Results 1 to 7 of 7
Thread: VW Touareg 2012 - Disabling front fog light as cornering
    Jun 2014
    Hi Guys
    In my VW Touareg 2012, the front fog lights turn on when the side markers and the light are on.
    According with the VAGCOM long code helping, to disable it the bit of bite 4 of module 9 (J519) has to be zero.
    I tried but does not works. It is appears this code it is not good for this module as the VAGCOM helper says.
    Anyone has try this tweak in a Touareg or an Audi with the same module ?
    This is the code of this module:
    Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
    Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
    Component: BCM1 2.0 H12 0100
    Revision: 15012002 Serial number: 00000001066769
    Coding: 26001012973C5D010020180300005D0C431C46088201026100 0000020000
    Shop #: WSC 31414 790 00001
    VCID: 6BD5206F8A9DD540E59
    Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 110902 31 0020
    Coding: 004DBD
    Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
    Component: RLFS H09 0011
    Coding: 025223
    Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
    Component: E1 - LDS H04 0031
    Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
    Component: USHL4.2 H30 0020
    Aug 2018
    I have this same question. It appears no one has the anwser.
    I unchecked the box that says fog lights when cornering yet they still come on.
    Hass Ross Tech been locked out/blocked from making certain changes to some modules?
    IMO a fog light coming on when signaling/turning is useless and does nothing but get people telling you one of your fog lamps is out.
    Jun 2017
    Please post current coding of unit 55
    Aug 2018
    Below is from a scan I did 7/3/19. Not sure what module 55 has to do with it. I thought module 9 had to be coded for this.
    Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
       Coding: 010A00010F000400
       VCID: 7CA1F4C39662AFE7961-8028
       Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0006
       Coding: 130000
       Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0006
       Coding: 130000
    Jun 2017
    In addition to deactivating the bit in Unit 09, set Byte 6 in Unit 55 to Hex 00.
    It might happen that the basic setting gets lost for the head lamps then. Just start the basic setting routine and quit it again using the options in Basic Settings dialog.
  6. Likes Uwe liked this post
    Aug 2018
    When I get some time I'll look into this.
    As for preforming basic settings I'm guessing the instruction in the link below are what your speaking of?
    http://wiki.ross-tech.com/wiki/index...Xenon_with_AFS)
    Jun 2017
    Quote Originally Posted by New2Tregs View Post
    Maybe Golf is the wrong comparison but the procedure to confirm a lost basic setting is just to START the basic setting and then to CONFIRM (however it is translated to english) the basic setting. (both in "Basic Setting" dialog of unit 55)
  9. Likes Uwe liked this post
