Is it possible to use VCDS to change my B5 S4 to Long Life Service intervals?
Klaus Ludwig
C?ID=227092
I am based in the UK and have a B5 Audi S4 Avant 2.7L. The service interval set up on my car has to the best of my knowledge never been changed since I have had the car. I bought it when it was 3 years old.
I would prefer to be on "Long Life" service intervals. I am assuming that I am not already.
I am not really sure what servicing my car is set to at the moment, but the 365 days and min/max hours in the screenshot below would seem to indicate that I am possibly on some kind of hybrid of annual servicing.
I don't understand why the min miles to service is higher that the max miles to service. Does this make sense?
BEFORE RESET
Saturday,02,July,2016,22:29:48:56826
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN:    License Plate:
Mileage: 128315   Repair Order:
VCDS Release 15.7.4:  SRI Reset
Control Module Part Number: 8D0 920 980 B       Labels:  8D0-920-xxx-17.lbl
Component:B5-KOMBIINSTR. VDO D05 , Coding:16464
Operation: General Service Reset
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	1             	0
40       	Mileage since Service                             	miles x100	129           	---
41       	Time since Service                                	Days      	411           	---
42       	Min Mileage to Service                            	miles x1000	19            	---
43       	Max Mileage to Service                            	miles x1000	9             	---
44       	Max Time to Service                               	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	---       	---           	---
48       	Thermal Load                                      	---       	---           	---
Address 17:8D0 920 980 B  channel 2 adapted from 1 to 00000
AFTER RESET
Saturday,02,July,2016,22:33:19:56826
VIN:    License Plate:
02       	Service Reminder Status                           	          	0             	---
40       	Mileage since Service                             	miles x100	0             	---
41       	Time since Service                                	Days      	0             	---
My car service manual states that there are two types of service intervals:-
Standard Servicing = 12 months or 10,000m
Long Life Servicing = 24 months or sooner according to driving style.
For Long Life servicing one has to use VW 503 01 spec oil. I am using VW 504.00 spec which supercedes VW 503 01.
The oil quality according to VCDS is currently set at 1. I am not sure if this is correct?
The following link gives an example of typical servicing options:-
http://wiki.ross-tech.com/wiki/index.php/SRI_Reset_Procedure
I only have one option in the drop down menu on this screen and that is for a General Service Reset.
Just in case required, I have also attached the latest auto scan:-
Saturday,02,July,2016,22:20:49:56826
VIN:    License Plate:
Chassis Type: XX (8D - Audi A4/S4/RS4 B5 (1995 > 2001))
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: XXXXXXXXXXXXXXXXX
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 8D0 907 551 D
   Component: 2.7l V6/5VT     G   0002
   Coding: 05711
   Shop #: WSC 00237
   VCID: 2B5523B1D9D8CA66FB-5124
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 8D0 907 389 E
   Component: ABS/ESP allrad      D36
   Coding: 04395
   Shop #: WSC 06435
   VCID: 356105C90F9C8C969D-5142
Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
   Part No: 8D0 820 043 P
   Component: A4     KLIMAAUTOMAT D56
   Coding: 00061
   Shop #: WSC 06325
   VCID: 2D512DA9E7CCC456E5-25A6
Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
   Part No: 8D0 959 655 F
   Component: Airbag Front+Kopf  0001
   Coding: 01306
   Shop #: WSC 06325
   VCID: 397909F9238468F679-5142
Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
   Part No: 8D0 920 980 B
   Component: B5-KOMBIINSTR. VDO D05
   Coding: 16464
   VCID: 2A5B26B5D622D36E00-5124
   XXXXXXXXXXXXXXXXX     AUZ7Z0X1144259
Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
   Part No: 8D0 862 257 E
   Component: CV-Pump, Alarm, RC  D13
   Coding: 14190
   Shop #: WSC 06325
   VCID: 2F6D37A1EDC0B646D7-4EEA
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
            35-00 -  -
            35-00 -  -
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
00955 - Key 1
            09-00 - Adaptation Limit Surpassed
Address 37: Navigation        Labels:
   VCID: 55A1A549ACDCAC967D-4AE8
   Note: Excessive Comm Errors
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00102
   Shop #: WSC 06325
   VCID: 60CF849DE09E593E1E-4B34
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D003
   Coding: 00012
   Shop #: WSC 06325
   VCID: 65C19589FFBC3C16ED-5142
Address 56: Radio        Labels: 4B0-035-192-RNSD-56.lbl
   Part No: 8D0 035 192 D
   Component: Radio              0004
   Coding: 00400
   Shop #: WSC 04760
   VCID: 2447C88DB406051E3A-4AE8
00852 - Loudspeaker(s); Front
            36-00 - Open Circuit
Address 76: Park Assist        Labels: 4B0-919-283.lbl
   Part No: 4B0 919 283
   Component: Parkingsystem A4 RDW D18
   Coding: 00114
   Shop #: WSC 06325
   VCID: 66C3928502BA370EE4-51B8
End-------------------------(Elapsed Time: 04:20)--------------------------
Many thanks
For Longlife on this car, I think you'd need to set the following:
45: 2
44: 730
43: 30
42: 15
But personally, I think it would be a mistake to go more than 10,000 miles or one year between oil changes, no matter the "quality" of the oil. In fact, in a car that I liked and intended to keep, I like to have the oil changed around 7500 miles.
