Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: VW Golf 7 ABS Brakes (J104) 15.7.4 and Beta 16.6 No Texts!
    Jun 2016
    Yesterday i have installed the latest Beta 16.6.
    First impression its start verry slow 10% 20 % 30 % ....
    After instalation i see again no Bytes and Bits on the ABS Brakes this was on the 15.7.4 and now olso with the beta 16.6.
    See the link: https://youtu.be/tvHdmeHpquw
    I olso cannot change the setting on the gateway
    (1)-Range gain-Range gain AC system,activated
    (2)-Range gain-Range gain auxiliary heater,activated
    (3)-Range gain-Range gain window defogger,activated
    (4)-Range gain-Range gain seat heater front,activated
    (5)-Range gain-Range gain front set ventilation,activated
    (6)-Range gain-Range gain rear heater,activated
    (7)-Range gain-Range gain fog light,activated
    (8)-Range gain-Range gain rear fog light,activated
    See link for the guestion: http://vagcomforum.de/index.php?showtopic=28393
    I olso cannot change the setting on the instrument cluster this was on the 15.7.4 and now olso with the beta 16.6.
    ID 190 (1)-Illumination_algorithm-Scale_switching_algorithm > parking_light
    ID 191 (2)-Illumination_algorithm-Pointer_illumination_algorithim > terminal_58xd_log_bus_parkinglight
    http://forums.ross-tech.com/showthre...remium-1-fault
    Saturday,09,July,2016,23:31:13:42750
    VCDS Version: 16.6.0.2
    Data version: 20160602 DS251
    VIN: WVWZZZAUZDP010048   License Plate:
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZDP010048   Mileage: 47379km-29439miles
    Address 01: Engine (J623-CJZB)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 E    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 7695
       Revision: WAH08---
       Coding: 01110032232415082000
       Shop #: WSC 51969 000 1048576
       ASAM Dataset: EV_ECM12TFS01104E906016E 001011
       ROD: EV_ECM12TFS01104E906016.rod
       VCID: 2468B6F82F7D01639D-8070
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
       Shop #: WSC 12345 123 123465
       VCID: 7DDEA39CEC5790ABB2-8028
       Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
       Component: Climatronic   H02 0503
       Revision: 00001K06
       Coding: 00020004200100011005000000101000
       ROD: EV_ACClimaBHBVW37X_VW37.rod
       VCID: 364C7CB089E183F333-8062
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 L
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011227800350
       Coding: 00040846C2C102FB0BA44080B11C0708100A000000000000000000000000
       ROD: EV_BCMBOSCH_VW37.rod
       VCID: 77D2B1B4CE6BBAFBE8-8022
       Component: WWS    120910  042 0551
       Serial number:         120924160900
       Coding: 0E4DD5
       Component: RLFS  024 0042
       Serial number: Y12M09D26H11M47S40S4
       Coding: 06A8DD
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY1306406H5
       Serial number: 00000000000056969920
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
       Component: PARKHILFE PLA 011 0029
       Revision: --------    Serial number: 61131204002703
       Coding: 0031161041
       ASAM Dataset: EV_EPHVA2CAU3700000 003014
       ROD: EV_EPHVA2CAU3700000_VW37.rod
       VCID: 3D5E639CACD750ABF2-8068
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R00E6ZJ
       Shop #: WSC 00028 028 00057
       VCID: 40A01A68DB253D4399-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 310 12
       Serial number: 35767000000E2845EB00
       Subsystem 2 - Part No SW: -----------    HW: 480 001 708 13
       Serial number: 35867000000ED2CC6D0F
       Subsystem 3 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3516502A90D19C31C0EK
       Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3526502AD0CD5EB313CY
       Subsystem 5 - Part No SW: -----------    HW: 480 400 210 12
       Serial number: 3556502B30CD5EB4531M
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Revision: --------    Serial number: 1510120003004H
       Coding: 8400
       Shop #: WSC 51454 001 104857
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 75CEBBBCD467C8EBFA-8020
       Part No SW: 5G0 920 871     HW: 5G0 920 871
       Component: KOMBI         353 2200
       Coding: 07AD0A00239000080D087E00040000
       VCID: 67F2E1F49ECB2A7B78-8032
       Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
       Component: GW MQB Mid    121 1144
       Revision: --------    Serial number: 0000104516
       Coding: 030100042B086400EF000648080F00010001000000000000000000000000
       Shop #: WSC 51454 001 1048576
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear.rod
       VCID: 3A546880BDF96793D7-806E
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
       Component: E221__MFL-DC1  H14 0035
       Serial number: 23130000529820100291
       Coding: 280000
       Serial number: 5430458201
    1537 - Data Set Implausible
              B2012 00 [009] -  -
                        Reset counter: 77
                        Mileage: 47049 km
                        Date: 2016.06.26
                        Time: 10:52:06
                        Supply voltage; Terminal 30: 14.7 V
                        Terminal 15: On
       Serial number: 29051301100188
       Coding: 001F0220D000020000001000
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
       Serial number: 00000000000000243883
       Coding: 03
       Component: TSG BFS       020 0023
       Serial number: 06031302090088
       Coding: 001F0020DE00020000801000
       VCID: 3FA21994A6DB42BBE0-806A
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
       Serial number: 00000000000000247280
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846
       Component: MU-S-N-ER     038 0421
       Serial number: V1F01510120522
       Coding: 02730001FF00000011110001000800001F0100940100010045
       Shop #: WSC 12345 666 54321
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 2772A1F45E4BEA7BB8-8072
       Component: ABT_Std_Nav  H51 0022
       Serial number: VWZ8Z9NJ902C5F
       Subsystem 2 - Part No SW: 5G0 919 866 AD    HW: -----------
       Component:  ECE 2016/17  --- 0059
    End-------------------------(Elapsed Time: 02:42)--------------------------
    Quote Originally Posted by barstanders View Post
    Specs of PC? What nannyware do you have installed on it?
    Jun 2016
    Intel Atom Quad core (4) 1330 MHZ windows 10.
    vcds 15.7.4 verry fast!
  4. Likes Uwe liked this post
    You didn't answer about nannyware.
    Jun 2016
    Nannyware you mean a antivirus program?
    The laptop used only for vcds and i have eset security installed
    Try turning it off (temporarily) or telling it to ignore the stuff in the folder you have the Beta installed in to see if it makes any difference.
    Jun 2016
    Can i uninstall everthing with vcds like the 15.7.4 EN and DE Beta and then reinstall again the beta only.
  9. #8
    You can, but I don't think there's much point in it.
  10. #9
    Jun 2016
    Oke, and what about the other options what dont work.
    Like changing the gateway settings and instrument cluster adaptations, and olso the byte and bit discription ABS . will this work when i final release coms???
  11. #10
    Just because an Adaptation channel might exist (by having being included in the list provided by VCDS), or even does exist (as indicated by a value being readable) does not mean the module's diagnostic API allows changes to that channel.
    If/when we come across proper documentation for the coding of these ABS modules, we'll included it in VCDS. Unfortunately, such documentation does not exist, even in the factory tool.
    Please keep in mind that VW gives us NO assistance of any kind with this stuff.
