Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2009 A6 with uncommon TPMS problem
    Jul 2016
    Hahaha. Moved about 2 years ago so you are right on the money!!
  2. Likes Uwe, Dana liked this post
  3. #12
    Jul 2016
    Thanks for the original scan.
    I might have good news. According to the information I located 7K6 (via Adaptation channel 013) is only supported on modules 4F0 910 732 C and up. For that reason 4F0 910 732 R should support it but this is going to be experimental. Please create an Adaptation Function Control Module Map and post the result here wrapped in [code] tags.
    If you have time I would really like to see Adaptation and Measuring Block maps from 03 and Adaptation only from 15. This is one of the rare cars with traditional 4F Bosch 8.0 ABS and the newer UDS protocol Airbags which use Adaptation channels that vary from our one and only Wiki page for the older units. That info from this vehicle should enable me to make a new Airbag AU1042 page... or at the least fill in some of the unknowns the next time we have a support inquiry.
    Hi Dana,
    Please see below. Is this what you were looking for? If not, let me know. I was not able to access Adaptation in 03 at all, even after I entered the security code. If there is a way to access it, then let me know and I will map it. Otherwise I checked every group/channel. I omitted a bunch of them because they were not available.
    Let me know if you would like me to map anything else.
    Thanks again
    {03} Measuring block map:
    Saturday,16,July,2016,13:18:46:60763
    VCDS Version: 15.7.4.1
    Data version: 20160216
                    Address 03: ABS Brakes  (4F0 910 517 AL)
    13:56:29 Group 001: Wheel Speed
      0.0 km/h  Wheel Speed Front Left
      0.0 km/h  Wheel Speed Front Right
      0.0 km/h  Wheel Speed Rear Left
      0.0 km/h  Wheel Speed Rear Right
    13:56:29 Group 002: Switches && Buttons
      0.0  Brake Test Switch
      0.0  Brake Light Switch
      Activated  Parking Brake Button
      0.0  ESP-Passive Button
    13:56:29 Group 003: Engine Data
      0 /min  Engine Speed
      5.1 Nm  Engine Torque
      20.4 Nm  Engine Torque (loss)
      0.0 %  Throttle Valve Angle
    13:56:40 Group 004: Standing Time && EDL-T Flag
      00:00  Standing Time
      OFF  EDL-T Flag
      N/A
      N/A
    13:56:40 Group 005
      0.0  Steering Angle Sensor (G85)
      0.00/s  Turn Rate
      -0.33 bar  Brake Pressure
      0.00 m/s*2  Lateral Acceleration
    13:56:40 Group 006
      11.54 V  Voltage Supply (Terminal 30)
      ON  Valve Relay
      OFF  Return Flow Pump Status
      02325  Workshop Code
    13:56:48 Group 007: Installation Position
      Invalid  Install. Position Front Left
      Invalid  Install. Position Front Right
      Invalid  Install. Position Rear Left
      Invalid  Install. Position Rear Right
    13:56:48 Group 008: Direction of Rotation
      Invalid  Direction Front Left
      Invalid  Direction Front Right
      Invalid  Direction Rear Left
      Invalid  Direction Rear Right
    13:56:48 Group 009
      N/A
    13:57:09 Group 014: Airbag Coding Info (not relevant)
      2  Error Code
      16  Error Code
      0  Error Code
      N/A
    13:57:09 Group 015: Engine Coding Info (not relevant)
      0x0006  Hex Value
      0x0001  Hex Value
      0x000A  Hex Value
      0  Error Code
    13:57:09 Group 016: Signals of Electro-Mechanical Parking Brake (not relevant)
      Valid
      0.00 m/s*2  Lateral Accel.
      0x0011  Hex Value
      0x0000  Hex Value
    13:57:31 Group 020
      BB061009V 0502 0001 0000 CCA
    13:57:31 Group 021
      Please use
      the first row
      for this
      data type
    13:57:31 Group 022: Steering Angle Sensor Data (not relevant)
      0x0000  Hex Value
      8.92  Steering Angle
      0x0000  Hex Value
      0x0000  Hex Value
    13:57:40 Group 021: Data from ESP Sensor Unit -G419- (not relevant)
      4F0907637A__6261283W7HUY08R_010129-09-08
    13:57:40 Group 021
      Please use
      the first row
      for this
      data type
    13:57:40 Group 023: Variant Coding Data (not relevant)
       0001111  Bin. Bits
      N/A
      N/A
      N/A
    13:58:21 Group 024
      01 00 00 00 01 00 00
    13:58:21 Group 040
      Please use
      the first row
      for this
      data type
    13:58:33 Group 040
      ICC: 21 FP: 24 FT: 01 aICC: 03
    13:58:33 Group 040
      Please use
      the first row
      for this
      data type
    13:58:50 Group 041
      ICC: 21 FP: 21 FT: 48 aICC: FD
    13:58:50 Group 040
      Please use
      the first row
      for this
      data type
    13:58:55 Group 042
      ICC: 21 FP: 21 FT: 49 aICC: FD
    13:58:55 Group 040
      Please use
      the first row
      for this
      data type
    13:58:58 Group 043
      ICC: 21 FP: 21 FT: 4B aICC: FD
    13:58:58 Group 040
      Please use
      the first row
      for this
      data type
    13:59:01 Group 044
