemanagement,not active
(1)-Head area heater-blower_speed,1
(2)-Head area heater-Temperature,-2
(1)-Int. light; 2nd generation-Aufloesung Dimmzeit,0.25 s
(2)-Int. light; 2nd generation-weicher Farbwechsel,not active
(3)-Int. light; 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active
(4)-Int. light; 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
(5)-Int. light; 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
(6)-Int. light; 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
(7)-Int. light; 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
(8)-Int. light; 2nd generation-Dachbeleuchtung mehrfarbig,not active
(9)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
(10)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
(11)-Int. light; 2nd generation-BAP Farbwert Farbe 1,0
(12)-Int. light; 2nd generation-BAP Farbwert Farbe 2,0
(13)-Int. light; 2nd generation-BAP Farbwert Farbe 3,0
(14)-Int. light; 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
(15)-Int. light; 2nd generation-Defaultwert Ambienteprofil Dach,80 %
(16)-Int. light; 2nd generation-Defaultwert Ambienteprofil Farbe,0
(17)-Int. light; 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
(18)-Int. light; 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active
(19)-Int. light; 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active
(20)-Int. light; 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active
(21)-Int. light; 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
(22)-Int. light; 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
(23)-Int. light; 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
(24)-Int. light; 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active
(25)-Int. light; 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
(26)-Int. light; 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
(27)-Int. light; 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
(28)-Int. light; 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
(29)-Int. light; 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
(30)-Int. light; 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
(31)-Int. light; 2nd generation-Rotwert Farbe 1,225
(32)-Int. light; 2nd generation-Gruenwert Farbe 1,225
(33)-Int. light; 2nd generation-Blauwert Farbe 1,225
(34)-Int. light; 2nd generation-Rotwert Farbe 2,225
(35)-Int. light; 2nd generation-Gruenwert Farbe 2,225
(36)-Int. light; 2nd generation-Blauwert Farbe 2,225
(37)-Int. light; 2nd generation-Rotwert Farbe 3,225
(38)-Int. light; 2nd generation-Gruenwert Farbe 3,225
(39)-Int. light; 2nd generation-Blauwert Farbe 3,225
(1)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed
(2)-Interior light; light configuration-Ambiente_Lautsprecher,not installed
(3)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
(4)-Interior light; light configuration-Cockpitbeleuchtung,not installed
(5)-Interior light; light configuration-Mittelkonsolenbeleuchtung,not installed
(6)-Interior light; light configuration-Dachbeleuchtung,not installed
(7)-Interior light; light configuration-Panoramaschiebedachbeleuchtung,not installed
(8)-Interior light; light configuration-Foot well lighting,installed
(9)-Interior light; light configuration-Farbwahl ueber HMI,not installed
(10)-Interior light; light configuration-Farbwahl ueber Fahrprofil,not installed
(11)-Interior light; light configuration-LIN-Dachkonsole lokal aktivierbar,not active
(12)-Interior light; light configuration-Ambientemenue mit globalem aus,not active
(13)-Interior light; light configuration-Ambientemenue mit alle Zonen,active
(14)-Interior light; light configuration-Ambient_Farbliste_HMI,not active
(15)-Interior light; light configuration-Frei_Farbwahl_ueber_HMI,not active
(1)-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
(2)-Interior lighting-KL30G ohne PWM,not active
(3)-Interior lighting-KL58 Einschalten mit Rampe,not active
(4)-Interior lighting-KL58 Verriegelungsausschalten,not active
(5)-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
(6)-Interior lighting-Suchbeleuchtung Festwert,50 %
(1)-Interior lighting; parameter-p_t_verzoegerung_einstieg_innenlicht,0 s
(2)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_innenlicht,0 s
(3)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_innenlicht,0 s
(4)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_innenlicht,0 s
(5)-Interior lighting; parameter-p_t_verzoegerung_schliessen_innenlicht,0 s
(6)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0 s
(7)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_innenlicht,0 s
(8)-Interior lighting; parameter-p_t_verzoegerung_einstieg_tueren,5 s
(9)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_tueren,0 s
(10)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_tueren,0 s
(11)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_tueren,0 s
(12)-Interior lighting; parameter-p_t_verzoegerung_schliessen_tueren,0 s
(13)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_tueren,0 s
(14)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_tueren,0 s
(15)-Interior lighting; parameter-p_t_verzoegerung_einstieg_fussraum,20 s
(16)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_fussraum,0 s
(17)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_fussraum,0 s
(18)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_fussraum,0 s
(19)-Interior lighting; parameter-p_t_verzoegerung_schliessen_fussraum,0 s
(20)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_fussraum,0 s
(21)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_fussraum,0 s
(22)-Interior lighting; parameter-p_t_verzoegerung_einstieg_cockpit,20 s
(23)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_cockpit,0 s
(24)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_cockpit,0 s
(25)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_cockpit,0 s
(26)-Interior lighting; parameter-p_t_verzoegerung_schliessen_cockpit,0 s
(27)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_cockpit,0 s
(28)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_cockpit,0 s
(29)-Interior lighting; parameter-p_t_verzoegerung_einstieg_miko,0 s
(30)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_miko,0 s
(31)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_miko,0 s
(32)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_miko,0 s
(33)-Interior lighting; parameter-p_t_verzoegerung_schliessen_miko,0 s
(34)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_miko,0 s
(35)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_miko,0 s
(36)-Interior lighting; parameter-p_t_verzoegerung_einstieg_dach,0 s
(37)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_dach,0 s
(38)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_dach,0 s
(39)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_dach,0 s
(40)-Interior lighting; parameter-p_t_verzoegerung_schliessen_dach,0 s
(41)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_dach,0 s
(42)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_dach,0 s
(43)-Interior lighting; parameter-p_helligkeit_entriegelt_innenlicht,100 %
(44)-Interior lighting; parameter-p_helligkeit_max_innenlicht,100 %
(45)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %
(46)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %
(47)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %
(48)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %
(49)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %
(50)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %
(51)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %
(52)-Interior lighting; parameter-p_helligkeit_einausstieg_innenlicht,100 %
(53)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %
(54)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %
(55)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %
(56)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %
(57)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %
(58)-Interior lighting; parameter-p_adaption_kundenwunsch_tuer,3C
(59)-Interior lighting; parameter-p_helligkeit_entriegelt_tueren,0 %
(60)-Interior lighting; parameter-p_helligkeit_max_tueren,96 %
(61)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %
(62)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %
(63)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %
(64)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %
(65)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %
(66)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %
(67)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %
(68)-Interior lighting; parameter-p_helligkeit_einausstieg_tueren,96 %
(69)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %
(70)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %
(71)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %
(72)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %
(73)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %
(74)-Interior lighting; parameter-p_adaption_kundenwunsch_fussraum,28
(75)-Interior lighting; parameter-p_helligkeit_entriegelt_fussraum,0 %
(76)-Interior lighting; parameter-p_helligkeit_max_fussraum,70 %
(77)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %
(78)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %
(79)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %
(80)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %
(81)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %
(82)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %
(83)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %
(84)-Interior lighting; parameter-p_helligkeit_einausstieg_fussraum,70 %
(85)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %
(86)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %
(87)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %
(88)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %
(89)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %
(90)-Interior lighting; parameter-p_adaption_kundenwunsch_lautsprecher,64
(91)-Interior lighting; parameter-p_helligkeit_entriegelt_lautsprecher,100 %
(92)-Interior lighting; parameter-p_helligkeit_max_lautsprecher,100 %
(93)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %
(94)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %
(95)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %
(96)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %
(97)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %
(98)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %
(99)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %
(100)-Interior lighting; parameter-p_helligkeit_einausstieg_lautsprecher,100 %
(101)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %
(102)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %
(103)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %
(104)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %
(105)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %
(106)-Interior lighting; parameter-p_adaption_kundenwunsch_itafel,3C
(107)-Interior lighting; parameter-p_helligkeit_entriegelt_itafel,0 %
(108)-Interior lighting; parameter-p_helligkeit_max_itafel,96 %
(109)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %
(110)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %
(111)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %
(112)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %
(113)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %
(114)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %
(115)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %
(116)-Interior lighting; parameter-p_helligkeit_einausstieg_itafel,96 %
(117)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %
(118)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %
(119)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %
(120)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %
(121)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,0 %
(122)-Interior lighting; parameter-p_adaption_kundenwunsch_cockpit,B7
(123)-Interior lighting; parameter-p_helligkeit_entriegelt_cockpit,0 %
(124)-Interior lighting; parameter-p_helligkeit_max_cockpit,0 %
(125)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,0 %
(126)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,0 %
(127)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,0 %
(128)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,188 %
(129)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,1 %
(130)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,1 %
(131)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,0 %
(132)-Interior lighting; parameter-p_helligkeit_einausstieg_cockpit,28 %
(133)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,1 %
(134)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,145 %
(135)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,0 %
(136)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,0 %
(137)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,0 %
(138)-Interior lighting; parameter-p_adaption_kundenwunsch_miko,B7
(139)-Interior lighting; parameter-p_helligkeit_entriegelt_miko,0 %
(140)-Interior lighting; parameter-p_helligkeit_max_miko,45 %
