Results 1 to 2 of 2
Thread: VW Crafter AdBlue MSB/Adaptation
    Jan 2015
    Slovenia
    I have a VW Crafter 2010 2.5 TDI with AdBlue fault on the dash. Probably the AdBlue just ran out, but after filling it's still there.There is no good support in Measuring Blocks and/or Adaptation.
    Does anyone have any info on which Measuring Blocks should I look, and where can I reset SCR/AdBlue stuff?
    Tuesday,28,June,2016,07:43:57:09308
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WV1ZZZ2EZB6012704   License Plate: CRAFTER-ADBLUE
    Chassis Type: 2E (2E - VW Crafter (LT3 / 2006 >))
              B0 B1 B2 B3 B4 B5 B6 C1
    Address 01: Engine (CEC)       Labels: Redir Fail!
       Part No SW: 076 906 022 P    HW: 076 906 022 G
       Component: R5 2,5L EDC A020SG  9022
       Revision: 24H37---    Serial number: VWXDZ0J1026241
       Coding: 0003072
       Shop #: WSC 07128 298 81854
       VCID: 204FE394F0E7BF3E5E-5106
    Readiness: 0 3 0 0 1
    Address 91: LT3 Engine        Labels: Redir Fail!
       Coding: 0003072
       VCID: 204FE394F3E7BF3E5E-8074
    Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
       Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
       Component: IMMO          0805  0815
       Revision: 00805000    Serial number: VWXDZ0J1026241
       VCID: 6DD1CAA074B5A256A5-8038
    Address 94: LT3 Airbag        Labels: None
       Part No HW: 9064461442
       Shop #: WSC 00117 555 00000
       ASAM Dataset: 3 3332
       ROD: CRFT_AB_3_3332.rod (*)
       VCID: 55A1824034250A967D-8000
    8 Faults Found:
    9003 - Supply voltage: Lower limit not reached
                Test Complete - Stored
    9195 - CAN info: Signal "Left-hand drive (LHD)/Right-hand drive (RHD)" not received
    9193 - CAN info: Signal "Country-specific Special Equipment" not received
    9196 - CAN info: Signal "Body" not received
    9197 - CAN info: Signal "Engine" not received
    9194 - CAN info: Signal "Model Series" not received
    9181 - CAN info: Signal "Terminal Status" not received
    9600 - Airbag control module (J234): Internal malfunction
    Address 95: LT3 ESP        Labels: None
       Part No SW: 9069022800    HW: 0004460153
       ASAM Dataset: 3 4101
       ROD: CRFT_ESP_3_4101.rod (*)
       VCID: 04078F048F3F431E5A-8050
    Address 96: LT3 Instruments        Labels: None
       Part No SW: 9069026400    HW: 9069011800
       ASAM Dataset: 32 787
       ROD: CRFT_KOMBI_32_787.rod (*)
    Address 99: LT3 Ign. Switch        Labels: None
       Part No HW: 9065455808
       ASAM Dataset: 67 257
       ROD: CRFT_EZS_67_257.rod (*)
    Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
       Component: HF-FFB        0805  0815
       Revision: 00805000    Serial number: 12345678901234
    Address 9B: LT3 Driver Door        Labels: None
       Part No HW: 9068205626
       ASAM Dataset: 33 260
       ROD: CRFT_FTUHR_33_260.rod
    900A - Driver's heated mirror: Short to Plus
                Test Complete - Active/Stored
    Address 9C: LT3 HVAC        Labels: None
       Part No SW: 2514450200    HW: 9068300885
       ASAM Dataset: 21 2
       ROD: CRFT_KLIMA_21_2.rod (*)
       VCID: 77FDE8C8CEE918864F-8022
    Address B4: LT3 Central Elec.        Labels: None
       Part No SW: 9069027500    HW: 9069011400
       ASAM Dataset: 33 548
       ROD: CRFT_EZE_33_548.rod (*)
       VCID: 0603950CB903710E44-8052
    901D - License plate lights/side-marker lights: Open circuit
    9042 - Front Interior Light (W1): Short to Plus
    9001 - Bulb for Left Parking Lamp (M1): Short to Plus
    90B5 - Control module: Faulty
    Address B6: LT3 Steering Wheel        Labels: None
       Part No SW: 9065402345    HW: 9065402345
       ASAM Dataset: 72 257
       ROD: CRFT_SML_72_257.rod (*)
    End-------------------------(Elapsed Time: 02:48)--------------------------
    Controller Maps: https://cloud.txt.si/index.php/s/iTgNcFPigzcOKZj
    Thanks in advance
    Nov 2015
    Czech Republic
    Hi, try MVB 172 Temperature field3, amount field 4
