Reset Inspection Due Warning 2016 Audi A3
jthompson
NE OHIO USA
C?ID=282755
I recently did my 15k oil change and inspection. I reset the Oil change warning/reminder manually, but can not reset the "inspection due" warning / reminder. This warning is different the change oil reminder and as far as I can tell can not be reset other than going to the dealer...
Is there a procedure to reset this warning / reminder with your "cable" / software?
Which system would I need to get this done?
Thanks,
Jeff
Steve Star
Thanks,
Jeff
It sounds like VW/Audi are holding our cars hostage to "their" service departments.
jthompson
NE OHIO USA
C?ID=282755
Generally, what is gained by going with a Hex-Net system over a Micro-Can system?
The Micro-CAN is USB only and only works with a limited range of cars. See here.
The HEX-NET can be used with VCDS via USB, or WiFi, includes VCDS-Mobile as well, and is a universal interface that works with all models of VW/Audi Group cars.
Bruce
Near Philadelphia, PA, USA
Gained with the HEX-NET is model year coverage, freedom from wires, freedom from platform dependence on Windows PC.
jthompson
NE OHIO USA
C?ID=282755
Hex-Net is ordered and on its way... Can you point me to the procedure to reset the "Inspection Due"?
Thanks!
What you're looking for starts at about 1:55 in the following video:
