Audi 8K _ 02-auto trans error
pronet
Romania
C?ID=157414
I found a strange DTC on 02 auto-trans. I searched also on wiki ross tech but no relevant info found. I get some explanation on a dutch site but nothing about the causes which trigger this error. I cleared now the DTC and I'll monitor to see if appear again. Scan below:
Friday,28,February,2014,02:29:40:56830
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUZZZ8K1BN021157   License Plate:
Mileage: 103970km-64603mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
VIN: WAUZZZ8K1BN021157   Mileage: 103970km/64603miles
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H10 8441
   Revision: 11H10---
   Coding: 0104002C02072118
   Shop #: WSC 22151 143 999999
   ASAM Dataset: EV_ECM20TDI03L906022MK A01009
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7AF007C1FD02A7CED53-802F
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [096] - Electrical Fault
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
   Component: 0AW 20TDI RdW H06 0009
   Revision: --H06---    Serial number: 0000000701
   Coding: 000001
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMVL381 A02017
   ROD: EV_TCMVL381.rod
   VCID: 77F61EF5CE10BAA6AAD-8022
9827 - Clutch Pressure Adaptation
          P1741 00 [044] - Limit Reached
                    Fault Frequency: 10
                    Mileage: 103467 km
                    Date: 2014.01.31
                    Time: 08:28:28
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 BF    HW: 8K0 907 379 BF
   Component: ESP8 front    H04 0030
   Coding: 170500
   Shop #: WSC 02391 823 56573
   VCID: 7EF80BD1E92A8BEEE9B-802B
   Part No SW: 8K0 907 064 CA    HW: 8K0 907 064 CA
   Component: BCM2 2.0      H04 0430
   Coding: 010100
   Shop #: WSC 02399 823 56573
   VCID: 71E220EDA874E496649-8024
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H50 0071
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0180
   Revision: A1000000    Serial number: 01250820100831
   Coding: 34100000
   VCID: 7DFA0CDDE42C90F6F01-8028
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H29 0392
   Revision: 10029001    Serial number: 00000000632588
   Coding: 690040B10134BE000001000300005F5F4F1C420802000001000000
   VCID: 3C7CC1D9BFB659FE87F-8069
   Component: WWS 200810  H06 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
   Component: E1 - LDS  H08 0090
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51241024300227
   Coding: 100103
   VCID: 4796AE35F6700A261AD-8012
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0K22TJ
   Coding: 30343435363030303030554A304C384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 448CB939CF46213EFFF-8011
   Serial number: 6334MSME563322598
   Serial number: 6344MSME56332746A
   Serial number: 6352QSME386F0B0EY
   Serial number: 6362QSME16692802C
   Serial number: 63732SME076C2804
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME6D5F37107
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90315JI3000AU
   Coding: 000016
   VCID: 3D7ACCDDA4AC50F6B01-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 N    HW: 8K0 920 930 N
   Component: KOMBIINSTR.   H22 0258
   Revision: 00000000    Serial number: EJC56ZP8A
   Coding: 0F37080002000008000001
   VCID: 3874DDC98B8E75DE637-806D
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E10816812D
   Coding: 00C303
   VCID: 830EFA2502C86606065-80D6
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H07 0170
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1401
   Coding: 011C02204000410001
   Shop #: WSC 10101 599 00000
   VCID: 53AE8A653228B686765-8006
   Revision: 00002001    Serial number: 0133106253
   Coding: 0100062000B900808120013280000000
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1401
   Coding: 011C02204C00410001
   VCID: 52A08F610D32BF8E7D3-8007
   Revision: 00000003    Serial number: 10000000596824
   VCID: 346CE9F997E691BE4FF-8061
   Part No SW: 4G0 035 053     HW: 4G0 035 053
   Component: Radio U Basic H51 0051
   Revision: AB001007    Serial number: 496I00A7550337
   Coding: 010003020100000001
   VCID: DBBEE245DAF8FEC62E5-808E
   Part No SW: 8T1 035 654 F    HW: 8T1 035 654 D
   Component: B-BNT-EU      H58 0144
   Revision: --------    Serial number: 324G/0A7515696
   Coding: 01010000030681ED01000F0E000000030000
   VCID: 3A70C7C1B58267CE953-806F
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0084
   Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
   Component: E0380 Bedient  H08 0100
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1401
   Coding: 010C02204000210001
   VCID: 56A8737121DAA3AE91B-8003
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H06 1401
vagtuning
VCDS Super-User
C?ID=57100
If error returns - Let the ECU be updated at the Dealer (TSB 2029800)
pronet
Romania
C?ID=157414
Ok. Thanks for info.
pronet
Romania
C?ID=157414
I checked for that TSB #. Are you sure that the number is correct because no data found.
vagtuning
VCDS Super-User
C?ID=57100
Unless my copy & paste is defective - yes :)
Can you find 2029798 - uses the same SVM-Code....
Dana
Western PA, USA
I found that as well and copy/paste rarely fails :-)
pronet, TPI/TSBs are copyrighted material belonging to VW/Audi so I can't give you much...but I can summarize.
All Software levels of 8K0927155AF are flashed to 8K5927155 @ SWL 0002 using SVM code 02A035 according to TPI 2029800/2.​
It is entirely possible that Audi revised the actual flash files since that TPI was last updated so please post another scan after the dealer visit so we know what the actual final values were.
-Dana
pronet
Romania
C?ID=157414
OK. Thanks both of you. I will check again. I pass the info to my friend. If the error returns he will visit the service IOT to update the ECU SW
