Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Vw golf mk5 2007 1.6 fsi limp mode
    Jun 2016
    Hi guys, i have problem problem whit my golf, i bought vag com to sort out the problem, but apparentlly it doesnt help.
    So when the engine is cold its drives fine, but just reach temperature 50-90 degress it losing power, and the engine sounds weird then accelerate.
    Scan whit vag com no fault found and no warning lights on the dash board... my mechanic doesn't have any ideas as well. My mechanic doesn't have any ideas as well.
    Maybe someone has this problem before? I do appreciate for any help! Thank you
    Please post an Auto-Scan so people can see exactly what ECU this vehicle has, what software that ECU has in it, plus the rest of the car in full context.
    Jun 2016
    Thanks for reply mate.
    Please see log below.
    Thursday,23,June,2016,19:54:12:44543
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WVWZZZ1KZ8P008906   License Plate: LY07SPU
    Mileage: 162910km-101227mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ8P008906   Mileage: 162910km-101227miles
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 EM    HW: 03C 906 056 T
       Component: MED9.5.10       G00 1179
       Revision: 66H09---    Serial number: VWX7Z0G53ND84M
       Coding: 0000072
       Shop #: WSC 00028 028 00001
       VCID: 72EBA1756D02DEAE78-8026
    Readiness: 0000 0001
       Revision: 00H11001
       Coding: 0019073
       VCID: 73E5A4711218D7A673-8026
       Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       VCID: 7BF58C513A489FE62B-802E
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Revision: 00H54000    Serial number: 01000007183545
       Coding: E48D0F2700041500471400001400000000087B075C000100000000000000
       VCID: 71E9AE796804E5B681-8024
       Component: Wischer 290507 021  0501
       Coding: 00038805
       Shop #: WSC 00028
       Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
       Component: RLS     140607 020  0105
       Coding: 00208933
       Shop #: WSC 00028
    00906 - Horn (H1)
                        Fault Status: 00101001
                        Reset counter: 147
                        Mileage: 162525 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.15 V
       Component: 38 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD19CKPU
       Coding: 0013112
       VCID: 3D71424964DC51D655-8068
       Subsystem 1 - Serial number: 6332MSME183E5B6BU
       Subsystem 2 - Serial number: 6342MSME185B0474C
       Subsystem 3 - Serial number: 6352QSME2F4D1D0D
       Subsystem 4 - Serial number: 6362QSME2F4F1E3D2
       Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
       Component: J0527           036 0070
       Coding: 0002022
       VCID: 75E19A691C6CC9965D-8020
       Part No SW: 1K0 920 974 A    HW: 1K0 920 974 A
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0G53ND84M
       Coding: 0003403
       Shop #: WSC 00717 210 83406
       VCID: 2C577F0D8FA6C85EF2-8078
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 010607F1000004
       Coding: E9807F060002020003
       VCID: 306F6B7DA38EACBECE-8064
                        Fault Frequency: 35
                        Reset counter: 147
                        Mileage: 162525 km
                        Time: 11:35:30
    01304 - Radio
                        Reset counter: 161
                        Mileage: 160358 km
                        Time: 15:51:52
       Component: IMMO            VDD 1216
       Shop #: WSC 06402 145 00197
       Component: Tuer-SG         006 120B
       Coding: 0000692
       VCID: 387F535D4BFE74FE86-806C
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.068 H08 1901
       VCID: 36635D6541EA828E94-8062
       Coding: 819002005103087F2D04840570085FC690FC00
       Shop #: WSC 00046 046 52295
       VCID: 0305F4B142B8E72663-8056
       Component: LIN BACKUP HORN H07 9001
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
       Coding: 0000692
       VCID: 3979565970F46DF679-806C
    00110 - Right Mirror Turn Signal Lamp (L132)
    Address 56: Radio
       Component: Tuer-SG         006 1202
       Coding: 0000144
       Shop #: WSC 00028 028 1012545
    00098 - Rear Left Central Locking (Safe) Motor (V163)
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:51)--------------------------
  4. Likes Uwe liked this post
    There's lots of measuring value data in that ECU you could monitor for signs of something wrong.
    Since you said, "when the engine is cold its drives fine, but just reach temperature 50-90 degress it losing power, and the engine sounds weird then accelerate" have you checked that the temperature the ECU sees matches reality?
    You could also look at stuff like fuel trims, misfire counters, and the mount of timing being pulled due to knock-sensing when it's misbehaving.
    In the end though, "Sounds weird" isn't much to work on.
  6. Likes Gavra liked this post
    Is the car modified?
    Log boost and in addition to ECT watch IAT.
    I see the Catalyst isnt ready, is it possible that it is partly obstructed?
    I believe that engine is naturally aspirated.
    Jun 2016
    Thanks for reply guys, I'm really appreciated.
    Mechanic told me maybe coolant temperature sensor fault I replaced yesterday check measuring data looks fine this sensors temperature reach 89 degrees and fan switch on.
    Shell i take picture of fuel trims, misfire counters, IAT and the etc? And then you can tell me if parameters are right because i was trying Google it but no luck probably im searching wrong way.
    Why Catalyst isn't ready i don't know, do you think it cause the problem as well?
    By the way im using 95 petrol maybe i need to start use 97 petrol for this 1.6fsi engine?
  10. #8
    Quote Originally Posted by jaunius View Post
    Audi UK strongly recommend using Super Unleaded (97/98 RON) on all FSI engines.
    BTW since this is a US hosted site you need to be aware that octane values are quoted differently in the US - in Europe we quote the RON value but in the US it's the average of the MON & RON values which is usually about 5 points lower. So when you or I say 98 octane, that's 93 octane so someone living in the US.
  11. Likes Jack@European_Parts, Uwe liked this post
  12. #9
    Jun 2016
    when i run out 95 petrol in tank when i will start using super unleaded, because now i put in the tank fuel system treatment. but thanks any way
  13. #10
    BLF sure is........
    03C stuff here is all boosted .......oops!
    Looking at engine now here for the pictures.
    http://www.ebay.co.uk/itm/VW-GOLF-MK...UAAOSwMNxXYRtv
    Be sure to check the crankcase ventilation valve on that VC to intake.
  14. Likes Uwe liked this post
