Results 1 to 9 of 9
Thread: 15 MK7 GTI ABS coding helper
    Jul 2016
    Does any one have the ABS module coding helper maps? Mine are missing in VCDS, are they going to be available in the next update? I'm trying to recode my ABS for ACC. Thanks in advance...
    You're retrofitting ACC?
    I have not seen anything that resembles an even remotely complete coding chart for the MK100 systems typically found in those cars.
    Jul 2016
    Thanks for the quick reply Uwe, my car already has DAP pkg, just want to make sure the ABS unit needs/not to be coded for ACC, since there's no info in VCDS for coding the ABS module.
    If it has DAP with ACC, I'm quite confident the factory got the coding right.
    But maybe you should take the advice given here and post an Auto-Scan..
    Jul 2016
    Finally got some time to work on my car today, Already installed the new steering wheel controls that support ACC, and did some coding according to an auto scan that is available here in the forums, here is my auto scan before and after the coding...
    ####################BEFORE####################
    Saturday,02,July,2016,17:14:03:63946
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: xxxxxxxxxxxxxxxxxx   License Plate:
    Mileage: 31024km-19277mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 75 A9
    VIN: xxxxxxxxxxxxxxxxxx   Mileage: 31024km-19277miles
    Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
       Component: 2.0l R4 TFSI  H13 0006
       Revision: --H13---
       Coding: 091D00324424002F1000
       Shop #: WSC 00066 790 00202
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
       ROD: EV_ECM20TFS0205G0906259A_VW37.rod
       VCID: 2C79FD4947F2FD5EF2-8078
    Readiness: 1010 1101
       Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4511
       Revision: 05853104    Serial number: TFK01412101379
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 2977045D4800E87609-807C
    No fault Found:
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 53454000000334
       Coding: 01FA6BA13427096F0080020681C32980D62C9000408194B410430050C005
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
       VCID: 47B3A2E5FE543E06FF-8012
       Revision: 00021000    Serial number: 0356326553
       Coding: 030C0C
       VCID: 3A55CB11BDA653EE70-806E
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
       Revision: 00001K01
       Coding: 00020004200100000000000010000000
       ROD: EV_ACManueBHBVW37X_SE37.rod
       VCID: 46ADAFE1F95E270E04-8012
       Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86580601151384
       Coding: 00111A464041A26969E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00206
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 4AB59BD1ED46C36EE0-801E
       Slave 1:
       Component: WWS    141205  043 0581
       Serial number:         150211015942
       Coding: 0E4DFD
       Slave 2:
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S3Y14M11D26H22M52S13
       Coding: 06A8DD
       Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0001WOUF00000
       Coding: 181801
    No fault Found:
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391433812357
       Coding: 0031151011
       ROD: EV_EPHVA18AU3700000_SK48.rod
       VCID: 3D5FC00DAC8864D655-8068
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 14121403271837
       Coding: 01201200FE033B
       ASAM Dataset: EV_ACCMRRBoschVW372 001015
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       VCID: 3851D11983AA41FE86-806C
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM01SKSC
       VCID: 51878CBD0010F0B6A1-8004
       Seat occupant detection; front passenger side:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J1500029IVO0Q
       Coding: 303131
       Subsystem 2 - Part No SW: -----------    HW: 480 000 612 14
       Serial number: 35700000000A30543210
       Subsystem 3 - Part No SW: -----------    HW: 480 000 612 14
       Serial number: 35800000000597303213
       Subsystem 4 - Part No SW: -----------    HW: 480 401 311 14
       Serial number: 3510002BB188FC11D06C
       Subsystem 5 - Part No SW: -----------    HW: 480 401 311 14
       Serial number: 35200029D188FC109327
       Subsystem 6 - Part No SW: -----------    HW: 480 402 511 14
       Serial number: 3550002B718B3A749314
       Subsystem 7 - Part No SW: -----------    HW: 480 402 511 14
       Serial number: 3560002B718B3A7261DA
    Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
       Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20141218400156
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 042975E98FE2D51E5A-8050
       Part No SW: 5G1 920 856     HW: 5G1 920 856
       Component: KOMBI         342 4270
       Coding: 0BAD091A2980CF0502887A011000000000000000
       VCID: 6BFB3E55827C3A66BB-803E
       Revision: --------    Serial number: 16011510000552
       Coding: 0101000820085900FF00002A1C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07029
       ROD: EV_GatewConti.rod
       VCID: 72C52331A556EBAE78-8026
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29140002882510035044
       Coding: 29FFFF
    No fault Found:
       Revision: 00000000    Serial number: 15000015223004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 3449E5299FC2A59EAA-8060
