Results 1 to 7 of 7
Thread: Informational: Install on domain-joined Win7 with UAC appears to need Run As Admin...
    CO, USA
    I've seen this with a few other applications as well - even though the user has Admin privileges, something about the machine being joined to a domain (possibly something set by the domain of course) seems to require Run As Administrator for the installer. (At least for 12.12.2 and Betas 14.5.0, 14.5.5, 14.6.0)
    On my so-equipped machine, running as a user with Admin privileges, the installer appears to run, but start menu icons are not created and the USB driver installer does not run. Re-running the installer with Run As Administrator works fine.
    On a similar non-domain-joined machine the install runs as expected for an Admin-privileged user.
    Probably a boundary condition as most users won't hit this, but posted as an FYI - no need for action on my account, I just have to remember to do it when I install new versions
    Richard
  2. Likes Uwe liked this post
  3. #2
    Domain-joined? That involves some big-brother type having control over your PC (which is supposed to be a PERSONAL computer) right?
    Thank you for the post; I do appreciate it. We probably would never have noticed this ourselves 'cause I refuse to allow a "Domain Controller" on our network. You see, despite the tongue-in-cheek 'dictator' tile, philosophically I'm actually an anarchist.
  4. Likes jakematic liked this post
  5. #3
    CO, USA
    Agreed! Unfortunately my work machine requires it, and I'm too lazy to carry both a work and a personal laptop so I have to adapt. This is one of the least annoying things that happens as a result.
    I posted it mainly in case someone else runs into the problem - at least this way the symptoms might ring a bell and y'all can tell the user to try running the installer as admin anyway. It might be something specific to my particular big-brother, but either the last big brother I had did the same thing or its something deeper to do with domain crap. I never dug particularly deeply, just worked around it and went on with life
    Duh, who else would have taken on this job?
    Richard
  6. #4
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    My laptop and several other machines, and a bunch of virtual machines are all joined to my own domain here at home. I haven't noticed any unusual behavior with VCDS or had to do anything special during install to make it work. There may be some policies defined on Richard's domain that aren't on mine.
    Jason
    CO, USA
    Agreed. Do you have UAC enabled? I.e. do you get the popups asking for permission for admin stuff to run? I attribute it to being domain-joined because both my current and previous employer's laptops did it, but it could easily be some domain policy that corporate IT folks consider best practices.
    Cincinnati, OH
    Quote Originally Posted by solomon View Post
    Yes, UAC is enabled and running with default settings. I do get a UAC pop-up when launching the installer, but after okaying that, the program and associated drivers install normally.
    Jason
    CO, USA
    Interesting - I don't think I get the UAC popup unless I check the properties box to run as admin. I get a box about running programs from the internet.
