Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 114
Thread: 07 GTI Won't Start. Turns over and fires a couple times
    Verified VCDS User GTIF's Avatar
    Jun 2016
    San Diego USA
    Hi, new to the forum and to computer controlled VWs. Background: I bought this 2007 GTI not running. PO said it just quit at a light and that was it. It sat for 9 months with no battery. I bought a battery and I started doing research and checking things. I replaced the spark plugs, crank sensor, cam sensor, and HPFP cam follower. Ran compression test, checked good. 130ish on all 4 (207K miles). Changed oil, new filter, checked for spark and fuel pressure, checked fuses, cleaned the MAF. No obvious cracks in intake tubes. Engine cranks and fires a couple times then nothing, just keeps cranking. Same results with starter fluid. OBDII codes wouldn't read so I bought a VCDS from Ross-Tech. The output tells me MAF, intake leak, or bad injectors (or all 3!). I will check the MAF with my multi meter tonight. Any thoughts?
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
    VIN: WVWFV71K37W16XXXX   Mileage: 333150km-207009miles
    Address 01: Engine        Labels: 06F-907-115-AXX.clb
       Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
       Revision: 5BH15---    Serial number: VWZ7Z0G8013765
       Coding: 0403010A1C070160
       Shop #: WSC 01279 067 57207
       VCID: 2B7BF8198AC3C266FB-807E
                   P0300 - 008 -  - Intermittent
                        Fault Status: 00111000
                        Mileage: 332939 km
                        Time: 19:57:33
                        RPM: 889 /min
                        Load: 25.5 %
                        Temperature: 86.0C
                        Temperature: 65.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.081 V
    008583 - Bank 1; System too Lean at Idle
                   P2187 - 004 -  - Intermittent
                        Fault Status: 00110100
                        Mileage: 333058 km
                        Time: 05:03:23
                        RPM: 1050 /min
                        Load: 15.3 %
                        Speed: 6.0 km/h
                        Temperature: 78.0C
                        Temperature: 57.0C
                        Voltage: 12.954 V
    008825 - Leak in Air Intake System
                   P2279 - 002 -  - Intermittent
                        Fault Status: 00110010
                        Mileage: 333058 km
                        Time: 05:03:36
                        RPM: 895 /min
                        Load: 15.7 %
                        Temperature: 78.0C
                        Temperature: 58.0C
                        Voltage: 12.954 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - Intermittent
                        Mileage: 333157 km
                        Load: 0.0 %
                        Temperature: 27.0C
                        Temperature: 28.0C
                        Voltage: 12.192 V
    Readiness: 0110 0101
    Address 02: Auto Trans        Labels: 02E-927-770.lbl
       Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
       Component: GSG DSG         070 1306
       Revision: 04607000    Serial number: 00000612040951
       Shop #: WSC 01279 785 00200
       VCID: 2265153DFD09032E48-8076
    18243 - Pressure Control Valve 5 (N233)
                P1835 - 000 - Short to Plus - Intermittent
                        Fault Frequency: 255
                        Reset counter: 8
                        Mileage: 308178 km
    19143 - Unexpected / Implausible Mechanical Gear Disengagement
                P2711 - 005 -  - Intermittent
                        Fault Status: 00100101
                        Reset counter: 37
                        Mileage: 312318 km
       Revision: 00H11001
       Coding: 0021122
       VCID: 73CB20791273DAA673-8026
       Part No: 1K0 820 047 GS
       VCID: 7BDB08593A2392E62B-802E
    00532 - Supply Voltage B+
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Revision: 00H52000    Serial number: 00000006559540
       Coding: 178D8F214004150047140000001400000028770B5C0001
       Shop #: WSC 22580 444 57677
       VCID: 6CF93B054F4D055EB2-8038
       Component: Wischer 201206 020  0501
       Coding: 00038805
       Shop #: WSC 22580
                        Fault Frequency: 6
                        Reset counter: 38
                        Mileage: 333157 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 8.90 V
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7F0024301
       VCID: 2E7DF10DB9D1B74EDC-807A
                        Reset counter: 38
                        Mileage: 333157 km
                        Time: 06:17:28
                        Voltage: 8.30 V
                        Reset counter: 38
                        Mileage: 333157 km
                        Time: 00:03:47
                        Voltage: 8.40 V
                000 -  -
                        Reset counter: 216
                        Mileage: 105914 km
                        Time: 13:42:53
    02788 - Internal Communications Error
                000 -  -
                        Reset counter: 253
                        Mileage: 333157 km
                        Time: 19:11:35
                        Bin. Bits: 00000000
                        Bin. Bits: 00000001
    01304 - Radio
                        Reset counter: 38
                        Mileage: 333157 km
                        Time: 00:01:34
       Component: 5L AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D07R6RE
       Coding: 0013644
       Shop #: WSC 01269 785 00200
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME151A07522
       Subsystem 3 - Serial number: 6342MSME156A6B6EV
       Subsystem 4 - Serial number: 6352QSME1C76133DN
       Subsystem 5 - Serial number: 6362QSME1E183E4D-
       Subsystem 6 - Serial number: 63727SME0B640C2E9
       Subsystem 7 - Serial number: 63827SME0B771B200
    00591 - Seat Belt Switch; Driver (E24)
                010 - Open or Short to Plus - Intermittent - MIL ON
    02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
                003 - Mechanical Failure - Intermittent - MIL ON
                008 - Implausible Signal - Intermittent - MIL ON
                002 - Lower Limit Exceeded - Intermittent - MIL ON
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
       Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
       Component: J0527           636 0070
       Coding: 0012122