(141)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_miko,1 %
(142)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_miko,156 %
(143)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,0 %
(144)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,0 %
(145)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,1 %
(146)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,36 %
(147)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,69 %
(148)-Interior lighting; parameter-p_helligkeit_einausstieg_miko,0 %
(149)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,0 %
(150)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,240 %
(151)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,0 %
(152)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,157 %
(153)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,0 %
(154)-Interior lighting; parameter-p_adaption_kundenwunsch_dach,00
(155)-Interior lighting; parameter-p_helligkeit_entriegelt_dach,0 %
(156)-Interior lighting; parameter-p_helligkeit_max_dach,176 %
(157)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_dach,1 %
(158)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_dach,0 %
(159)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,0 %
(160)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,0 %
(161)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,0 %
(162)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,1 %
(163)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,0 %
(164)-Interior lighting; parameter-p_helligkeit_einausstieg_dach,0 %
(165)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,0 %
(166)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,0 %
(167)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,0 %
(168)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,1 %
(169)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,1 %
(170)-Interior lighting; parameter-p_adaption_kundenwunsch_psd,00
(171)-Interior lighting; parameter-p_helligkeit_entriegelt_psd,0 %
(172)-Interior lighting; parameter-p_helligkeit_max_psd,32 %
(173)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %
(174)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_psd,182 %
(175)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,86 %
(176)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,215 %
(177)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,200 %
(178)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,1 %
(179)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %
(180)-Interior lighting; parameter-p_helligkeit_einausstieg_psd,0 %
(181)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %
(182)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,176 %
(183)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,1 %
(184)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %
(185)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %
(186)-Interior lighting; parameter-p_dimmfaktor_farbwechsel_auf,00
(187)-Interior lighting; parameter-p_dimmfaktor_farbwechsel_ab,00
(188)-Interior lighting; parameter-p_farbwechsel_delay,A7
(189)-Interior lighting; parameter-p_farbauswahl_HMI,C8
(190)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI,01
(191)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_2,00
(192)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_3,00
(193)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_4,00
(194)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI,B0
(195)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_2,01
(196)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_3,00
(197)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_4,00
(198)-Interior lighting; parameter-p_verzoegerung_berechnen,01
(199)-Interior lighting; parameter-p_t_HMI_verzoegerung_helligkeitswerte,0 ms
(1)-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten
(2)-Light configuration-BAP Bitposition 0,34
(3)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Light configuration-Lichtfunktion A 0,2
(5)-Light configuration-Lichtfunktion B 0,0
(6)-Light configuration-Dimmwert AB 0,127
(7)-Light configuration-Lichtansteuerung HD AB 0,Always
(8)-Light configuration-Lichtfunktion C 0,0
(9)-Light configuration-Lichtfunktion D 0,0
(10)-Light configuration-Dimmwert CD 0,0
(11)-Light configuration-Dimming Direction CD 0,maximize
(12)-Light configuration-Lichtfunktion E 0,0
(13)-Light configuration-Lichtfunktion F 0,0
(14)-Light configuration-Dimmwert EF 0,0
(15)-Light configuration-Dimming Direction EF 0,maximize
(16)-Light configuration-Lichtfunktion G 0,0
(17)-Light configuration-Lichtfunktion H 0,0
(18)-Light configuration-Dimmwert GH 0,0
(19)-Light configuration-Dimming Direction GH 0,maximize
(20)-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten
(21)-Light configuration-BAP Bitposition 1,3E
(22)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
(23)-Light configuration-Lichtfunktion A 1,4
(24)-Light configuration-Lichtfunktion B 1,0
(25)-Light configuration-Dimmwert AB 1,127
(26)-Light configuration-Lichtansteuerung HD AB 1,Always
(27)-Light configuration-Lichtfunktion C 1,0
(28)-Light configuration-Lichtfunktion D 1,0
(29)-Light configuration-Dimmwert CD 1,0
(30)-Light configuration-Dimming Direction CD 1,maximize
(31)-Light configuration-Lichtfunktion E 1,0
(32)-Light configuration-Lichtfunktion F 1,0
(33)-Light configuration-Dimmwert EF 1,0
(34)-Light configuration-Dimming Direction EF 1,maximize
(35)-Light configuration-Lichtfunktion G 1,0
(36)-Light configuration-Lichtfunktion H 1,0
(37)-Light configuration-Dimmwert GH 1,0
(38)-Light configuration-Dimming Direction GH 1,maximize
(39)-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
(40)-Light configuration-BAP Bitposition 2,48
(41)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
(42)-Light configuration-Lichtfunktion A 2,20
(43)-Light configuration-Lichtfunktion B 2,0
(44)-Light configuration-Dimmwert AB 2,100
(45)-Light configuration-Lichtansteuerung HD AB 2,Always
(46)-Light configuration-Lichtfunktion C 2,6
(47)-Light configuration-Lichtfunktion D 2,0
(48)-Light configuration-Dimmwert CD 2,28
(49)-Light configuration-Dimming Direction CD 2,minimize
(50)-Light configuration-Lichtfunktion E 2,8
(51)-Light configuration-Lichtfunktion F 2,9
(52)-Light configuration-Dimmwert EF 2,28
(53)-Light configuration-Dimming Direction EF 2,maximize
(54)-Light configuration-Lichtfunktion G 2,18
(55)-Light configuration-Lichtfunktion H 2,0
(56)-Light configuration-Dimmwert GH 2,28
(57)-Light configuration-Dimming Direction GH 2,minimize
(58)-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
(59)-Light configuration-BAP Bitposition 3,4C
(60)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C
(61)-Light configuration-Lichtfunktion A 3,20
(62)-Light configuration-Lichtfunktion B 3,0
(63)-Light configuration-Dimmwert AB 3,100
(64)-Light configuration-Lichtansteuerung HD AB 3,Always
(65)-Light configuration-Lichtfunktion C 3,7
(66)-Light configuration-Lichtfunktion D 3,0
(67)-Light configuration-Dimmwert CD 3,28
(68)-Light configuration-Dimming Direction CD 3,minimize
(69)-Light configuration-Lichtfunktion E 3,8
(70)-Light configuration-Lichtfunktion F3,10
(71)-Light configuration-Dimmwert EF 3,28
(72)-Light configuration-Dimming Direction EF 3,maximize
(73)-Light configuration-Lichtfunktion G 3,19
(74)-Light configuration-Lichtfunktion H 3,0
(75)-Light configuration-Dimmwert GH 3,28
(76)-Light configuration-Dimming Direction GH 3,minimize
(77)-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
(78)-Light configuration-BAP Bitposition 4,3A
(79)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49
(80)-Light configuration-Lichtfunktion A 4,20
(81)-Light configuration-Lichtfunktion B 4,0
(82)-Light configuration-Dimmwert AB 4,127
(83)-Light configuration-Lichtansteuerung HD AB 4,Always
(84)-Light configuration-Lichtfunktion C 4,0
(85)-Light configuration-Lichtfunktion D 4,0
(86)-Light configuration-Dimmwert CD 4,0
(87)-Light configuration-Dimming Direction CD 4,maximize
(88)-Light configuration-Lichtfunktion E 4,8
(89)-Light configuration-Lichtfunktion F 4,9
(90)-Light configuration-Dimmwert EF 4,127
(91)-Light configuration-Dimming Direction EF 4,maximize
(92)-Light configuration-Lichtfunktion G 4,0
(93)-Light configuration-Lichtfunktion H 4,0
(94)-Light configuration-Dimmwert GH 4,0
(95)-Light configuration-Dimming Direction GH 4,maximize
(96)-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
(97)-Light configuration-BAP Bitposition 5,44
(98)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B
(99)-Light configuration-Lichtfunktion A 5,20
(100)-Light configuration-Lichtfunktion B 5,0
(101)-Light configuration-Dimmwert AB 5,127
(102)-Light configuration-Lichtansteuerung HD AB 5,Always
(103)-Light configuration-Lichtfunktion C 5,0
(104)-Light configuration-Lichtfunktion D 5,0
(105)-Light configuration-Dimmwert CD 5,0
(106)-Light configuration-Dimming Direction CD 5,maximize
(107)-Light configuration-Lichtfunktion E 5,8
(108)-Light configuration-Lichtfunktion F5,10
(109)-Light configuration-Dimmwert EF 5,127
(110)-Light configuration-Dimming Direction EF 5,maximize
(111)-Light configuration-Lichtfunktion G 5,0
(112)-Light configuration-Lichtfunktion H 5,0
(113)-Light configuration-Dimmwert GH 5,0
(114)-Light configuration-Dimming Direction GH 5,maximize
(115)-Light configuration-Lasttyp 6,5 - LED Abblendlicht
(116)-Light configuration-BAP Bitposition 6,36
(117)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
(118)-Light configuration-Lichtfunktion A 6,11
(119)-Light configuration-Lichtfunktion B 6,15
(120)-Light configuration-Dimmwert AB 6,127
(121)-Light configuration-Lichtansteuerung HD AB 6,Always
(122)-Light configuration-Lichtfunktion C 6,0
(123)-Light configuration-Lichtfunktion D 6,0
(124)-Light configuration-Dimmwert CD 6,0
(125)-Light configuration-Dimming Direction CD 6,maximize
(126)-Light configuration-Lichtfunktion E 6,0
(127)-Light configuration-Lichtfunktion F 6,0
(128)-Light configuration-Dimmwert EF 6,0
(129)-Light configuration-Dimming Direction EF 6,maximize
(130)-Light configuration-Lichtfunktion G 6,0
(131)-Light configuration-Lichtfunktion H 6,0
(132)-Light configuration-Dimmwert GH 6,0
(133)-Light configuration-Dimming Direction GH 6,maximize
(134)-Light configuration-Lasttyp 7,5 - LED Abblendlicht
(135)-Light configuration-BAP Bitposition 7,40
(136)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
(137)-Light configuration-Lichtfunktion A 7,12
(138)-Light configuration-Lichtfunktion B 7,15
(139)-Light configuration-Dimmwert AB 7,127
(140)-Light configuration-Lichtansteuerung HD AB 7,Always
(141)-Light configuration-Lichtfunktion C 7,0
(142)-Light configuration-Lichtfunktion D 7,0
(143)-Light configuration-Dimmwert CD 7,0
(144)-Light configuration-Dimming Direction CD 7,maximize
(145)-Light configuration-Lichtfunktion E 7,0
(146)-Light configuration-Lichtfunktion F 7,0
(147)-Light configuration-Dimmwert EF 7,0
(148)-Light configuration-Dimming Direction EF 7,maximize
(149)-Light configuration-Lichtfunktion G 7,0
(150)-Light configuration-Lichtfunktion H 7,0
(151)-Light configuration-Dimmwert GH 7,0
(152)-Light configuration-Dimming Direction GH 7,maximize
(154)-Light configuration-BAP Bitposition 8,00
(155)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,00
(156)-Light configuration-Lichtfunktion A 8,0
(157)-Light configuration-Lichtfunktion B 8,0
(158)-Light configuration-Dimmwert AB 8,60
(159)-Light configuration-Lichtansteuerung HD AB 8,only_if_closed
(160)-Light configuration-Lichtfunktion C 8,1
(161)-Light configuration-Lichtfunktion D 8,1
(162)-Light configuration-Dimmwert CD 8,0
(163)-Light configuration-Dimming Direction CD 8,maximize
(164)-Light configuration-Lichtfunktion E 8,28
(165)-Light configuration-Lichtfunktion F 8,1
(166)-Light configuration-Dimmwert EF 8,17
(167)-Light configuration-Dimming Direction EF 8,minimize
(168)-Light configuration-Lichtfunktion G 8,0
(169)-Light configuration-Lichtfunktion H 8,0
(170)-Light configuration-Dimmwert GH 8,0
(171)-Light configuration-Dimming Direction GH 8,maximize
(173)-Light configuration-BAP Bitposition 9,00
(174)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,01
(175)-Light configuration-Lichtfunktion A 9,156
(176)-Light configuration-Lichtfunktion B 9,0
(177)-Light configuration-Dimmwert AB 9,0
(178)-Light configuration-Lichtansteuerung HD AB 9,Always
(179)-Light configuration-Lichtfunktion C 9,1
(180)-Light configuration-Lichtfunktion D 9,0
(181)-Light configuration-Dimmwert CD 9,53
(182)-Light configuration-Dimming Direction CD 9,maximize
(183)-Light configuration-Lichtfunktion E 9,0
(184)-Light configuration-Lichtfunktion F 9,0
(185)-Light configuration-Dimmwert EF 9,112
(186)-Light configuration-Dimming Direction EF 9,minimize
(187)-Light configuration-Lichtfunktion G 9,0
(188)-Light configuration-Lichtfunktion H 9,97
(189)-Light configuration-Dimmwert GH 9,0
(190)-Light configuration-Dimming Direction GH 9,maximize
(191)-Light configuration-Lasttyp 10,not active
(192)-Light configuration-BAP Bitposition 10,00
(193)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,01
(194)-Light configuration-Lichtfunktion A 10,0
