- Jun 3, 2016
- 208
- 22
- Netherlands
- C?ID=277262
Yesterday i have installed the latest Beta 16.6.
First impression its start verry slow 10% 20 % 30 % ....
After instalation i see again no Bytes and Bits on the ABS Brakes this was on the 15.7.4 and now olso with the beta 16.6.
See the link: https://youtu.be/tvHdmeHpquw
I olso cannot change the setting on the gateway
(1)-Range gain-Range gain AC system,activated
(2)-Range gain-Range gain auxiliary heater,activated
(3)-Range gain-Range gain window defogger,activated
(4)-Range gain-Range gain seat heater front,activated
(5)-Range gain-Range gain front set ventilation,activated
(6)-Range gain-Range gain rear heater,activated
(7)-Range gain-Range gain fog light,activated
(8)-Range gain-Range gain rear fog light,activated
See link for the guestion: http://vagcomforum.de/index.php?showtopic=28393
I olso cannot change the setting on the instrument cluster this was on the 15.7.4 and now olso with the beta 16.6.
ID 190 (1)-Illumination_algorithm-Scale_switching_algorithm > parking_light
ID 191 (2)-Illumination_algorithm-Pointer_illumination_algorithim > terminal_58xd_log_bus_parkinglight
http://forums.ross-tech.com/showthr...nstrument-cluster-retrofit-to-Premium-1-fault
Saturday,09,July,2016,23:31:13:42750
VCDS Version: 16.6.0.2
Data version: 20160602 DS251
VIN: WVWZZZAUZDP010048 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDP010048 Mileage: 47379km-29439miles
Address 01: Engine (J623-CJZB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 E HW: 04E 907 309 A
Component: 1.2l R4 TSI H08 7695
Revision: WAH08---
Coding: 01110032232415082000
Shop #: WSC 51969 000 1048576
ASAM Dataset: EV_ECM12TFS01104E906016E 001011
ROD: EV_ECM12TFS01104E906016.rod
VCID: 2468B6F82F7D01639D-8070
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
Shop #: WSC 12345 123 123465
VCID: 7DDEA39CEC5790ABB2-8028
Part No SW: 5G0 907 044 R HW: 5G0 907 044 R
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00020004200100011005000000101000
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: 364C7CB089E183F333-8062
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 L
Component: BCM MQBAB H H14 0112
Serial number: 00011227800350
Coding: 00040846C2C102FB0BA44080B11C0708100A000000000000000000000000
ROD: EV_BCMBOSCH_VW37.rod
VCID: 77D2B1B4CE6BBAFBE8-8022
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 120910 042 0551
Serial number: 120924160900
Coding: 0E4DD5
Component: RLFS 024 0042
Serial number: Y12M09D26H11M47S40S4
Coding: 06A8DD
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY1306406H5
Serial number: 00000000000056969920
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Revision: -------- Serial number: 61131204002703
Coding: 0031161041
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 3D5E639CACD750ABF2-8068
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Serial number: 003F5R00E6ZJ
Shop #: WSC 00028 028 00057
VCID: 40A01A68DB253D4399-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 310 12
Serial number: 35767000000E2845EB00
Subsystem 2 - Part No SW: ----------- HW: 480 001 708 13
Serial number: 35867000000ED2CC6D0F
Subsystem 3 - Part No SW: ----------- HW: 480 400 910 12
Serial number: 3516502A90D19C31C0EK
Subsystem 4 - Part No SW: ----------- HW: 480 400 910 12
Serial number: 3526502AD0CD5EB313CY
Subsystem 5 - Part No SW: ----------- HW: 480 400 210 12
Serial number: 3556502B30CD5EB4531M
Part No SW: 5Q0 953 507 AA HW: 5Q0 953 549
Revision: -------- Serial number: 1510120003004H
Coding: 8400
Shop #: WSC 51454 001 104857
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 75CEBBBCD467C8EBFA-8020
Part No SW: 5G0 920 871 HW: 5G0 920 871
Component: KOMBI 353 2200
Coding: 07AD0A00239000080D087E00040000
ROD: EV_DashBoardVDDMQBAB_VW37.rod
VCID: 67F2E1F49ECB2A7B78-8032
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
Component: GW MQB Mid 121 1144
Revision: -------- Serial number: 0000104516
Coding: 030100042B086400EF000648080F00010001000000000000000000000000
Shop #: WSC 51454 001 1048576
ROD: EV_GatewLear.rod
VCID: 3A546880BDF96793D7-806E
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H14 0035
Serial number: 23130000529820100291
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 5430458201
1537 - Data Set Implausible
B2012 00 [009] - -
Fault Frequency: 6
Reset counter: 77
Mileage: 47049 km
Date: 2016.06.26
Time: 10:52:06
Supply voltage; Terminal 30: 14.7 V
Terminal 15: On
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 29051301100188
Coding: 001F0220D000020000001000
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Serial number: 00000000000000243883
Coding: 03
ROD: EV_SteerAssisMQB_VW37.rod
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0023
Serial number: 06031302090088
Coding: 001F0020DE00020000801000
VCID: 3FA21994A6DB42BBE0-806A
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Serial number: 00000000000000247280
Coding: 090000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846
Component: MU-S-N-ER 038 0421
Serial number: V1F01510120522
Coding: 02730001FF00000011110001000800001F0100940100010045
Shop #: WSC 12345 666 54321
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 2772A1F45E4BEA7BB8-8072
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NJ902C5F
Subsystem 2 - Part No SW: 5G0 919 866 AD HW: -----------
Component: ECE 2016/17 --- 0059
End-------------------------(Elapsed Time: 02:42)--------------------------