      ICC: 21 FP: 21 FT: 50 aICC: FD
    13:59:01 Group 040
      Please use
      the first row
      for this
      data type
    13:59:04 Group 045
    13:59:04 Group 040
      Please use
      the first row
      for this
      data type
    14:00:10 Group 125: CAN-Databus Communication (Powertrain)
      Steer. ang. 1  Steering Angle Sensor
      Engine 1  Engine
      Transm. 1  Automatic Transmission
      Instruments 1  Instrument Cluster
    14:00:10 Group 126: CAN-Databus Communication (Powertrain)
      Distance 1  Distance Regulation (ACC)
      Gateway 1  CAN-Gateway
      Park Brake 1  Electric Parking Brake (EPB)
      ESP Sens. 1  ESP Sensor Cluster
    14:00:10 Group 127: CAN-Databus Communication (Powertrain)
      Level 0  Level Control
      Airbag 1  Airbag
      N/A
      N/A
    14:01:22 Group 225
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
      0.0  (no units)
    14:01:22 Group 226
      0.0  (no units)
      0.0  (no units)
      4.0  (no units)
      0.0  (no units)
    14:01:22 Group 227
      255.0  (no units)
      0.0  (no units)
      N/A
      N/A
    {15} Adaptation values:
    Saturday,30,July,2016,14:02:38:60763
    VIN: WAUSG74F39N017562   License Plate:
    UDS Adaptation Channel: (1)-Airbag adaptations-Seat occupied recognition
    Stored value activated
    UDS Adaptation Channel: (2)-Airbag adaptations-Driver side active head restraint igniter
    Stored value not defined
    UDS Adaptation Channel: (3)-Airbag adaptations-Igniter for battery interrupt
    UDS Adaptation Channel: (4)-Airbag adaptations-Key switch
    Stored value Airbag deactivation key switch not parameterized
    UDS Adaptation Channel: (5)-Airbag adaptations-Passenger side rear safety belt tension igniter
    UDS Adaptation Channel: (6)-Airbag adaptations-Driver side rear safety belt tension igniter
    UDS Adaptation Channel: (7)-Airbag adaptations-Center rear seat belt tensioner igniter
    UDS Adaptation Channel: (8)-Airbag adaptations-Igniter for active head restraint on frt. passenger side
    UDS Adaptation Channel: (9)-Airbag adaptations-Front passenger side seat belt tension igniter
    UDS Adaptation Channel: (10)-Airbag adaptations-Driver side seat belt tension igniter
    UDS Adaptation Channel: (11)-Airbag adaptations-Front passenger knee airbag igniter
    UDS Adaptation Channel: (12)-Airbag adaptations-Driver knee airbag igniter
    UDS Adaptation Channel: (13)-Airbag adaptations-Passenger side rear thorax airbag igniter
    UDS Adaptation Channel: (14)-Airbag adaptations-Driver side rear thorax airbag igniter
    UDS Adaptation Channel: (15)-Airbag adaptations-Front passenger head curtain airbag igniter
    UDS Adaptation Channel: (16)-Airbag adaptations-Driver head curtain airbag igniter
    UDS Adaptation Channel: (17)-Airbag adaptations-Passenger airbag igniter
    UDS Adaptation Channel: (18)-Airbag adaptations-Driver airbag igniter
    UDS Adaptation Channel: (19)-Airbag adaptations-Front passenger side airbag igniter
    UDS Adaptation Channel: (20)-Airbag adaptations-Driver thorax airbag igniter
    UDS Adaptation Channel: ESP coding information brakes
    Stored value 10
    UDS Adaptation Channel: ESP coding information drivetrain type
    Stored value All Wheel Drive (AWD)
    UDS Adaptation Channel: ESP coding information ESP1
    Stored value 00
    UDS Adaptation Channel: ESP coding information ESP2
    Stored value 00
    UDS Adaptation Channel: ESP coding information ESP3
    Stored value 00
    Stored value 00
    UDS Adaptation Channel: ESP coding information vehicle variant
    Stored value normal vehicle
    UDS Adaptation Channel: GFA key
    Stored value
    UDS Adaptation Channel: IKA key
    Stored value ERROR: Channel Not Available
  4. #13
    United States
    Sorry I missed that post. I think that's all I needed - but I'll bump this back up if we need any additional info.
    Thanks,
    Dana
  5. Likes Uwe liked this post
  6. #14
    United States
    Hi Peter,
    If you have the time I'd like to know if that 15-Airbag module will accept Security Access code: 20103. I believe the code in the pop-up balloon is incorrect and would like to test the alternative code if possible. A result such as Security Access Accepted would be a great sign and you'd want to exit the module at that point. I completely understand if you don't have the time.
    Side note - Sebastian got the 7K6 TPMS Adp info added to that Control Head lbl file in the meanwhile so VCDS 16.8 contains the info we discussed above.
  7. Likes Uwe liked this post
  8. #15
    Jul 2016
    Dana i will get that for you in about a week or so when i get back home from FL. Take care
  9. Likes Dana liked this post
  10. #16
    Jul 2016
    Hi Dana,
    Sorry for delay. Code 20103 was accepted. Let me know of further tests.
    I looked into 07... great that it's there. Might come handy to someone when replacing faulty head unit,
  11. Likes Dana liked this post