(195)-Light configuration-Lichtfunktion B 10,0
(196)-Light configuration-Dimmwert AB 10,0
(197)-Light configuration-Lichtansteuerung HD AB 10,Always
(198)-Light configuration-Lichtfunktion C 10,0
(199)-Light configuration-Lichtfunktion D 10,1
(200)-Light configuration-Dimmwert CD 10,0
(201)-Light configuration-Dimming Direction CD 10,maximize
(202)-Light configuration-Lichtfunktion E 10,0
(203)-Light configuration-Lichtfunktion F 10,0
(204)-Light configuration-Dimmwert EF 10,0
(205)-Light configuration-Dimming Direction EF 10,maximize
(206)-Light configuration-Lichtfunktion G 10,0
(207)-Light configuration-Lichtfunktion H 10,1
(208)-Light configuration-Dimmwert GH 10,1
(209)-Light configuration-Dimming Direction GH 10,maximize
(210)-Light configuration-Lasttyp 11,not active
(211)-Light configuration-BAP Bitposition 11,00
(212)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00
(213)-Light configuration-Lichtfunktion A 11,19
(214)-Light configuration-Lichtfunktion B 11,86
(215)-Light configuration-Dimmwert AB 11,87
(216)-Light configuration-Lichtansteuerung HD AB 11,only_if_closed
(217)-Light configuration-Lichtfunktion C 11,200
(218)-Light configuration-Lichtfunktion D 11,1
(219)-Light configuration-Dimmwert CD 11,0
(220)-Light configuration-Dimming Direction CD 11,maximize
(221)-Light configuration-Lichtfunktion E 11,0
(222)-Light configuration-Lichtfunktion F 11,0
(223)-Light configuration-Dimmwert EF 11,48
(224)-Light configuration-Dimming Direction EF 11,minimize
(225)-Light configuration-Lichtfunktion G 11,1
(226)-Light configuration-Lichtfunktion H 11,0
(227)-Light configuration-Dimmwert GH 11,0
(228)-Light configuration-Dimming Direction GH 11,maximize
(229)-Light configuration-Lasttyp 12,not active
(230)-Light configuration-BAP Bitposition 12,00
(231)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,C8
(232)-Light configuration-Lichtfunktion A 12,1
(233)-Light configuration-Lichtfunktion B 12,0
(234)-Light configuration-Dimmwert AB 12,0
(235)-Light configuration-Lichtansteuerung HD AB 12,Always
(236)-Light configuration-Lichtfunktion C 12,0
(237)-Light configuration-Lichtfunktion D 12,176
(238)-Light configuration-Dimmwert CD 12,1
(239)-Light configuration-Dimming Direction CD 12,maximize
(240)-Light configuration-Lichtfunktion E 12,0
(241)-Light configuration-Lichtfunktion F 12,0
(242)-Light configuration-Dimmwert EF 12,1
(243)-Light configuration-Dimming Direction EF 12,maximize
(244)-Light configuration-Lichtfunktion G 12,0
(245)-Light configuration-Lichtfunktion H 12,229
(246)-Light configuration-Dimmwert GH 12,1
(247)-Light configuration-Dimming Direction GH 12,maximize
(248)-Light configuration-Lasttyp 13,not active
(249)-Light configuration-BAP Bitposition 13,00
(250)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,01
(251)-Light configuration-Lichtfunktion A 13,55
(252)-Light configuration-Lichtfunktion B 13,1
(253)-Light configuration-Dimmwert AB 13,119
(254)-Light configuration-Lichtansteuerung HD AB 13,only_if_closed
(255)-Light configuration-Lichtfunktion C 13,0
(256)-Light configuration-Lichtfunktion D 13,1
(257)-Light configuration-Dimmwert CD 13,0
(258)-Light configuration-Dimming Direction CD 13,maximize
(259)-Light configuration-Lichtfunktion E 13,0
(260)-Light configuration-Lichtfunktion F 13,0
(261)-Light configuration-Dimmwert EF 13,48
(262)-Light configuration-Dimming Direction EF 13,minimize
(263)-Light configuration-Lichtfunktion G 13,1
(264)-Light configuration-Lichtfunktion H 13,0
(265)-Light configuration-Dimmwert GH 13,0
(266)-Light configuration-Dimming Direction GH 13,maximize
(267)-Light configuration-Lasttyp 14,not active
(268)-Light configuration-BAP Bitposition 14,00
(269)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,01
(270)-Light configuration-Lichtfunktion A 14,1
(271)-Light configuration-Lichtfunktion B 14,0
(272)-Light configuration-Dimmwert AB 14,0
(273)-Light configuration-Lichtansteuerung HD AB 14,Always
(274)-Light configuration-Lichtfunktion C 14,0
(275)-Light configuration-Lichtfunktion D 14,1
(276)-Light configuration-Dimmwert CD 14,0
(277)-Light configuration-Dimming Direction CD 14,maximize
(278)-Light configuration-Lichtfunktion E 14,255
(279)-Light configuration-Lichtfunktion F 14,52
(280)-Light configuration-Dimmwert EF 14,0
(281)-Light configuration-Dimming Direction EF 14,maximize
(282)-Light configuration-Lichtfunktion G 14,0
(283)-Light configuration-Lichtfunktion H 14,77
(284)-Light configuration-Dimmwert GH 14,1
(285)-Light configuration-Dimming Direction GH 14,maximize
(287)-Light configuration-BAP Bitposition 15,00
(288)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,01
(289)-Light configuration-Lichtfunktion A 15,58
(290)-Light configuration-Lichtfunktion B 15,0
(291)-Light configuration-Dimmwert AB 15,9
(292)-Light configuration-Lichtansteuerung HD AB 15,Always
(293)-Light configuration-Lichtfunktion C 15,50
(294)-Light configuration-Lichtfunktion D 15,0
(295)-Light configuration-Dimmwert CD 15,0
(296)-Light configuration-Dimming Direction CD 15,maximize
(297)-Light configuration-Lichtfunktion E 15,0
(298)-Light configuration-Lichtfunktion F 15,253
(299)-Light configuration-Dimmwert EF 15,0
(300)-Light configuration-Dimming Direction EF 15,maximize
(301)-Light configuration-Lichtfunktion G 15,0
(302)-Light configuration-Lichtfunktion H 15,1
(303)-Light configuration-Dimmwert GH 15,0
(304)-Light configuration-Dimming Direction GH 15,maximize
(306)-Light configuration-BAP Bitposition 16,00
(307)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,FB
(308)-Light configuration-Lichtfunktion A 16,240
(309)-Light configuration-Lichtfunktion B 16,251
(310)-Light configuration-Dimmwert AB 16,0
(311)-Light configuration-Lichtansteuerung HD AB 16,Always
(312)-Light configuration-Lichtfunktion C 16,0
(313)-Light configuration-Lichtfunktion D 16,254
(314)-Light configuration-Dimmwert CD 16,0
(315)-Light configuration-Dimming Direction CD 16,maximize
(316)-Light configuration-Lichtfunktion E 16,0
(317)-Light configuration-Lichtfunktion F 16,0
(318)-Light configuration-Dimmwert EF 16,0
(319)-Light configuration-Dimming Direction EF 16,maximize
(320)-Light configuration-Lichtfunktion G 16,0
(321)-Light configuration-Lichtfunktion H 16,67
(322)-Light configuration-Dimmwert GH 16,1
(323)-Light configuration-Dimming Direction GH 16,maximize
(324)-Light configuration-Lasttyp 17,not active
(325)-Light configuration-BAP Bitposition 17,00
(326)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,FB
(327)-Light configuration-Lichtfunktion A 17,0
(328)-Light configuration-Lichtfunktion B 17,0
(329)-Light configuration-Dimmwert AB 17,6
(330)-Light configuration-Lichtansteuerung HD AB 17,Always
(331)-Light configuration-Lichtfunktion C 17,0
(332)-Light configuration-Lichtfunktion D 17,0
(333)-Light configuration-Dimmwert CD 17,0
(334)-Light configuration-Dimming Direction CD 17,maximize
(335)-Light configuration-Lichtfunktion E 17,194
(336)-Light configuration-Lichtfunktion F 17,1
(337)-Light configuration-Dimmwert EF 17,118
(338)-Light configuration-Dimming Direction EF 17,minimize
(339)-Light configuration-Lichtfunktion G 17,86
(340)-Light configuration-Lichtfunktion H 17,48
(341)-Light configuration-Dimmwert GH 17,2
(342)-Light configuration-Dimming Direction GH 17,maximize
(344)-Light configuration-BAP Bitposition 18,FB
(345)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,00
(346)-Light configuration-Lichtfunktion A 18,14
(347)-Light configuration-Lichtfunktion B 18,0
(348)-Light configuration-Dimmwert AB 18,13
(349)-Light configuration-Lichtansteuerung HD AB 18,Always
(350)-Light configuration-Lichtfunktion C 18,85
(351)-Light configuration-Lichtfunktion D 18,0
(352)-Light configuration-Dimmwert CD 18,0
(353)-Light configuration-Dimming Direction CD 18,maximize
(354)-Light configuration-Lichtfunktion E 18,224
(355)-Light configuration-Lichtfunktion F 18,0
(356)-Light configuration-Dimmwert EF 18,16
(357)-Light configuration-Dimming Direction EF 18,minimize
(358)-Light configuration-Lichtfunktion G 18,1
(359)-Light configuration-Lichtfunktion H 18,224
(360)-Light configuration-Dimmwert GH 18,1
(361)-Light configuration-Dimming Direction GH 18,maximize
(362)-Light configuration-Lasttyp 19,not active
(363)-Light configuration-BAP Bitposition 19,00
(364)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,FB
(365)-Light configuration-Lichtfunktion A 19,144
(366)-Light configuration-Lichtfunktion B 19,251
(367)-Light configuration-Dimmwert AB 19,21
(368)-Light configuration-Lichtansteuerung HD AB 19,Always
(369)-Light configuration-Lichtfunktion C 19,251
(370)-Light configuration-Lichtfunktion D 19,0
(371)-Light configuration-Dimmwert CD 19,0
(372)-Light configuration-Dimming Direction CD 19,maximize
(373)-Light configuration-Lichtfunktion E 19,211
(374)-Light configuration-Lichtfunktion F 19,1
(375)-Light configuration-Dimmwert EF 19,0
(376)-Light configuration-Dimming Direction EF 19,maximize
(377)-Light configuration-Lichtfunktion G 19,0
(378)-Light configuration-Lichtfunktion H 19,0
(379)-Light configuration-Dimmwert GH 19,0
(380)-Light configuration-Dimming Direction GH 19,maximize
(381)-Light configuration-Lasttyp 20,not active
(382)-Light configuration-BAP Bitposition 20,00
(383)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,00
(384)-Light configuration-Lichtfunktion A 20,62
(385)-Light configuration-Lichtfunktion B 20,0
(386)-Light configuration-Dimmwert AB 20,74
(387)-Light configuration-Lichtansteuerung HD AB 20,only_if_closed
(388)-Light configuration-Lichtfunktion C 20,1
(389)-Light configuration-Lichtfunktion D 20,0
(390)-Light configuration-Dimmwert CD 20,0
(391)-Light configuration-Dimming Direction CD 20,maximize
(392)-Light configuration-Lichtfunktion E 20,233
(393)-Light configuration-Lichtfunktion F 20,0
(394)-Light configuration-Dimmwert EF 20,1
(395)-Light configuration-Dimming Direction EF 20,maximize
(396)-Light configuration-Lichtfunktion G 20,0
(397)-Light configuration-Lichtfunktion H 20,16
(398)-Light configuration-Dimmwert GH 20,0
(399)-Light configuration-Dimming Direction GH 20,maximize
(400)-Light configuration-Lasttyp 21,5 - LED Abblendlicht
(401)-Light configuration-BAP Bitposition 21,00
(402)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,00
(403)-Light configuration-Lichtfunktion A 21,241
(404)-Light configuration-Lichtfunktion B 21,0
(405)-Light configuration-Dimmwert AB 21,0
(406)-Light configuration-Lichtansteuerung HD AB 21,Always
(407)-Light configuration-Lichtfunktion C 21,0
(408)-Light configuration-Lichtfunktion D 21,0
(409)-Light configuration-Dimmwert CD 21,0
(410)-Light configuration-Dimming Direction CD 21,maximize
(411)-Light configuration-Lichtfunktion E 21,31
(412)-Light configuration-Lichtfunktion F 21,251
(413)-Light configuration-Dimmwert EF 21,0
(414)-Light configuration-Dimming Direction EF 21,maximize
(415)-Light configuration-Lichtfunktion G 21,0
(416)-Light configuration-Lichtfunktion H 21,0
(417)-Light configuration-Dimmwert GH 21,0
(418)-Light configuration-Dimming Direction GH 21,maximize
(419)-Light configuration-Lasttyp 22,not active
(420)-Light configuration-BAP Bitposition 22,00
(421)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,00
(422)-Light configuration-Lichtfunktion A 22,1
(423)-Light configuration-Lichtfunktion B 22,0
(424)-Light configuration-Dimmwert AB 22,48
(425)-Light configuration-Lichtansteuerung HD AB 22,only_if_closed
(426)-Light configuration-Lichtfunktion C 22,0
(427)-Light configuration-Lichtfunktion D 22,176
(428)-Light configuration-Dimmwert CD 22,0
(429)-Light configuration-Dimming Direction CD 22,maximize
(430)-Light configuration-Lichtfunktion E 22,1
(431)-Light configuration-Lichtfunktion F 22,0
(432)-Light configuration-Dimmwert EF 22,16
(433)-Light configuration-Dimming Direction EF 22,maximize
(434)-Light configuration-Lichtfunktion G 22,0
(435)-Light configuration-Lichtfunktion H 22,13
(436)-Light configuration-Dimmwert GH 22,1
(437)-Light configuration-Dimming Direction GH 22,maximize
(439)-Light configuration-BAP Bitposition 23,00
(440)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00
(441)-Light configuration-Lichtfunktion A 23,232
(442)-Light configuration-Lichtfunktion B 23,0
(443)-Light configuration-Dimmwert AB 23,48
(444)-Light configuration-Lichtansteuerung HD AB 23,only_if_closed
(445)-Light configuration-Lichtfunktion C 23,0
(446)-Light configuration-Lichtfunktion D 23,144
(447)-Light configuration-Dimmwert CD 23,0
(448)-Light configuration-Dimming Direction CD 23,maximize
(449)-Light configuration-Lichtfunktion E 23,98
(450)-Light configuration-Lichtfunktion F 23,1
(451)-Light configuration-Dimmwert EF 23,36
(452)-Light configuration-Dimming Direction EF 23,minimize
(453)-Light configuration-Lichtfunktion G 23,0
(454)-Light configuration-Lichtfunktion H 23,144
(455)-Light configuration-Dimmwert GH 23,0
(456)-Light configuration-Dimming Direction GH 23,maximize
(457)-Light configuration-Lasttyp 24,not active
(458)-Light configuration-BAP Bitposition 24,00
(459)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00
(460)-Light configuration-Lichtfunktion A 24,1
(461)-Light configuration-Lichtfunktion B 24,0
