Results 1 to 7 of 7
Thread: Audi 8K xenon retrofitting
    Romania
    Hello guys,
    A friend of mine wants to retrofit the factory halogen to xenon headlights. I check if the 09 Centr.electric supports this retrofit but it seems not. Also, not all bites/byts were documented. I'm asking you if, using the actual central electric is possible this retrofitting. Scan below:
    Friday,28,February,2014,02:29:40:56830
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WAUZZZ8K1BN021157   License Plate:
    Mileage: 103970km-64603mi   Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
    VIN: WAUZZZ8K1BN021157   Mileage: 103970km/64603miles
    Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
       Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
       Component: R4 2,0L EDC   H10 8441
       Revision: 11H10---
       Coding: 0104002C02072118
       Shop #: WSC 22151 143 999999
       ASAM Dataset: EV_ECM20TDI03L906022MK A01009
       ROD: EV_ECM20TDI03L906022C.rod
       VCID: 7AF007C1FD02A7CED53-802F
    4987 - Cylinder 4 Glow Plug Circuit (Q13)
              P0674 00 [096] - Electrical Fault
    Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
       Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
       Component: 0AW 20TDI RdW H06 0009
       Revision: --H06---    Serial number: 0000000701
       Coding: 000001
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_TCMVL381 A02017
       ROD: EV_TCMVL381.rod
       VCID: 77F61EF5CE10BAA6AAD-8022
    9827 - Clutch Pressure Adaptation
              P1741 00 [044] - Limit Reached
                        Fault Frequency: 10
                        Mileage: 103467 km
                        Date: 2014.01.31
                        Time: 08:28:28
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 BF    HW: 8K0 907 379 BF
       Component: ESP8 front    H04 0030
       Coding: 170500
       Shop #: WSC 02391 823 56573
       VCID: 7EF80BD1E92A8BEEE9B-802B
       Part No SW: 8K0 907 064 CA    HW: 8K0 907 064 CA
       Component: BCM2 2.0      H04 0430
       Coding: 010100
       Shop #: WSC 02399 823 56573
       VCID: 71E220EDA874E496649-8024
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H50 0071
       Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
       Component: KLIMA 1 ZONE  H08 0180
       Revision: A1000000    Serial number: 01250820100831
       Coding: 34100000
       VCID: 7DFA0CDDE42C90F6F01-8028
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H29 0392
       Revision: 10029001    Serial number: 00000000632588
       Coding: 690040B10134BE000001000300005F5F4F1C420802000001000000
       VCID: 3C7CC1D9BFB659FE87F-8069
       Component: WWS 200810  H06 0070
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
       Component: E1 - LDS  H08 0090
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51241024300227
       Coding: 100103
       VCID: 4796AE35F6700A261AD-8012
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GKD0K22TJ
       Coding: 30343435363030303030554A304C384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 448CB939CF46213EFFF-8011
       Serial number: 6334MSME563322598
       Serial number: 6344MSME56332746A
       Serial number: 6352QSME386F0B0EY
       Serial number: 6362QSME16692802C
       Serial number: 63732SME076C2804
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME6D5F37107
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90315JI3000AU
       Coding: 000016
       VCID: 3D7ACCDDA4AC50F6B01-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 930 N    HW: 8K0 920 930 N
       Component: KOMBIINSTR.   H22 0258
       Revision: 00000000    Serial number: EJC56ZP8A
       Coding: 0F37080002000008000001
       VCID: 3874DDC98B8E75DE637-806D
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E10816812D
       Coding: 00C303
       VCID: 830EFA2502C86606065-80D6
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
       Component: TSG FA        H08 1401
       Coding: 011C02204000410001
       Shop #: WSC 10101 599 00000
       VCID: 53AE8A653228B686765-8006
       Revision: 00002001    Serial number: 0133106253
       Coding: 0100062000B900808120013280000000
       Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
       Component: TSG BF        H08 1401
       Coding: 011C02204C00410001
       VCID: 52A08F610D32BF8E7D3-8007
       Revision: 00000003    Serial number: 10000000596824
       VCID: 346CE9F997E691BE4FF-8061
       Part No SW: 4G0 035 053     HW: 4G0 035 053
       Component: Radio U Basic H51 0051
       Revision: AB001007    Serial number: 496I00A7550337
       Coding: 010003020100000001
       VCID: DBBEE245DAF8FEC62E5-808E
       Part No SW: 8T1 035 654 F    HW: 8T1 035 654 D
       Component: B-BNT-EU      H58 0144
       Revision: --------    Serial number: 324G/0A7515696
       Coding: 01010000030681ED01000F0E000000030000
       VCID: 3A70C7C1B58267CE953-806F
       Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
       Component: DU6 Basic  H42 0084
       Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
       Component: E0380 Bedient  H08 0100
       Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
       Component: TSG HL        H06 1401
       Coding: 010C02204000210001
       VCID: 56A8737121DAA3AE91B-8003
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H06 1401
    Slovenia - Kranj
    Welcome
    You'll have to replace bcm1 which controls the lights, because they will not be part of the high beam. Each car has no factory built-in extra pin. Original bcm unit you must activate the car to an authorized service center
  3. Likes Uwe liked this post
    Romania
    Ok. I got it. Thanks you very much. Why I have to go to an authorized service? As far as I known the BCM is not pin protected. I assume if I have the BCM I can mounted my self, I'm correct or not?
    Slovenia - Kranj
    bcm heave component protection and unlock only authorized service
    United States
    Hi dules!
    pronet I agree, most of the modules in a 8K/8T/8R Audi have Component Protection so a new BCM1 controller would need to be unlocked via SVM.
    -Dana
    Romania
    Ok. Thanks Dana. What does SVM stand for?
    Lansdale, PA
    software version management
