Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 114
Thread: 07 GTI Won't Start. Turns over and fires a couple times
  1. #21
    Auto Up/Down windows just need to be re-synched.
    From the driver's door:
    1) Run a window all the way down. Continue to hold the switch in the down position for a 3-count. Release, and press down for another 3-count.
    2) Run the window all the way up. Continue to hold the switch in the up position for a 3-count. Release, and press up for another 3-count.
    You may need to repeat this a couple of times.
    Once you get one working properly, repeat for the other window(s).
  2. Likes PetrolDave liked this post
  3. #22
    Verified VCDS User GTIF's Avatar
    Jun 2016
    San Diego USA
    Passenger side worked when I got in the car today. I must have run it more times than the driver side. That did it for the driver side. Thanks. Now should I try to clear the codes to see what it's still putting out?
  4. #23
    Quote Originally Posted by GTIF View Post
    I would.
  5. #24
    Does this car run now?
  6. Likes ivagp liked this post
  7. #25
    Jun 2016
    San Diego USA
    Still no start. Unable to clear all DTCs. It says Professional Grade interface required for this function.
  8. #26
    With a Micro-CAN, you need to go to each control module that has fault codes and clear them there.
  9. Likes Jack@European_Parts liked this post
  10. #27
    Jun 2016
    San Diego USA
    Deleted all the codes and the car almost starts! It turns over and fires multiple times but won't continue enough to run. It certainly sounds a whole lot closer to running than it did though. What next? Here's the new code readout:
    Wednesday,31,August,2016,16:32:53:50930
    VCDS Version: 16.8.0.3 (x64)
    Data version: 20160803 DS255
    VIN: WVWFV71K37W1XXXX   License Plate:
    Mileage: 333150km-207009mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
    VIN: WVWFV71K37W166153   Mileage: 333150km-207009miles
    Address 01: Engine        Labels: 06F-907-115-AXX.clb
       Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
       Revision: 5BH15---    Serial number: VWZ7Z0G8013765
       Coding: 0403010A1C070160
       Shop #: WSC 01279 067 57207
       VCID: 2B7BF8198AC3C21A25-807E
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - Intermittent
                        Mileage: 333157 km
                        Time: 04:15:41
                        Temperature: 33.0C
                        Temperature: 39.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 12.192 V
    000801 - Engine Speed Sensor (G28)
                   P0321 - 001 - Implausible Signal
                        Fault Status: 01100001
                        Mileage: 333157 km
                        Time: 04:26:20
                        RPM: 179 /min
                        Load: 31.4 %
                        Temperature: 33.0C
                        Temperature: 39.0C
                        Voltage: 10.541 V
    Readiness: 0110 0101
       Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
       Component: GSG DSG         070 1306
       Revision: 04607000    Serial number: 00000612040951
       Shop #: WSC 01279 785 00200
       VCID: 2265153DFD09035296-8076
       Revision: 00H11001
       Coding: 0021122
       VCID: 73CB20791273DADAAD-8026
       Part No: 1K0 820 047 GS
       Component: Climatic PQ35   120 0606
       VCID: 7BDB08593A23929AF5-802E
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000006559540
       Coding: 178D8F214004150047140000001400000028770B5C0001
       Shop #: WSC 22580 444 57677
       VCID: 6CF93B054F4D05226C-8038
       Component: Wischer 201206 020  0501
       Coding: 00038805
       Shop #: WSC 22580
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7F0024301
       VCID: 2E7DF10DB9D1B73202-807A
                        Reset counter: 253
                        Mileage: 333157 km
                        Time: 04:18:46
    02788 - Internal Communications Error
                        Reset counter: 253
                        Mileage: 333157 km
                        Time: 04:29:38
                        Bin. Bits: 00000000
                        Bin. Bits: 00000001
       Component: 5L AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D07R6RE
       Coding: 0013644
       Shop #: WSC 01269 785 00200
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME151A07522
       Subsystem 3 - Serial number: 6342MSME156A6B6EV
       Subsystem 4 - Serial number: 6352QSME1C76133DN
       Subsystem 5 - Serial number: 6362QSME1E183E4D-
       Subsystem 6 - Serial number: 63727SME0B640C2E9
       Subsystem 7 - Serial number: 63827SME0B771B200
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    00591 - Seat Belt Switch; Driver (E24)
       Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
       Component: J0527           636 0070
       Coding: 0012122
       VCID: 77D31469060BB6FA91-8022
       Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
       Component: KOMBIINSTRUMENT VDD 1610
       Revision: V0003000    Serial number: VWZ7Z0G8013765
       Coding: 0007207
       Shop #: WSC 22580 444 53700
       VCID: 3147EA71A8EFA8CA1F-8064
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 070107F1001226
       Coding: 7F8F03600F000000
       VCID: 2F43EC09BEDBBE3A09-807A
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T1QSF03
       VCID: 7DDF064124379CAACB-8028
       Component: IMMO            VDD 1610
       Component: Tuer-SG         005 0983
       Coding: 0001077
       VCID: 3851D7554B95798258-806C
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.074 H07 1806
       Shop #: WSC 00000 028 00001
       VCID: 3449E36557FD9DE274-8060
       Component:    KSG PQ35 RDK 052 0218
       Coding: 139006885103281B0904058FB0080A04889C00
       Shop #: WSC 22580 444 999999
       VCID: 042973A547DDED6284-8050
       Coding: 0001076
       VCID: 3957D251709F608AA7-806C
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74C92365177DDDE2B4-8020
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio PM6       017 0023
       Revision: 00017000    Serial number: VWZ5Z7F2121101
       Coding: 0040401
       VCID: 24691325E71D0D62E4-8070
       Component:    RDK              0440
       Coding: 0100101
    End-------------------------(Elapsed Time: 01:10)--------------------------
    Good Thing It's Fast! '07 GTI Fahrenheit
  11. #28
    Looks like MAF and G28 are suspect change G28 first to see if you hit the lotto.
  12. Likes Uwe liked this post
  13. #29
    Jun 2016
    San Diego USA
    That was replaced. Do you think I got a bad one?
  14. #30
    Yup or installed with incorrect air gap from wrong part, or not installed properly for being seated causing FOD.