(462)-Light configuration-Dimmwert AB 24,17
(463)-Light configuration-Lichtansteuerung HD AB 24,only_if_closed
(464)-Light configuration-Lichtfunktion C 24,0
(465)-Light configuration-Lichtfunktion D 24,112
(466)-Light configuration-Dimmwert CD 24,1
(467)-Light configuration-Dimming Direction CD 24,maximize
(468)-Light configuration-Lichtfunktion E 24,144
(469)-Light configuration-Lichtfunktion F 24,0
(470)-Light configuration-Dimmwert EF 24,1
(471)-Light configuration-Dimming Direction EF 24,maximize
(472)-Light configuration-Lichtfunktion G 24,0
(473)-Light configuration-Lichtfunktion H 24,211
(474)-Light configuration-Dimmwert GH 24,0
(475)-Light configuration-Dimming Direction GH 24,maximize
(477)-Light configuration-BAP Bitposition 25,00
(478)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,01
(479)-Light configuration-Lichtfunktion A 25,58
(480)-Light configuration-Lichtfunktion B 25,0
(481)-Light configuration-Dimmwert AB 25,56
(482)-Light configuration-Lichtansteuerung HD AB 25,only_if_closed
(483)-Light configuration-Lichtfunktion C 25,0
(484)-Light configuration-Lichtfunktion D 25,1
(485)-Light configuration-Dimmwert CD 25,0
(486)-Light configuration-Dimming Direction CD 25,maximize
(487)-Light configuration-Lichtfunktion E 25,0
(488)-Light configuration-Lichtfunktion F 25,0
(489)-Light configuration-Dimmwert EF 25,0
(490)-Light configuration-Dimming Direction EF 25,maximize
(491)-Light configuration-Lichtfunktion G 25,0
(492)-Light configuration-Lichtfunktion H 25,1
(493)-Light configuration-Dimmwert GH 25,0
(494)-Light configuration-Dimming Direction GH 25,maximize
(495)-Light configuration-Lasttyp 26,40 - allgemeine LED
(496)-Light configuration-BAP Bitposition 26,00
(497)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,01
(498)-Light configuration-Lichtfunktion A 26,144
(499)-Light configuration-Lichtfunktion B 26,0
(500)-Light configuration-Dimmwert AB 26,24
(501)-Light configuration-Lichtansteuerung HD AB 26,Always
(502)-Light configuration-Lichtfunktion C 26,1
(503)-Light configuration-Lichtfunktion D 26,24
(504)-Light configuration-Dimmwert CD 26,1
(505)-Light configuration-Dimming Direction CD 26,maximize
(506)-Light configuration-Lichtfunktion E 26,24
(507)-Light configuration-Lichtfunktion F 26,1
(508)-Light configuration-Dimmwert EF 26,126
(509)-Light configuration-Dimming Direction EF 26,minimize
(510)-Light configuration-Lichtfunktion G 26,255
(511)-Light configuration-Lichtfunktion H 26,128
(512)-Light configuration-Dimmwert GH 26,0
(513)-Light configuration-Dimming Direction GH 26,maximize
(514)-Light configuration-Lasttyp 27,not active
(515)-Light configuration-BAP Bitposition 27,00
(516)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,01
(517)-Light configuration-Lichtfunktion A 27,128
(518)-Light configuration-Lichtfunktion B 27,0
(519)-Light configuration-Dimmwert AB 27,71
(520)-Light configuration-Lichtansteuerung HD AB 27,Always
(521)-Light configuration-Lichtfunktion C 27,251
(522)-Light configuration-Lichtfunktion D 27,101
(523)-Light configuration-Dimmwert CD 27,0
(524)-Light configuration-Dimming Direction CD 27,maximize
(525)-Light configuration-Lichtfunktion E 27,0
(526)-Light configuration-Lichtfunktion F 27,0
(527)-Light configuration-Dimmwert EF 27,32
(528)-Light configuration-Dimming Direction EF 27,minimize
(529)-Light configuration-Lichtfunktion G 27,0
(530)-Light configuration-Lichtfunktion H 27,254
(531)-Light configuration-Dimmwert GH 27,127
(532)-Light configuration-Dimming Direction GH 27,minimize
(533)-Light configuration-Lasttyp 28,not active
(534)-Light configuration-BAP Bitposition 28,00
(535)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,01
(536)-Light configuration-Lichtfunktion A 28,0
(537)-Light configuration-Lichtfunktion B 28,0
(538)-Light configuration-Dimmwert AB 28,0
(539)-Light configuration-Lichtansteuerung HD AB 28,Always
(540)-Light configuration-Lichtfunktion C 28,0
(541)-Light configuration-Lichtfunktion D 28,120
(542)-Light configuration-Dimmwert CD 28,0
(543)-Light configuration-Dimming Direction CD 28,maximize
(544)-Light configuration-Lichtfunktion E 28,144
(545)-Light configuration-Lichtfunktion F 28,0
(546)-Light configuration-Dimmwert EF 28,0
(547)-Light configuration-Dimming Direction EF 28,maximize
(548)-Light configuration-Lichtfunktion G 28,255
(549)-Light configuration-Lichtfunktion H 28,144
(550)-Light configuration-Dimmwert GH 28,0
(551)-Light configuration-Dimming Direction GH 28,maximize
(553)-Light configuration-BAP Bitposition 29,FF
(554)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,01
(555)-Light configuration-Lichtfunktion A 29,62
(556)-Light configuration-Lichtfunktion B 29,0
(557)-Light configuration-Dimmwert AB 29,40
(558)-Light configuration-Lichtansteuerung HD AB 29,only_if_closed
(559)-Light configuration-Lichtfunktion C 29,0
(560)-Light configuration-Lichtfunktion D 29,24
(561)-Light configuration-Dimmwert CD 29,0
(562)-Light configuration-Dimming Direction CD 29,maximize
(563)-Light configuration-Lichtfunktion E 29,19
(564)-Light configuration-Lichtfunktion F 29,0
(565)-Light configuration-Dimmwert EF 29,5
(566)-Light configuration-Dimming Direction EF 29,maximize
(567)-Light configuration-Lichtfunktion G 29,0
(568)-Light configuration-Lichtfunktion H 29,0
(569)-Light configuration-Dimmwert GH 29,0
(570)-Light configuration-Dimming Direction GH 29,maximize
(571)-Light configuration-Lasttyp 30,not active
(572)-Light configuration-BAP Bitposition 30,00
(573)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00
(574)-Light configuration-Lichtfunktion A 30,78
(575)-Light configuration-Lichtfunktion B 30,0
(576)-Light configuration-Dimmwert AB 30,0
(577)-Light configuration-Lichtansteuerung HD AB 30,Always
(578)-Light configuration-Lichtfunktion C 30,0
(579)-Light configuration-Lichtfunktion D 30,232
(580)-Light configuration-Dimmwert CD 30,1
(581)-Light configuration-Dimming Direction CD 30,maximize
(582)-Light configuration-Lichtfunktion E 30,65
(583)-Light configuration-Lichtfunktion F 30,1
(584)-Light configuration-Dimmwert EF 30,68
(585)-Light configuration-Dimming Direction EF 30,maximize
(586)-Light configuration-Lichtfunktion G 30,69
(587)-Light configuration-Lichtfunktion H 30,0
(588)-Light configuration-Dimmwert GH 30,0
(589)-Light configuration-Dimming Direction GH 30,maximize
(591)-Light configuration-BAP Bitposition 31,00
(592)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00
(593)-Light configuration-Lichtfunktion A 31,62
(594)-Light configuration-Lichtfunktion B 31,0
(595)-Light configuration-Dimmwert AB 31,0
(596)-Light configuration-Lichtansteuerung HD AB 31,Always
(597)-Light configuration-Lichtfunktion C 31,0
(598)-Light configuration-Lichtfunktion D 31,16
(599)-Light configuration-Dimmwert CD 31,0
(600)-Light configuration-Dimming Direction CD 31,maximize
(601)-Light configuration-Lichtfunktion E 31,207
(602)-Light configuration-Lichtfunktion F 31,251
(603)-Light configuration-Dimmwert EF 31,0
(604)-Light configuration-Dimming Direction EF 31,maximize
(605)-Light configuration-Lichtfunktion G 31,0
(606)-Light configuration-Lichtfunktion H 31,0
(607)-Light configuration-Dimmwert GH 31,0
(608)-Light configuration-Dimming Direction GH 31,maximize
(609)-Light configuration-Lasttyp 32,1 - LED Tagfahrlichtmodul Versorgung
(610)-Light configuration-BAP Bitposition 32,00
(611)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00
(612)-Light configuration-Lichtfunktion A 32,254
(613)-Light configuration-Lichtfunktion B 32,255
(614)-Light configuration-Dimmwert AB 32,9
(615)-Light configuration-Lichtansteuerung HD AB 32,only_if_closed
(616)-Light configuration-Lichtfunktion C 32,0
(617)-Light configuration-Lichtfunktion D 32,0
(618)-Light configuration-Dimmwert CD 32,1
(619)-Light configuration-Dimming Direction CD 32,maximize
(620)-Light configuration-Lichtfunktion E 32,199
(621)-Light configuration-Lichtfunktion F 32,0
(622)-Light configuration-Dimmwert EF 32,0
(623)-Light configuration-Dimming Direction EF 32,maximize
(624)-Light configuration-Lichtfunktion G 32,0
(625)-Light configuration-Lichtfunktion H 32,0
(626)-Light configuration-Dimmwert GH 32,0
(627)-Light configuration-Dimming Direction GH 32,maximize
(628)-Light configuration-Lasttyp 33,not active
(629)-Light configuration-BAP Bitposition 33,00
(630)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00
(631)-Light configuration-Lichtfunktion A 33,62
(632)-Light configuration-Lichtfunktion B 33,0
(633)-Light configuration-Dimmwert AB 33,16
(634)-Light configuration-Lichtansteuerung HD AB 33,only_if_closed
(635)-Light configuration-Lichtfunktion C 33,0
(636)-Light configuration-Lichtfunktion D 33,72
(637)-Light configuration-Dimmwert CD 33,0
(638)-Light configuration-Dimming Direction CD 33,maximize
(639)-Light configuration-Lichtfunktion E 33,1
(640)-Light configuration-Lichtfunktion F 33,0
(641)-Light configuration-Dimmwert EF 33,0
(642)-Light configuration-Dimming Direction EF 33,maximize
(643)-Light configuration-Lichtfunktion G 33,0
(644)-Light configuration-Lichtfunktion H 33,0
(645)-Light configuration-Dimmwert GH 33,0
(646)-Light configuration-Dimming Direction GH 33,maximize
(648)-Light configuration-BAP Bitposition 34,00
(649)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,FF
(650)-Light configuration-Lichtfunktion A 34,255
(651)-Light configuration-Lichtfunktion B 34,255
(652)-Light configuration-Dimmwert AB 34,52
(653)-Light configuration-Lichtansteuerung HD AB 34,only_if_closed
(654)-Light configuration-Lichtfunktion C 34,251
(655)-Light configuration-Lichtfunktion D 34,207
(656)-Light configuration-Dimmwert CD 34,123
(657)-Light configuration-Dimming Direction CD 34,minimize
(658)-Light configuration-Lichtfunktion E 34,0
(659)-Light configuration-Lichtfunktion F 34,0
(660)-Light configuration-Dimmwert EF 34,0
(661)-Light configuration-Dimming Direction EF 34,maximize
(662)-Light configuration-Lichtfunktion G 34,0
(663)-Light configuration-Lichtfunktion H 34,0
(664)-Light configuration-Dimmwert GH 34,0
(665)-Light configuration-Dimming Direction GH 34,maximize
(1)-Light sensor-Einschaltgrenze_CHO_LHO,30 lx
(2)-Light sensor-Daemmerungsgrenze; Hysterese_obergrenze,60 lx
(3)-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,110 lx
(4)-Light sensor-Helligkeitsgrenze_sehr_hell,100 lx
(5)-Light sensor-Helligkeitsgrenze_Licht__einschalten,60 lx
(6)-Light sensor-Helligkeitsgrenze_Licht_ausschalten,110 lx
(7)-Light sensor-Minimale_Beleuchtungsstaerke,0 lx
(8)-Light sensor-Maximale_Beleuchtungsstaerke,300 lx
(9)-Light sensor-Minimale_Ausgangsspannung,2000 mV
(10)-Light sensor-Maximale_Ausgangsspannung,4500 mV
(11)-Light sensor-Tunnel_einschalt_verzoegerung,02
(12)-Light sensor-ECE_Lichteinschaltschwelle,1000 lx
(13)-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,80
lower turn position,26.30 °
Position during interval mode,24.89 °
(1)-Production mode-Scheinwerferreinigung,not active
(2)-Production mode-Frontwischer deaktivieren,not active
(3)-Production mode-Heckwischer,not active
(4)-Production mode-Interior lighting,not active
(5)-Production mode-Aussenbeleuchtung,not active
(6)-Production mode-Access control,not active
(7)-Production mode-Virtuel_pedal,not active
Read parameter address,FE 00 00
(1)-Rear Window Wiper-Komfortwischen Heck,active
(2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
(3)-Rear Window Wiper-Automatisches Heckwischen,not active
(4)-Rear Window Wiper-Traenenwischen Heck,active
(5)-Rear Window Wiper-Heckwischer Weiterlauf,not active
(6)-Rear Window Wiper-Kein automatisches Abparken,not active
(7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
(8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
(9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
(10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
(11)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
(12)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
(13)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
Roller test bench mode; functional,not active
(1)-Seat fan charac. curve-Level_1_Sitz,30 %
(2)-Seat fan charac. curve-Level_1_Lehne,30 %
(3)-Seat fan charac. curve-Level_2_Sitz,30 %
(4)-Seat fan charac. curve-Level_2_Lehne,30 %
(5)-Seat fan charac. curve-Level_3_Sitz,50 %
(6)-Seat fan charac. curve-Level_3_Lehne,50 %
(7)-Seat fan charac. curve-Level_4_Sitz,50 %
(8)-Seat fan charac. curve-Level_4_Lehne,50 %
(9)-Seat fan charac. curve-Level_5_Sitz,75 %
(10)-Seat fan charac. curve-Level_5_Lehne,75 %
(11)-Seat fan charac. curve-Level_6_Sitz,80 %
(12)-Seat fan charac. curve-Level_6_Lehne,80 %
(1)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,22.00 °C
(2)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,23.00 °C
(3)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C
(4)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,23.00 °C
(5)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C
(6)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C
(7)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C
(8)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C
(9)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,53.00 °C
(10)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C