       Serial number: 12011506050B9W
       Coding: 003E13200000040000000000
       VCID: 40A1B9F9DB7A093E3E-8014
       Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
       Serial number: 00000000000000594835
       Coding: 011000
       Coding: 8102
       ROD: EV_SteerAssisMQB.rod
       VCID: 3753D2258EB44E868F-8062
       Serial number: 3001150605063O
       Coding: 003E13200400040000000000
       VCID: 3FA3BA05A68476C647-806A
       Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
       Serial number: 00000000000000432560
       Coding: 091000
       Coding: 021A01010B000400
       ROD: EV_HeadlRegulVWAFS_SE26.rod
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B00401151412
       Coding: 027300000000000021220002001800001F0203340100010002
       ROD: EV_MUStd4CPASE_SK37.rod
       VCID: 64E955696FA2751EFA-8030
    NO fault Found:
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Component: OCULowMQBUS   007 0564
       Coding: 02730002C2823A017F1E06000000
       Shop #: WSC 00066 790 00123
       ROD: EV_OCULowMQB.rod
       VCID: 43ABB6F5CA6C122623-8016
    No fault Found:
       Part No SW: 5G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0014
       Serial number: 141125201646
    End-------------------------(Elapsed Time: 03:54)--------------------------
    ##################AFTER####################
    Sunday,24,July,2016,11:04:25:63946
    VIN: xxxxxxxxxxxxxxxxx  License Plate:
    Mileage: 32279km-20057mi   Repair Order:
    VIN: xxxxxxxxxxxxxxxx   Mileage: 32279km-20057miles
       Revision: --H13---
       Coding: 091D00324464002F1000
    22008 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [039] - -
                        Mileage: 32279 km
                        Date: 2016.07.24
                        Time: 10:57:34
    Readiness: 1110 1101
    no fault Found:
       Coding: 030C0C
       Revision: 00001K01
       Slave 1:
       Slave 2:
       Coding: 06A8DD
       Coding: 181801
    No fault Found:
       Coding: 0031151011
       Coding: 013C1200FE033B
    1039 - Databus
                        Reset counter: 155
                        Mileage: 32279 km
                        Date: 2016.07.24
                        Time: 10:36:27
       Coding: 303131
       Coding: 0410
       Coding: 0BAD091A2D80CF0502887A011000000000000000
       Coding: 0101000830085900FF00022A1C0F00000001050000000000000000000000
       Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
       Component: E221__MFL-DC1  H11 0040
       Serial number: 29150002465840055505
       Coding: 35FFFF
       Coding: 011000
       Coding: 8102
       Coding: 091000
       Coding: 2E0000
       Coding: 2E0000
    No fault Found:
    No fault Found:
  6. Likes Uwe liked this post
    May 2014
    ^^^^^ASR : I can't help with your ABS question (I also await a list of long coding helper screens for this beastie), but it looks like you have altered Byte 5 of the engine module (address hex01) by making it Hex64 (was Hex24).
    My engine module is different, but are you sure this is the correct setting? According to the long coding helper screen from my car, giving Bit 4-6 a value of "hex6" (i.e. setting Bit 6 and Bit5) tells the Engine that your ACC has front assist. Given the DTC message about "no comms with Cruise Control Front Distance sensor" this could be what we down here term a "doobie" code change ( i.e. slang for "dubious"). Perhaps a value for Byte 5 of hex44 might be worth considering?
    Also interesting that the control module at address hex16 hasn't had a code change (see picture below from my car, again which has a slightly different number)
  8. Likes Uwe liked this post
    Jul 2016
    Thanks for the response Don, I re-checked the coding and everything looks OK. you have pointed out the coding for the steering wheel coding that says "Cruise Control NOT Installed", for some weird reason it comes coded like that even if I already had CCS, I tried coding for hex 60 ACC, but It won't take the code.
    I pretty much narrowed down to the ABS coding, controller no. 3Q0 907 379 P. I wonder if UWE has some long coding helper info. on this controller...
    Here are some of my errors symptoms
    1. ACC buttons on MFSW is inop., although radio, phone and volume buttons work fine.
    2. "ACC Deactivated" message in MFD.
    3. ACC settings show in radio display, but when trying to press the check boxes, I get "Function not available" message.
    4. Address 01 Engine 1 fault-- 22008 - No Communications with Cruise Control (Front) Distance Sensor
    U0235 00 [039] - -
    5. Address 13 Auto Dist. Reg. 1 fault-- Databus U1123 00 [009] - Received Error Message.
    It looks like there is a missing link between the two controllers.
  10. #8
    Jul 2016
    Ok, searching the Internet I found that my ABS unit only supports PR-8T7 ( ACC w/o follow to stop function) where the 2016 U.S. spec. GTI ABS units supports PR-8T8 (ACC with follow to stop function) so I've been coding it for Hex 60 (PR-8T8). For some reason there is no option for 8T7 in the 01 Engine address.
  11. #9
    Jul 2016
    I tried to find the coding for 8T7 and it's nowhere in VCDS, maybe an unsupported option, last resort would be to swap to a compatible ABS unit....