       VCID: 77D31469060BB6864F-8022
       Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
       Revision: V0003000    Serial number: VWZ7Z0G8013765
       Coding: 0007207
       Shop #: WSC 22580 444 53700
       VCID: 3147EA71A8EFA8B6C1-8064
    9 Faults Found:
                        Reset counter: 38
                        Mileage: 333157 km
                        Time: 00:03:21
    00771 - Fuel Level Sensor (G)
                        Fault Status: 00101010
                        Fault Frequency: 9
                        Reset counter: 38
                        Mileage: 332184 km
                        Time: 06:09:43
                        Reset counter: 38
                        Mileage: 333157 km
                        Time: 00:04:17
                        Reset counter: 38
    01316 - ABS Control Module
                        Reset counter: 38
                        Reset counter: 38
                        Reset counter: 38
                        Reset counter: 38
                        Fault Frequency: 9
                        Reset counter: 38
                        Mileage: 332184 km
                        Time: 06:09:43
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 070107F1001226
       Coding: 7F8F03600F000000
       VCID: 2F43EC09BEDBBE46D7-807A
                        Reset counter: 37
                        Mileage: 333157 km
                        Time: 00:04:17
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T1QSF03
       VCID: 7DDF064124379CD615-8028
       Component: IMMO            VDD 1610
    01176 - Key
       Component: Tuer-SG         005 0983
       Coding: 0001077
       VCID: 3851D7554B9579FE86-806C
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
    01552 - Motor for Central Locking; Drivers Door (V56); Lock
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.074 H07 1806
       Shop #: WSC 00000 028 00001
       VCID: 3449E36557FD9D9EAA-8060
                        Mileage: 333150 km
                        Temperature: 17.0C
                        Voltage: 6.00 V
                        Voltage: 5.80 V
                000 -  -
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Component:    KSG PQ35 RDK 052 0218
       Coding: 139006885103281B0904058FB0080A04889C00
       Shop #: WSC 22580 444 999999
       VCID: 042973A547DDED1E5A-8050
                000 -  -  - Intermittent
                        Fault Frequency: 61
                        Reset counter: 38
                        Mileage: 330689 km
                        Time: 04:39:02
                        Fault Frequency: 6
                        Reset counter: 38
                        Mileage: 333157 km
                        Time: 00:04:16
       Coding: 0001076
       VCID: 3957D251709F60F679-806C
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74C92365177DDD9E6A-8020
    00070 - Starting Battery Voltage
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio PM6       017 0023
       Revision: 00017000    Serial number: VWZ5Z7F2121101
       Coding: 0040401
       VCID: 24691325E71D0D1E3A-8070
                        Fault Frequency: 7
                        Reset counter: 37
                        Mileage: 333157 km
                        Time: 09:00:23
       Component:    RDK              0440
       Coding: 0100101
    End-------------------------(Elapsed Time: 01:16)--------------------------
    Last edited by GTIF; 06-29-2016 at 03:05 PM. Reason: still getting this code wrap thing worked out
    Good Thing It's Fast! '07 GTI Fahrenheit
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #2
    Verified VCDS User Gavra's Avatar
    Mar 2015
    Melbourne/Belgrade
    Put new fuel,fuel filter and when it start give some revs up and keep it there for 3-5min. After erase DTC and run again with new auto-scan .
  4. Likes GTIF liked this post
  5. #3
    HQ
    130 PSI compression seems a bit low to me, generally we'd like to see +160 PSI. Having said that, I'd expect the engine to still run.
    Pull the plugs up, crank... any fuel poofing out?
    Jef
  6. Likes GTIF liked this post
  7. #4
    Add oil to cylinders and see if compression comes up.
    Check fuel PSI and volume delivery from HPP and to it.
    Check or soak/clean fuel injectors and check spray pattern if possible.
    Check intake and PCV for leaks as well as a stuck N80 dumping fuel resulting in washing cylinders/rings.
  8. Likes GTIF liked this post
  9. #5
    Jun 2016
    San Diego USA
    All good advice. Thanks. Now to decide which to do first. Before putting in new plugs, I pulled the old ones after trying to start and checked color and condition. One was wet, two were a little moist, and one was pretty dry. All were a dark brown color, typical of burning oil. I did not see any "poof" of fuel out the coil holes when turning it over to check the plugs, but I wasn't really looking for it either. I picked up a new fuel filter today.
  10. #6
    Jun 2016
    San Diego USA
    I decided to empty the fuel tank first. My siphon pump tube won't go down the fuel filler tube enough. Is there another easy way to drain the tank? Is 9 month old gas already bad enough to make the engine not start? It doesn't smell like old gas.
  11. #7
    Run fuel output hose at sender to fuel collection tank and run the pump manually. Add your own additional hose to extend from lift pump.
  12. Likes Eric, GTIF liked this post
  13. #8
    Jun 2016
    San Diego USA
    Sounds simple enough. When you say manually, you mean run a 12v lead directly to the tank pump? I tested the MAF yesterday by putting my multimeter on ohms across the connector pins and got no readings. Should they be open or show resistance?
    Emptied the gas tank. New filter and fresh 91 octane and no change. I'll start looking at the PCV and N80 and checking out the injectors by listening for pulse, then if necessary, pulling them and cleaning them.
  14. #9
    Jun 2016
    San Diego USA
    I pulled the PCV and it flows both ways freely. I assume it should shut on one direction. I'm going to get a spark tester (OTC 6589) and check the coils again. Maybe they're weak but showed spark. Can't get to it for a couple weeks though.
  15. #10
    Jul 2014
    dont strain ur brain. ur compression is way to lo. when u checked comp was the battery charged if not charge battery and retest. like jack said add oil just a few drops should do. if you put to much oil u can damage the engine