(11)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,53.00 °C
(12)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C
(13)-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s
(14)-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C
Service position,153.30 °
(1)-static AFS light-bei Rueckwaertsfahrt,both sides
(2)-static AFS light-Vorschrift,ECE R119
(3)-static AFS light-Lower speed threshold,0.00 km/h
(4)-static AFS light-Upper speed threshold,40.00 km/h
(5)-static AFS light-Steering wheel angle; offset,0.25 °
(6)-static AFS light-Unterer Lenkradwinkel,80 °
(7)-static AFS light-Oberer Lenkradwinkel,120 °
(8)-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
(9)-static AFS light-Maximaltemperatur,100.00 °C
(10)-static AFS light-obere Grenztemperatur,95.00 °C
(11)-static AFS light-untere Grenztemperatur,80.00 °C
Transport mode,active
(1)-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
(2)-Turn signal control-Komfortblinken Blinkzyklen,5
(3)-Turn signal control-Sonderfunktionen,not enabled
(4)-Turn signal control-Signalprioritaet fuer Blinker,MFG
(5)-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
(6)-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
(7)-Turn signal control-Komfortblinken,active
(8)-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %
(9)-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
(10)-Turn signal control-Abbruch Komfortblinken,active
upper turn position,171.30 °
(1)-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
(2)-Window heater-Temperaturabhaengige Einschaltzeit FSH,active
(3)-Window heater-FSH Automatik,active
(4)-Window heater-Heckscheibenheizung Zeitwert,320 s
(5)-Window heater-Running time of heated front window,240 s
(6)-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
(7)-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
(1)-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10
(2)-Windshield wiper-SRA Verzoegerungszeit,2000 ms
(3)-Windshield wiper-SRA Waschzeit,1200 ms
(4)-Windshield wiper-SRA Einweichpausenzeit,2550 ms
(5)-Windshield wiper-SRA Nachwaschzeit,1200 ms
(6)-Windshield wiper-SRA Pausenzeit,0 ms
(7)-Windshield wiper-SRA bei Waschwassermangel,not active
(8)-Windshield wiper-Frontwischer Referenzlauf,active
(9)-Windshield wiper-Variable Regensensoraktivierung,not active
(10)-Windshield wiper-Wischer stop bei KL15 aus,not active
(11)-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
(12)-Windshield wiper-Regensensor aktivieren,Deactivating
(13)-Windshield wiper-Menuesteuerung Frontwischer,not active
(14)-Windshield wiper-Frontwischer Notlaufprogramm,active
(15)-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
(16)-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
(17)-Windshield wiper-Traenenwischen Front Status,not active
(18)-Windshield wiper-Washer_Tipwiping_Variant,0
(19)-Windshield wiper-Adaptives Nachwischen bei SRA,not active
(20)-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
(21)-Windshield wiper-Tippendes_Frontwaschen,not active
(22)-Windshield wiper-Frontwischer_Abtauposition,not active
(1)-Writing parameter-Parameter address,FE 00 00
(2)-Writing parameter-Value,130
(1)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed
(2)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door
(3)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00
(4)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed
(5)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door
(6)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00
(7)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed
(8)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door
(9)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00
(10)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed
(11)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door
(12)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00
(13)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed
(14)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door
(15)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00
(16)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed
(17)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door
(18)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00
(19)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed
(20)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door
(21)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00
(22)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed
(23)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door
(24)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00
(25)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed
(26)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door
(27)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00
(28)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed
(29)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door
(30)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00
(31)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed
(32)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door
(33)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00
(34)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed
(35)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door
(36)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00
(37)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed
(38)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door
(39)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00
(40)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed
(41)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door
(42)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00
(43)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed
(44)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door
(45)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00
(1)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0
(2)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed
(3)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00
(4)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0
(5)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed
(6)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0
(7)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0
(8)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed
(9)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0
(10)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0
(11)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed
(12)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0
(13)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0
(14)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed
(15)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0
(16)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0
(17)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed
(18)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0
(19)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0
(20)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed
(21)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0
(22)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0
(23)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed
(24)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0
(25)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0
(26)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed
(27)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0
(28)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0
(29)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed
(30)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0
(31)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0
(32)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed
(33)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0
(34)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0
(35)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed
(36)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0
(37)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0
(38)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed
(39)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0
(40)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0
(41)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed
(42)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0
(43)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0
(44)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed
(45)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0
(46)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0
(47)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed
(48)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0
(49)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0
(50)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed
(51)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0
(52)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0
(53)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed
(54)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0
(55)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0
(56)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed
(57)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0
(58)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0
(59)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed
(60)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0
(1)-debug_light_function-Adresse,0
(2)-debug_light_function-Bitmask,0
(3)-debug_light_function-Offset,0
(4)-debug_light_function-Divisor,0
(5)-debug_light_function-Polaritaet,0
(6)-debug_light_function-Activation,0
(7)-debug_light_function-WBT-Ausgabe,0
(1)-Innenbeleuchtung Abdimmen-x0,0 ms
(2)-Innenbeleuchtung Abdimmen-X1,200 ms
(3)-Innenbeleuchtung Abdimmen-X2,400 ms
(4)-Innenbeleuchtung Abdimmen-X3,600 ms
(5)-Innenbeleuchtung Abdimmen-X4,800 ms
(6)-Innenbeleuchtung Abdimmen-X5,1000 ms
(7)-Innenbeleuchtung Abdimmen-X6,1200 ms
(8)-Innenbeleuchtung Abdimmen-x7,1400 ms
(9)-Innenbeleuchtung Abdimmen-x8,1600 ms
(10)-Innenbeleuchtung Abdimmen-x9,1800 ms
(11)-Innenbeleuchtung Abdimmen-x10,2000 ms
(12)-Innenbeleuchtung Abdimmen-y0,100.00 %
(13)-Innenbeleuchtung Abdimmen-Y1,72.00 %
(14)-Innenbeleuchtung Abdimmen-Y2,48.00 %
(15)-Innenbeleuchtung Abdimmen-Y3,33.00 %
(16)-Innenbeleuchtung Abdimmen-Y4,18.00 %
(17)-Innenbeleuchtung Abdimmen-Y5,12.00 %
(18)-Innenbeleuchtung Abdimmen-Y6,8.00 %
(19)-Innenbeleuchtung Abdimmen-y7,6.00 %
(20)-Innenbeleuchtung Abdimmen-y8,4.00 %
(21)-Innenbeleuchtung Abdimmen-y9,2.00 %
(22)-Innenbeleuchtung Abdimmen-y10,0.00 %
(1)-Innenbeleuchtung Fotosensor-x0,0
(2)-Innenbeleuchtung Fotosensor-X1,50
(3)-Innenbeleuchtung Fotosensor-X2,100
(4)-Innenbeleuchtung Fotosensor-X3,200
(5)-Innenbeleuchtung Fotosensor-X4,253
(6)-Innenbeleuchtung Fotosensor-X5,0
(7)-Innenbeleuchtung Fotosensor-X6,0
(8)-Innenbeleuchtung Fotosensor-x7,0
(9)-Innenbeleuchtung Fotosensor-x8,0
(10)-Innenbeleuchtung Fotosensor-x9,0
(11)-Innenbeleuchtung Fotosensor-x10,0
(12)-Innenbeleuchtung Fotosensor-y0,0 lx
(13)-Innenbeleuchtung Fotosensor-Y1,50 lx
(14)-Innenbeleuchtung Fotosensor-Y2,100 lx
(15)-Innenbeleuchtung Fotosensor-Y3,200
(16)-Innenbeleuchtung Fotosensor-Y4,500
(17)-Innenbeleuchtung Fotosensor-Y5,0
(18)-Innenbeleuchtung Fotosensor-Y6,0 lx
(19)-Innenbeleuchtung Fotosensor-y7,0 lx
(20)-Innenbeleuchtung Fotosensor-y8,0 lx
(21)-Innenbeleuchtung Fotosensor-y9,0 lx
(22)-Innenbeleuchtung Fotosensor-y10,0 lx
(1)-Innenbeleuchtung Hochdimmen-x0,0 ms
(2)-Innenbeleuchtung Hochdimmen-X1,200 ms
(3)-Innenbeleuchtung Hochdimmen-X2,400 ms
(4)-Innenbeleuchtung Hochdimmen-X3,600 ms
(5)-Innenbeleuchtung Hochdimmen-X4,800 ms
(6)-Innenbeleuchtung Hochdimmen-X5,1000 ms
(7)-Innenbeleuchtung Hochdimmen-X6,1200 ms
(8)-Innenbeleuchtung Hochdimmen-x7,1400 ms
(9)-Innenbeleuchtung Hochdimmen-x8,1600 ms
(10)-Innenbeleuchtung Hochdimmen-x9,1800 ms
(11)-Innenbeleuchtung Hochdimmen-x10,2000 ms
(12)-Innenbeleuchtung Hochdimmen-y0,0.00 %
(13)-Innenbeleuchtung Hochdimmen-Y1,1.00 %
(14)-Innenbeleuchtung Hochdimmen-Y2,3.00 %
(15)-Innenbeleuchtung Hochdimmen-Y3,5.00 %
(16)-Innenbeleuchtung Hochdimmen-Y4,11.00 %
(17)-Innenbeleuchtung Hochdimmen-Y5,22.00 %
(18)-Innenbeleuchtung Hochdimmen-Y6,40.00 %
(19)-Innenbeleuchtung Hochdimmen-y7,80.00 %
(20)-Innenbeleuchtung Hochdimmen-y8,95.00 %
(21)-Innenbeleuchtung Hochdimmen-y9,100.00 %
(22)-Innenbeleuchtung Hochdimmen-y10,100.00 %
(1)-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
(2)-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
(3)-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
(4)-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
(5)-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
(6)-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
(7)-Innenbeleuchtung KL 58xd log Bus-y0,10
(8)-Innenbeleuchtung KL 58xd log Bus-Y1,10
(9)-Innenbeleuchtung KL 58xd log Bus-Y2,100
(10)-Innenbeleuchtung KL 58xd log Bus-Y3,150
(11)-Innenbeleuchtung KL 58xd log Bus-Y4,220
(12)-Innenbeleuchtung KL 58xd log Bus-Y5,253
(1)-Innenbeleuchtung KL 58xd max-x0,0 lx
(2)-Innenbeleuchtung KL 58xd max-X1,8 lx
(3)-Innenbeleuchtung KL 58xd max-X2,200 lx
