Results 1 to 1 of 1
Thread: GOLF 6 GTI Bi-Xenon + AFS - Retrofit on a car with DCC
    Jun 2016
    Croatia
    Hi Dana,
    Just to share Auto-scan of my car after retrofitting Bi-Xenon + AFS on a car with DCC.
    All the functions work just fine with this coding (see the auto scan) of xenon range module. Previously I had coding from a car with same lights but no DCC. AFS and xenon range didn't work at all. Apparently when the car has DCC the data from the rear level sensor comes to xenon range module via can bus. Therefore a different coding of the xenon range module has to be inserted so that the module knows where the signal form the rear level sensor is coming from. (wires or can bus) This is the reason why there is a retrofit kit on a market for cars with DCC and without DCC. The only difference from two kits is wiring with 3 wires for rear level sensor and rear level sensor. I was missing this information while I was installing it on a car so I thought it might be helpful to share it for future retrofits.
    First coding: 1441908 - DID NOT WORK ON A CAR WITH DCC
    Current coding: 1444956 - WORKS FINE ON A CAR WIRH DCC
    Thanks to Dana and new coding I have all the functions working.
    Wednesday,13,July,2016,12:10:50:55568
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 15.7.4.1
    Data version: 20160216
    VIN: WVWZZZ1KZAW001711   License Plate:
    Mileage: 127610km-79293mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 47 52 55
              56 62 72
    VIN: WVWZZZ1KZAW001711   Mileage: 127610km-79293miles
    Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
       Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0040
       Revision: AAH03---    Serial number:
       Coding: 0403000C1C070160
       Shop #: WSC 00191 264 15243
       VCID: 67DA070A56B4C406DF-8032
       Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1932
       Revision: 04844002    Serial number: 00000904290866
       VCID: 224C561EFD16E12E48-8076
       Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
       Component: ESP MK60EC1   H45 0108
       Revision: 00H45001
       Coding: 143B600D892200FB281206E5911A0041B508
       VCID: 7DF64562E4287ED615-8028
       Part No SW: 5K0 907 044 BD    HW: 5K0 907 044 BD
       Component: Climatronic   H14 0608
       Revision: 00003001
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 6ED4722EB14E154E9C-803A
       Part No SW: 1K0 937 087 AD    HW: 1K0 937 087 AD
       Component: BCM PQ35  H   111 0709
       Revision: AC111709
       Coding: 46180A3AF8334AC040080080310089CC47FD0400737D8D20E48428040000
       Shop #: WSC 55459 123 10485
       VCID: 73E2635AD26C38A673-8026
       Component: Wischer 08050  21  0501
       Coding: 009F95
       Component: RLS 070509 05  54  0402
       Coding: 1630AD
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5K0 919 475 C    HW: 5K0 919 475
       Component: PARKHILFE 8K  H07 0008
       Revision: --------    Serial number: 12940913101613
       Coding: 100103
       VCID: 36649A4E819E6D8E94-8062
    Address 14: Susp. Elect. (J250)       Labels: None
       Component: DAEMPFUNGS-SG H07 0070
       Revision: 00000000    Serial number: 23040900290001
       Coding: 000180
       VCID: 275A470A563404061F-8072
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    033 0604
       Serial number: 003C2R86434Q
       Coding: 00003135
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360_SE36.rod
       VCID: 77FA574ACE1454864F-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 6E161548ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 16702047ZZZZZZZZZZZZ
       Serial number: 04322453ZZZZZZZZZZZZ
       Serial number: 0C4A2623ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Coding: 0001632
       VCID: 76E45A4E011E2D8E54-8022
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000131
       Part No SW: 5K6 920 870 B    HW: 5K6 920 870 B
       Component: KOMBI         H05 0206
       Coding: 170D00
       VCID: 326CA65E65F671AEB8-8066
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 230409F1002354
       Coding: EDA97F06500212000002
       VCID: 66C40A0E51BEDD0EE4-8032
       Component: IMMO          H05 0206
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0084
       Revision: A1001003    Serial number: 7667429920
       VCID: 26444A0E513E1D0E24-8072
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
       Component: RNS-MID       H06 2680
       Revision: AB001001    Serial number: VWZ6Z7K7047029
       Coding: 040700000400009000
       Shop #: WSC 00020 790 12345
       VCID: 2E54B22E79CE554EDC-807A
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 5K0 959 701 E    HW: 5K0 959 701 E
       Component: Tuer-SG         009 2123
       Coding: 0004278
       VCID: 3460A04657E27F9EAA-8060
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 183    2901
       Revision: 00H15000
       VCID: 2F6AAF2ABEC45C46D7-807A
       Part No SW: 5K0 035 456     HW: 5K0 035 456
       Component: KonzernAmp 8K H06 0316
       Revision: --------    Serial number: BP218198601923
       VCID: 67DA070A9EB4C406DF-8032
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
       Component: Tuer-SG         009 2109
       Coding: 0004534
       VCID: 3362A35A52EC78A6B3-8066
       Coding: 1444956
       Coding: 00000022
       Coding: 00000022
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
       VCID: 35669D425C9866969D-8060
    End-------------------------(Elapsed Time: 03:09)--------------------------
  2. Likes Uwe liked this post
