Results 1 to 6 of 6
Thread: 2008 VW JETTA SEL PRNDS issues
    Jul 2016
    ///Quick Backstory///
    Had issue with motor that controls A/C flap "erratic sound at startup near glovebox". got replacement part from junk yard in doing so had to disconnect battery. after replacing part-which works fine now. Had a ton of indicator lights. the most apparent was that I am no longer able to disengage the gear selector and the PRNDS is not visible on the MFD. I read where I could remove the boot from the gear selector and bypass the solenoid I put car in (D)rive and steering wheel indicator went away. The only ones that are still visible is the MIL, Light (I have a light out) stability control system.
    Things I have done so far:
    1. Verified all fuses
    2. I tried a different Transmission Control Module (TCM) from a 2009 Jetta-no display of PRNDS
    3. waited for my lucky star to appear at night so I wish upon it...maybe they are punishing me
    Any assistance would be greatly appreciated.
    VCDS Version: Release 15.7.4 Running on Windows 10 x86
    Data version: 20160216
    Saturday,09,July,2016,18:01:52:51409
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
    72
    VIN: 3VWRM71K68M147580 Mileage: 291940km-181403miles
    02-Auto Trans -- Status: Cannot be reached 1100
    1C-Position Sensing -- Status: Malfunction 0010
    Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
    Part No SW: 07K 906 032 BJ HW: 07K 906 032 Q
    Component: 2,5l R5/4V G 1862
    Revision: 1NH03--- Serial number: VWX7Z0H124C09S
    Coding: 0000003
    Shop #: WSC 00066 000 00000
    VCID: 72C527A36D67F0AE78-8026
    049409 - No Communication with Transmission Control Module
    U0101 - 008 -
    Fault Status: 01101000
    Mileage: 291943 km
    Time: 01:33:04
    RPM: 765 /min
    Load: 26.3 %
    Temperature: 47.0C
    Temperature: 32.0C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.097 V
    Readiness: 0110 1101
    Address 02: Auto Trans
    Revision: 00H11001
    Coding: 0021122
    VCID: 73CB22A7127DF9A673-8026
    Part No SW: 1K0 820 047 HJ HW: 1K0 820 047 HJ
    Component: Climatic PQ35 141 1010
    Revision: 00141028 Serial number: 00000000000000
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Revision: 00H54000 Serial number: 00000007404611
    Coding: 14058E234004150007140000001400000008730B5C00010000 0000000000
    VCID: 71C728AF6861CBB681-8024
    Component: Wischer 050308 021 0501
    Coding: 00038805
    Shop #: WSC 00066
    Fault Status: 01101100
    Reset counter: 234
    Mileage: 291943 km
    Date: 2005.09.13
    Time: 31:63:63
    Voltage: 13.95 V
    Revision: 00000000 Serial number: AUZ4Z7H0278647
    Coding: 0000000
    VCID: 334BE2A752FDB9A6B3-8066
    Reset counter: 233
    Mileage: 291943 km
    Time: 16:37:27
    Component: 6A AIRBAG VW8R 034 8000
    Revision: 05034000 Serial number: 003B6M04JFZT
    Coding: 0013889
    VCID: 6CF939DB4F43265EB2-8038
    Subsystem 2 - Serial number: 6332MSME2D1045488
    Subsystem 3 - Serial number: 6342MSME35536E76L
    Subsystem 4 - Serial number: 6351HSME1336190A0
    Subsystem 5 - Serial number: 6361HSME13162F501
    Subsystem 6 - Serial number: 63727SME124D2925+
    Subsystem 7 - Serial number: 63827SME125B2B33%
    Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
    Component: J0527 051 0100
    Coding: 0012021
    VCID: 78D1158B0B1B9AFE46-802C
    Component: E0221 002 0010
    00002 - Transmission Control Unit
    Part No SW: 1K0 920 974 J HW: 1K0 920 974 J
    Component: KOMBIINSTRUMENT 3HL 2216
    Revision: V0002000 Serial number: VWX7Z0H124C09S
    Coding: 0023203
    Shop #: WSC 00066 067 57207
    VCID: 354FDCBF5C89A7969D-8060
    Reset counter: 234
    Mileage: 291943 km
    Time: 01:33:18
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533 Gateway H07 0052
    Revision: H07 01 Serial number: 220108F2001486
    Coding: ED807F071013021002
    VCID: 3041EDABA3EB82BECE-8064
    Reset counter: 234
    Mileage: 291943 km
    Time: 16:45:18
    Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
    Component: Kompass 005 0004
    Revision: 00005000 Serial number: 1293324T2X8P04
    Coding: 0000003
    VCID: 3957D08F709143F679-806C
    01316 - ABS Control Module
    015 - Cannot Be Tested at this Time - Intermittent - MIL ON
    Fault Status: 10111111
    Fault Frequency: 255
    Reset counter: 95
    Time Indication: 15
    Reset counter: 55
    Reset counter: 16
    Time Indication: 15
    Component: IMMO 3HL 2216
    Shop #: WSC 58402 001 1048576
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1133
    Revision: 32008001 Serial number: 00000088088110
    Coding: 0001205
    VCID: 3B5BCA877AAD71E66B-806E
    Fault Status: 00100101
    Reset counter: 17
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.070 H08 1901
    Shop #: WSC 02069 000 90108
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Coding: 13900F880186281B0904058FB0880F0488DC00
    VCID: 0429717B47D3CE1E5A-8050
    Address 47: Sound System Labels: 3C0-035-456.lbl
    Part No SW: 1K6 035 456 B HW: 1K6 035 456 B
    Component: 08K Audioverst. 0006
    Revision: 00004000 Serial number: 00000008140024
    VCID: 2B7BFAC78ACDE166FB-807E
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1133
    Revision: 32008001 Serial number: 00000040188221
    Coding: 0001204
    VCID: 3C59C99B7FA376DE62-8068
    Reset counter: 17
    Component: Radio DE2 016 0020
    Revision: 00016000 Serial number: VWZ4Z7H2188153
    Coding: 0010400
    VCID: 297700CF8031F37609-807C
    00003 - Control Module
    014 - Defective
    Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
    Component: J388 TUER-SG HL 1120
    Revision: 12006001 Serial number: 00000002785209
    Coding: 0001168
    VCID: 3E5DC39369BF64CE4C-806A
    Reset counter: 17
    Component: RDK 0450
    Coding: 0100101
    Shop #: WSC 92724 999 796063
    Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
    Component: J389 TUER-SG HR 1120
    Revision: 12006001 Serial number: 00000002793391
    Coding: 0001168
    VCID: 3FA3BE976EB56DC647-806A
    End-------------------------(Elapsed Time: 01:30)--------------------------
    Lucky star.....
    Did you check the TCU for power and grounds at module?
    What part number module is in the car currently?
    I
    Jul 2016
    Lucky star.....
    I
    I believe the part # is 09G 927 750 HE. Regarding your first comment, how exactly do I check power at the module? Do you mean check the pins with the TCM removed?
    Yup.......
    Time to get a repair manual and trace via WD.
    Learn how to use a meter and test light by searching YouTube videos.
    Jul 2016
    Yup.......
    If a wire is fried so to speak, do you feel that one of the fuses might have gone out in the process?
  6. #6
  7. Likes NZDubNurd liked this post
