Results 1 to 10 of 19
Thread: creating ecm codes
    Jul 2016
    creating ecm codes
    hi where do i find the list for creating a ecm code for my car ?
    the car in question is a uk 2003 audi a4 1.9 tdi multitronic the code currently is set at 000001 and having communication errors and wondering if this could be the cause of it.
    gearbox tcu has been opened and no wiring faults have been found but its the abs fault code that making me wonder if its the engine ecm thats not configured properly with its current coding and been looking for ages trying to find the list
    Sunday,10,July,2016,13:43:48:44553
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WAUZZZ8E84A046688   License Plate:
    Mileage: 187230km-116339mi   Repair Order:
              67 69 75 76 77
    VIN: WAUZZZ8E84A046688   Mileage: 187230km-116339miles
    Address 01: Engine        Labels: 038-906-019-AVF.lbl
       Part No: 038 906 019 LJ
       Component: 1,9l R4 EDC 0000AG  4910
       Coding: 00001
       Shop #: WSC 63351
       VCID: 6ADBBA4F16D1E06EC0-4B00
       WAUZZZ8E84A046688     AUZ6Z0C0205287
    18034 - Powertrain Data Bus
                P1626 - 35-00 - Missing Message from TCU
    17994 - Engine Mount Solenoid Valves (N144/N145)
                P1586 - 35-10 - Short to Plus - Intermittent
    Readiness: 1 1 1 1 1
       Part No: 8E0 614 517
       Component: ABS/ESP front       3429
       Coding: 04259
       Shop #: WSC 06435
       VCID: 65C1C973FFCFCF16ED-5140
                35-00 -  -
    18055 - Check Coding of ECUs on Powertrain Data Bus
                P1647 - 35-00 -
       Part No: 8E0 820 043 AA
       Component:   A4 Klimaautomat   1219
       Coding: 00000
       Shop #: WSC 63351
       VCID: 60CFD867E0EDAA3E1E-515E
       Part No: 8E0 907 279 E
       Component: int. Lastmodul  RDW 0305
       Coding: 00001
       VCID: 346764370495669EAA-4B00
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 B
       Component: Airbag 8.4EP        3002
       Coding: 0010602
       Shop #: WSC 63351 000 00000
       VCID: 36635E3F42E9748E94-5140
       Part No: 8E0 953 549 F
       Component: Lenksáulenmodul     0308
       Coding: 01011
       Shop #: WSC 63351
       VCID: 36635E3F12E9748E94-4B00
       Part No: 8E0 920 950 J
       Component: KOMBI+WEGFAHRS. RB4 D36
       Coding: 00400
       Shop #: WSC 00048
       VCID: 306F6827F08D5ABECE-515E
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0604
       Coding: 00001
       VCID: 6BD5BF4B192BF966BB-5140
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 BC
       Component: Komfortgerát T3B    1311
       Coding: 06859
       Shop #: WSC 63351
       VCID: 73E5A72B411B21A673-4B00
       Subsystem 1 - Part No: 8E2959802B
       Component: Tőrsteuer.FS BRM 0003
       Subsystem 2 - Part No: 8E2959801B
       Component: Tőrsteuer.BF BRM 0003
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0003
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0003
    No Faults Found
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 8E0 035 186 J
       Component: concert II  GRO    0008
       Coding: 01001
       Shop #: WSC 63351
       VCID: 2E53765FEAB94C4EDC-4B00
    End-------------------------(Elapsed Time: 06:09)--------------------------
    Mar 2016
    Does the TCU has all of it power and ground? No bad connection on the fuse holder on the battery?
    Jul 2016
    fuse holder on battery ?
    going to try a different battery on car as current one holding just over 12v
    Northern ireland
    You have no communication with your tcu, would it not be best practice to get the relevant wiring diagrams and then check power and earth's to the tcu?
    What exactly is wrong with the car?
    Jul 2016
    no drive via gearbox and no prds symbols on the dash gear selector lights work but does nothing regarding gear selection have tested down at the socket and pins 9 and 10 do have power but around 11.9v hence wanting to try another battery
    when i bought the car the 4 relays under the ecu had been submerged in water all have been opened and tested to confirm they work and no fuses found to be popped
  6. #6
    Northern ireland
    How did you conduct a wiring test/check??
  7. #7
    Jul 2016
    meterman digital meter between pins and chassis
    if you have a full way to test the wiring the help would be much appreciated as have only been able to find bits and pieces
  8. #8
    Northern ireland
    Checking resistance, Continuity and short to ground/positive/each other?( continuity should never be used for testing condition of wires) Unfortunately my laptop is in the workshop so I have no access to my wiring diagrams, but in this occasion I don't think coding is your problem. I would nearly be sure these Engine modules only having coding of 00001 or 00002, but irrespective of that, you need to have comms with the tcu or you'll never get it to work.
  9. #9
    Jul 2016
    its the p1647 message from the abs ecu saying Check Coding of ECUs on Powertrain Data Bus thats making me wonder if its due to something loosing its coding thats causing the tcu not to be listened too
  10. #10
    Quote Originally Posted by starkie View Post
    I don't think so. Notice that your ABS is also complaining that it can't talk to the TCU, and that VCDS can't talk to the TCU?
  11. Likes dubTECH liked this post