(4)-Innenbeleuchtung KL 58xd max-X3,300 lx
(5)-Innenbeleuchtung KL 58xd max-X4,500 lx
(6)-Innenbeleuchtung KL 58xd max-y0,16.00
(7)-Innenbeleuchtung KL 58xd max-Y1,16.00
(8)-Innenbeleuchtung KL 58xd max-Y2,100.00
(9)-Innenbeleuchtung KL 58xd max-Y3,100.00
(10)-Innenbeleuchtung KL 58xd max-Y4,100.00
(1)-Innenbeleuchtung KL 58xd min-x0,0 lx
(2)-Innenbeleuchtung KL 58xd min-X1,50 lx
(3)-Innenbeleuchtung KL 58xd min-X2,220 lx
(4)-Innenbeleuchtung KL 58xd min-X3,300 lx
(5)-Innenbeleuchtung KL 58xd min-X4,500 lx
(6)-Innenbeleuchtung KL 58xd min-y0,6.00
(7)-Innenbeleuchtung KL 58xd min-Y1,16.00
(8)-Innenbeleuchtung KL 58xd min-Y2,25.00
(9)-Innenbeleuchtung KL 58xd min-Y3,30.00
(10)-Innenbeleuchtung KL 58xd min-Y4,50.00
(1)-Innenbeleuchtung KL 58xd PWM-x0,0
(2)-Innenbeleuchtung KL 58xd PWM-X1,10
(3)-Innenbeleuchtung KL 58xd PWM-X2,50
(4)-Innenbeleuchtung KL 58xd PWM-X3,100
(5)-Innenbeleuchtung KL 58xd PWM-X4,220
(6)-Innenbeleuchtung KL 58xd PWM-X5,253
(7)-Innenbeleuchtung KL 58xd PWM-y0,2.00 %
(8)-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %
(9)-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %
(10)-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %
(11)-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %
(12)-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
(1)-Innenbeleuchtung KL 58xs max-x0,0 lx
(2)-Innenbeleuchtung KL 58xs max-X1,8 lx
(3)-Innenbeleuchtung KL 58xs max-X2,50 lx
(4)-Innenbeleuchtung KL 58xs max-X3,500 lx
(5)-Innenbeleuchtung KL 58xs max-y0,100.00
(6)-Innenbeleuchtung KL 58xs max-Y1,100.00
(7)-Innenbeleuchtung KL 58xs max-Y2,100.00
(8)-Innenbeleuchtung KL 58xs max-Y3,100.00
(1)-Innenbeleuchtung KL 58xs min-x0,0 lx
(2)-Innenbeleuchtung KL 58xs min-X1,8 lx
(3)-Innenbeleuchtung KL 58xs min-X2,50 lx
(4)-Innenbeleuchtung KL 58xs min-X3,500 lx
(5)-Innenbeleuchtung KL 58xs min-y0,6.00
(6)-Innenbeleuchtung KL 58xs min-Y1,6.00
(7)-Innenbeleuchtung KL 58xs min-Y2,100.00
(8)-Innenbeleuchtung KL 58xs min-Y3,100.00
(1)-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
(2)-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
(3)-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
(4)-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
(5)-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
(6)-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
(1)-Innenbeleuchtung KL 58xt max-x0,0 lx
(2)-Innenbeleuchtung KL 58xt max-X1,8 lx
(3)-Innenbeleuchtung KL 58xt max-X2,50 lx
(4)-Innenbeleuchtung KL 58xt max-X3,500 lx
(5)-Innenbeleuchtung KL 58xt max-y0,100.00
(6)-Innenbeleuchtung KL 58xt max-Y1,100.00
(7)-Innenbeleuchtung KL 58xt max-Y2,100.00
(8)-Innenbeleuchtung KL 58xt max-Y3,100.00
(1)-Innenbeleuchtung KL 58xt min-x0,0 lx
(2)-Innenbeleuchtung KL 58xt min-X1,8 lx
(3)-Innenbeleuchtung KL 58xt min-X2,50 lx
(4)-Innenbeleuchtung KL 58xt min-X3,500 lx
(5)-Innenbeleuchtung KL 58xt min-y0,6.00
(6)-Innenbeleuchtung KL 58xt min-Y1,6.00
(7)-Innenbeleuchtung KL 58xt min-Y2,100.00
(8)-Innenbeleuchtung KL 58xt min-Y3,100.00
(1)-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
(2)-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
(3)-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
(4)-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
(5)-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
(6)-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
(1)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
(2)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms
(3)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms
(4)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms
(5)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms
(6)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
(7)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
(8)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
(9)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00
(10)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
(1)-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten
(2)-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
(3)-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,127
(7)-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
(1)-Leuchte10SHUTTER LB23-Lasttyp 10,not active
(2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00
(3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00
(4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active
(5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active
(6)-Leuchte10SHUTTER LB23-Dimmwert AB 10,0
(7)-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
(8)-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
(9)-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
(10)-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
(11)-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
(12)-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
(13)-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
(14)-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
(15)-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
(16)-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
(17)-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
(18)-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
(19)-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
(1)-Leuchte11SHUTTER RB22-Lasttyp 11,not active
(2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00
(3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,00
(4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active
(5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active
(6)-Leuchte11SHUTTER RB22-Dimmwert AB 11,0
(7)-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
(8)-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
(9)-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
(10)-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
(11)-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
(12)-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
(13)-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
(14)-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
(15)-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
(16)-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
(17)-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
(18)-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
(19)-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
(1)-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer
(2)-Leuchte12NL LB45-Lampendefektbitposition 12,38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
(4)-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12,not active
(6)-Leuchte12NL LB45-Dimmwert AB 12,100
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
(8)-Leuchte12NL LB45-Lichtfunktion C 12,not active
(9)-Leuchte12NL LB45-Lichtfunktion D 12,not active
(10)-Leuchte12NL LB45-Dimmwert CD 12,0
(11)-Leuchte12NL LB45-Dimming Direction CD 12,maximize
(12)-Leuchte12NL LB45-Lichtfunktion E 12,not active
(13)-Leuchte12NL LB45-Lichtfunktion F 12,not active
(14)-Leuchte12NL LB45-Dimmwert EF 12,0
(15)-Leuchte12NL LB45-Dimming Direction EF 12,maximize
(16)-Leuchte12NL LB45-Lichtfunktion G 12,not active
(17)-Leuchte12NL LB45-Lichtfunktion H 12,not active
(18)-Leuchte12NL LB45-Dimmwert GH 12,0
(19)-Leuchte12NL LB45-Dimming Direction GH 12,maximize
(1)-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer
(2)-Leuchte13NL RB5-Lampendefektbitposition 13,42
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
(4)-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13,not active
(6)-Leuchte13NL RB5-Dimmwert AB 13,100
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
(8)-Leuchte13NL RB5-Lichtfunktion C 13,not active
(9)-Leuchte13NL RB5-Lichtfunktion D 13,not active
(10)-Leuchte13NL RB5-Dimmwert CD 13,0
(11)-Leuchte13NL RB5-Dimming Direction CD 13,maximize
(12)-Leuchte13NL RB5-Lichtfunktion E 13,not active
(13)-Leuchte13NL RB5-Lichtfunktion F 13,not active
(14)-Leuchte13NL RB5-Dimmwert EF 13,0
(15)-Leuchte13NL RB5-Dimming Direction EF 13,maximize
(16)-Leuchte13NL RB5-Lichtfunktion G 13,not active
(17)-Leuchte13NL RB5-Lichtfunktion H 13,not active
(18)-Leuchte13NL RB5-Dimmwert GH 13,0
(19)-Leuchte13NL RB5-Dimming Direction GH 13,maximize
(1)-Leuchte15AL RB44-Lasttyp 15,not active
(2)-Leuchte15AL RB44-Lampendefektbitposition 15,00
(3)-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
(4)-Leuchte15AL RB44-Lichtfunktion A 15,not active
(5)-Leuchte15AL RB44-Lichtfunktion B 15,not active
(6)-Leuchte15AL RB44-Dimmwert AB 15,0
(7)-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
(8)-Leuchte15AL RB44-Lichtfunktion C 15,not active
(9)-Leuchte15AL RB44-Lichtfunktion D 15,not active
(10)-Leuchte15AL RB44-Dimmwert CD 15,0
(11)-Leuchte15AL RB44-Dimming Direction CD 15,maximize
(12)-Leuchte15AL RB44-Lichtfunktion E 15,not active
(13)-Leuchte15AL RB44-Lichtfunktion F 15,not active
(14)-Leuchte15AL RB44-Dimmwert EF 15,0
(15)-Leuchte15AL RB44-Dimming Direction EF 15,maximize
(16)-Leuchte15AL RB44-Lichtfunktion G 15,not active
(17)-Leuchte15AL RB44-Lichtfunktion H 15,not active
(18)-Leuchte15AL RB44-Dimmwert GH 15,0
(19)-Leuchte15AL RB44-Dimming Direction GH 15,maximize
(1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W
(2)-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,20
(3)-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,3A
(4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100
(7)-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
(8)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Brake light
(9)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
(10)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,100
(11)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
(12)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
(13)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
(14)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
(15)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
(16)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
(17)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
(18)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
(19)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
(1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W
(2)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,10
(3)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,39
(4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100
(7)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
(8)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Brake light
(9)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
(10)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,100
(11)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
(12)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
(13)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
(14)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
(15)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
(16)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
(17)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
(18)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
(19)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
(1)-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten
(2)-Leuchte18BLK HLA60-Lampendefektbitposition 18,08
(3)-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16
(4)-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase
(5)-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
(6)-Leuchte18BLK HLA60-Dimmwert AB 18,100
(7)-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
(8)-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
(9)-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
(10)-Leuchte18BLK HLA60-Dimmwert CD 18,0
(11)-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
(12)-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
(13)-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
(14)-Leuchte18BLK HLA60-Dimmwert EF 18,0
(15)-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
(16)-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
(17)-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
(18)-Leuchte18BLK HLA60-Dimmwert GH 18,0
(19)-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
(1)-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten
(2)-Leuchte19BLK HRC31-Lampendefektbitposition 19,18
(3)-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18
(4)-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase
(5)-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
(6)-Leuchte19BLK HRC31-Dimmwert AB 19,100
(7)-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
(8)-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
(9)-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
(10)-Leuchte19BLK HRC31-Dimmwert CD 19,0
(11)-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
(12)-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
(13)-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
(14)-Leuchte19BLK HRC31-Dimmwert EF 19,0
(15)-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
(16)-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
(17)-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
(18)-Leuchte19BLK HRC31-Dimmwert GH 19,0
