Results 1 to 6 of 6
Thread: 2007 Audi Q7 New Member
    Jun 2016
    Hey just wondering if anyone knows how to eliminate the warning beep from automatic wipers/ automatic headlights defective that goes off every couple minutes while driving. I dont really want to fix this just wondering if anyone knows how to eliminate the beeping from VAGCOM.
    Also If anyone has any free time and would like to tell me what is going on with my Q7 on any of the faults that I have I would really appreciate it!
    Here is my scan
    Monday,20,June,2016,02:04:08:18403
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WA1AY74L57D029677   License Plate:
    Mileage: 163530km-101612mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 42 46 47 4F 52 56 61
              62 65 6F 72
    VIN: WA1AY74L57D029677   Mileage: 163530km-101612miles
    Address 01: Engine        Labels: 03H-907-309-V1.clb
       Part No SW: 03H 906 032 L    HW: 03H 906 032 G
       Component: Q7 3.6-FSI-LEV2 G00 9970
       Revision: --H03---    Serial number:
       Coding: 0001175
       Shop #: WSC 31414 790 00001
       VCID: 2B5569678A42D366FB-807E
    005241 - Brake Boost Vacuum System
                   P1479 - 008 - Mechanical Failure
                        Mileage: 157136 km
                        Date: 2016.03.10
                        Time: 16:14:29
                        RPM: 796 /min
                        Load: 48.2 %
                        Temperature: 86.0°C
                        Temperature: 62.0°C
                        Absolute Pres.: 910.0 mbar
                        Voltage: 13.208 V
       Part No SW: 4L0 910 156 A    HW: 0AT 927 156
       Component: AG6 0AT 3,6 FSI USA 0040
       Revision: --H01---    Serial number:        4001476
       VCID: 275D955796AAF7061F-8072
    Address 03: ABS Brakes        Labels: 4L0-910-517-V1.clb
       Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
       Component: ESP ALLRAD MK25E1   0130
       Revision: 00H21001
       Coding: 0017425
       VCID: 285F966B9BB4F87E16-807C
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H31 0210
       Revision: 27120501    Serial number: 10601000478940
       Coding: 0000139
       Shop #: WSC 05142 444 83694
       VCID: 63C5C147A2125B2603-8036
       Subsystem 1 - Part No: 4F0 910 131 J
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head        Labels: Redir Fail!
       Part No SW: 4L0 910 730 C    HW: 4L0 035 730 C
       Component: MMI Cockpit     H80 0370
       Revision: C61120EU    Serial number: AUZ6Z3FC9H02L2
       Coding: 0455222
       Component: E0380 BedienteilH01 0050
       Subsystem 2 - Serial number: 00000000428196
       Subsystem 3 - Serial number: 0129.05.060000000100010723ÿ
       Subsystem 4 - Serial number: 010723ÿ
    01964 - Control Module for Seat & Steering Column Memory (J136)
                        Reset counter: 1
                        Mileage: 157135 km
                        Date: 2016.03.10
                        Time: 14:04:14
                000 -  -  - Intermittent
                        Fault Frequency: 98
                        Mileage: 157218 km
                        Date: 2016.03.11
                        Time: 06:21:03
       Part No SW: 4L0 910 043     HW: 4L0 820 043 F
       Revision: 00---008    Serial number: 00000000046402
       Coding: 0524326
       VCID: 61C9CB4FB80E493611-8034
                        Fault Status: 00100011
                        Reset counter: 22
                        Mileage: 158493 km
                        Date: 2016.03.25
                        Time: 15:55:48
                        Voltage: 14.20 V
                        Temperature: 29.0°C
                        (no units): 160.0
                        (no units): 148.0
                        Temperature: 27.0°C
    01844 - Control Module for Fresh Air Blower (J126)
                001 - Upper Limit Exceeded
                        Fault Status: 01100001
                        Reset counter: 239
                        Mileage: 162485 km
                        Date: 2016.06.01
                        Time: 13:07:10
                        Temperature: 50.0°C
                        Speed: 47.0 km/h
                        (no units): 0.0
                        (no units): 67.0
    01273 - Fresh Air Blower (V2)
                        Fault Status: 00101001
                        Fault Frequency: 43
                        Reset counter: 24
                        Mileage: 162562 km
                        Date: 2016.06.02
                        Time: 16:53:14
                        Temperature: 46.0°C
                        Speed: 1.0 km/h
                        (no units): 0.0
                        (no units): 67.0
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Coding: 0010103
       VCID: 31697B0FA86EB9B6C1-8064
       Component: Wischer AU716   H12 0080
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                        Fault Status: 00100111
                        Reset counter: 19
                        Mileage: 162492 km
                        Date: 2016.06.01
                        Time: 13:55:00
                        Fault Status: 01100101
                        Reset counter: 239
                        Mileage: 157048 km
                        Date: 2016.03.08
                        Time: 16:11:00
    02382 - Sensor for Light Detection (G399)
                        Fault Status: 00101110
                        Reset counter: 24
                        Mileage: 157048 km
                        Date: 2016.03.08
                        Time: 16:17:00
    01024 - Rain Sensor (G213)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 239
