Audi A6 -05 ABS/ESP problem
Finnspring
New Member
Hello everyone, im new member to here very fancy forum and future VCDS owner! Because this is already my 4th VAG-consern car and there is always problems.... :banghead:
All scans what i have made, its my father in law vcds, thanks to him for that!
I have a big problems with my Audi now, and i really appreciate your help guys if you know what i have to do next...:o
First of all, last winter, i get big problem, blinking lights to my dash panel, ABS, ESP and red exclamation mark. They stayed there like 1 week, after that they were gone, then they came back, then again gone then came back and keep staying. Here is first SCAN LIST!
And you can fix this post if this is too long etc.. Thank you! =)
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WAUZZZ4F96N007974   License Plate: ONI-724
Mileage: 228780km-142157mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 42 46 47 4F 52 53 55
          56 61 62 69 72 76
Address 01: Engine (BDW)       Labels: 06E-910-552-BDW.clb
   Part No SW: 4F0 910 552 P    HW: 4F0 907 552 D
   Component: 2.4l V6 MPI         0020
   Revision: --H17---    Serial number:
   Coding: 010D000302070120
   Shop #: WSC 02325 785 00200
   VCID: 30572EFFA35A90BEC1-8064
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -  - Intermittent
                    Fault Frequency: 108
                    Reset counter: 40
                    Mileage: 226819 km
                    Date: 2015.11.14
                    Time: 18:19:02
                    RPM: 1152 /min
                    Mass Air / Rev.: 152.6 mg/str
                    Temperature: 9.0°C
                        Idle
                    Load: 20.4 %
   Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
   Component: ESP 8.0 front   H03 0090
   Coding: 0004946
   Shop #: WSC 12000 205 66904
   VCID: 2C6F3A8F8F72F45EFD-8078
01418 - Switch Valve 1 for Electronic Stability Program (N225)
            000 -  -  - Intermittent
                    Fault Frequency: 32
                    Reset counter: 70
                    Mileage: 228165 km
                    Date: 2016.01.05
                    Time: 16:17:30
                    Hex Value: 0x0100
                    Hex Value: 0x4006
                    Hex Value: 0x0016
                    Hex Value: 0xB8AA
                    Hex Value: 0x00FF
                    Reset counter: 70
                    Mileage: 228548 km
                    Date: 2016.01.18
                    Time: 19:25:51
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x0186
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Component: FBSAUDIC6 ELV   H30 0220
   Revision: 31050601    Serial number: 10600300143625
   Coding: 0000131
   Shop #: WSC 12000 205 57849
   VCID: 63FD91B3A22C7B260C-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H44 0070
   Component: FBSAUDIC6 IDG   H39 0040
00956 - Key 2
                    Reset counter: 55
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0002122
   Shop #: WSC 02335 785 00200
   VCID: 66FB88A7511E0E0EEB-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
                    Fault Status: 00101011
                    Fault Frequency: 10
                    Reset counter: 66
                    Mileage: 228132 km
                    Date: 2016.01.05
                    Time: 14:42:00
   Part No SW: 4F0 910 792 C    HW: 4F0 959 792 C
   Component: TSG BF          H11 0040
   Coding: 0001546
   Shop #: WSC 02327 785 00200
   VCID: 2961C39B8080E17606-807C
                    Fault Frequency: 68
                    Reset counter: 30
                    Mileage: 213575 km
                    Date: 2014.05.30
                    Time: 20:31:59
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0002031
   Shop #: WSC 02334 785 00200
   VCID: 5D89A74B84484DD63A-8008
                    Fault Status: 00101101
                    Reset counter: 70
                    Mileage: 226816 km
                    Date: 2015.11.14
                    Time: 18:19:04
                    Voltage: 12.84 V
                    Count: 236
   Part No SW: 4F0 910 283     HW: 4F0 919 283
   Component: Parkhilfe 4-Kan H09 0030
   Revision: 06.00.54    Serial number: 00067811720506
   Coding: 0011016
   VCID: 61F19BBBB83069361E-8034
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 55
                    Reset counter: 160
                    Mileage: 213575 km
                    Date: 2014.05.30
                    Time: 20:48:23
                    Fault Frequency: 51
                    Reset counter: 145
                    Mileage: 213575 km
                    Date: 2014.05.30
                    Time: 20:48:23
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                    Fault Frequency: 55
                    Reset counter: 145
                    Mileage: 213575 km
                    Date: 2014.05.30
                    Time: 20:48:23
After that, i checked every wire what i can find, then i checked all fuses, and replaced most of them, and then i changed battery to new one and coded that, and surprise, everything worked and was fine!! :eek: After driving like 2 month, all faults came back..... :S
But now little bit differently, only ABS and ESP signs, and then after starting car, it says parking brake malfunction, but parking brake works normally!! i think....