(19)-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
(1)-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten
(2)-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
(3)-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
(4)-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
(5)-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
(6)-Leuchte1BLK VRB20-Dimmwert AB 1,127
(7)-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
(8)-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
(9)-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 1,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
(13)-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
(14)-Leuchte1BLK VRB20-Dimmwert EF 1,0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
(17)-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
(18)-Leuchte1BLK VRB20-Dimmwert GH 1,0
(19)-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
(1)-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten
(2)-Leuchte20BR LA71-Lampendefektbitposition 20,09
(3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B
(4)-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
(5)-Leuchte20BR LA71-Lichtfunktion B 20,not active
(6)-Leuchte20BR LA71-Dimmwert AB 20,100
(7)-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
(8)-Leuchte20BR LA71-Lichtfunktion C 20,not active
(9)-Leuchte20BR LA71-Lichtfunktion D 20,not active
(10)-Leuchte20BR LA71-Dimmwert CD 20,0
(11)-Leuchte20BR LA71-Dimming Direction CD 20,maximize
(12)-Leuchte20BR LA71-Lichtfunktion E 20,not active
(13)-Leuchte20BR LA71-Lichtfunktion F 20,not active
(14)-Leuchte20BR LA71-Dimmwert EF 20,0
(15)-Leuchte20BR LA71-Dimming Direction EF 20,maximize
(16)-Leuchte20BR LA71-Lichtfunktion G 20,not active
(17)-Leuchte20BR LA71-Lichtfunktion H 20,not active
(18)-Leuchte20BR LA71-Dimmwert GH 20,0
(19)-Leuchte20BR LA71-Dimming Direction GH 20,maximize
(1)-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten
(2)-Leuchte21BR RC8-Lampendefektbitposition 21,19
(3)-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D
(4)-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
(5)-Leuchte21BR RC8-Lichtfunktion B 21,not active
(6)-Leuchte21BR RC8-Dimmwert AB 21,100
(7)-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
(8)-Leuchte21BR RC8-Lichtfunktion C 21,not active
(9)-Leuchte21BR RC8-Lichtfunktion D 21,not active
(10)-Leuchte21BR RC8-Dimmwert CD 21,0
(11)-Leuchte21BR RC8-Dimming Direction CD 21,maximize
(12)-Leuchte21BR RC8-Lichtfunktion E 21,not active
(13)-Leuchte21BR RC8-Lichtfunktion F 21,not active
(14)-Leuchte21BR RC8-Dimmwert EF 21,0
(15)-Leuchte21BR RC8-Dimming Direction EF 21,maximize
(16)-Leuchte21BR RC8-Lichtfunktion G 21,not active
(17)-Leuchte21BR RC8-Lichtfunktion H 21,not active
(18)-Leuchte21BR RC8-Dimmwert GH 21,0
(19)-Leuchte21BR RC8-Dimming Direction GH 21,maximize
(1)-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
(2)-Leuchte22BR MA57-Lampendefektbitposition 22,29
(3)-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
(4)-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
(5)-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1
(6)-Leuchte22BR MA57-Dimmwert AB 22,100
(7)-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
(8)-Leuchte22BR MA57-Lichtfunktion C 22,not active
(9)-Leuchte22BR MA57-Lichtfunktion D 22,not active
(10)-Leuchte22BR MA57-Dimmwert CD 22,0
(11)-Leuchte22BR MA57-Dimming Direction CD 22,maximize
(12)-Leuchte22BR MA57-Lichtfunktion E 22,not active
(13)-Leuchte22BR MA57-Lichtfunktion F 22,not active
(14)-Leuchte22BR MA57-Dimmwert EF 22,0
(15)-Leuchte22BR MA57-Dimming Direction EF 22,maximize
(16)-Leuchte22BR MA57-Lichtfunktion G 22,not active
(17)-Leuchte22BR MA57-Lichtfunktion H 22,not active
(18)-Leuchte22BR MA57-Dimmwert GH 22,0
(19)-Leuchte22BR MA57-Dimming Direction GH 22,maximize
(1)-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W
(2)-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
(3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
(4)-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte23SL HLC10-Dimmwert AB 23,100
(7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
(8)-Leuchte23SL HLC10-Lichtfunktion C 23,Blinken links aktiv (beide Phasen)
(9)-Leuchte23SL HLC10-Lichtfunktion D 23,Brake light
(10)-Leuchte23SL HLC10-Dimmwert CD 23,0
(11)-Leuchte23SL HLC10-Dimming Direction CD 23,minimize
(12)-Leuchte23SL HLC10-Lichtfunktion E 23,not active
(13)-Leuchte23SL HLC10-Lichtfunktion F 23,not active
(14)-Leuchte23SL HLC10-Dimmwert EF 23,0
(15)-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
(16)-Leuchte23SL HLC10-Lichtfunktion G 23,not active
(17)-Leuchte23SL HLC10-Lichtfunktion H 23,not active
(18)-Leuchte23SL HLC10-Dimmwert GH 23,0
(19)-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
(1)-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W
(2)-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
(3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
(4)-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right
(6)-Leuchte24SL HRA65-Dimmwert AB 24,100
(7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
(8)-Leuchte24SL HRA65-Lichtfunktion C 24,Blinken rechts aktiv (beide Phasen)
(9)-Leuchte24SL HRA65-Lichtfunktion D 24,Brake light
(10)-Leuchte24SL HRA65-Dimmwert CD 24,0
(11)-Leuchte24SL HRA65-Dimming Direction CD 24,minimize
(12)-Leuchte24SL HRA65-Lichtfunktion E 24,not active
(13)-Leuchte24SL HRA65-Lichtfunktion F 24,not active
(14)-Leuchte24SL HRA65-Dimmwert EF 24,0
(15)-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
(16)-Leuchte24SL HRA65-Lichtfunktion G 24,not active
(17)-Leuchte24SL HRA65-Lichtfunktion H 24,not active
(18)-Leuchte24SL HRA65-Dimmwert GH 24,0
(19)-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
(1)-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED
(2)-Leuchte25KZL HA59-Lampendefektbitposition 25,28
(3)-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
(4)-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte25KZL HA59-Lichtfunktion B 25,not active
(6)-Leuchte25KZL HA59-Dimmwert AB 25,127
(7)-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
(8)-Leuchte25KZL HA59-Lichtfunktion C 25,not active
(9)-Leuchte25KZL HA59-Lichtfunktion D 25,not active
(10)-Leuchte25KZL HA59-Dimmwert CD 25,0
(11)-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
(12)-Leuchte25KZL HA59-Lichtfunktion E 25,not active
(13)-Leuchte25KZL HA59-Lichtfunktion F 25,not active
(14)-Leuchte25KZL HA59-Dimmwert EF 25,0
(15)-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
(16)-Leuchte25KZL HA59-Lichtfunktion G 25,not active
(17)-Leuchte25KZL HA59-Lichtfunktion H 25,not active
(18)-Leuchte25KZL HA59-Dimmwert GH 25,0
(19)-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
(1)-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED
(2)-Leuchte26NSL LA72-Lampendefektbitposition 26,0C
(3)-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E
(4)-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
(5)-Leuchte26NSL LA72-Lichtfunktion B 26,not active
(6)-Leuchte26NSL LA72-Dimmwert AB 26,90
(7)-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed
(8)-Leuchte26NSL LA72-Lichtfunktion C 26,not active
(9)-Leuchte26NSL LA72-Lichtfunktion D 26,not active
(10)-Leuchte26NSL LA72-Dimmwert CD 26,0
(11)-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
(12)-Leuchte26NSL LA72-Lichtfunktion E 26,not active
(13)-Leuchte26NSL LA72-Lichtfunktion F 26,not active
(14)-Leuchte26NSL LA72-Dimmwert EF 26,0
(15)-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
(16)-Leuchte26NSL LA72-Lichtfunktion G 26,not active
(17)-Leuchte26NSL LA72-Lichtfunktion H 26,not active
(18)-Leuchte26NSL LA72-Dimmwert GH 26,0
(19)-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
(1)-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W
(2)-Leuchte27NSL RC6-Lampendefektbitposition 27,1A
(3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36
(4)-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte27NSL RC6-Lichtfunktion B 27,not active
(6)-Leuchte27NSL RC6-Dimmwert AB 27,100
(7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
(8)-Leuchte27NSL RC6-Lichtfunktion C 27,Brake light
(9)-Leuchte27NSL RC6-Lichtfunktion D 27,not active
(10)-Leuchte27NSL RC6-Dimmwert CD 27,0
(11)-Leuchte27NSL RC6-Dimming Direction CD 27,minimize
(12)-Leuchte27NSL RC6-Lichtfunktion E 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
(13)-Leuchte27NSL RC6-Lichtfunktion F 27,not active
(14)-Leuchte27NSL RC6-Dimmwert EF 27,100
(15)-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
(16)-Leuchte27NSL RC6-Lichtfunktion G 27,not active
(17)-Leuchte27NSL RC6-Lichtfunktion H 27,not active
(18)-Leuchte27NSL RC6-Dimmwert GH 27,0
(19)-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
(1)-Leuchte28RFL LC11-Lasttyp 28,34 - LED Bremsleuchten
(2)-Leuchte28RFL LC11-Lampendefektbitposition 28,09
(3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,37
(4)-Leuchte28RFL LC11-Lichtfunktion A 28,Brake light
(5)-Leuchte28RFL LC11-Lichtfunktion B 28,not active
(6)-Leuchte28RFL LC11-Dimmwert AB 28,100
(7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
(8)-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
(9)-Leuchte28RFL LC11-Lichtfunktion D 28,not active
(10)-Leuchte28RFL LC11-Dimmwert CD 28,0
(11)-Leuchte28RFL LC11-Dimming Direction CD 28,minimize
(12)-Leuchte28RFL LC11-Lichtfunktion E 28,not active
(13)-Leuchte28RFL LC11-Lichtfunktion F 28,not active
(14)-Leuchte28RFL LC11-Dimmwert EF 28,0
(15)-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
(16)-Leuchte28RFL LC11-Lichtfunktion G 28,not active
(17)-Leuchte28RFL LC11-Lichtfunktion H 28,not active
(18)-Leuchte28RFL LC11-Dimmwert GH 28,0
(19)-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
(1)-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W
(2)-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
(3)-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
(4)-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
(5)-Leuchte29RFL RA64-Lichtfunktion B 29,not active
(6)-Leuchte29RFL RA64-Dimmwert AB 29,100
(7)-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
(8)-Leuchte29RFL RA64-Lichtfunktion C 29,not active
(9)-Leuchte29RFL RA64-Lichtfunktion D 29,not active
(10)-Leuchte29RFL RA64-Dimmwert CD 29,0
(11)-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
(12)-Leuchte29RFL RA64-Lichtfunktion E 29,not active
(13)-Leuchte29RFL RA64-Lichtfunktion F 29,not active
(14)-Leuchte29RFL RA64-Dimmwert EF 29,0
(15)-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
(16)-Leuchte29RFL RA64-Lichtfunktion G 29,not active
(17)-Leuchte29RFL RA64-Lichtfunktion H 29,not active
(18)-Leuchte29RFL RA64-Dimmwert GH 29,0
(19)-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
(1)-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte2SL VLB10-Lampendefektbitposition 2,48
(3)-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A
(4)-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights
(5)-Leuchte2SL VLB10-Lichtfunktion B 2,not active
(6)-Leuchte2SL VLB10-Dimmwert AB 2,100
(7)-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
(8)-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen)
(9)-Leuchte2SL VLB10-Lichtfunktion D 2,not active
(10)-Leuchte2SL VLB10-Dimmwert CD 2,28
(11)-Leuchte2SL VLB10-Dimming Direction CD 2,minimize
(12)-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(14)-Leuchte2SL VLB10-Dimmwert EF 2,28
(15)-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
(16)-Leuchte2SL VLB10-Lichtfunktion G 2,Nebellicht links
(17)-Leuchte2SL VLB10-Lichtfunktion H 2,not active
(18)-Leuchte2SL VLB10-Dimmwert GH 2,28
(19)-Leuchte2SL VLB10-Dimming Direction GH 2,minimize
(1)-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung
(2)-Leuchte30FR LC72-Lampendefektbitposition 30,00
(3)-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02
(4)-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light
(5)-Leuchte30FR LC72-Lichtfunktion B 30,not active
(6)-Leuchte30FR LC72-Dimmwert AB 30,100
(7)-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
(8)-Leuchte30FR LC72-Lichtfunktion C 30,not active
(9)-Leuchte30FR LC72-Lichtfunktion D 30,not active
(10)-Leuchte30FR LC72-Dimmwert CD 30,0
(11)-Leuchte30FR LC72-Dimming Direction CD 30,maximize
(12)-Leuchte30FR LC72-Lichtfunktion E 30,not active
(13)-Leuchte30FR LC72-Lichtfunktion F 30,not active
(14)-Leuchte30FR LC72-Dimmwert EF 30,0
(15)-Leuchte30FR LC72-Dimming Direction EF 30,maximize
(16)-Leuchte30FR LC72-Lichtfunktion G 30,not active
(17)-Leuchte30FR LC72-Lichtfunktion H 30,not active
(18)-Leuchte30FR LC72-Dimmwert GH 30,0
(19)-Leuchte30FR LC72-Dimming Direction GH 30,maximize
(1)-Leuchte31AMBL 1C61-Lasttyp 31,not active
(2)-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
(3)-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00
(4)-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active
(5)-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
(6)-Leuchte31AMBL 1C61-Dimmwert AB 31,0
(7)-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
(8)-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
(9)-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
(10)-Leuchte31AMBL 1C61-Dimmwert CD 31,0
