Results 1 to 10 of 20
Thread: Security Code to access ABS unit.
    Verified VCDS User TommyKnocker's Avatar
    Mar 2016
    Italy
    Is there any chance to have the security code to access this controller?
    Part No SW: 8S0 907 379 C HW: 8S0 907 379 C
    Component: ESC H31 0511
    Revision: 00000000 Serial number: 61825000000019
    Coding: 24AA608D0A9915B040940866C299930EA2240650A8021043C9 7045
    Shop #: WSC 06385 790 00016
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
    ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
    VCID: 418EE94FD0F0464B96-8014
    2016 Audi TTs
    thanks,
    best regards.
    Magdeburg, Germany
    What exactly are you trying to accomplish?
    Mar 2016
    Italy
    would like to change the electronic Differential lock threshold under adaptations, fatcory setting is medium, would like to give a try to other settings.
    thanks
    Mar 2016
    Italy
    anyone with the sec. code?
    thanks
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    Have you tried 20103?
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
    Mar 2016
    Italy
    i give a try to this set of codes but none worked out
    20103
    01138
    01295
    01972
    02168
    is it possible that this particular adaptation is locked or lsaved to other adaptation(s)?
    thanks again for the help
  7. #7
    Apr 2015
    Quote Originally Posted by TommyKnocker View Post
    20103
    01138
    01295
    01972
    02168
    Cannot see this adaptation being locked, saved or linked to other adaptations as it's not within the A/S/RS3 8V cars.
    I am yet to map these to their related 03 adaptations, but here is a list of all the codes I have been able to extract and find:
    10815
    11122
    11966
    14108
    14451
    15081
    18573
    20103
    24435
    24990
    25004
    25377
    25757
    28183
    31857
    32304
    33776
    33777
    37201
    37202
    37203
    37483
    40168
    40304
    44595
    74999
    75201
    75202
    VAG Car Coding
    @vagcarcoding
  8. Likes TommyKnocker liked this post
  9. #8
    Mar 2016
    Italy
    Thanks for the help DjAlix, I'll give a shot to this list, much appreciated.
    I noted the controller accepts any 5 digit code you enter, if it's not correct you'll be notified when you change any value, is closing the VCDS and re accessing the unit enough to reset security?
  10. #9
    Apr 2015
    In my experience the module / VCDS will let you know if the entered code is incorrect and too many incorrect entries will lock the related module out for a period of time, which only ticks down while the ignition is on. If a code does not work for your needed adaptation, but was accepted without issue via SA, it does not count as an incorrect entery towards a lockout. Hope this all makes sense...
    VAG Car Coding
    @vagcarcoding
  11. Likes Uwe, TommyKnocker liked this post
  12. #10
    Quote Originally Posted by DJAlix View Post
    Right. In this module one should also be able to check the Measuring Value named "Security Access: Number of invalid keys". As a general rule, if this reaches 3, the module will no longer accept any attempts until it times out (with ignition on) and reverts to 0.
  13. Likes TommyKnocker, DJAlix, DV52, mabnz liked this post