And here is the second scan list now:
Monday,18,July,2016,21:02:02:31171
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ4F96N007974   License Plate: ONI-724 II
Mileage: 233260km-144941mi   Repair Order:
          56 61 62 69 72 76
   VCID: 30572EFFA35A90BECE-8064
            P1653 - 008 -
                    Fault Frequency: 166
                    Reset counter: 40
                    Mileage: 229138 km
                    Date: 2016.01.25
                    Time: 18:59:35
                    RPM: 1216 /min
                    Mass Air / Rev.: 141.7 mg/str
                    Temperature: 51.0°C
                        Idle
                    Load: 17.6 %
   Coding: 0004946
   VCID: 2C6F3A8F8F72F45EF2-8078
                    Fault Frequency: 115
                    Reset counter: 231
                    Mileage: 229138 km
                    Date: 2016.01.25
                    Time: 18:59:35
                    Hex Value: 0x37C4
                    Hex Value: 0x4016
                    Hex Value: 0x0016
                    Hex Value: 0xC09B
                    Hex Value: 0x00FF
                    Fault Frequency: 70
                    Reset counter: 191
                    Mileage: 231762 km
                    Date: 2016.06.12
                    Time: 17:45:00
                    Hex Value: 0x0000
                    Hex Value: 0x4382
                    Hex Value: 0x001C
                    Hex Value: 0xB195
                    Hex Value: 0x00FF
01419 - Switch Valve 2 for Electronic Stability Program (N226)
                    Reset counter: 227
                    Mileage: 232601 km
                    Date: 2016.07.11
                    Time: 04:36:08
                    Hex Value: 0x8800
                    Hex Value: 0x4302
                    Hex Value: 0x0017
                    Hex Value: 0xB5AB
                    Hex Value: 0x00FF
   Coding: 0001546
   VCID: 2961C39B8080E17609-807C
                    Fault Frequency: 9
                    Reset counter: 161
                    Mileage: 228791 km
                    Date: 2016.01.23
                    Time: 13:52:13
   Revision: C63C0030
   Coding: 0002031
   VCID: 5D89A74B84484DD635-8008
                    Reset counter: 231
                    Mileage: 229136 km
                    Date: 2016.01.25
                    Time: 18:59:37
                    Voltage: 12.84 V
                    Count: 236
   Component: ENERGIEMANAGER  H12 0470
   Revision: 00000000    Serial number: 00000000005107
   VCID: 237DD1B3E2AC3B2643-8076
   Subsystem 1 - Part No: 4F0 915 105 B
   Component: von MLA  0092S50130
   Coding: 34463039313531303542204D4C4130303932533530313330
   Shop #: WSC 00000 384 00290
                    Mileage: 229547 km
                    Date: 2016.03.02
                    Time: 08:42:23
02276 - Quiescent Current Stage 5
                    Mileage: 229547 km
                    Date: 2016.03.02
                    Time: 10:10:14
02274 - Quiescent Current Stage 3
                    Mileage: 229547 km
                    Date: 2016.03.02
                    Time: 10:10:24
                    Mileage: 229547 km
                    Date: 2016.03.02
                    Time: 10:10:34
   Coding: 0011016
   VCID: 61F19BBBB830693611-8034
6 Faults Found:
                    Fault Frequency: 13
                    Reset counter: 190
                    Mileage: 228791 km
                    Date: 2016.01.23
                    Time: 13:54:08
                    Fault Frequency: 9
                    Reset counter: 178
                    Mileage: 228791 km
                    Date: 2016.01.23
                    Time: 13:54:08
                    Fault Frequency: 13
                    Reset counter: 178
                    Mileage: 228791 km
                    Date: 2016.01.23
                    Time: 13:54:08
                    Reset counter: 230
                    Mileage: 231916 km
                    Date: 2016.06.24
                    Time: 14:23:20
                    Reset counter: 217
                    Mileage: 231368 km
                    Date: 2016.05.10
                    Time: 15:08:17
                    Reset counter: 201
                    Mileage: 230972 km
                    Date: 2016.04.16
                    Time: 16:49:10
So please, everyone here, help me to solve this ABS, ESP, brake problem... :S I dont care any heating mirror problem or park assists, i can turn my head :D