(11)-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
(12)-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
(13)-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
(14)-Leuchte31AMBL 1C61-Dimmwert EF 31,0
(15)-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
(16)-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
(17)-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
(18)-Leuchte31AMBL 1C61-Dimmwert GH 31,0
(19)-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
(1)-Leuchte32AMBL 2C35-Lasttyp 32,not active
(2)-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
(3)-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00
(4)-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active
(5)-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
(6)-Leuchte32AMBL 2C35-Dimmwert AB 32,0
(7)-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
(8)-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
(9)-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
(10)-Leuchte32AMBL 2C35-Dimmwert CD 32,0
(11)-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
(12)-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
(13)-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
(14)-Leuchte32AMBL 2C35-Dimmwert EF 32,0
(15)-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
(16)-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
(17)-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
(18)-Leuchte32AMBL 2C35-Dimmwert GH 32,0
(19)-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
(1)-Leuchte33AMBL 3C36-Lasttyp 33,not active
(2)-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
(3)-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00
(4)-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active
(5)-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
(6)-Leuchte33AMBL 3C36-Dimmwert AB 33,0
(7)-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
(8)-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
(9)-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
(10)-Leuchte33AMBL 3C36-Dimmwert CD 33,0
(11)-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
(12)-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
(13)-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
(14)-Leuchte33AMBL 3C36-Dimmwert EF 33,0
(15)-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
(16)-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
(17)-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
(18)-Leuchte33AMBL 3C36-Dimmwert GH 33,0
(19)-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
(1)-Leuchte34AMBL 4C37-Lasttyp 34,not active
(2)-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
(3)-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00
(4)-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active
(5)-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
(6)-Leuchte34AMBL 4C37-Dimmwert AB 34,0
(7)-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
(8)-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
(9)-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
(10)-Leuchte34AMBL 4C37-Dimmwert CD 34,0
(11)-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
(12)-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
(13)-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
(14)-Leuchte34AMBL 4C37-Dimmwert EF 34,0
(15)-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
(16)-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
(17)-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
(18)-Leuchte34AMBL 4C37-Dimmwert GH 34,0
(19)-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
(1)-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
(3)-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C
(4)-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights
(5)-Leuchte3SL VRB21-Lichtfunktion B 3,not active
(6)-Leuchte3SL VRB21-Dimmwert AB 3,100
(7)-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
(8)-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen)
(9)-Leuchte3SL VRB21-Lichtfunktion D 3,not active
(10)-Leuchte3SL VRB21-Dimmwert CD 3,28
(11)-Leuchte3SL VRB21-Dimming Direction CD 3,minimize
(12)-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right
(14)-Leuchte3SL VRB21-Dimmwert EF 3,28
(15)-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3,Nebellicht rechts
(17)-Leuchte3SL VRB21-Lichtfunktion H 3,not active
(18)-Leuchte3SL VRB21-Dimmwert GH 3,28
(19)-Leuchte3SL VRB21-Dimming Direction GH 3,minimize
(1)-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
(3)-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49
(4)-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights
(5)-Leuchte4TFL LB4-Lichtfunktion B 4,not active
(6)-Leuchte4TFL LB4-Dimmwert AB 4,127
(7)-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
(8)-Leuchte4TFL LB4-Lichtfunktion C 4,not active
(9)-Leuchte4TFL LB4-Lichtfunktion D 4,not active
(10)-Leuchte4TFL LB4-Dimmwert CD 4,0
(11)-Leuchte4TFL LB4-Dimming Direction CD 4,maximize
(12)-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
(14)-Leuchte4TFL LB4-Dimmwert EF 4,127
(15)-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
(16)-Leuchte4TFL LB4-Lichtfunktion G 4,not active
(17)-Leuchte4TFL LB4-Lichtfunktion H 4,not active
(18)-Leuchte4TFL LB4-Dimmwert GH 4,0
(19)-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
(1)-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
(3)-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B
(4)-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights
(5)-Leuchte5 TFL RB32-Lichtfunktion B 5,not active
(6)-Leuchte5 TFL RB32-Dimmwert AB 5,127
(7)-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5,not active
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
(10)-Leuchte5 TFL RB32-Dimmwert CD 5,0
(11)-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize
(12)-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right
(14)-Leuchte5 TFL RB32-Dimmwert EF 5,127
(15)-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
(16)-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
(17)-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
(18)-Leuchte5 TFL RB32-Dimmwert GH 5,0
(19)-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
(1)-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht
(2)-Leuchte6ABL LC5-Lampendefektbitposition 6,36
(3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
(4)-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
(5)-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6,127
(7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
(8)-Leuchte6ABL LC5-Lichtfunktion C 6,not active
(9)-Leuchte6ABL LC5-Lichtfunktion D 6,not active
(10)-Leuchte6ABL LC5-Dimmwert CD 6,0
(11)-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
(12)-Leuchte6ABL LC5-Lichtfunktion E 6,not active
(13)-Leuchte6ABL LC5-Lichtfunktion F 6,not active
(14)-Leuchte6ABL LC5-Dimmwert EF 6,0
(15)-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
(16)-Leuchte6ABL LC5-Lichtfunktion G 6,not active
(17)-Leuchte6ABL LC5-Lichtfunktion H 6,not active
(18)-Leuchte6ABL LC5-Dimmwert GH 6,0
(19)-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
(1)-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht
(2)-Leuchte7ABL RB1-Lampendefektbitposition 7,40
(3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
(4)-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
(5)-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7,127
(7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
(8)-Leuchte7ABL RB1-Lichtfunktion C 7,not active
(9)-Leuchte7ABL RB1-Lichtfunktion D 7,not active
(10)-Leuchte7ABL RB1-Dimmwert CD 7,0
(11)-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
(12)-Leuchte7ABL RB1-Lichtfunktion E 7,not active
(13)-Leuchte7ABL RB1-Lichtfunktion F 7,not active
(14)-Leuchte7ABL RB1-Dimmwert EF 7,0
(15)-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
(16)-Leuchte7ABL RB1-Lichtfunktion G 7,not active
(17)-Leuchte7ABL RB1-Lichtfunktion H 7,not active
(18)-Leuchte7ABL RB1-Dimmwert GH 7,0
(19)-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
(1)-Leuchte8FL LB39-Lasttyp 8,not active
(2)-Leuchte8FL LB39-Lampendefektbitposition 8,00
(3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00
(4)-Leuchte8FL LB39-Lichtfunktion A 8,not active
(5)-Leuchte8FL LB39-Lichtfunktion B 8,not active
(6)-Leuchte8FL LB39-Dimmwert AB 8,0
(7)-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
(8)-Leuchte8FL LB39-Lichtfunktion C 8,not active
(9)-Leuchte8FL LB39-Lichtfunktion D 8,not active
(10)-Leuchte8FL LB39-Dimmwert CD 8,0
(11)-Leuchte8FL LB39-Dimming Direction CD 8,maximize
(12)-Leuchte8FL LB39-Lichtfunktion E 8,not active
(13)-Leuchte8FL LB39-Lichtfunktion F 8,not active
(14)-Leuchte8FL LB39-Dimmwert EF 8,0
(15)-Leuchte8FL LB39-Dimming Direction EF 8,maximize
(16)-Leuchte8FL LB39-Lichtfunktion G 8,not active
(17)-Leuchte8FL LB39-Lichtfunktion H 8,not active
(18)-Leuchte8FL LB39-Dimmwert GH 8,0
(19)-Leuchte8FL LB39-Dimming Direction GH 8,maximize
(1)-Leuchte9FL RB2-Lasttyp 9,not active
(2)-Leuchte9FL RB2-Lampendefektbitposition 9,00
(3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00
(4)-Leuchte9FL RB2-Lichtfunktion A 9,not active
(5)-Leuchte9FL RB2-Lichtfunktion B 9,not active
(6)-Leuchte9FL RB2-Dimmwert AB 9,0
(7)-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
(8)-Leuchte9FL RB2-Lichtfunktion C 9,not active
(9)-Leuchte9FL RB2-Lichtfunktion D 9,not active
(10)-Leuchte9FL RB2-Dimmwert CD 9,0
(11)-Leuchte9FL RB2-Dimming Direction CD 9,maximize
(12)-Leuchte9FL RB2-Lichtfunktion E 9,not active
(13)-Leuchte9FL RB2-Lichtfunktion F 9,not active
(14)-Leuchte9FL RB2-Dimmwert EF 9,0
(15)-Leuchte9FL RB2-Dimming Direction EF 9,maximize
(16)-Leuchte9FL RB2-Lichtfunktion G 9,not active
(17)-Leuchte9FL RB2-Lichtfunktion H 9,not active
(18)-Leuchte9FL RB2-Dimmwert GH 9,0
(19)-Leuchte9FL RB2-Dimming Direction GH 9,maximize
(1)-Leuchten14AL LB6-Lasttyp 14,not active
(2)-Leuchten14AL LB6-Lampendefektbitposition 14,00
(3)-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
(4)-Leuchten14AL LB6-Lichtfunktion A 14,not active
(5)-Leuchten14AL LB6-Lichtfunktion B 14,not active
(6)-Leuchten14AL LB6-Dimmwert AB 14,0
(7)-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
(8)-Leuchten14AL LB6-Lichtfunktion C 14,not active
(9)-Leuchten14AL LB6-Lichtfunktion D 14,not active
(10)-Leuchten14AL LB6-Dimmwert CD 14,0
(11)-Leuchten14AL LB6-Dimming Direction CD 14,maximize
(12)-Leuchten14AL LB6-Lichtfunktion E 14,not active
(13)-Leuchten14AL LB6-Lichtfunktion F 14,not active
(14)-Leuchten14AL LB6-Dimmwert EF 14,0
(15)-Leuchten14AL LB6-Dimming Direction EF 14,maximize
(16)-Leuchten14AL LB6-Lichtfunktion G 14,not active
(17)-Leuchten14AL LB6-Lichtfunktion H 14,not active
(18)-Leuchten14AL LB6-Dimmwert GH 14,0
(19)-Leuchten14AL LB6-Dimming Direction GH 14,maximize
(1)-LIN-Mirrormode-mirror_mode_typ,not active
(2)-LIN-Mirrormode-Data bus LIN 1,active
(3)-LIN-Mirrormode-Data bus LIN 2,active
(4)-LIN-Mirrormode-Data bus LIN 3,active
(5)-LIN-Mirrormode-Data bus LIN 4,active
(6)-LIN-Mirrormode-Data bus LIN 5,active
(7)-LIN-Mirrormode-Data bus LIN 6,active
(1)-LuB Lichtrouter Kennlinie 1-x0,0.00 %
(2)-LuB Lichtrouter Kennlinie 1-X1,5.00 %
(3)-LuB Lichtrouter Kennlinie 1-X2,50.00 %
(4)-LuB Lichtrouter Kennlinie 1-X3,75.00 %
(5)-LuB Lichtrouter Kennlinie 1-X4,110.00
(6)-LuB Lichtrouter Kennlinie 1-X5,126.50
(7)-LuB Lichtrouter Kennlinie 1-y0,0.00 %
(8)-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
(9)-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
(10)-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
(11)-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
(12)-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
(1)-Personalisierung-Personalisierung_aktiv,active
(2)-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,active
(3)-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active
(4)-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active
(5)-Personalisierung-Anzahl_Benutzerkonten,4
(6)-Personalisierung-Automatische_ Schluesselzuordnung,not active
(7)-Personalisierung-PSO_FSG_Setup2_Bit_0,not active
(8)-Personalisierung-PSO_FSG_Setup2_Bit_1,active
(9)-Personalisierung-PSO_FSG_Setup2_Bit_2,active
(10)-Personalisierung-PSO_FSG_Setup2_Bit_3,not active
(11)-Personalisierung-PSO_FSG_Setup2_Bit_4,not active
(12)-Personalisierung-PSO_FSG_Setup2_Bit_5,not active
(13)-Personalisierung-PSO_FSG_Setup2_Bit_6,not active
(14)-Personalisierung-PSO_FSG_Setup2_Bit_7,not active
(1)-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active
(2)-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active
(1)-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
(2)-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
(3)-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
(4)-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
(5)-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
(6)-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
(7)-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
(8)-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
(9)-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
(10)-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