                        Mileage: 157048 km
                        Date: 2016.03.08
                        Time: 16:11:00
    Address 0E: Media Player 1        Labels: None
       Coding: 0455222
       Component: 73 AIRBAG AUDI8RH39 0210
       Revision: 03H39000    Serial number: 0038QD030X77
       Coding: 0014131
       Subsystem 1 - Part No: 4L0 910 339
       Component: BF-Gewichtsens. H02 0020
       Subsystem 2 - Serial number: 6332QSME114622090
       Subsystem 3 - Serial number: 6342QSME0F56211FL
       Subsystem 4 - Serial number: 6352QSME0E487961Q
       Subsystem 5 - Serial number: 6362QSME11390E118
       Subsystem 6 - Serial number: 63734SME0E3C54578
       Subsystem 7 - Serial number: 63834SME0E2E250FB
       Revision: 00H08000    Serial number: 90054061670022
       Coding: 0002022
       VCID: 66C3D85351202E0EE4-8032
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 900 C    HW: 4L0 920 950 B
       Component: KOMBIINSTR. M73 H11 0240
       Revision: 00200000    Serial number: 4ZS12NR66
       Coding: 0531203
       VCID: 204F8E4BF384003E5E-8074
    Address 19: CAN Gateway        Labels: 4L0-910-468.clb
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B0661680D6
       Coding: E5579E57700202
       VCID: 6CD7AA7B4FCC145EB2-8038
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4L0 910 111 A    HW: 4L0 035 111
       Component: CD-Changer      H41 0100
       Revision: 00000000    Serial number: AUZ5ZBF3026596
       VCID: 1E33B0B3C9F036CE6C-804A
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00-00000
       Coding: 0035403
       VCID: 2F6D7D77BE5AAF46D7-807A
    Address 46: Central Conv.        Labels: 4L0-910-289.lbl
       Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
       Component: Komfortgeraet   H05 0020
       Revision: 0020 ---    Serial number: 01015208390000
       Coding: 4487325
    Address 47: Sound System        Labels: 4F0-910-7xx-47.lbl
       Coding: 0455222
                        Reset counter: 239
                        Mileage: 157135 km
                        Date: 2016.03.10
                        Time: 13:33:31
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000029201
       Coding: 0012001
       VCID: 5EB3F0B3897076CE2C-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00-00000
       Coding: 0035403
    Address 56: Radio        Labels: None
       Coding: 0455222
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000027139
       Shop #: WSC 97000 444 57541
       VCID: 64C7C25BA71C5C1EFA-8030
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  2606010130
       Coding: 344630393135313035432056413032363036303130313330
                        Fault Frequency: 27
                        Mileage: 157278 km
                        Date: 2016.03.11
                        Time: 21:34:29
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Coding: 0035338
       Revision: 00050100    Serial number: 00000900024452
       Coding: 0062424
       VCID: 224B8443FD88122E48-8076
    Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
       Part No HW: 4L0 907 290 A
       Component: MDECKEL3 NO RESPONS
       Revision: AAH05044    Serial number: 001746406-----
       Coding: 0003599
       VCID: 55A1EF9FFC46B5967D-8000
       Component: J_245_EE14_SKB09H10 0160
       Component: J_394_EE14_SKB09H10 0160
    02906 - Control Module for Sliding Roof; Rear (J392)
                        Reset counter: 239
                        Mileage: 163161 km
                        Date: 2016.06.12
                        Time: 20:59:21
                        Reset counter: 239
                        Mileage: 163161 km
                        Date: 2016.06.12
                        Time: 20:59:21
    02907 - Control Module for Roof Shade (J394)
                        Reset counter: 9
                        Mileage: 163243 km
                        Date: 2016.06.14
                        Time: 01:34:25
                        Reset counter: 239
                        Mileage: 163161 km
                        Date: 2016.06.12
                        Time: 20:59:21
                        Reset counter: 24
                        Mileage: 163531 km
                        Date: 2016.06.20
                        Time: 01:20:57
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Coding: 0035338
    End-------------------------(Elapsed Time: 02:20)--------------------------
    Jun 2016
    Anyone got anything on this ?
    It would be better to fix the issue's and empty the water from the truck............get a bucket.
  4. Likes MartinsX liked this post
    Jun 2016
    USA (Alabama)
    Hello Shipitcity....I too have a 2007 Audi Q7 with wiring issues, so I share your pain. So the "beeping" is because the auto-wipers & headlights are not operating properly? I see in the scan that Energy Management has been activated also.
  6. Likes Jack@European_Parts liked this post
    Sep 2016
    Riga, Latvia
    Quote Originally Posted by flat12 View Post
    Each car is individual. A simple rule works here: Your full autoscan and descriptions of problems - other forum members comments and suggestions. Reason why one car have some warning lights and audible warnings on could be completely different from another car doing the same.
  8. Likes Jack@European_Parts liked this post
  9. #6
    Jun 2016
    USA (Alabama)
    Hello MartinsX...I understand that each car should be treated individually. I already have a thread going for my issues, I should have stated that in my post - sorry. I was simply asking this forum member about the source of the "beeping".....