golfi_vend
Tartu, Estonia
C?ID=195131
Actually while talking to heavy machinery guys, the longlife doesn't necessarily depend all on oil. It depends on the oil filter capacity. A 0.5l oilfilter vs. 3-4 liter can and will make a difference. Also there are 2 in some trucks.
About the oil change frequency, i remember reading a article about when changing the oil too frequent. The additives in oil which help to neutralize the remains of old oil can harm the engine internals when there isn't any old oil to neutralize. My oil change is 9.3k miles/15k km.
My 2 cents.
Klaus Ludwig
C?ID=227092
Keithuk
Thanks. Yes I had noticed.
Klaus Ludwig
C?ID=227092
Thanks!
If I did leave the settings as they are, I am not clear as to how the switch is made between Standard (fixed) servicing and Long Life (variable) servicing. I note that my maximum mileage setting (9,000m) is lower that my minimum mileage setting (19,000m). I suspect that these settings would have been made by an authorised Audi dealer when the car was fairly new. Could it be that this is to force selection of the maximum mileage setting - for Standard (fixed) servicing or is it likely to be an error? Could it be that the Long Life (variable) servicing is initiated by selecting oil quality 2 instead of 1?
dubTECH
Northern ireland
C?ID=104757
Can I ask why you feel the need for the long life servicing schedule??
Klaus Ludwig
C?ID=227092
dubTECH
I am considering options as per the service manual after just completing a service and I am using VW 504 00 spec oil which I understand is compatible with the Long Life service option.
I was told by the main Audi Dealer who I purchased the car from many years ago that it was on Long Life servicing, but now that I have VCDS I can see that it is not.
I may well leave it as is, but am still curious as to how things work and why my min max mileage settings are set as they are with the min higher than the max.
On that cluster, I believe it is primarily the Oil Quality channel that determines whether you're on Standard/Fixed or Long-Life/Flexible. However, the other channels should be adjusted to corresponding sensible values.
Yeah, that part doesn't make much sense to me.
Klaus Ludwig
C?ID=227092
:) Thanks - I'm glad it's not just me who is looking at my mileage service settings and questioning the logic - though perhaps there is some to someone! Well at least I am confident now that I am definitely not on Long Life servicing and I now have a much better idea of what to do if I want to go there.
Klaus Ludwig
C?ID=227092
dubTECH
Northern ireland
C?ID=104757
Hi Klaus, yes the reason I was asking is because at that time the car was built, I don't think they actually had the option of the QG1, I worked for VW at that time and the earliest I remember the mention of "longlife" would have been around 2002.
Unfortunately there are some plebs employed in main dealers who haven't a clue about the function of such intervals. I remember one time sending a friend into a dealership for a service and Haldex service, came out with a bill for a normal service..... I queried the Haldex issue to then be told yes sure it's ticked in the service book..... they then pointed at the cabin filter tick box!!!! If the technicians can't comprehend what a Haldex unit is, what makes you think they understand the difference between QG0 and QG1 PR codes. Lol
Klaus Ludwig
C?ID=227092
dubTECH
I have no connections to vehicle maintenance, but I do see your point. The Haldex story is scary. However, it may be that VAG LL servicing did in fact begin as early as 1999 as that is the date on the back page of the pdf document I posted a link to in my last message. However, there is no mention of an S4 in that document. My car was built in 1999 and first registered in 2000. On reflection LL servicing is probably not a good idea for an S4 driven enthusiastically - even if it was an option.
